Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nvidia GeForce GTX 560 / GTX 560 Ti
Geforce GTX 460 was Nvidia's life saver, and all reports are indicating that it has been selling well. Even AMD admitted that to its analists. This is the main reason why Nvidia won’t release a new GTX 560 until early next year. This is the card that is supposed to replace the GTX 460. The new card is based on GF114 chip, which is an improved GF104 with better clocks and all eight clusters enabled. If you enable all eight clusters the number of shaders jumps from current 336 to 384. The math behind is very simple. “Each Streaming Multiprocessor(SM) in the GPU of GF104/106/108 architecture contains 48 SPs and 8 SFUs Special Function Unit” more here. Also the complete GF104 core contains 64 texture address units and 512 texture filtering units.The number of SFUs jumps from 56 to 64. You can also expect a significant increase in clock speed as well as memory and the “new” card will run at higher than 675MHz core and 1350MHz shaders. The launch of the card is a sales decision and it will come only if Radeon HD 6870 and 6850 see dramatic price cuts and put additional pressure on Nvidia. If all goes as planned you will see this card early next year. We expect some average 15 to 20 percent performance increase from GTX 560 compared to GTX 460. Of course GF104 had all these clusters inside but Nvidia has simply dissabled one as it didn't need so much performance back at the summer time. |
GF114 with 8 clusters enabled Geforce GTX 460 was Nvidia's life saver, and all reports are indicating that it has been selling well. Even AMD admitted that to its analists. This is the main reason why Nvidia won’t release a new GTX 560 until early next year. This is the card that is supposed to replace the GTX 460. The new card is based on GF114 chip, which is an improved GF104 with better clocks and all eight clusters enabled. If you enable all eight clusters the number of shaders jumps from current 336 to 384. The math behind is very simple. “Each Streaming Multiprocessor(SM) in the GPU of GF104/106/108 architecture contains 48 SPs and 8 SFUs Special Function Unit” more here. Also the complete GF104 core contains 64 texture address units and 512 texture filtering units.The number of SFUs jumps from 56 to 64. You can also expect a significant increase in clock speed as well as memory and the “new” card will run at higher than 675MHz core and 1350MHz shaders. The launch of the card is a sales decision and it will come only if Radeon HD 6870 and 6850 see dramatic price cuts and put additional pressure on Nvidia. If all goes as planned you will see this card early next year. We expect some average 15 to 20 percent performance increase from GTX 560 compared to GTX 460. Of course GF104 had all these clusters inside but Nvidia has simply dissabled one as it didn't need so much performance back at the summer time. |
#2 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Postovi: 33,996
Rano su se sjetili. Dok ona izađe, AMD će imati brdo kartica različite snage na tržištu već mjesecima.
Postovi: 6,214
![]() C L O W N I N G ![]() |
#5 | |
Super Moderators
Postovi: 17,485
Aha, opet navlače ko i sa GTS-icom pa je Citiraj:
![]() Pri čemu su nesretni kupci GTS-ica prolili nemalu količinu sline po netu ![]() Prodaja 460 ide fino, ovo je samo "mojne si pitku ATI za žićbo jer bu nagodinu bila mrak grafa a jeftinija? ![]()
Datum registracije: Dec 2009
Postovi: 97
kažu da 5xx serija od nvidije je razvila još bolje hlađenje od 4xx serije, a znam da 460 gtx u idlu radi na 28°C što bi moglo bi bit jako zanimljivo. Kažu da će imat i bolje performanse od 460 GTX. Pa neće valjda odmah stavit u prodaju i 560 gtx...treba prvo pobrat pare sa 460 gtx... ![]() http://www.bug.hr/vijesti/geforce-gt...ne/104930.aspx |
Postovi: 5,991
Temp u Idleu ima veze samo sa ambijentom i ne znaci puno. I kicpuca gtx480 se u idleu moze spustit na 30c pa nakon par sec skoci preko 90. Pise da nece odmah stavit u prodaju, nego pocetkom iduce godine, sto daje 460tki jos bar dva, tri mj. za prodaju. |
#8 | |
Postovi: 97
Postovi: 59
Nekako mi se cini da nam Nvidia malo kasni. Ati je vec izbacio skolo cijelu seriju 6xxx i peru Nvidiu i po performansama i po cijenama. Premda se Nvidia odlucila na pametan potez te ce zato cijena 460 i 470 past za oko 20% te ce onda cjenovno konkurirat HD 6870 - gtx 470 po meni s obzirom na tu informaciju treba jos malcice sacekat prije nego se kupi ikoja kartica od te dvije (460, 470) ![]() |
Postovi: 5,991
Nvidija igra dobro sa onim kaj ima. Kod nas gtx470 kosta isto ko i 6870 vec neko vrijeme. Zadnjih par dana je malo poskupila ali to je vjerojatno zbog pocetka bozicnog ugodaja. Sumnjam da budu pojeftinile jos 20%, mozda nesto malo jer su ovako pozicionirane sasvim ok. |
#11 | |
Datum registracije: Jan 2010
Postovi: 149
Vani su cijene HD 6870 osjetno manje od GTX 470, a to što je malo slabija nadoknađuje nižim temp. i razinom buke pa pretpostavljam da nekima to svejedno opravdava kupnju. |
#12 | |
Datum registracije: Nov 2010
Postovi: 1,942
Mislim da će GTX560 sasvim fino doći da popuni rupu između trenutnog višeg-srednjeg i visokog ranga. |
Postovi: 1,942
Vjerojatno će biti i jaći jer ako gledamo direktno nasljednike i predhodnike bili su tu 5770 i GTX460 koji je bio dost bolji. AMD može jedino smanjiti taj zaostatak tj. jedino da nVidia napravi manji skok u performansama što čisto sumljam. |
Datum registracije: Aug 2010
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
Nvidia jako dobro radi u zadnje vrijeme, cijene ok, performasne jako dobre, nisam ljubitelj ni jednih ni drugih, al malo više simpatiziram nvidiu. Jer sam prvu grafičku imao njihovu, drugu također, i sad mi je treća radeonka 5850, al planiram preć na nvidiu 560 kad izađe. Do tad ni nemam neku potrebu kupovat nove iz ati serije, pošto me trenutna služi jako dobro a to što su joj performanse 20 posto slabije od novije serije me ne jebe. Ionako sam si uveo pravilo, da grafičku mjenjam svake tri godine, procesor također. Smatram da ljudi previše para troše na "najnovije", umjesto da se malo strpe, ionako nije razlika u performansama u svijetlosnim godinama već u postocima. Al što se kaže, nek svatko radi kako misli da je za njega najbolje. Uglavnom drago mi je za nvidiu da se malo trgnula iz monotonije, jer što bude nvidia jača i amd će morat malo korigirat cijene iako nije neka velika razlika trenutno u cijenama. Al npr da nvidia osjetno oslabi, i ne bude imala šta ponudit više na tržištu amd bude digo cijene osjetno zato navijam za nvidiu da ne dozvoli amd-u da se uspava i da napuca visoke cijene. To je za sve nas gamere, jako jako dobro i poželjno! |
#16 | ||
Postovi: 7,568
S tim da im ovaj put ne treba 11 kartica, jer za 2011. imaju procesore koji dolaze s IGP-om i samim time nemaju potrebu za kojekakvim slabašnim karticama iz donjeg segmenta. Citiraj:
![]() Primjera radi, jedna bijedna HD 5550 na području multimedije nudi više nego GTX 480 i "nova" GTX 580, a tek je GTX 460 donijela kakav-takav napredak po tom pitanju. Zato jer ustraju na monolitnoj arhitekturi, pa iz generacije u generaciju vuku "korijene" iz one prethodne, a zahvaljujući nakrcanim i ogromnim čipovima ne mogu kvalitetno implementirati nove tehnologije. AMD s HD 5000 uvede i predstavi Eyefinity i UVD 2.2, da bi s prvim HD 6800 karticama (koje nisu ništ revolucionarno, već samo nadogradnja i poliranje postojeće Evergreen arhitekture) uveli novi UVD 3.0, poboljšali Eyefinity, CrossFire, teselaciju i mnoštvo drugih sitnica. Većina bude rekla da im to nije bitno i to je vredu, jer svaki gleda i kupuje ono kaj mu trenutačno najbolje odgovara, ali na kraju dana ostaje činenjica da nVidia zadnjih godina uporno gura dvije-tri već dobro uhodane tehnologije i kombinira ih s moćnim/ogromnim čipovima, pa ljudi imaju dojam da su dobili super novo rješenje i super novu karticu. Zato velim da se maknu iz te rutine i da s novim karticama ponude i stvarno nova tehnološka i još k tome poboljšana rješenja - svi bi još bolje prošli. Ovak iz godine u godinu nude brutalne kartice po isto takvim cijenama, a kasnije se ljudi čude zbog čega nVidiji trebaju dvije generacije kartica da napokon s GTX 400 serijom uvedu prijenos zvuka prek HDMI-a. Da ne pričam kak im za Surround još uvijek treba SLi sustav, mada su i GTX 470 i GTX 480, a bome i GTX 580 sami po sebi dosta za igranje na tri monitora. To se vuče još od GTX 200 kartica, a sad kad već nude treću generaciju, oni još uvijek nisu tim moćnim čipovima harvderski osposobili prikaz na više monitora, nego se okreću k driverima i SLi sustavu. Zadnje izmijenjeno od: McG. 17.11.2010. u 18:06. |
#17 |
Postovi: 517
Okej budimo realni, nimalo ni amd/ati ne zaostaje po brutalnosti i jednog i drugog. Pogledajte samo, da dobijemo perspektivu, top end kartice prije nešto godina. ![]() Zauzimale su duplo manje mjesta, i ko zna koliko manje trošile. Čak i ova svojedobno zbog "ogromnog grijanja buke i potrošnje" popljuvana gf5800ultra. Svi idu u širinu, malo je tu optimizacija unutar istih gabarita. Istina je i da su procesori postali gladniji, ali mislim da s obzirom koliko jezgri su dobili, dakle do 6 punokrvnih procesora u jednom kućištu, trebali bi, prema receptu grafičkih kartuša, sada zauzimati pola kućišta i hladiti se watertowerom. No jedno treba raščistiti: unatoč svemu, grafe su povoljne. Dok se međusobno gložu proizvođači, novi modeli u istoj klasi iz generacije u generaciju održavaju istu cijenu. Evo primjera dalekog pretka (iz gornjeg primjera, generacija fx5700) buduće gtx560. |
#18 |
Postovi: 7,568
Ne velim da AMD-ATi ne radi brutalne kartice po brutalnoj cijeni - HD 5970 je najbolji primjer toga, ali je fora u tome da AMD ne cilja isključivo na takve modele da im prodaju cijelu seriju kartica. Ono na kaj sam ja skrenul pažnju, je to da AMD-ATi (pa čak i Intel sa svojim novim Sandy i Ivy Bridge IGP-om) sa svakom novom generacijom ponudi i određene ili kompletno nove ili bar poboljšanje tehnologije iz prijašnje genaracije. nVidia pak prvo cilja na čistu sirovu snagu, a tek onda sa svakom drugom-trećom generacijom ponudi i koje novo tehnološko rješenje. Primjera radi, nVidia bude izdala GTX 570 koji ne bude ništ drugo nego GTX 580 s 480SP-a i ponudili budu GTX 560 koji ne bude ništ više nego prvotno zamišljen GTX 460. I to je to. Nema napredka po pitanju VPU-a, nema audio bitstreaminga putem HDMI-a, nema micanja ograničenja na SLi sustave dok se priča o višemonitorskim namjenama, nema uvođenja kojekakvih sitnica (npr. više DP i HDMI konektora) koje bi ljudima stvarno i dale dojam da kupuju novu karticu. I dalje budu se reklamirali PhysX, CUDA, SLi i Surround koji su skoro pa isti zadnjih nekolko generacija i čisto na softverskoj bazi se poboljšavaju i to ovisno o verziji drivera. Kome se da nek prošvrlja forumom u potrazi za temama u kojima ljudi pizde, jer moraju spajati S/PDIF kabel sa zvučnom i grafičkom iz GTX 200 serije, jer se nVidia nije udostojila složiti zvuk prek HDMI-a. Kad se pogleda, to je sitnica i glupost od implementacije, ali opet znači nekog vraga i ljudima daje određenu komociju na koju imaju potpuno pravo kad iskeširaju nekolko stotina ili tisuća kuna za modernu grafičku karticu. Na kraju se sve svodi na to da nVidia već dulje vrijeme ne predstavlja ništ novo, bar kad su u pitanju nove tehnologije. Za GTX 580 su iz orginalnog GF100 "jednostavno" maknuli 200 milijuna (očito) nepotrebnih tranzistora, ne bi li dobili manju potrošnju i zagrijavanje kojim su svi oduševljeni, te su u isto vrijeme ljudima napokon dali ono kaj su trebali dobiti krajem 2009. Da nema konkurencije i to malo novih tehnologija koje implementiraju u svoje čipove, nVidia ne bi prstom mrdnula, već bi svake godine predstavili novi čip i nula novih tehnologija. Čisto kao primjer; AMD-ATi ih je sa svojim Eyefinity rješenjem natjeral da, ako ništ drugo bar pokradu tu ideju, pa ju (nažalost zbrda-zdola) implementiraju u svoju GTX 400 (pa nadalje) seriju. Imaju moćne kartice koje su moćne isključivo na polju sirove snage samog GPU-a, a sve ostalo je nVidiji manje bitno. Dok s druge strane konkurencija iz generacije u generaciju nudi nekaj novo. Zadnje izmijenjeno od: McG. 17.11.2010. u 21:19. |
#19 | |
Postovi: 5,991
Avg 470 je 250$ (oko 340$ kod nas) a avg. 6870 (isto 340$) je 260$ u USA. 470 je kod nas poskupila 10tak $ u odnosu na pocetak ovog mj. a 6870 je poskupila nesto manje ali je. Mislim da je to priprema terena prije bozicnih ponuda. Zadnje izmijenjeno od: MAGARAC. 17.11.2010. u 22:07. |
#20 |
Postovi: 149
Zapravo ovisi od dućana do dućana. Gledao sam u Austriji, u jednom je razlika čak preko 30€, ali u prosjeku je oko 10-15€ što i nije puno. |
#21 |
Postovi: 260
McG, slažem se Nvidia griješi u nekim stvarima, al kažem nisam fan ni amd radeon ni nvidia, al nvidia mi nekako malo bliža jel. A evo malo kako ja gledam na to, cijena mora bit ok(ne smije bit u nebesima), i da su dobre performanse(znači koliko sam platio, da sam toliko i dobio), to su mi glavni kriteriji kako se odlučujem za neku grafičku. Normalno uvijek je bilo i bit će propusta, pa nije ni amd radeon bez greški, al normalno to je po meni razumljivo dok god nema nekih velikih problema s temperaturama i kvarovima ne žalim se. I još ponavljam, amd radeon trenutno isprijed nvidie i još imaju više love zato navijam za nvidiu da ne propadne jer ako se izgubi konkurencija cijene amd radeon će bit veće sigurno. Isto ko i intel amd, da nema amd-a intel bi još osjetno digo cijene normalno amd mu ne da jer bi izgubio dio tržišta ako bi nabio cijene kao da su sami na tržištu. Zato mi je drago da postoji ta konkurencija, i kud sreće da se pojavi još takvih firmi koje će postat konkurencija navedenim, a uz put imat i kvalitetu i povoljne cijene. Al šta je tu je, samo nek nvidia drži korak za amd-om koliko može i nek cijene budu kakve su sad neću se bunit. |
#22 |
Postovi: 1,075
Ostavi se takvih priča o propadanju nvidije. Nvidija i ati su se godinama smjenjivali u ovakvim situacijama. Vezano uz ovu gore priču, uvijek bih prije uzeo 6870 zbog potrošnje i zagrijavanja. A i okreće mi se želudac kad vidim kako nvidija siluje ati u pogledu implementacija i optimizacija igri za svoje kartice (neke 'the way it's meant to be played' igre; optimizacija igre da bottlenecka opoziciju npr. u zadnje vrijeme aktualno je forsiranje visokog faktora teselacije). Polako se kreće prema duopolu kod kojega će svaka firma imati svoje igre koje na protivnikovom hardveru neće raditi. edit: Većinu mojih postova se ne smije shvatiti doslovno jer su karikirani. Čest je slučaj već sada da neka igra daje 100 fps na jednoj kartici i 75 fps na drugoj kartici (i jedno i drugo je daleko od neigrivoga, ali marketing radi svoje), a u većini ostalih igara su kartice unutar 5%. S forsiranjem nekih tehnologija je realno moguće da će se to dogoditi. Pogledaj npr. physx. Zadnje izmijenjeno od: generic. 18.11.2010. u 00:34. |
#23 | |
Postovi: 517
Da se vratim gtx560tki: ima li tko infoa, oće li ova kartuša dimenzijama pratit sadašnje gtx460tke? Nadam se da neće biti kao gtx260-praktički istih gabarita kao i gtx285 :/ |
#24 |
Postovi: 7,568
Nema razloga da referentna GTX 560 bude dimenzijama veća, tj. drukčija od postojeće i trenutno aktualne GTX 460 kartice. Pogotovo, ako bude GTX 560 punkorvni GF104 čip, a sve ostalo isto. Za atpične dimenzije su najčešće odgovorni nereferentni modeli, dizajnirani od strane kojekakvih partnera. ![]() |
#25 | |
Postovi: 6,214
NVIDIA Readies GeForce GTX 560 to Counter Radeon HD 6950
![]() http://www.techpowerup.com/136907/NV...n-HD-6950.html Kao što je i očekivano, nakon izbacivanja HD6950 NVIDIA sprema odgovor za početak sljedeće godine.
#26 |
Postovi: 517
... no nevidim nikakvih događaja po ovoj temi, a "početak slijedeće godine" je u toku? Ima tko kakav svježiji linkos? Ili je ipak konkurencija preslaba, a prodaja gtx460 predobra da se intervenira sa novim izdanjem? Edit; vidim na wiki da je procjena izlaska 20.1 ? Zadnje izmijenjeno od: Overhaul. 04.01.2011. u 17:55. |
#28 | |
Postovi: 6,214
GeForce GTX 560 called GTX 560 Ti and releases Jan 25th
![]() C L O W N I N G ![]() Zadnje izmijenjeno od: Doink the Clown. 12.01.2011. u 22:13. Razlog: nadopuna |
#29 | |
Postovi: 6,214
Gigabyte GeForce GTX 560 Ti Graphics Card Pictured
![]() ![]() http://www.techpowerup.com/138621/Gi...-Pictured.html
#30 |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Titanium is back? ![]() ![]()
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
