Staro 28.11.2010., 15:57   #1081
n_way
n_way's Avatar
Lokacija: Šenkovec
Postovi: 61
Dal se može jailbreak iPhone v2.0.2 02.08.2001 sa BlackRa1n-om???? Ili s koji softwareom se može??
Zadnje izmijenjeno od: n_way. 28.11.2010. u 17:04.
n_way je offline   Reply With Quote
Staro 28.11.2010., 22:33   #1082
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Novi unlock i to za baseband 06.15!! Otkud sad ta brojka? - evo malo štiva za za čitanje: http://blog.iphone-dev.org/post/1718.../ultra-recycle
Koji mix, svaka čast
Staro 28.11.2010., 22:59   #1083
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Flajpan
Aj molim te objasni mi par stvari, pročital sam ovo al pošto ne kužim sve pojmove recimo dobro ko ti neke stvari mi nisu jasne...a pročital sam i neke komentare pa vidim da ima i puno sličnih.
Ja sad imam 4.1(8B117) FW 05.14.02
JB sa Limera1n.
E kaj sad? Hoću napravit čisti RESTORE sa iTunesom na najnoviju verziju(4.2.1) .
I tada jel mogu napravit JB i UL ? I sa čime?
Zadnje izmijenjeno od: danc00. 28.11.2010. u 23:12.
danc00 je offline   Reply With Quote
Staro 29.11.2010., 00:01   #1084
flajpan
flajpan's Avatar
Postovi: 1,796
Ne moraš updateat na 4.2.1 nego napraviš 4.1 custom sa novim 4.1.3 Pwnage tool u kojem odabereš da koristi baseband (06.15) iz iPadovog firmwarea koji se može otključat
Al pročitaj i upozorenje:
WARNING — YOU DO THIS AT YOUR OWN RISK! PLEASE UNDERSTAND THE CONSEQUENCES OF UPDATING TO 06.15.
1. There is no way to come back down from 06.15, and there’s no hiding the baseband version from Apple. You’ll be voiding your warranty in a very obvious way.
2. If some future baseband comes out with a critical fix, you won’t be able to update to it if it remains down in the 05.xx sequence (then again, you wouldn’t update to it if you wanted to keep your unlock anyway).
3. Starting with FW 4.2.1 if you have 06.15 on your iPhone you won’t ever be able to restore to stock firmware (it will fail). You’ll need to only restore to custom IPSWs (then again, if you’re unlocker you should already be doing that).
P.S.
@danc00 Koji iPhone? 3G i 3GS stari bootrom možeš 4.2.1 custom, 3GS novi bootrom - 4.1 custom stavljat gore (razlog untethered
Zadnje izmijenjeno od: flajpan. 29.11.2010. u 00:08.
Staro 29.11.2010., 00:37   #1085
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Ajoj, ne volim te custom, mislil sam da je došel ONE CLICK UL i JB ko u stara vremena...
Imam 3GS. Možda i to dođe uskoro...
Staro 30.11.2010., 09:12   #1086
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
ima netko iskustva kako posložiti mms postavke za tomato na iphone?
Na ovome linku su podaci ali ne pašu nazivi postavki i kikak da pogodim
http://www.tomato.com.hr/tomato/show...&idnews=689276
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 30.11.2010., 17:14   #1087
spawn
spawn's Avatar
Postovi: 8,425
Autor danc00
Skini novi redsn0w 0.96-b5 ,izaberi iphone 4.1 original firmware i kad ti izadje menu za biranje opcija,skini kvacicu sa INSTALL CYDIJA i izaberi onu opciju FLASH BASEBAND FIRMWARE (slicno tome) i redsnow ce ti samo update-at baseband na 6.15 i nakon toga samo preko cydije instaliras ultrasnow.
Napomena: kad to napravis neces vise moci update-ati original firmware preko itunesa jer je taj bb 6.15 zapravo od ipad-a pa ces stalno morati stavljati custom (trenutno je takva situacija ali vjerojatno ce to netko kasnije srediti)
Staro 30.11.2010., 19:53   #1088
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Skužil sam za to, i to nikak nebi htel...zato ću čekat
Staro 30.11.2010., 21:02   #1089
spawn
spawn's Avatar
Postovi: 8,425
Autor n_way Pregled postova
To je prastari firmware i postoji par toolova za to npr. ziphone,ali je to imho verzija koja vise ne sluzi nicemu. Stavi lijepo verziju 3.1.3 i jailbreakaj sa spiritom i unlockaj sa ultrasnow-om.
Staro 01.12.2010., 19:07   #1090
n_way
n_way's Avatar
Lokacija: Šenkovec
Postovi: 61
Ok, hvala
Staro 01.12.2010., 22:46   #1091
J0Błack'
J0Błack''s Avatar
Datum registracije: Aug 2009
Lokacija: WC
Postovi: 19
Pozz,posto ne vidim niti jednu temu za iPod u slicnu temu cu postat ;
Imam problema sa iPodom,ipod sam kupio polovan i na njemu je bilo 4.1 (8B117),problemi su sljedeci,spojim ga na usb,ne zeli se punit,ne prepoznaje ga iTunes niti jedan drugi slican program za prebacivat muziku itd,ali cuje se USB kod spajanja i od spajanja.Citam malo po netu i kazu da je mozda do greske kod jailbreaka,skinem greenpois0n za 4.1 i pratim upute i sve ok kaze jailbreaking finished.Tijekom JB iskocio je prozor za USB i pisalo je "apple usb hardware nesto u tom smislu"i nakon sto se JB obavio iPod se iskljucio te sam ga ja ponovno ukljucio,ali nazalost opet se nije punio niti ga je pc prepoznao.POMOC,hvala.
J0Błack' je offline   Reply With Quote
Staro 03.12.2010., 12:01   #1092
n_way
n_way's Avatar
Lokacija: Šenkovec
Postovi: 61
Pa jel bi se dalo sa ziphone-om jailbreakat verzija 2.0.2 3G, zato jer vidim da svugdje u ziphone-u piše da je za verziju 1.1.4, pa me to malo zbunjuje!??
Inače mislio sam ga jailbreakat sa QuickPwn-om pa me zanima ako netko zna dali nakon toga treba raditi kakav restor sa iTunesom ili kad QuickPwn završi to je to netreba više ništa i on je jailbreakan????
Staro 03.12.2010., 12:35   #1093
flajpan
flajpan's Avatar
Postovi: 1,796
Daj napravi ovo što ti je @Bruno_Rv rekao.
Staro 04.12.2010., 00:56   #1094
spawn
spawn's Avatar
Postovi: 8,425
Mozes i quickpwnom ali moram ponovit: 2.0.2 ne sluzi nicemu. Nijedna aplikacija vise ne radi na toj verziji. Poslusaj kolegu Flajpana
BTW: dodatak za one koji zele unlockat 4.1 i visu verziju tj. bb 5.13,5.14 i 5.15 na iphone-u 3g/3gs : BB v. 6.15 koja se stavlja na iphone za potrebe unlocka ima neke probleme s gps signalom (ne na svim iphone-ima),pa ako mozete bolje pricekajte nekakav bug fix/hack.
Zadnje izmijenjeno od: spawn. 04.12.2010. u 01:05.
Staro 04.12.2010., 11:22   #1095
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor J0Błack' Pregled postova
A jesi probao napraviti restore?
Staro 04.12.2010., 13:11   #1096
Ivan007
Datum registracije: Sep 2010
Postovi: 14
OK koliko sam skuzio doso je konacno unlock za Iphone....
Ja imam 3g i stvarno mi je dosta te 3310 nokije pa bi se rado ponovo vratio na Iphone koji mi je do sada skupljo prasinu....
Procito sam sva vasa uputstva ali me je jednostavno strah ponovo radit sam, jer sam se i prosli put tak zeznuo sto je rezultiralo 3 mjeseca bez mobitela...mozda bi ovaj put mogo pokusat ponovo ali me jednostavno strah da opet nekej ne updejtam pa da opet moram cekat....
Dakle trenutno sam na 3.1.3 a firmware mi je na 05.14.02...
Najbitnije stvar mi je navigacija na mobitelu jer bez nje neznam izac iz zagreba....vidio sma da je novi tom tom izaso i nadam se da za njega netreba 4.1....
Jer ima neko ko bi mi mogo otkljucat ajfon da mi radi na tomato? I ako je potrebno updejtat ga na 4.1 da mogu imat navigaciju na njemu?
Molim vas ako ne zelite tu da mi na PP javite...ja sam na pol puta izmedju Samobora i Zagreba...posaljite mi na pp cijenu i broj mobitela pa vas nazovem da se najdemo negdje ili dojdete kod mene na sok i kolace hehe
Hvala unaprijed
Ivan007 je offline   Reply With Quote
Staro 04.12.2010., 18:22   #1097
spawn
spawn's Avatar
Postovi: 8,425
Autor Ivan007 Pregled postova
Hvala unaprijed
Dva posta prije tvog sam napisao da unlock radi ali je dosta ljudi prijavilo probleme s gps-om. Znaci ako ti treba gps,mozes riskirati i otkljucat ga i mozda ces imati probleme a mozda i neces. I to je to.
Staro 05.12.2010., 12:15   #1098
Salko01
Salko01's Avatar
Lokacija: PcEkspert forum
Postovi: 554
Zna netko mozda kako rijesiti ovaj problem?
Danas sam dobio IP 3gs koji je dosao na 4.2.1 i zakljucan je na Švicarskoj mrezi,da li se moze napraviti JB i unlock ili vratiti na neki stari software i kako?
Salko01 je offline   Reply With Quote
Staro 05.12.2010., 13:34   #1099
Ivan007
Postovi: 14
Hmm morat cu opet sam izgleda buduci da mi se niko nije javio....
Jer ima nesto na kaj moram posebno pazit? Cito sam malo o tome 6.15 kao da se nece moc maknut dok ne izadje u budučnosti neki alat i svakavih informacija koje pol ne kuzim....
Uglavnom ja sad imam 3.1.3 verziju jer moze neko napisat kaj trebam radit onak korak po korak kak ste vec objasnili?
Dal trebam opet skidat onu tinnyumbrela ili netreba?
Meni je iPhone trebnutno JB s onim jailbreakme.com dal sad samo s onim ultrasn0w ili kak to ide?
Cito sam na netu ali sam naso bar 4 stvari kak treba i siguran sam da bi ja izabro krivu xD
Staro 05.12.2010., 15:00   #1100
J0Błack'
J0Błack''s Avatar
Lokacija: WC
Postovi: 19
Autor Mihael Pregled postova
Jesam,ali javlja error,1611 i jos jedan nemogu se sjetit broja tocno.Nema sanse da ga restore nikako.
Staro 05.12.2010., 21:08   #1101
spawn
spawn's Avatar
Postovi: 8,425
Autor Salko01 Pregled postova
Mozes ali:
1. Moras staviti bb 6.15 sa redsnow 0.9.6.b6
2. Moras napraviti jb sa iszim redsnowom ali ne smijes dozvolit da ostanes bez baterije radi tethered jailbreaka. Za vise info procitaj ovaj thread ili gugaj
Staro 05.12.2010., 22:20   #1102
Salko01
Salko01's Avatar
Postovi: 554
Mozes ali:
To sam vec isprobo,dodje do waithing for reboot i tu stane.
Znaci to mi je bila jedina opcija ili se moze vratiti na jedan od starih softwera?
Staro 06.12.2010., 00:15   #1103
spawn
spawn's Avatar
Postovi: 8,425
Ako je nov i ima tvornicki 4.2.1 ili nije nov ali nije nikad bio jb-an,ne mozes vratit na stariju verziju
Staro 06.12.2010., 02:18   #1104
rjanma
Datum registracije: Mar 2009
Postovi: 25
3gs baseband 06.15, ios 4.1, otkljucan i sve ok, ali GPS NE RADI!! Tako da ne racunate na gps nakon tog postupka. To trebaju raditi samo unlockeri (oni koji nisu na T-Mobileu) koji su iz ovog ili onog razloga zavrsili na basebandu 05.12.04 (kao ja naprimjer ). Svi ostali koji imate otkljucan mobitel koji radi, okanite se corava posla posto se unlockovi ionako rijetko desavaju.
Nego imam ja i jedno pitanje. Planiram kupiti za bozic voljenoj osobi iphone 4 ali sad su svi koji se prodaju po oglasnicima vec na novom basebandu i ios-u 4.1 tako da je nemoguc unlock a posto moram imati unlock neda mi se davati novce za iPod ???
Zna li netko gdje se moze nabavit starih iphonova 4, baseband 01.59.xx? Mozda netko ima na lageru?
rjanma je offline   Reply With Quote
Staro 06.12.2010., 07:45   #1105
Salko01
Salko01's Avatar
Postovi: 554
Ne nije nov i nikad nije imo JB.
Bas super,imam iphone za hitne pozive!
Kad bi trebo izaci unlock i JB 4.2.1??
Zadnje izmijenjeno od: Salko01. 06.12.2010. u 09:51.
Staro 06.12.2010., 10:25   #1106
rjanma
Postovi: 25
pa jailbreake bi trebao raditi na 4.2.1 (tethered), a unlock se ne zna kad ce (đekna )
Staro 06.12.2010., 19:16   #1107
mate11111
mate11111's Avatar
Lokacija: Đurđevac
Postovi: 22
Ja sam svoj 3G 16Gb apdejtal na 4.2.1 verziju i napravil jailbreak i unlock
I uključil sam multitasking al je dost sporiji dok je to instalirano + wallpaper iza ikonica i postotak baterija! Koristil sam RedSn0w najnoviji
mate11111 je offline   Reply With Quote
Staro 07.12.2010., 02:04   #1108
spawn
spawn's Avatar
Postovi: 8,425
Pa iznad sam napisao:
Ja ne znam sta je s vama kolgama ovdje u zadnje vrijeme ,zelite da vam posudim moje naocale
Staro 07.12.2010., 10:19   #1109
Postovi: 16,859
Evo, moj frend je imao isti problem, odnio ga na popravak, neka greška bila, popravili mu ga i sad je sve super...
Staro 07.12.2010., 14:28   #1110
Salko01
Salko01's Avatar
Postovi: 554
