Staro 15.12.2010., 14:16   #781
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Alfa_R Pregled postova
Gdje nisku potrošnju vidis?
Drzi se 570 ko pijana plota... osim u blue ray-u gdje trosi dvostruko više jer memorija neide dole....
A 570 joj je konkurencija...
http://www.techpowerup.com/reviews/H...D_6970/27.html
Gledao sam PCEkspertov review. Neznam kak je kod drugih.
EDIT: Hebote ja govorim o HD6950 ne HD6970.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 15.12.2010., 14:24   #782
Alfa_R
Alfa_R's Avatar
Postovi: 2,924
Autor DraŽ Pregled postova
Sorry, moja greška.
6950 ima dobru potrošnju....
6970 je katastrofalna po tome ako se u obzir uzme 5870 i 6870... Nadoknadili sve što su imali naprema nvidiji, ali ne i performanse...
Alfa_R je online   Reply With Quote
Staro 15.12.2010., 14:43   #783
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Nakon tolkog hypea, ipak ostaje blago razocaranje, ocekivao sam vise, ja barem...
J
Pogledao sam review HD6950 Crossfire i usporedio sa HD6850 crossfire-om i mogu reći da je HD6950 cross tek nešto brži, a negdje vrlo blizak sa HD6850 cross-om.
http://www.techpowerup.com/reviews/A...ossFire/1.html
HD6850 cross The Way To Go.
Snimih istu stvar, 6850 Cross FTW
Staro 15.12.2010., 15:07   #784
Astral
Postovi: 2,523
ne kuzim po cemu to tvrdite? pogledo sam ova dva pechpowerup CF review-a i 6950 CF ima dobru prednost od 6850CF, sam krivo nes gledo?
Astral je offline   Reply With Quote
Staro 15.12.2010., 15:19   #785
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Astral Pregled postova
Negdje su jako blizu, negdje ima većeg lufta (očituje se samo kod vrlo visokog fps-a npr. u COD4, Hawx...) no na visokom fps-u 20-30 fps-a tak i onak ništa neznači jer je jako nestabilan, a i ja zbog vrlo neugodnog screen tearinga moram uključit prokleti vSync koji ograničava broj fps-a na 60.
Uglavnom dosta o fps glupostima, razlika između tih crossova je relativno mala, a u cijeni je 2000kn(za cross).
~1400kn HD6850
~2400kn HD6950
~2800kn HD6850 CROSS
~3800kn GTX580
~4300kn HD5970
~4800kn HD6950 CROSS
TV: LG 7450
GAMEPAD: XBOX One
Staro 15.12.2010., 15:19   #786
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,717
Sve veliki analiticari, znalo se od prije da 6970 nece biti brza od 580 gtx, tako da tu nema velikog iznenadenja. U igrama koje su meni vazne razlika izmedu 6970 i 580 je minimalna, a potrosnja struje je niza od 570. S 10.12 driverima mogu biti samo jos blize 580. O cijeni da ne pricamo, odlicna cijena za te performanse tako da je AMD jos jednom uspio napraviti savrseno izbalansirani proizvod.
U Furmarku 2x 6970 trose manje nego jedna 580, a 6970 ima skoro 90W manju potrosnju u full loadu od 570.
Zadnje izmijenjeno od: Bono. 15.12.2010. u 15:25.
Bono je online   Reply With Quote
Staro 15.12.2010., 16:48   #787
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Graficke su strava na 2560x1600 i bodu Nvidiju u bolno mjesto. Sve ovo ispod je blago razocarenje ili nije kad se uzme u obzir da je broj shadera dosta manji nego sto se bilo mislilo.
Glavno su uspijesno sredili, dx11 i teselizacija.
Staro 15.12.2010., 17:01   #788
Postovi: 7,568
Autor pingmachine Pregled postova
a treći je xbitlabs.com
Da, ali X-bit Labs je miljama ispred ovih. Mada su svi Rusi, ali X-bit Labs ima puno bolje odrađene recenzije; em su detaljnije, em im se nikud ne žuri ko ostatku svijeta, em su jedni od rijetkih koji sve pokriju kak spada, em pišu jasnim skoro pa književno britanskim engleskim, pa ih je tim veći gušt čitati.
Sve u svemu, tehnoloski gledano - ati je lagano kiksnuo. Em su povecali potrosnju (a s tim su se hvalili), em je dobitak na performansama minimalan.
Bio bi ne Epic, ali Fail, no cijene ce vjerovatno iskorigirati to.
Ti si već lagano naporan s tim fejlom. Ko da čitam BUG-forum di je sve fejl, ako ne košta 4.000 kn i ako se ne clocka ko da nema sutra i uz to ima super performanse u 3DMarku. Uporno pročitano tumačiš kak ti paše.
Ili gledaš samo grafove? Da, kartice su fejl - ne koštaju manje od 200 dolara/eura, nemaju 10.000 bodova u 3DMarku 11 i ne clockaju se na 1.5 sa 10GHz. Prodaja bude poražavajuća.
Staro 15.12.2010., 17:03   #789
nathan
IT Consultant
nathan's Avatar
Lokacija: Geneva, Petit-Lancy / Zagreb , Dubrava
Postovi: 323
Autor MAGARAC Pregled postova
vecina testova je sta i sami kazete na 10.11 driverima, dakle pricekajmo vise testova na 10.12, makar ni 10.12 driveri nisu cudo, veca poboljsanja sto se drivera tice trebaju biti ocekivana od iduce godine, nadalje overclock potencijal je dobar, potrosnja energije isto, i jos jedna zanimljiva stvar, dvostruki bios, koji ce vjerujem tek od kraja prvog i pocetka drugog mjeseca 2011 poceti pokazivati sve mogucnosti serije hd69xx.
i guru3d ima ok recenziju...
evo u svicarskoj cijene za 6950 = 2084kn, za 6970 = 2524kn (izvor)
"All we have to decide is what to do with the time that is given us" J.R.R. Tolkien
Zadnje izmijenjeno od: nathan. 15.12.2010. u 17:29.
nathan je offline   Reply With Quote
Staro 15.12.2010., 17:22   #790
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Jako mi se sviđa kaj je AMD napravio od ovih kartica, istina i bog malo peče kaj nije najjača single gpu. Najveća rak rana je bila osrednje ili nikakvo skaliranje u XF i teselizacija, ali ovo kaj sam sad vidio je fenomenalno. Jako me zainteresirala stvar koju sam škicnuo kod tomeka, je da bi serija 5xxx i 68xx trebale jednako skalirati u XF i da je to stvar drivera, a ne arhitkture. Ima tko XF serije 5 da potvdi ovo?
d4rk_ch1ld je offline   Reply With Quote
Staro 15.12.2010., 18:05   #791
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
S obzirom da je to potpuno nova arhitektura, nije loše. Mene jedino bodu u oči odlične performanse Barts čipova koji su puno manji, a ne zaostaju puno za Caymanima. Ali to prepisujem upravo novoj arhitekturi i neoptimiziranim driverima. Valjda su to seljaci mogli malo prije testirati pa poslati recenzentima barem neke beta drivere na vrijeme.
cccp je offline   Reply With Quote
Staro 15.12.2010., 18:27   #792
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
http://217.14.221.177/StartEU.ashx?_...mAhjJPxxRn44jd
Ove bas i nije tako jako povoljno. Vidjet cemo kak ce se dalje stvari razvijat.
Staro 15.12.2010., 18:28   #793
Jerry
Jerry's Avatar
Postovi: 1,816
Ja mislim da je HD69xx kao i bilo koji drugi komad HWa po tebi FAIL ako ima 5% manje performanse od konkurencije pa kostao on i 2x puta manje tako da tvoje misljenje a i jos nekih na forumu treba opcenito - IGNORIRATI!
Stupid is as stupid does
Zadnje izmijenjeno od: Jerry. 15.12.2010. u 18:38.
Jerry je offline   Reply With Quote
Staro 15.12.2010., 18:30   #794
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,717
Refreshaj koji puta mozda bude bolja cijena.
Slazem se ovo je malo previsoko, past ce to vrlo brzo na neke realne razine.
Staro 15.12.2010., 18:36   #795
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Ja sam ocekival 6970 oko 3000 ili nesto malo manje a 6950 oko 2400 ili nesto manje.
Ovdje bi cijene trebalo dosta srezat da bi dosle do te razine. Kad bi ostalo ovako ili malo manje nebi bilo nikakvog rezanja cijena kod 570 i 580.
Staro 15.12.2010., 18:39   #796
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Bas se drze racunice: $ x 10 = kn
Staro 15.12.2010., 18:55   #797
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor Bono Pregled postova
Misliš? A tko ih tjera da naprave to? Još skuplja konkurencija?
C L O W N I N G A R O U N D
Staro 15.12.2010., 18:58   #798
Jerry
Jerry's Avatar
Postovi: 1,816
Evo i malo gameplaya u rezi 5760x1080 8AA/16AF (CFX 6950/6970 vs GTX580/GTX570 SLI):
http://www.hardwareheaven.com/review...ty-vs-sli.html
Staro 15.12.2010., 18:58   #799
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,717
Govorio sam o HR trzistu, bolja dobavljivost nize cijene, 3000kn moze kostati 6970, a ne 6950. Sto se tice cijena van HR, cijena je i i vise nego postena.
Staro 15.12.2010., 19:01   #800
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
U EU je 6970 275 eura + porez. Kod nas je od prilike 20% skuplje + PDV, sto bi bilo oko 330 eura + PDV sto bi na kraju ispalo ravno 3000kn za 6970 ili po toj racunici 2500kn za 6950.
To u ovom slucaju djeluje jako optimisticno.
Nase su cijene najblize onima u U.K. iako su i od njih 10tak % skuplje. Inace u U.K. od 1.1. njihov pdv, vat ide gore za par % tak da ce bit jos slicnije kao kod nas.
Staro 15.12.2010., 20:54   #801
nathan
IT Consultant
nathan's Avatar
Postovi: 323
srecom pa je nas standard isti kao i u UK ili bilo kojoj od zemalja zapadne europe... sorry na ali morao sam
ps. jesi pogledao cijene koje sam ja stavio???
Staro 15.12.2010., 21:09   #802
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Autor Jerry Pregled postova
Treba u reviewue ubacit i testove sa 3 monitora jer su danasnje high end grafe u sli i cf debeli overkill za prosjecnog gamera i avg. monitore. Zato mi se i njihov review gtx 580 svidao.
Staro 15.12.2010., 21:44   #803
Alfa_R
Alfa_R's Avatar
Postovi: 2,924
Autor McG Pregled postova
Šta želiš da kažem da je super? Žao mi je, 5870 je bio Win. Nakon blamaže
sa renejmanjem kartice sami su se osudili na to. Vjerovatno im bart ispao
predobar pa nisu mogli da ga prodaju za manje para kao 67** seriju i sad ih
to ugrizlo za dupe jer su svi razočarani performansama kao i cijenom ovog
novog "flagship" modela. Cijena još ostaje za vidjeti kod nas.
Da su bart ostavili malo manje kloknut za manje para i onda ovo za normalne
pare onda bi bio itekakav Win bez obzira na potrošnju i kvadraturu (ili
guubitak prednosti u tome) . Ovako su se izjednačili sa Nvidiom Gtx 5xx koju
atijevci predvođeni charlijem zovu fail.
Ono što mene osobno čudi je izbor cijena za 6870 jer se ATI buca u prsa sa
mm2 i onda čip sa malo mm2 cijeni papreno i onda izda ovo po tim cijenama.
Lagana pohlepa? A znalo se pljuvati po Egu od "Velikog vođe"....
Jerry
Citiraj:Autor Alfa_R
Bio bi ne Epic, ali Fail, no cijene ce vjerojatno iskorigirati to.
Ti počeo malo ranije ignorirati pa si izignorirao i bitnu rečenicu za tvoj navedeni zaključak....
No ne brini, podcrtat ću ti bitno...
Nažalost govoriš istinu
Nije bitna cijena, nego to što nvidija nemože napumpati dovoljno kartica da iz proda po potražnji koja bi išla sa nižom cijenom.
Tako da je za njih skup ati ustvari bolji nego da se spušte na niže razine.
Staro 15.12.2010., 21:54   #804
sliver
Datum registracije: Jan 2010
Postovi: 149
U Austriji su odlične cijene: , još ako se uspije dobiti povrat poreza, milina.
sliver je offline   Reply With Quote
Staro 15.12.2010., 22:16   #805
Postovi: 7,568
Ne moraš ništ govoriti, jer ti si već prije nekolko stranica krenul s epic fail bedastoćama, a i očito je da si bez obzira na sve moguće recenzije krenul u čitanje istih s već stvorenim (epic fail) mišljenjem. Žalosno je da svoje negodovanje oko HD 6900 serije nisi u stanju napisati i elaborirati kak spada, već pribjegavaš k dječjim epic fail epitetima. Daleko od toga da se od tebe traži da odobravaš ili raširenih ruku čekaš HD 6900 (ili bilo koji drugi komad hardvera ili proizvođača), ali da svoje negodovanje, nezadovoljstvo i opće razočaranje nisi u stanju propisno i elokventno argumentirati, već ti je epic fail unatrag dvije-tri stranice jedino čime puniš svoje postove - e to ne kužim.
Ako već nisi zadovoljan nečim, onda se bar izrazi kak i priliči. Kak sam i rekel u prijašnjem postu, vrtiš svoj film još i prije nego su stigle recenzije, ne uvažavaš ono kaj pročitaš ili kaj ti ljudi na temi pričaju i možemo do sutra, ali nema smisla, jer si ti svoje mišljenje već stvoril - HD 6900 je epic fail. I to je vredu, ali nažalost ti se ne znaš ni izraziti po pitanju podbacivanja HD 6900 serije, već pišeš gluposti, tj. svoje viđenje stvari.
Ma ne, pa super je tip. Fura se na Apple, vidi Boga u Stevanu, a i sam koristi isključivo Apple računala. Mantra mu je za 10.
Zadnje izmijenjeno od: McG. 15.12.2010. u 22:24.
Staro 15.12.2010., 22:39   #806
alengrosevic
alengrosevic's Avatar
Postovi: 3,785
ne znam ako je bilo ali ako nije evo ga: Review 6950 & 6970
http://www.guru3d.com/article/radeon-6950-6970-review/
Staro 15.12.2010., 23:14   #807
Alfa_R
Alfa_R's Avatar
Postovi: 2,924
Šta imaš protiv epiteta Fail ili Epic fail? Ako ti toliko smeta onda možemo uvesti drugačiji - Kartica je jako razočarala, kartica je malo razočarala, Ni vrit, ni mimo, i tako sve dalje do kartica je genijalna... Jedino što je različito je da je ono "fail" i "win" lakše napisati.
Molim te, pročitaj onu boldanu rečenicu jerry-u iz koje se da iščitati bude bi cijena prava nije ni fail, a kamo li Epic fail (koji ja nisam pisao u svakom postu). Samo što nisam to tako očito napisao.
Možemo mi razglabati o tome da VLIW5 na VLIW4 nije urodio plodom na ovoj 40nm i da power tune je malo korisna stvar koju će rijetki koristiti jer je trebaju na takvom entuzijastičnom segmentu kartice.
Naravno, ovo zadnje se možda baš pokaže presudno u zaobilaženju od 300W kod dual kartice, no o tome kad izađe.
Možemo i o tome koliko je dual bios dobar izum i da šteta što nvidija to nema.
Možemo i o Eyefinitiju i poboljšanjima istog, no na ovim prostorima to je premalo tržište. Naravno da onom kome to baš treba to je sve.
No nakraju većini kupaca takve kartice ostaju samo performanse, hlađenje, potrošnja i cijena.
I sad, nakon što ti kažem zašto sam razočaran osim charlija (a i na njegovom forumu ćeš naći jako puno negodovanja i razočaranja) i zašto smatram da je nastalo takvo veliko razočaranje (cijena, omjeri s bartsom, dizanje skale cijena bez praćenja performansama) ti tražiš dodatnu elaboraciju i to ne subjektivnu? Ne kužim, očeš razgovor prebaciti o mm2 i profitima ne uštedom ne za nas nego proizvođačima?
I još jednom da ponovim ja nisam stvorio mišljnje epic fail. Ti meni pripisuješ fanboy-izam i da ja u svakom postu pišem Epic Fail bez da si pročitao moje postove sa razumijevanjem - jer inače bi vidio da nisam tipični nevidijaš kojem se očito obraćaš sa ovakvim postom. Ti si stvorio sliku o meni unaprijed, a ne ja o kartici. Unaprijed sam stvorio mišljenje na temelju leakova, no navijao sam da kartica bude što bolja jer to, na kraju krajeva, je ono što meni donosi uštedu.
Da pojasnim još jednom:
Ono što sam ja napisao je da je ati malo kiksao - što je, da je ostavio gorak okus mnogima s obzirom da se očekivalo više i zašto mislim da je to tako - što je i da ako je cijena prava (recimo do 2.500) da je sve to ok. S tim da cijenu ne smatram da nvidija ostane na skoro 3000 i 4000, nego da ide niže.
A sad umjesto da zbog jedne rečenice gdje epic fail piše samo kao da nije to i onda razvlačimo bezveze besmislen razgovor - da čujem zašto je kartica bolja od recimo gtx 570? Ili ako misliš da je kartica super - koji su razlozi za to?
EDIT: @ LB - WA -> Tražiš elaborat, a onda ti to ne paše -
Zadnje izmijenjeno od: Alfa_R. 15.12.2010. u 23:29.
Staro 15.12.2010., 23:22   #808
Postovi: 7,568
Čovek Božji ti se svađaš sam sa sobom. Ne trebam ti ja za sugovornika.
Staro 16.12.2010., 00:04   #809
vuYa
vuYa's Avatar
Lokacija: Vinkovci
Postovi: 49
bolja je od gtx 570 jer je jeftinija..tako da oni koji imaju manje novca ce prije uzet 6950 nego nvidiu
vuYa je offline   Reply With Quote
Staro 16.12.2010., 00:09   #810
Alfa_R
Alfa_R's Avatar
Postovi: 2,924
Autor vuYa Pregled postova
Čuj, ati je dobro rekao - 6950 je klasa sama za sebe.
Nvidija u tom razredu za sada nema odgovora.....
