3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Asus A9T max supported CPU?
Imam navedeni laptop i unutra je neki Celeron Dothan M380, ako se ne varam. Koji procesor max može unutra i jel to problem promijeniti? Ovaj je unutra: Code:
Polje Trenutna vrijednost Informacije o procesoru Procesor Mobile Intel Celeron M LV, 1600 MHz (16 x 100) Jezgra procesora Dothan-1024 CPU stepping C0 Podržani setovi instrukcija x86, MMX, SSE, SSE2 Originalna frekvencija 1600 MHz Min / Max CPU množitelj 6x / 16x Engineering Sample Ne L1 cache za kod 32 KB L1 cache za podatke 32 KB L2 cache 1 MB (On-Die, ECC, Full-Speed) Fizikalne informacije o procesoru Tip pakiranja 479 Ball uFCBGA / 478 Pin uFCPGA Dimenzije 3.5 cm x 3.5 cm Broj tranzistora 140 milijuna Tehnologija izrade 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si Veličina silicijske pločice 88 mm2 Napon jezgre 1.164 V I/O napon 1.164 V Standardna potrošnja 3.0 - 21.0 W (ovisno o frekvenciji) Maksimalna potrošnja 3.3 - 28.1 W (ovisno o frekvenciji) Proizvođač procesora Naziv tvrtke Intel Corporation Informacije o proizvodu http://www.intel.com/products/processor Zauzeće procesora Procesor #1 1 % |
Lokacija: Opuzen/Zagreb
Postovi: 347
Ja bi reka ovaj, ali samo da malo jos vidim po netu. http://www.cpu-world.com/CPUs/Pentiu...2266FJ%29.html "Upgrading socket M motherboards To determine which processors are supported by your system you'll need to determine computer model (for brand-name notebooks, like Dell or HP), or a manufacturer and a model of your motherboard, and then search on manufacturer's website for that computer or motherboard model. Most manufacturers don't post CPU upgrade information for notebooks, but sometimes you may find upgrade recommendations in manufacturer's product support forums. Also try to send an e-mail to manufacturer's custom support, or post in other computer-related forums, but don't expect many responses." EDIT: Mislim da ovi svi, ili vecina njih pase! http://www.cpu-world.com/CPUs/Pentiu...%20Dothan.html Bolje da netko strucniji potvrdi. ![]()
Najgore se sekirat!!! ![]() Acer TimelineX 5830G Zadnje izmijenjeno od: [Psyho]Cox. 10.12.2010. u 13:41. |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Evo našao sam Dothana Pentium M750 i kako izgleda trebao bi ići u taj lap... http://ark.intel.com/Compare.aspx?ids=27593,27146, Jel problem zamijenit CPU ili je piece of cake kao na desktop računalu? |
Postovi: 33,923
Najčešće proc u socketu ne drži polugica kao u desktop konfama nego malo veći šaraf. I dobro pazi kad skidaš cooler da ne shebeš toplovodne cijevi u njemu.
Postovi: 1,215
Ma, nemaš tu baš šta izbaksuzirat. ![]() Samo kad kupuješ proc, vodi računa o sljedećem: Obavezno Dothan sa 2 MB L2 cache-a, i ako ti je unutra DDR1 SODIMM, sa 400 MHz fsb-om. Ako staviš, npr. proc iz te serije sa 533 MHz fsb-om, neće raditi na punoj frekvenciji.
Udomljujem stare laptope i njihove dijelove. ![]() |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Code:
Polje Trenutna vrijednost Informacije o matičnoj ploči ID matične ploče 63-1546-009999-00101111-101205-SIS661FX$0AAAA005_BIOS DATE: 10/12/05 VER: 206 Naziv matične ploče Asus A9000T Series Notebook Informacije o FSB-u Tip sabirnice Intel AGTL+ Širina sabirnice 64 bit Osnovna frekvencija 100 MHz (QDR) Efektivna frekvencija 400 MHz Propusnost 3200 MB/s Informacije o memorijskoj sabirnici Tip sabirnice DDR SDRAM Širina sabirnice 64 bit DRAM:FSB omjer 5:3 Osnovna frekvencija 167 MHz (DDR) Efektivna frekvencija 333 MHz Propusnost 2667 MB/s Informacije o chipset sabirnici Tip sabirnice SiS MuTIOL Širina sabirnice 16 bit Proizvođač matične ploče Naziv tvrtke ASUSTeK Computer Inc. Informacije o proizvodu http://www.asus.com/products.aspx?l1=3 BIOS download http://support.asus.com/download/download.aspx?SLanguage=en-us Nadogradnja drivera http://driveragent.com?ref=59 BIOS nadogradnje http://www.esupport.com/biosagent/index.cfm?refererid=40 Code:
Polje Trenutna vrijednost Informacije o memorijskim modulima Naziv modula Hynix HYMD564M646B6-J Serijski broj 1C3C5101h (22101020) Kapacitet modula 512 MB (2 ranks, 4 banks) Tip memorijskog modula Unbuffered Tip memorije DDR SDRAM Brzina modula PC2700 (166 MHz) Širina modula (bit) 64 bit Napon na modulu SSTL 2.5 Metoda otkrivanja pogreški Nema Brzina osvježavanja Skraćeno (7.8 us), Self-Refresh Memorijski tajminzi @ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) / 10-12-2 (RC-RFC-RRD) @ 133 MHz 2.0-3-3-6 (CL-RCD-RP-RAS) / 8-10-2 (RC-RFC-RRD) Podrška memorijskog modula Early RAS# Precharge Nije podržano Auto-Precharge Nije podržano Precharge All Nije podržano Write1/Read Burst Nije podržano Buffered Address/Control Inputs Nije podržano Registered Address/Control Inputs Nije podržano On-Card PLL (Clock) Nije podržano Buffered DQMB Inputs Nije podržano Registered DQMB Inputs Nije podržano Differential Clock Input Podržano Redundant Row Address Nije podržano Proizvođač memorijskog modula Naziv tvrtke Hynix Semiconductor Inc. Informacije o proizvodu http://www.hynix.com/gl/products Ovo znači da idu samo 400MHz procesori unutra i da bi 533MHz Dothani radili na 400MHz ili? |
Datum registracije: Aug 2009
Postovi: 613
može u everestu pod motherboard/spd, može i u cpu-z edit: koliko kasnim s odgovorom ![]()
Zadnje izmijenjeno od: vranjba. 11.12.2010. u 13:01. |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT Evo ga i ohoho jeftinije ![]() |
Adrenaline junkie
Postovi: 3,593
Pa za 8 + 3 € se ipslati kupiti pa probati. Ako ne bude radio staviš ga ovde na tržnicu i doviđenja.
#17 |
Postovi: 7,618
__________________ |
#18 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Da, samo je pitanje bi li ti 533MHz Dothani radili u full speedu na mom laptopu...a 400MHz Dothana je gotovo nemoguće naći ispod 200kn (konkretno našao sam jednog M745 za cca 37 USD na ebayu). Sad je pitanje, ubosti bolje ovog M750 ili ići na ziher sa M745 koji je dosta skuplji. |
#20 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
A što je sa ovom T serijom Meroma(konkretno nudi mi se jedan T7400) koja ide na taj 478/479 socket? To ne može ni pod razno? Nigdje na netu ne mogu izguglati koji max CPU podržava ploča ovog laptopa sa SIS čipsetom... |
#21 |
muimerP
Lokacija: VG
Postovi: 3,334
Kad smo već kod ovoga, onda i mene zanima kako bi radili 533 FSB procevi na 400tki? BTW, odkad ti dottore imas 745icu? Kitiš se perjem tuđim a? ![]() @Dizla- nemoj se brinut o grijanju, napravi se lagani undervolt i ako vidiš preko 52c u prime 95 režem ruku. Moj je sad evo idle 34c, još se vent nepali ![]()
#22 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Ma nisam nikad dosad šarafao po laptopima pa me vuna da nešto ne strgam, sve mi to nekako prekrhko izgleda iznutra... Ajmo nek netko izvidi jel mogu Meromi na ove SIS čipsete. To bi bio the right deal, dualcore CPU, ohoho. Ovdje je slika ploče koja je unutra sa specifikacijama: ![]() http://www.trademe.co.nz/Computers/L...-333601989.htm |
#23 |
Postovi: 7,618
@Halos Imam ih otprilike 2 i pol tjedna. Zaboravio sam ti reći jer u posljednje vrijeme premalo vremena . @Dizel mislim da Meromi idu na 945 chipset. Dual core i DDR1 ne idu skupa. ![]()
#25 |
Postovi: 913
bilo koji dothan će ti radit, čak i najjači, imao sam taj lap i trpao sam svašta u njega |
#26 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Evo ekipa, stigao Dothan M750 za cca 80kn sa šipingom sa ibeja i odmah ga tata uvalio unutra, radi mali kao zmaj full speedom ![]() Code:
Polje Trenutna vrijednost Informacije o procesoru Procesor Mobile Intel Pentium M 750 Jezgra procesora Dothan CPU stepping C0 Engineering Sample Ne CPUID (naziv procesora) Intel(R) Pentium(R) M processor 1.86GHz CPUID revizija 000006D8h CPU VID 1.3560 V CPU Brzina Brzina procesora 1861.9 MHz (original: 1866 MHz) CPU Množitelj 14x CPU FSB 133.0 MHz (original: 133 MHz) Memorijska sabirnica 166.2 MHz DRAM:FSB omjer 5:4 CPU Cache L1 cache za kod 32 KB L1 cache za podatke 32 KB L2 cache 2 MB (On-Die, ECC, Full-Speed) Informacije o matičnoj ploči ID matične ploče 63-1546-009999-00101111-101205-SIS661FX$0AAAA005_BIOS DATE: 10/12/05 VER: 206 Naziv matične ploče Asus A9000T Series Notebook Informacije o chipsetu Chipset na matičnoj ploči SiS M661MX Memorijski tajminzi 2.5-3-3-5 (CL-RCD-RP-RAS) DIMM1: Hynix HYMD564M646B6-J 512 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz) DIMM2: Nanya NT512D64SH8B0GN-6K 512 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz) BIOS informacije Datum izdanja sistemskog BIOS-a 10/12/05 Datum izdanja video BIOS-a 07/22/05 DMI verzija BIOSa 206 Informacije o grafičkom procesoru Grafička kartica SiS 330 Mirage Integrated Kodno ime grafičkog procesora Mirage (SiS661) (Integrated 1039 / 6330, Rev 00) Radni takt grafičkog procesora 134 MHz Frekvencija memorije 183 MHz Code:
Polje Trenutna vrijednost Informacije o procesoru Procesor Mobile Intel Pentium M 750, 1866 MHz (14 x 133) Jezgra procesora Dothan CPU stepping C0 Podržani setovi instrukcija x86, MMX, SSE, SSE2 Originalna frekvencija 1866 MHz Min / Max CPU množitelj 6x / 14x Engineering Sample Ne L1 cache za kod 32 KB L1 cache za podatke 32 KB L2 cache 2 MB (On-Die, ECC, Full-Speed) Fizikalne informacije o procesoru Tip pakiranja 479 Ball uFCBGA / 478 Pin uFCPGA Dimenzije 3.5 cm x 3.5 cm Broj tranzistora 140 milijuna Tehnologija izrade 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si Veličina silicijske pločice 88 mm2 Napon jezgre 0.988 - 1.356 V I/O napon 0.988 - 1.356 V Standardna potrošnja 3.0 - 21.0 W (ovisno o frekvenciji) Maksimalna potrošnja 3.3 - 28.1 W (ovisno o frekvenciji) Proizvođač procesora Naziv tvrtke Intel Corporation Informacije o proizvodu http://www.intel.com/products/processor Zauzeće procesora Procesor #1 6 % |
#27 |
Postovi: 913
pa reko sam ti, imam takav lap doma, crklo mu punjenje i sad stoji al znam da sam maknuo celerona i pukno dothana i da je radio ko čigra ![]() |
#28 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Sad je pila sasma solidna, procesor je apgrejdan na Dothana 1.86, 2x512MB DDR 333, 60GB WD Scorpio, WLAN kartica ubačena. Još samo da se se grafička može promijeniti ![]() Temperature sa ovim Dothanom M 750 2M su još i manje nego sa starim originalnim Celeronom M 380 1M, vjerovatno i zato što sam odljepio onu staru žvaku sa heatipipe koja bi trebala glumiti termalnu pastu, a i hitpajpu sam dobro pošmiglao i zagladio na mirror finish prije nakeljivanja na ovog Dothana ![]() |
#29 |
Postovi: 913
celer ti je stalno radio na full a dothan sviča množitelj ili fsb pa se manje grije i troši. taj bratov hp ima problema sa prašinom vjerovatno jer svi koje znam ne bruje ( ja čistio i paste mjenjao, hehe) |
#30 |
muimerP
Lokacija: VG
Postovi: 3,334
Ja sad nekužim... Znaći tvoj lapac je do max fsb400, a ti si grunuo procesor koji je 533fsb i on radi na full speed? To znači da ipak nije 400 vec 533, ali kako onda ide 533 fsb sa ddr1?
