Staro 17.12.2010., 17:02   #301
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Zotac Readies New GTX 580 Extreme Edition Graphics Card with Strong VRM
Zotac is flexing its engineering muscle again. Known for several novelty high-end non-reference design graphics cards, Zotac's latest work is based on the NVIDIA GeForce GTX 580, and revolves around backing the GPU and memory with a strong VRM. So complex is its VRM circuit, that it extends the PCB's height by a good one inch. The VRM consists of over 16 phases, making use of high-grade chokes, capacitors, POSCAPs, and prodalizers. Power is drawn in from 8-pin and 6-pin power connectors.
To cool the beast, there's a monolithic aluminum heatsink that runs through all corners of the PCB, cooling MOSFETs and memory chips. The GPU is cooled by a 2+ slot air cooler that makes use of two 120 mm fans blowing air onto a dense aluminum fin array. This cooler can be detached, and a universal water block for the GPU can be used without having to worry about cooling other components. Although the clock speeds aren't known, one can expect them to either be high, or moderately high leaving a large overclocking headroom. Zotac will brand this card "Zotac GTX 580 Extreme Edition".
http://www.techpowerup.com/136582/Zo...trong-VRM.html
Perverzno konstruirana hladnjača za ohladit VRM na ovoj zvjerki.
C L O W N I N G A R O U N D
Staro 17.12.2010., 18:20   #302
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,871
onda se od zotaca mora očekivat 1 gzh za gpu.
Staro 19.12.2010., 23:33   #303
NumbDigger
Datum registracije: Dec 2010
Lokacija: kae
Postovi: 17
Čitam 1. stranicu ovog topica, i moram reći da je prava poslastica.
Toliko FAIL-anih prognoza, a moram priznati da mi je najsmješniji kolega forumaš McG koji je GTX 580 proglasio 'hoax-om'.
Virtualnom grafom koja je plasirana da bi se, je li, pokvario AMD-ov Cayman launch.
Kad ono gtx 580 izasao ranije od Caymana,
koji jadan muku muči sa Nvidijinim 2nd ešalonom u vidu GTX 570. lulz
NumbDigger je offline   Reply With Quote
Staro 20.12.2010., 11:36   #304
Alfa_R
Alfa_R's Avatar
Postovi: 2,917
Svejedno kartica nema na bacanje i zato nema ni rata cijenama. Nvidija jedva proda koju, a ati ima cijeli spektar od najslabijih, do malo starijih (5870) do novijih (6870-6970)..
Nvidija ne može spustiti cijenu (jer nema čime pokriti toliku prodaju) a atiju se ne isplati kad dominira tržištem.
No sa korisnikovog stajališta - da, gtx 5xx je super serija i u hrvatskoj sa trenutnim cijenama puno bolji izbor od 69xx serje.
Staro 20.12.2010., 12:50   #305
NumbDigger
Lokacija: kae
Postovi: 17
Hmm...da. Nvidija nema bajnu dostupnost, a to se posebice pokazalo nakon Cayman launcha
Staro 20.12.2010., 13:02   #306
Alfa_R
Alfa_R's Avatar
Postovi: 2,917
pojasni malo što želiš reći?
Staro 20.12.2010., 13:12   #307
NumbDigger
Lokacija: kae
Postovi: 17
Pa nakon Cayman launcha je doslo do OUT OF STOCK GTX 580 na Neweggu. Naručiš i moraš čekati na isporuku.
Staro 20.12.2010., 13:19   #308
Alfa_R
Alfa_R's Avatar
Postovi: 2,917
Kužim. Ono malo se razgrabilo. Neutralni (ne fanbojevi) su čekali kako će kajman ispasti, pa kad je ispao običan krezubi aligatorić su brže bolje kupili najbolju single gpu karticu...
Staro 20.12.2010., 13:38   #309
NumbDigger
Lokacija: kae
Postovi: 17
EVGA je prva nestala, pa gigabyte, msi itd.
Ostalo nesto Galaxija, pa otisao i on, a PNY se zadnji rasprodao.
Staro 20.12.2010., 17:22   #310
Ivan123
Postovi: 191
Takva situacija je bila i prije Caymana... Znam da je u HR bilo svega 5 kartica i da se nakon tjedan dana nakon sto su dosle u RH moralo narucivati i cekati 20-ak dana, a ni sada nije bolje stanje
Ivan123 je offline   Reply With Quote
Staro 22.12.2010., 03:17   #311
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Gainward navodno priprema najbrzu GTX 580 na trzistu.
http://vr-zone.com/articles/gainward...le-/10260.html
Jeiii, nova GS-ica
Da makar utrpaju na nju malo bolje hladjenje, tipa ovog novog 'Phantoma'
NovA Squadron
kripton je offline   Reply With Quote
Staro 22.12.2010., 09:15   #312
Doink the Clown
Postovi: 6,214
Autor kripton Pregled postova
Dok se ne pojavi Gigabyteova SOC edicija
Staro 11.01.2011., 12:30   #313
red_bull
red_bull's Avatar
Lokacija: Varazdin
Postovi: 66
covjece kako dugo nisam vidio golden sample karticu.. godinama.
on topic: tko danas kupi gtx580 ja garantiram da netreba nikakve amd-iće sljedecih 2 god.. znam po gtxu 280 kojeg imam od izlaska i dan danas je jedan mocni gpu isplativiji od bilo kakvog multigpu rjesenja.
fly me to the moon
red_bull je offline   Reply With Quote
Staro 11.01.2011., 13:19   #314
klem
Postovi: 594
Autor red_bull Pregled postova
misliš da npr s hd4890 nije ista stvar )). Potpuno je svejedno dal imaš grafu iz crvenog ili zelenog tabora...obje su dobre.
klem je offline   Reply With Quote
Staro 12.01.2011., 09:53   #315
Doink the Clown
Postovi: 6,214
ASUS Readies Another Monster: GeForce GTX 580 DirectCu II
After showing off a monstrous DirectCu II cooled Radeon HD 6970 at CES, ASUS released pictures of another card which probably couldn't make it to Vegas. The GeForce GTX 580 DirectCu II from ASUS is just as beastly as its Radeon cousin. It uses a completely in-house design, with custom PCB that uses a strong VRM; and a triple-slot cooler which uses copper heatpipes that make direct contact with the GPU. The PCB uses an 8-phase vGPU VRM, it draws power from two 8-pin power connectors. The power circuit is also completely localized, meaning that it draws absolutely zero power from the PCI-Express slot. The VRM makes use of high-grade components, including an NEC-made proadlizer to condition power for the GPU.
The DirectCu II cooler uses a large aluminum fin array to which heat is conveyed by five heatpipes that make direct contact with the GPU. Two 100 mm fans are in charge of ventilation. The rear panel consists of two DVI, and one each of DisplayPort and HDMI. The card is bound to have factory overclocked speeds, with room for more overclocking. The cooler, though large and with two fans, is tested by the company to be quieter than NVIDIA's reference design cooler. The GeForce GTX 580 is NVIDIA's flagship DirectX 11 GPU. It packs 512 CUDA cores, and connects to 1536 MB of memory over a 384-bit wide GDDR5 memory interface.
http://www.techpowerup.com/138234/AS...rectCu-II.html
Eto i perverzno ogromne GTX-ice od Asusa
Staro 12.01.2011., 12:01   #316
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
3way sli... NOT!
Staro 12.01.2011., 13:21   #317
Alfa_R
Alfa_R's Avatar
Postovi: 2,917
Bar ima backplate.
Staro 12.01.2011., 13:50   #318
chief_wolfinjo
uskoro bu grafičke kartice kao jedan mini tower
Staro 14.01.2011., 16:20   #319
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
ZOTAC GeForce GTX 580 AMP! Edition 1536 MB
ZOTAC's GeForce GTX 580 AMP! Edition does not bring many improvements to the table. The card is a complete implementation of NVIDIA's reference design with higher clocks. Its increased clock speed of 815 MHz, vs. 772 MHz on the reference design, can deliver a small performance improvement in our benchmarks - up around 3%. If you are willing to do some additional overclocking then you can expect a higher clock headroom on the AMP! Edition than on other reference design cards. According to ZOTAC, some special binning is performed at the factory where GPUs are picked that can handle the highest clocks. Compared to other reference designs, which max out at around 830 MHz, the 895 MHz on the AMP! Edition are a good improvement.
Whereas the GTX 480 AMP! Edition used a Zalman cooler, ZOTAC's GTX 580 AMP! comes only with the reference cooler. I talked to ZOTAC about the cooler and they mentioned that they were planning on using a different cooling solution but at the end it didn't work out for what were mostly political reasons beyond ZOTAC's influence.
Overall the GTX 580 AMP! Edition is a solid card but feels a bit too expensive with a $50 price premium over the normal clocked cards.
MSI Announces New N500GTX Twin Frozr II Series Graphics Cards
MSI's Exclusive Twin Frozr II Cooling Design
The MSI N500 Twin Frozr II series graphics cards feature the advanced Twin Frozr II Thermal Design. By utilizing its engineering expertise, MSI has created the ultimate Thermal Design that decreases operating temperatures by up to 20°C. The GPU spreader is covered with a large surface area heat sink with a copper base, ensuring the best possible thermal transfer surface. Surrounding components like Memory and PWM components are covered by a large unibody metal heat sink. Additionally, with MSI's SuperPipe heat pipe technology, excess heat is transferred quickly to a high density aluminum cooling fin assembly. The low-noise fan setup, which includes two temperature-controlled 8cm PWM fans, ensures excellent air flow to all parts of the Twin Frozr II Thermal Design while reducing sound levels by up to 8.4dB.
Izvor: techpowerup
Staro 21.01.2011., 13:46   #320
Doink the Clown
Postovi: 6,214
Gainward Readies GeForce GTX 580 Phantom 3 GB Graphics Card
Uf, evo i GTX580 Fantomke, u ozbiljnom sam iskušenju
Last month, Gainward introduced its GeForce GTX 570 Phantom, which won quite some appreciation among readers for its radical design. The company decided to extend it to the GeForce GTX 580, too, since it's based on the same GF110 silicon. The only major change is that 2 Gbit memory chips are used, yielding a total memory of 3072 MB (3 GB). The memory is spread across 12 2 Gbit memory chips across a 384-bit wide GDDR5 memory interface. Clock speeds stick to NVIDIA reference: 783/1566/4020 MHz (core/CUDA cores/memory effective). The GTX 580 packs 512 CUDA cores.
The cooler makes use of a black aluminum fin array, to which heat is fed by six heat pipes. Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The result is a better-looking product. Display outputs include two DVI, and one each of HDMI and DisplayPort. Gainward will release its 3 GB GTX 580 Phantom graphics card soon, at a premium over the reference design.
Staro 21.01.2011., 14:28   #321
kripton
Cars & Tunning
kripton's Avatar
Postovi: 536
3gb memorije i super uber hladnjak Gainward's back
GTX 580 od Asusa me podsjetila na jednu staru nvidiinu reklamu od valjda FX 5800 XT kada se likovi zafrkaju da se moze koristi za vise stvari pa tako kucanske poslove, kao fen, za ciscenje od lišća i slicno
NovA Squadron
Staro 03.02.2011., 15:57   #322
Doink the Clown
Postovi: 6,214
MSI GeForce GTX 580 HydroGen OC Priced
Op op.
MSI's high-end GeForce GTX 580 graphics card that's ready for water-cooling out of the box, the MSI N580GTX HydroGen OC, released in the European retail market, priced at €563. The N580GTX HydroGen uses the same full-coverage water-block as the N480GTX HydroGen, probably sourced from Heatkiller. The block uses a full copper base and composite metal top. It is ready for G 1/4" threads. The card comes slightly overclocked out of the box, but with the kind of cooling at its disposal, it leaves the fun part to you. The GPU is clocked at 823 MHz, CUDA cores at 1645 MHz, and memory at 4276 MHz, against reference speeds of 772/1544/4008 MHz.
Staro 03.02.2011., 23:14   #323
NinX
NinX's Avatar
Datum registracije: Jan 2010
Lokacija: Lyon/Zagreb
Postovi: 296
ASUS GeForce GTX 580 DirectCU II Overclocked at 1519MHz!!!
NinX je offline   Reply With Quote
Staro 25.02.2011., 21:55   #324
Doink the Clown
Postovi: 6,214
SPARKLE Announces GeForce GTX 580 Thermal Guru Graphics Card
SPARKLE Computer Co., Ltd., the professional VGA card manufacturer and supplier, today announced the SPARKLE GTX580 Thermal Guru Graphics Card with Effective Own Design Cooler, the ultimate DX11 3D monster from SPARKLE, which delivers intense performance and premium cooling effect for gamers who demand the best.
The SPARKLE GTX580 Thermal Guru Graphics Card is the latest new addition to SPARKLE’s GTX 580 Series. Its core and memory clock are 772 and 4008 MHz respectively. Designed specifically for gamers who demand the best, the SPARKLE GTX580 Thermal Guru Graphics Card is built with NVDIA GeForce GTX 580 GPU. Based on 40nm processor and advanced GDDR5 memory technology, it consists of ground-breaking features including Microsoft DirectX 11 and NVIDIA PhysX which lead to incredibly immersive HD gaming experience and unrivaled performance.
Light Sense Design -- The Perfect Balance of Weight and Performance
For the cooler design, SPARKLE always has its own unique concept, it has been to balance the weight and the cooling performance of graphic cards' cooler. So as for this SPARKLE GTX580 Thermal Guru Graphics Card, it adopts the aluminum fins with the pure copper heat pipes to enhance heat transfer efficiency while also reducing the weight of the cooler, effectively avoiding the risk of bending the plate. This cooler also integrated many of the most advanced manufacturing process, the whole cooler uses tin free welding process, pillars traversed cooling fins technology and pillars inserted cooling fins technology to ensure cooling efficiency, use life and the sense of integrated design. With this cooler, the full loading GPU temperature is 5 degree Celsius lower than the reference cooler of GeForce GTX 580 graphics card. The weight of the cooler is only half of the reference design.
One Slot Iron Bracket Design
The SPARKLE GTX580 Thermal Guru Graphics Card takes up 2 PCI slots, but only with one slot iron bracket, making the card to be more light and clean.
Dual 80mm Fans Design
The SPARKLE Announced GTX580 Thermal Guru Graphics Card's cooler comes with two 80mm cooling fans. Compared with single fan design, they make the card running quieter and provide more powerful air flow for the graphics card.
Direct Contact Technology
The cooler of the SPARKLE Announced GTX580 Thermal Guru Graphics Card use four pure copper heat pipes, combing with the GPU direct contact technology to enable more efficient heat transfer.
Unique&Advanced Cooling Fins Assembly Technology
Combining with pure aluminum cooling fins, the pure copper heat pipes use tin free welding process and cooling fins assembly technology, effectively avoiding the heat pipes' oxidation due to the corrosion from the high temperature tin melting process in the tin welding process and the high welding temperature.
Unique Designed Wind Collecting Cover
The most graphics cards' coolers can only randomly draw the air to do cooling job. But SPARKLE deliberately designs a unique wind collecting cover for the cooler. Using the specially designed air duct on the cover, the flow of the air will enter the cooler along the fixed orbit, to enhance the efficiency of heat dissipation, while reducing wear and tear on the fan. In addition, the air duct design can effectively avoid the hand injury due to touching the cooler during the graphics card installation and taking down process.
Ray Tracing Support: The Future Of Gaming
The SPARKLE GTX580 Thermal Guru Graphics Card enables interactive ray tracing for ultra photo-realistic scenes. The SPARKLE GTX580 Thermal Guru Graphics Card powers interactive raytracing, bringing spectacular, photo-realistic renderings to your screen for the first time. By using the power of the GF110 GPUs, the SPARKLE GTX580 Thermal Guru Graphics Card supports recursion in hardware, enabling efficient ray tracing and a host of other graphics algorithms. It excels not just at standard ray tracing, but also at advanced global illumination algorithms such as path tracing.
32x Anti-Aliasing Technology
The SPARKLE GTX580 Thermal Guru Graphics Card implements a brand new 32x anti-aliasing mode for higher levels of image quality. And the GeForce GTX 580's enhanced compression engine maintains incredible performance with anti-aliasing and resolution cranked up, providing both high frame rates and top notch image quality.
Total Immersive With NVIDIA 3D Vision Surround Technology
Prepare to be blown away by the most immersive PC gaming experience imaginable. Leveraging the power of multiple GF110 GPUs in an NVIDIA SLI configuration, NVIDIA 3D Vision Surround enables a new level of eye-popping 3D stereo gaming, expanding your real estate across 3 panels for the ultimate “inside the game” feeling. The SPARKLE GTX580 Thermal Guru Graphics Card provides the incredible graphics horsepower to run your game in 3D stereo, across 3 panels, at HD resolutions up to 5760x1080. The SPARKLE GTX580 Thermal Guru Graphics Card aslo supports gaming across three non-3D displays with resolutions up to 2560x1600,it's the best in Class 2D Surround Gaming.
Stunning DX11 Gaming Performance
Packing in 512 CUDA cores, a high speed GDDR5 memory interface, and full DirectX 11 support, the SPARKLE Announced GTX580 Thermal Guru Graphics Card .With Effective Own Design Cooler is designed for groundbreaking graphics performance. With a revolutionary new scalable geometry pipeline and enhanced anti-aliasing capabilities, the SPARKLE GTX580 Thermal Guru Graphics Card is the world’s most powerful single GPU Graphics Card solution.
1536MB Incredible Large High Speed GDDR5 Video Memory
Today‘s DX11 game, such as Stalker: Call Of Pripyat, Metro 2033, they insanely use as large as possible number of bump texture, transparent texture to describe faces of characters and render realistic gaming scenes, so these DX11 games put rigorous demands on the bandwidth and capacities of video memory. The current situation demands at least 1GB video memory to run these games. Compared with high-end graphics cards on market with 1GB GDDR5 video memory, the SPARKLE GTX580 Thermal Guru Graphics Card comes with incredible large 1536MB high speed GDDR5 video memory, meeting the rigorous demands from current DX11 games.
http://www.techpowerup.com/141134/SP...hics-Card.html
Staro 26.02.2011., 00:45   #325
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
"čudan" izgled, al me baš zanima kakve su performanse tog hlađenja
btw: (sry ako je već bilo):
ASUS GeForce GTX 580 DirectCU II vs Gainward GeForce GTX 580 Phantom 3 Graphics Card Review
http://www.hardwareheaven.com/review...-phantom3.html
Staro 26.02.2011., 13:37   #326
Brlja
Postovi: 874
Kome treba dat guze da se ovo nabavi za ispod 3000kn?
Brlja je offline   Reply With Quote
Staro 26.02.2011., 20:52   #327
rockodaddy
rockodaddy's Avatar
Postovi: 207
Nema još slike ali ZVIJER sigurno dolazi,ajme meni nije mi dobro!!!!!
rockodaddy je offline   Reply With Quote
Staro 26.02.2011., 21:30   #328
kripton
Cars & Tunning
kripton's Avatar
Postovi: 536
To cudo izgleda kao nešto iz Crysisa
Dobar je ovaj Sparkle, šteta što nije tako raširen kod nas, s ovakvim dizajnom bi ga rado kupio
da imam koju milju eura viška.. heh
NovA Squadron
Staro 27.02.2011., 00:15   #329
Doink the Clown
Postovi: 6,214
Autor rockodaddy Pregled postova
Baš me zanima koliko će modificirati hladnjak za ovu karticu u odnosu na ostale SOC modele GTX5xx serije.
Staro 27.02.2011., 10:24   #330
rockodaddy
rockodaddy's Avatar
Postovi: 207
Netko voli mercedes,netko ferrari a ja sam bas skroman jer volim gigabyte superoverclock...mislim malo se salim ali jednostavno ne razumim kako nasi prodavaci ne mogu prepoznat kvalitetu ovih kartica i dovesti ih vec jednom na svoje police.Blazen dan kad se to dogodi!
