Staro 10.12.2010., 12:50   #1
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Asus A9T max supported CPU?
Imam navedeni laptop i unutra je neki Celeron Dothan M380, ako se ne varam.
Koji procesor max može unutra i jel to problem promijeniti?
Ovaj je unutra:
Code:
Polje	Trenutna vrijednost
Informacije o procesoru
Procesor	Mobile Intel Celeron M LV, 1600 MHz (16 x 100)
Jezgra procesora	Dothan-1024
CPU stepping	C0
Podržani setovi instrukcija	x86, MMX, SSE, SSE2
Originalna frekvencija	1600 MHz
Min / Max CPU množitelj	6x / 16x
Engineering Sample	Ne
L1 cache za kod	32 KB
L1 cache za podatke	32 KB
L2 cache	1 MB  (On-Die, ECC, Full-Speed)
Fizikalne informacije o procesoru
Tip pakiranja	479 Ball uFCBGA / 478 Pin uFCPGA
Dimenzije	3.5 cm x 3.5 cm
Broj tranzistora	140 milijuna
Tehnologija izrade	7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Veličina silicijske pločice	88 mm2
Napon jezgre	1.164 V
I/O napon	1.164 V
Standardna potrošnja	3.0 - 21.0 W  (ovisno o frekvenciji)
Maksimalna potrošnja	3.3 - 28.1 W  (ovisno o frekvenciji)
Proizvođač procesora
Naziv tvrtke	Intel Corporation
Informacije o proizvodu	http://www.intel.com/products/processor
Zauzeće procesora
Procesor #1	1 %
Staro 10.12.2010., 13:59   #2
[Psyho]Cox
[Psyho]Cox's Avatar
Lokacija: Opuzen/Zagreb
Postovi: 347
Ja bi reka ovaj, ali samo da malo jos vidim po netu.
http://www.cpu-world.com/CPUs/Pentiu...2266FJ%29.html
"Upgrading socket M motherboards
To determine which processors are supported by your system you'll need to determine computer model (for brand-name notebooks, like Dell or HP), or a manufacturer and a model of your motherboard, and then search on manufacturer's website for that computer or motherboard model. Most manufacturers don't post CPU upgrade information for notebooks, but sometimes you may find upgrade recommendations in manufacturer's product support forums. Also try to send an e-mail to manufacturer's custom support, or post in other computer-related forums, but don't expect many responses."
EDIT: Mislim da ovi svi, ili vecina njih pase!
http://www.cpu-world.com/CPUs/Pentiu...%20Dothan.html
Bolje da netko strucniji potvrdi.
Najgore se sekirat!!!
Acer TimelineX 5830G
Zadnje izmijenjeno od: [Psyho]Cox. 10.12.2010. u 14:41.
[Psyho]Cox je offline   Reply With Quote
Staro 11.12.2010., 12:27   #3
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Evo našao sam Dothana Pentium M750 i kako izgleda trebao bi ići u taj lap...
http://ark.intel.com/Compare.aspx?ids=27593,27146,
Jel problem zamijenit CPU ili je piece of cake kao na desktop računalu?
Staro 11.12.2010., 12:38   #4
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Standardni postupak kao i na desktopu. Jedino je zajeb ako moraš rastaviti pola laptopa da bi došao do hladnjaka i procesora.
Staro 11.12.2010., 12:41   #5
Postovi: 34,060
Najčešće proc u socketu ne drži polugica kao u desktop konfama nego malo veći šaraf. I dobro pazi kad skidaš cooler da ne shebeš toplovodne cijevi u njemu.
Staro 11.12.2010., 12:48   #6
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Kakav sam baksuz u zadnje vrijeme, čisto bi me čudilo da lap proradi nakon te moje zamjene...
Staro 11.12.2010., 12:58   #7
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Ma, nemaš tu baš šta izbaksuzirat.
Samo kad kupuješ proc, vodi računa o sljedećem:
Obavezno Dothan sa 2 MB L2 cache-a, i ako ti je unutra DDR1 SODIMM, sa 400 MHz fsb-om. Ako staviš, npr. proc iz te serije sa 533 MHz fsb-om, neće raditi na punoj frekvenciji.
[GOW]Nec je offline   Reply With Quote
Staro 11.12.2010., 13:08   #8
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
E jebat ga. Di da vidim tip rama? Everest?
Staro 11.12.2010., 13:39   #9
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Code:
Informacije o matičnoj ploči
ID matične ploče	63-1546-009999-00101111-101205-SIS661FX$0AAAA005_BIOS DATE: 10/12/05 VER: 206
Naziv matične ploče	Asus A9000T Series Notebook
Informacije o FSB-u
Tip sabirnice	Intel AGTL+
Širina sabirnice	64 bit
Osnovna frekvencija	100 MHz (QDR)
Efektivna frekvencija	400 MHz
Propusnost	3200 MB/s
Informacije o memorijskoj sabirnici
Tip sabirnice	DDR SDRAM
DRAM:FSB omjer	5:3
Osnovna frekvencija	167 MHz (DDR)
Efektivna frekvencija	333 MHz
Propusnost	2667 MB/s
Informacije o chipset sabirnici
Tip sabirnice	SiS MuTIOL
Širina sabirnice	16 bit
Proizvođač matične ploče
Naziv tvrtke	ASUSTeK Computer Inc.
Informacije o proizvodu	http://www.asus.com/products.aspx?l1=3
BIOS download	http://support.asus.com/download/download.aspx?SLanguage=en-us
Nadogradnja drivera	http://driveragent.com?ref=59
BIOS nadogradnje	http://www.esupport.com/biosagent/index.cfm?refererid=40
Code:
Informacije o memorijskim modulima
Naziv modula	Hynix HYMD564M646B6-J
Serijski broj	1C3C5101h (22101020)
Kapacitet modula	512 MB (2 ranks, 4 banks)
Tip memorijskog modula	Unbuffered
Tip memorije	DDR SDRAM
Brzina modula	PC2700 (166 MHz)
Širina modula (bit)	64 bit
Napon na modulu	SSTL 2.5
Metoda otkrivanja pogreški	Nema
Brzina osvježavanja	Skraćeno (7.8 us), Self-Refresh
Memorijski tajminzi
@ 166 MHz	2.5-3-3-7  (CL-RCD-RP-RAS) / 10-12-2  (RC-RFC-RRD)
@ 133 MHz	2.0-3-3-6  (CL-RCD-RP-RAS) / 8-10-2  (RC-RFC-RRD)
Podrška memorijskog modula
Early RAS# Precharge	Nije podržano
Auto-Precharge	Nije podržano
Precharge All	Nije podržano
Write1/Read Burst	Nije podržano
Buffered Address/Control Inputs	Nije podržano
Registered Address/Control Inputs	Nije podržano
On-Card PLL (Clock)	Nije podržano
Buffered DQMB Inputs	Nije podržano
Registered DQMB Inputs	Nije podržano
Differential Clock Input	Podržano
Redundant Row Address	Nije podržano
Proizvođač memorijskog modula
Naziv tvrtke	Hynix Semiconductor Inc.
Informacije o proizvodu	http://www.hynix.com/gl/products
Ovo znači da idu samo 400MHz procesori unutra i da bi 533MHz Dothani radili na 400MHz ili?
Staro 11.12.2010., 13:55   #10
vranjba
vranjba's Avatar
Datum registracije: Aug 2009
Postovi: 613
može u everestu pod motherboard/spd, može i u cpu-z
edit: koliko kasnim s odgovorom
CPU: AMD Phenom II X2 545 @X4 B45 + AC Freezer 64 Pro PWM
MBO: Asrock a780GXH @ bios 1.70
RAM: Kingmax 2x2GB PC2-8500
VGA: Sapphire HD5570 1GB
Zvučna: Asus xonar d1
HDD: WD6401AALS + WD2000JB + WD3200AAJS
PSU: Corsair cx400W
Case: Gigabyte GZ-X6
Keyboard: Logitech mk520 + Microsoft Natural Wireless Mouse 6000
Daljnski: Mce ir
Zvučnici: Swans d1080mkii 08
Monitori: Philips 220SW + HP L1950g
TV: Panasonic TX-P50C3E
AIO: HP Deskjet F4280
OS: Windows 7 x64
HP Compaq nx7010
CPU: Pentium centrino 2.0 GHz
RAM: 1gb + 512mb PC2700
VGA: ATI Mobility Radeon 9200 32mb
HDD: wd 40 GB
OS: Win XP SP3 x32
CPU: Pentium 3 1.0 GHz + Glacialtech igloo 2520
MBO: Intel D815EFV
RAM: 2x 256mb PC133
HDD: Maxtor 80gb + Seagate Barracuda 7200.7 160gb
PSU: Codegen 400W
OS: Win XP SP3 x32
PCI Lan: Linksys cisco gigabit EG1032 v3
Routher: Thomson ST780i WL
Net: T-com Flat
Acernote lite 350pc
CPU: Pentium 100 MHz
RAM: 8 mb edo onboard
VGA: chips&tech f65545
HDD: ibm 540 mb
OS: win 95
CPU: pentium 166 MHz
MBO: ga 586vx rev 3.37
RAM: 4x16 mb edo ram
VGA: Ati 3D rage II +dvd 4 mb
HDD: quantum fireball se2.1a 2.1 gb
PSU: seasonic ssa-200g
Monitor: Acer 13"
OS: dos 6.22
Zadnje izmijenjeno od: vranjba. 11.12.2010. u 14:01.
vranjba je offline   Reply With Quote
Staro 11.12.2010., 13:59   #11
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Staro 11.12.2010., 14:01   #12
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
Evo ga i ohoho jeftinije Samo je pitanje oćel taj 533MHz CPU raditi normalno na ovoj ploči koja je u laptopu...
Staro 11.12.2010., 14:52   #13
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Pa za 8 + 3 € se ipslati kupiti pa probati. Ako ne bude radio staviš ga ovde na tržnicu i doviđenja.
Staro 11.12.2010., 15:52   #14
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
A vidit ćemo score uskoro
Staro 11.12.2010., 16:13   #15
Dottore
Dottore's Avatar
Postovi: 7,701
M760 grije jače Imam ga ja na T43p
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 11.12.2010., 16:19   #16
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Di ćeš jače, i ovaj Celer 380 zna otperjat na 60 celzija...
Staro 11.12.2010., 16:35   #17
Dottore
Dottore's Avatar
Postovi: 7,701
Autor Dottore Pregled postova
Moj lapus. imam M770 ( 2,13Ghz ) uz full opterečenju ide do 78C.
M735 i M745 (oba 400Mhz FSB ) nemaju problema s grijanjem. Provjereno.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 11.12.2010., 19:43   #18
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Da, samo je pitanje bi li ti 533MHz Dothani radili u full speedu na mom laptopu...a 400MHz Dothana je gotovo nemoguće naći ispod 200kn (konkretno našao sam jednog M745 za cca 37 USD na ebayu).
Sad je pitanje, ubosti bolje ovog M750 ili ići na ziher sa M745 koji je dosta skuplji.
Staro 11.12.2010., 20:38   #19
Dottore
Dottore's Avatar
Postovi: 7,701
Iima na newsu, njuškalu. Neki dan sam ih vidio 50 d 150kn
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 12.12.2010., 13:17   #20
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
A što je sa ovom T serijom Meroma(konkretno nudi mi se jedan T7400) koja ide na taj 478/479 socket? To ne može ni pod razno? Nigdje na netu ne mogu izguglati koji max CPU podržava ploča ovog laptopa sa SIS čipsetom...
Staro 12.12.2010., 13:31   #21
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Kad smo već kod ovoga, onda i mene zanima kako bi radili 533 FSB procevi na 400tki?
BTW, odkad ti dottore imas 745icu? Kitiš se perjem tuđim a?
@Dizla- nemoj se brinut o grijanju, napravi se lagani undervolt i ako vidiš preko 52c u prime 95 režem ruku. Moj je sad evo idle 34c, još se vent nepali
Staro 12.12.2010., 14:07   #22
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ma nisam nikad dosad šarafao po laptopima pa me vuna da nešto ne strgam, sve mi to nekako prekrhko izgleda iznutra...
Ajmo nek netko izvidi jel mogu Meromi na ove SIS čipsete. To bi bio the right deal, dualcore CPU, ohoho.
Ovdje je slika ploče koja je unutra sa specifikacijama:
http://www.trademe.co.nz/Computers/L...-333601989.htm
Staro 12.12.2010., 15:06   #23
Dottore
Dottore's Avatar
Postovi: 7,701
@Halos
Imam ih otprilike 2 i pol tjedna. Zaboravio sam ti reći jer u posljednje vrijeme premalo vremena .
@Dizel
mislim da Meromi idu na 945 chipset. Dual core i DDR1 ne idu skupa.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 12.12.2010., 15:16   #24
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Tako sam si i mislio otprilike...
Staro 12.12.2010., 15:32   #25
MMI
MMI's Avatar
Postovi: 913
bilo koji dothan će ti radit, čak i najjači, imao sam taj lap i trpao sam svašta u njega
MMI je offline   Reply With Quote
Staro 24.12.2010., 18:25   #26
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Evo ekipa, stigao Dothan M750 za cca 80kn sa šipingom sa ibeja i odmah ga tata uvalio unutra, radi mali kao zmaj full speedom
Code:
Procesor	Mobile Intel Pentium M 750
CPU stepping	C0
CPUID (naziv procesora)	Intel(R) Pentium(R) M processor 1.86GHz
CPUID revizija	000006D8h
CPU VID	1.3560 V
CPU Brzina
Brzina procesora	1861.9 MHz  (original: 1866 MHz)
CPU Množitelj	14x
CPU FSB	133.0 MHz  (original: 133 MHz)
Memorijska sabirnica	166.2 MHz
DRAM:FSB omjer	5:4
CPU Cache
L2 cache	2 MB  (On-Die, ECC, Full-Speed)
Informacije o chipsetu
Chipset na matičnoj ploči	SiS M661MX
Memorijski tajminzi	2.5-3-3-5  (CL-RCD-RP-RAS)
DIMM1: Hynix HYMD564M646B6-J	512 MB PC2700 DDR SDRAM  (2.5-3-3-7 @ 166 MHz)  (2.0-3-3-6 @ 133 MHz)
DIMM2: Nanya NT512D64SH8B0GN-6K	512 MB PC2700 DDR SDRAM  (2.5-3-3-7 @ 166 MHz)  (2.0-3-3-6 @ 133 MHz)
BIOS informacije
Datum izdanja sistemskog BIOS-a	10/12/05
Datum izdanja video BIOS-a	07/22/05
DMI verzija BIOSa	206
Informacije o grafičkom procesoru
Grafička kartica	SiS 330 Mirage Integrated
Kodno ime grafičkog procesora	Mirage (SiS661)  (Integrated 1039 / 6330, Rev 00)
Radni takt grafičkog procesora	134 MHz
Frekvencija memorije	183 MHz
Code:
Procesor	Mobile Intel Pentium M 750, 1866 MHz (14 x 133)
CPU stepping	C0
Originalna frekvencija	1866 MHz
Min / Max CPU množitelj	6x / 14x
Napon jezgre	0.988 - 1.356 V
I/O napon	0.988 - 1.356 V
Zauzeće procesora
Procesor #1	6 %
Staro 24.12.2010., 19:00   #27
MMI
MMI's Avatar
Postovi: 913
pa reko sam ti, imam takav lap doma, crklo mu punjenje i sad stoji al znam da sam maknuo celerona i pukno dothana i da je radio ko čigra
Staro 25.12.2010., 11:16   #28
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Sad je pila sasma solidna, procesor je apgrejdan na Dothana 1.86, 2x512MB DDR 333, 60GB WD Scorpio, WLAN kartica ubačena. Još samo da se se grafička može promijeniti
Temperature sa ovim Dothanom M 750 2M su još i manje nego sa starim originalnim Celeronom M 380 1M, vjerovatno i zato što sam odljepio onu staru žvaku sa heatipipe koja bi trebala glumiti termalnu pastu, a i hitpajpu sam dobro pošmiglao i zagladio na mirror finish prije nakeljivanja na ovog Dothana Vent se pali jako rijetko, a i kad radi na 2500 RPM ja ga ne čujem. Spram bratovog HP 6735S ovo je milina, njegov lap urla kao kosilica pod Win7, vjerovatno zbog Aera kojeg ja ne mogu tjerati s ovim SiS GPU-om.
Staro 25.12.2010., 14:07   #29
MMI
MMI's Avatar
Postovi: 913
celer ti je stalno radio na full a dothan sviča množitelj ili fsb pa se manje grije i troši. taj bratov hp ima problema sa prašinom vjerovatno jer svi koje znam ne bruje ( ja čistio i paste mjenjao, hehe)
Staro 25.12.2010., 14:22   #30
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Ja sad nekužim...
Znaći tvoj lapac je do max fsb400, a ti si grunuo procesor koji je 533fsb i on radi na full speed?
To znači da ipak nije 400 vec 533, ali kako onda ide 533 fsb sa ddr1?
