#4171 |
Datum registracije: Mar 2009
Postovi: 26
pozdrav! gledam malo sony 40nx700.. snizen je sa 9500 na 7000.. nisam naso na neke vece reviewe na netu, na cnetu nema, pa jel mi zna neko od vas rec nest vise o tom tvu, kaj ne pise u karakteristikama? jel vrijedi tih novaca? evo link ko nezna o cem se radi.. hvala!http://www.sancta-domenica.hr/detalj...00hz_sony.aspx |
#4172 |
Lokacija: Našice
Postovi: 13
DivX na 42PJ350 RADI!!!!
Uspio sam, naravno ništa bez Francuza : http://www.lg-hack.info/cgi-bin/sn_f...pg=1&sc=20&x=0 DivX na 42PJ350 radi!!! Kao i na svim modelima sa Saturn6 procesorom! ![]() |
#4173 |
Datum registracije: Jan 2002
Lokacija: ?
Postovi: 2,274
@ oko1976 To nije nikakva novost... |
#4174 |
Lokacija: Našice
Postovi: 13
Pa ja nisam primjetio da je to nešto staro, pogotovo za PK PJ seriju plazmi s firwarom 3.14 i novijim, nije dovoljno imati univerzalni daljinski i promjeniti jednu postavku! Da vijest je stara 10-ak dana ![]() OFFSET CALCULATION FOR LGMOD patch.sh FOR RELEASE firmware 3.19 INTRO: This is the procedure that I have followed to find my offset to the word that needs to be changed in RELEASE for USB playback. I followed this based in the brilliant work of Arno and Jenya. I have no access to a good decompiler nor to a cramfs kernel module that supports XIPS, so I just have checkout the code string pointed by the Arno 3.14 firmware fix. What this all means is that this method is quick and dirty but it worked for me. Arno, if you think that this method is somehow risky I will delete the post. Please comment. 1. Buckup your firmware from lgmod web interface of just your lgapp partition from the serial console. I will explain the serial console procedure since we will need serial connection later on. 1.1.- Get a serial cable and connect to your TV set. 1.2.- Start your TV set and wait until normal TV channel is playing. 1.3.- Start your computer and connect at 9600 , no parity, no flow control an 8 bits data and 1 stop bit (9600,8,N,1) with your favorit communication program (minicom is my case). 1.4.- Enter debug mode typing "debug" + enter key. Then again "d" + enter key and finally "sh" + enter key to get to the command console. 1.5.- Insert a FAT formated drive pen in your TV set and wait until TV sees it. 1.6.- Backup your lgapp partition: "cat /dev/mtd8 > /mnt/usb1/Drive1/8_lgapp" 1.7.- Umount the usb drive: "umount /dev/sda1" 1.8.- Now you can remove the usb drive. 2. Check out your offset to the lgapp partition: You should still be connected via serial cable and logged in the shell. If not follow steps 1.1 to 1.4 2.1.- Check out the offset until your lgapp partition: Type in "cat /proc/xipfs" this will output a number in hexadecimal base in my case "0x7100000", take note of the number that YOU ARE GETTING. 3. Calculating the offset to the divx capability test function result byte: (You will need a linux box) 3.1.- Copy the lgapp partition file to your working directory in your linux box. 3.2.- Uncompress the lgapp partition: 3.2.1.- For this you need the lzopack tool, you can find it at http://lgmod.free.fr/tools/lgapp 3.2.2.- Unpack with: "#./lzopack -d 08_lgapp 08_lgapp_cramfs" 3.3.- Edit with an hex editor the resulting 08_lgapp_cramfs for example with hexedit: #hexedit 08_lgapp_cramfs 3.3.1.- You will see a view similar to this: 00000000 45 3D CD 28 00 10 EA 00 03 00 00 00 00 00 00 00 43 6F 6D 70 72 65 73 73 E=.(............Compress 00000018 65 64 20 52 4F 4D 46 53 93 FA D4 D3 00 00 00 00 A6 02 00 00 04 00 00 00 ed ROMFS................ 00000030 43 6F 6D 70 72 65 73 73 65 64 00 00 00 00 00 00 ED 41 49 04 48 00 00 64 Compressed.......AI.H..d 00000048 C0 04 00 00 ED 83 49 04 A0 31 D3 64 42 09 00 00 52 45 4C 45 41 53 45 00 ......I..1.dB...RELEASE. 00000060 A4 81 49 04 50 E3 25 64 03 00 35 0D 52 45 4C 45 41 53 45 2E 73 79 6D 00 ..I.P.%d..5.RELEASE.sym. 00000078 A4 81 49 04 38 68 04 64 04 EA 83 0E 75 2D 62 6F 6F 74 2D 73 70 69 2E 62 ..I.8h.d....u-boot-spi.b 3.3.2.- Now we have to search for the string "050040141C80828F2000BF8F9C5242900800E003". I use such a long string because I want to get sure that this is not another statistical match in the RELEASE code. To search this string we should press Ctrl+s and we will see hexedit prompting us for the string like this: Hexa string to search: 3.3.3.- Type in the string (or better copy&paste :-)). And press enter. In my case hexedit finds that the string is beginning at 0x36D4, you will see something like this at the last line at the console: --- 08_lgapp_cramfs --0x36D4/0xEA1000 3.3.4.- Add number from step 2.1 "0x7100000" (in my firmware) and 3.3.3 "0x36D4" (also my firmware). The result in my case is "0x71036D4". Remember to do it with an hex calculator since you maybe are not us lucky as I am with the lgapp partition offset. 4.- Add a line to patch.sh in lgmod1.54: In my case "devmem 0x71036D4 32 0x00000000" in yours the result of your calculation. |
#4175 |
Lokacija: ?
Postovi: 2,274
PJ350 se uvijek mogao otključati ulaskom u servisni meni isto kao LCD LH modeli. |
#4176 | |
Lokacija: Našice
Postovi: 13
![]() Pogledaj zadnji post na ovom linku, svaka čast Arno !!! http://www.lg-hack.info/cgi-bin/sn_f...=60&pg=1&sc=20 Zadnje izmijenjeno od: oko1976. 01.11.2010. u 20:20. |
#4177 | |
Postovi: 1,193
Super LCD....neš takvog i ja namjeravam kupit |
#4178 |
Datum registracije: Oct 2010
Postovi: 2
Pozdrav, kupio sam Samsung LCD-LE32C530 i imam problem s gledanjem filmova preko USB-a (.avi, .mkv). Problem je u titlovima koji su premali. Na daljinskom ima opcija povecavanja i smanjivanja titlova, ali to ne pomaze jer su titlovi svejedno premali. |
#4179 | |
Lokacija: ?
Postovi: 2,274
Zašto tako grubo? |
#4181 | |
Lokacija: karlovac
Postovi: 13
ja sam isto vidio da su snizili ovaj model.. i takodjer me zanima ako netko ima kakav komentar.. da li je to ok kupovina? u biti, ja sam vec odlučio kupiti panasonicovu plazmu 42s20e ali dok sam cekao da je jos malo snize, vidjeh ovo. cini mi se tv ok na prvu, ali nisam neki expert i ne mogu bas procijenit da li se isplati to kupit. odnosno, da li se isplati dat 2000 kn vise za taj tv nego 5000kn za s20???? a opet u tom cjenonvnom rangu (7000+kn) dolazi i p42g20e... totalno sam sad zbunjen. kaj bi vi na mom mjestu? (ne mislim igrat nikakve igrice, samo filmovi, internet i tak to) |
#4182 | |
El Mattador
Lokacija: <->
Postovi: 1,925
#4183 |
Lokacija: karlovac
Postovi: 13
aj dobro. hvala na misljenju. onda cu pricekat jos malo da vidim oce snizit taj g20 bar još malo jer je to totalno van mojih financijskih mogucnosti.. s obzirom da sam i za s20 htio netgnut malo vise para nego sto sam u pocetku htio dat za tv, a eto me sad vec na 7 i pol.... ![]() |
#4184 |
Lazy person
Datum registracije: Jul 2009
Lokacija: U blizini zg
Postovi: 91
Kupio bih novi tv za dnevnu sobu. Savršena veličina bi bila 37" Najvisa cijena do koje bih isao je 5000 kuna. Gledao sam malo po netu i vidio ovaj TV Philips 37 PFL 5405H. Zanima me Vase misljenje o njemu te da li ima bolji tv za te novce.. Hvala Vam na pomoci |
#4185 | |
Lokacija: u mraku
Postovi: 850
ima, panasonic plasma s20 recimo... odi na hd televizija portal i čitaj recenzije..... |
#4187 | |
► Play ▌▌ Pause ■ Stop
Datum registracije: Jan 2010
Postovi: 1,179
Tu sam ga ja uzeo i super je.A što se tiče savršenosti za prostoriju, neznam kolka ti je veličina sobe? Moja je skoro pa 20 kvadrata i trebao sam uzet 50". ![]() Zadnje izmijenjeno od: DiRT. 01.11.2010. u 16:46. |
#4188 |
Lokacija: vž
Postovi: 77
pozdrav... trebam savjet, pročitao sam zadnjih dvadesetak stranica ove teme ali sam sad još u većim dvojbama trebao bi hitno preporuku za TV do 3500 kn max, po mogućnosti i niže.... TV ide u stan koji će se iznajmljivati pa ne mogu reći za što će ga budući najmoprimci koristiti, tako da tražim neki best buy za tu lovu... Tv bi se gledao sa nekih 2,5 m udaljenosti, da ima DVB-T i DVB-C mpeg4, mislim da bi 32" bilo taman, eventualno 37", svejedno dal plazma ili LCD.... uz preporuku modela dobrodošli su i linkovi gdje se može kupiti u Zagrebu... puno hvala unaprijed edit: nakon malo surfanja po nabava.net, po cijeni su mi prihvatljivi ovi modeli: LG 32LD350 / 32LD420 / 32LD450 / 32LD465 Sony KDL-32BX300 / KDL-32BX400 / KDL-32EX302 / KDL-32EX402 Samsung LE32C350 / LE32C450 Panasonic L32C linija pa ako netko preporuča neki od navedenih... Zadnje izmijenjeno od: veva. 02.11.2010. u 19:59. |
#4189 | |
Lokacija: Našice
Postovi: 13
#4190 |
Postovi: 347
TV sa mpeg4 do 3000kn
Tražim TV do 3000kn za starce. Dakle ništa sa nekim uber naprednim funkcijama, netreba gro utora i te spike već vulgaris TV sa mpeg4 tunerom i da je min 82cm. na TV-u bi se 99,9% vremena vrtio TV signal tak da je recimo najbitnije da TV ima dobru obradu slike i upscaling... Ovo sam izdvodjio u tom cjenovnom rangu: Toshiba 32AV733 2579kn Samsung LE32C350D1 2799kn Grunding 32-6940T 2739kn Panasonic TX-L32C2E 2749kn LG 32LD320 2650kn Sony 32BX300AEP 2766kn Sharp LC32DH510EV 2999kn Toshiba 32LV733G 2999kn koje bi bile vaše preporuke i zašto? Zadnje izmijenjeno od: gesaugen. 05.11.2010. u 15:02. |
#4191 |
Lazy person
Postovi: 91
Covjek mi moze jeftino nabaviti lcd Medion life s16000, pa me zanima sto mislite o njemu jer ja iskreno nikad cuo za firmu. Mislim da je firma iz Njemacke a cak i to nisam siguran. Evo malo o tv http://www.idealo.de/preisvergleich/...08-medion.html |
#4192 | |
Datum registracije: Nov 2010
Lokacija: v srcu Prigorja
Postovi: 11
#4193 |
Lokacija: vukovar
Postovi: 57
definitivno najbolji izbor u tom rangu cijena i dijagonale... |
#4194 |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Pozdrav ljudi! Rodbina mi je u procesu kupovine novog TV-a. Pošto nisam u ovim vodama došao sam po savjet. Jasno mi je da su plazme iznad LCD-a, ali ovde imam nabacano par modela (i LCD i plazma) pa hoću da vidim šta mislite o njima.Situacija: Budžet: 3700 kn Šta će se gledati: trenutno kablovska (analogna), kasnije digitalni program, filmovi u svim mogućim formatima Udaljenost od TV-a: 3-4m Ono što mi je dostupno su sledeći modeli: LG 42PJ350 3622 kn LG LF32LH3000 3330 kn PHILIPS 32PFL3605H/12 3034 kn PHILIPS 32PFL3403 2627 kn PHILIPS 32PFL5404 3700 kn PANASONIC TX-L32C10F 2590 kn PANASONIC TX-L32U2E 3548 kn PANASONIC TX-P37C2E 3700 kn PANASONIC 32C20F 2960 kn BEKO ACTIVE PRO 32-911B 2960 kn BEKO ACTIVE PRO 32-911B DVB-T 2786 kn BEKO ACTIVE PRO 32-910B 2652 kn BEKO W32LX-LY1B 2590 kn SONY KDL-32EX3021EP 2941 kn TELEFUNKEN TB32D857 2582 kn TELEFUNKEN TB37HD857L 3563 kn Eto, to je to što mi je trenutno dostupno. Trebam neku preporuku šta uzeti od navedenog za gore pomenute potrebe.
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#4195 |
Postovi: 11
mislim da im bude 32" LCD televizor premali s obzirom na udaljenost od TV-a... bar je meni tak. |
#4196 |
Postovi: 352
#4197 |
Lokacija: Duga Resa
Postovi: 514
@Milentije - preporuka Plazma Panasonic TX-P42X20E - 3714kn http://protis.hr/products/details/pl...0274?service=1 |
#4198 |
Adrenaline junkie
Postovi: 3,593
Sve je to OK, ali ja mogu uzeti samo nesto od ovih modela sto sam stavio na spisak. Mada mislim da bih nekako mogao žicati nekog uvoznika da vidim može li napaviti nešto, jedino nisam siguran da li taj dila Philips ili Panasonic. Hvala na preporukama, ali da li bi ste još mogli izabrati neki sa ovog spiska.
#4199 | |
Postovi: 352
ako je sa spiska onda možda 37c2e |
#4200 |
Postovi: 11
Nije ni plazma LG 42PJ350 loš izbor, pogotovo ne za cca 3500kn. |
