#6241 |
Postovi: 668
kakva je sad situacija sa tim mapama,jel izasao sluzbeni patch,ako ne,jel ima servera na kojemu rade te mape sa nesluzbenim patchom? |
#6242 | |
Postovi: 1,668
ne koristim twitter pa ga bas i ne kuzim uglavnom, i dalje sam misljenja da je patch trebo izac danas, ali da su jucerasnji dogadjaji to odgodili. evo i neki rusi su uspjeli otkljucati meni od Vietnama EDIT: Citiraj:
#6243 |
znaci nema optike (ocekivano), ali nema i body armora. nema cg-a fala isusu, samo rpg. bilo si sve dobro da su dali djabe za PC, ovako nema sanse da uzimam kad nam dolaze 4 nove mape za obicni bc2, a uskoro pocinje beta za bf play 4 free... |
#6245 |
pa cold war, harvest day, oasis i heavy metal. jucer smo cak igrali sve osim heavy metal. |
#6248 | |
Addicted to music.
Postovi: 1,782
No, svejedno, bmk za Vietnam. ![]()
All you have is your fire and the place you need to reach. Don't you ever tame your demons, always keep them on a leash. |
#6249 | |||
Postovi: 1,668
malo sam zujo po ofisl forumu pa sam naisao na nesto sto bi moglo pomoc ekipi koja ima problema sa stutteringom i lagom. c/p sa foruma Disable High Precision Event Timer (HPET) in BIOS High Precision Event Timer - Wikipedia, the free encyclopedia Quote:
High Precision Event Timer and gaming performance - NVIDIA Forums Quote:
High Precision Event Timer - XtremeSystems Forums Quote:
My own result with DPC Latency Checker (http://www.thesycon.de/eng/latency_check.shtml): HPET 64-Bit ON: between 100-150us HPET OFF: between 5-15us I loss 3-4 frames per second, single card and CFX with HPET OFF, but I know responsiveness improved and chance of stuttering decreased accordingly. Disable CPU Enhanced Halt (C1E) & EIST (SpeedStep) or AMD Power Management equivalents in BIOS CPU Enhanced Halt (C1E) & EIST decrease overclocking reliability, create DPC latency spikes and hiccups in some circonstances. Remove AMD CCC.exe from automatic startup and/or kill process CCC.exe & MOM.exe before gaming (single card & CrossFireX) CCC.exe is a DPC hanger, cause of stuttering, you can check that with Resplendence Tools (Resplendence Software - Advanced System Tools and Developer Components) & DPC Latency Checker (DPC Latency Checker). Shut down that stuttering DPC latency lalalalala and her mother (MOM.exe), you will get some additional fps from it. The slower your computer the bigger the increase in responsiveness and stuttering reduction, dual core benefit the most. Right-click taskbar> Start Task Manager > right-click CCC.exe> End Process> right-click MOM.exe> End Process. Install AnVir Task Manager (AnVir Task Manager | Manager, Startup, Processes, Services, Programs) to easily untick CCC from startup. CCC can still be opened from right-click on desktop to change settings if needed, just kill the processes again after your changes. jos preporucaju da se u postavkama mrežne kartice iskljuci TCP/IPv6 protokol i da se ostavi samo TCP/IPv4 http://img251.imageshack.us/img251/7...properties.png jedan clan je napravio moddane ATI catalyst drivere http://forums.guru3d.com/showthread.php?t=332395 EDIT: svi hvale drivere i da donose poboljsanja ![]() Zadnje izmijenjeno od: zgmmax. 26.11.2010. u 09:22. |
#6250 |
znaci ipak je do nasih kompova, ne do igre, rajt ![]() najdrazi mi je ipak ovaj dio da iskljucim C1E i EIST ![]() |
#6251 | |
Postovi: 1,668
kolko sam skuzio EIST i C1E su procesi koji podrzavaju power saving, znaci zaduzeni su za nadgledanje potrosnje sustava. Citiraj:
trebali bi vi kaj imate probleme sa time isprobati iskljuciti to i vidjeti da li ima nekih promjena. |
#6252 | |
LateralusX
Postovi: 1,788
#6254 | |
pa da, to su instrukcije za power saving, i to je nesto najbolje sto su donijeli core 2 procesori. kad to ugasis proc ti nepotrebno przi na najvisoj frekvenciji i voltazi, i sto je najbitnije nemos u sleep. nisam cuo ni za jedan program/igru koja bi imala s tim problema, dakle... ![]() |
#6256 | |
Postovi: 4,403
I da, to nema nikakve veze s igricom, možda kod nekog pali kome je mušićava ploča i regulacija na istoj. A ovo za jezgre da izazivaju lagg, u teoriji nebi smjelo, a u praksi je neprimjetno jer to nije parni stroj da ga treba nakrkat ugljenom i zagrijat. Kaj se tiče moddanih drivera, tu ima više i za jednu i drugu firmu. Najpoznatiji su DNA i XG, dok su manje poznati driveri od genetixa (po meni još i najbolji).
Zadnje izmijenjeno od: ThePornstar. 26.11.2010. u 13:32. |
#6258 |
Datum registracije: Jul 2009
Postovi: 600
kad će vise taj mappack?! jebem vas nestrpljive ![]()
dankojunasevic.tk |
#6259 |
Postovi: 1,668
onda laga i ima stuttering radi chata kak mansky kaze. mislim da chat imam memory leak nakon odredjene kolicine podataka i zato se to desava. ja sve to nemam ili meni to ne smeta tolko da ih primjecujem ![]() Sto se tice MP7 neki su ga vec i iskusali ![]() |
#6260 |
Lokacija: Éire
Postovi: 1,811
Danas se puca gumenim metcima, hit detekcija fina 0. Ubijaju me ko budalu sa m416, m16, mg3 u bliskoj borbi i na kraju runde vidim preciznost sa VSS-om 25%... Tenk naleti na 2 mine i PREŽIVI!!! |
#6262 | |
uglavnom, to su korisne stvari, jer cim ti spusti voltazu - spusta i potrosnju i zagrijavanje. uostalom nije li to smjer kojim idu sve vise komponente? graficke u idleu trose mizeriju sto je prije nekoliko godina bio SF... |
#6264 |
Lokacija: localhost
Postovi: 1,072
#6265 |
done. |
#6266 | |
Postovi: 4,403
Naravno ako se undervolta da je manja potrosnja, pogotovo na grafickim karticama sa ddr5 memorijom u kombinaciji sa nizim frekvencijama. Samo undervoltanje Gpu-a ne utjece bas na smanjenje potrosnje cijele kartice.
#6267 |
Postovi: 2,248
evo vam na http://g.bfbcs.com/67229/pc_tudajfor.png Ako imate ime od 2 dijela upišite _ izmedju. Da vidite koliki ste njubovi ![]() ja sam 22% noob ![]() Potrgao sam se od smijeha kada sam ovo vidio!
![]() RedGreenBlue |
#6268 |
Postovi: 668
bezveze,23.3% sam,a imam samo 200-injak killova sa gustavom i m60. http://g.bfbcs.com/67229/pc_the_constantine.png |
#6269 |
Postovi: 4,403
#6270 | |
zato sto si heli whore :P |
