Premium spammer
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Nvidia ForceWare 263.09 WHQL driveri
What’s New in Version 263.09 -Added support for the GeForce GTX 580 and the GeForce GTX 460 SE. -This driver package installs NVIDIA PhysX System Software v9.10.0514. NVIDIA PhysX acceleration is available on all GeForce 8‐series, 9‐series, 100‐series, 200‐series, and 400‐series GPUs with a minimum of 256MB dedicated graphics memory and a minimum of 32 processor cores. -This driver package installs the HD audio driver, version 1.1.9.0. Limitations in This Release The following are features that are not currently supported or have limited support in this driver release: - Surround Gaming with 3‐way SLI Surround gaming is not supported on a 3‐way SLI system using GeForce GTX 200 series GPUs. - NVIDIA Control Panel Display Category The Graph tab on the Adjust Desktop Color Settings page is not available. - Hybrid Power Support for Hybrid Power, a Hybrid SLI technology, is discontinued and not available with this driver. win7/vista 32bit: Code:
http://www.nvidia.com/object/win7-winvista-32bit-263.09-whql-driver.html Code:
http://www.nvidia.com/Download/index.aspx?lang=en-us |
Datum registracije: Nov 2010
Postovi: 1,942
Kad odem na službene stranice i odaberem model i os izbaci mi 260.99, su ovi driveri povućeni ili šta? Na ostalim stranicama tipa Guru3D i FileHippo ipak stoje kao posljednji 263.09. |
#3 | |
Premium spammer
Lokacija: D.Zagora
Postovi: 776
Code:
http://www.nvidia.com/object/win7-winvista-32bit-263.09-whql2-driver.html |
Lokacija: Rijeka / Grobnik
Postovi: 4,396
Postovi: 682
Piše lijepo ispod: "This is a WHQL-certified driver for GeForce GTX 570 and GeForce GTX 580." Supported products: GeForce 500 series: GTX 580, GTX 570 Zadnje izmijenjeno od: Verbum. 22.12.2010. u 19:59. |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Postovi: 5,993
Ak netko ima zelju instalirat te drivere treba ih otpakirat u neki folder, isto to napravit sa nekim starijim driverom npr. 260.99 pa u njemu pronaci NV_DISP.INF koji se nalazi u Display.Driver folderu i koprat ga u Display.Driver folder u otpakiranom 263.09. Onda se normalno pokrene i normalno prode instalacija. Jos jednostavnije je pronaci taj .inf fajl u Nvida folderu kojeg driveri naprave na HDDu i kopirat ga u raspakirani 263.09. |
Lokacija: Sveta Nedelja
Postovi: 21
