Datum registracije: Dec 2009
Lokacija: Graz
Postovi: 539
Svaki puta pri paljenju PC- Blue screen izbacuje
Znaci drustvo,imam problem s tim prokletim blue screenom,cijeli komp sam si novi sagradio,imate pod moj pc koji,koristim windows 7 64bit ultimate,ovi su frisko instalirani,jer sam mislio da je do starog problem ali nije,i na starom i na friskim win izbacuje blue screen,nakon sto mi se napokon digne sistem dobijem ovaj log Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1050 Additional information about the problem: BCCode: 1000007e BCP1: FFFFFFFFC0000005 BCP2: FFFFF8800449B9B2 BCP3: FFFFF88003B70938 BCP4: FFFFF88003B701A0 OS Version: 6_1_7600 Service Pack: 0_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\100810-23197-01.dmp C:\Users\ePlati\AppData\Local\Temp\WER-29952-0.sysdata.xml Read our privacy statement online: http://go.microsoft.com/fwlink/?link...8&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
7800X3D @ Scythe Fuma 2 ASRock B650I Lightning WiFi 32 GB Corsair Vengeance DDR5-6000 RTX 4070 ti Gamerock Corsair SF750 Cooler Master NR200P |
Postovi: 33,995
Deinstaliraj taj ePlati program (vjerojatno nekakav netbanking) pa vidi šta će se dogoditi.
Lokacija: Graz
Postovi: 539
doink,event viewer,kako se to otvori i pogleda?coconut,nemam nikakav netbanking instaliran
Postovi: 12,425
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
![]() C L O W N I N G ![]() |
Postovi: 12,613
Ajd digni ovdje ovaj file: C:\Windows\Minidump\100810-23197-01.dmp
Lokacija: Graz
Postovi: 539
Postovi: 12,613
The file link that you requested is not valid. Please contact link publisher or try to make a search. Daj ga na http://www.sendspace.com Nece ni tu dole.
Prodajem kucu na klizistu.. Nije puno presla..... Member Of PC Ekspert 100+kg Demolition Squad NAJNOVIJE = Povoljno RAM..http://www.downloadmoreram.com/... tor i AMD kupili.... NOVO! Prodajem visokokvalitetni tropleteni hardverski konac za fixiranje coolera Zadnje izmijenjeno od: nino. 08.10.2010. u 13:16. |
Lokacija: Graz
Postovi: 539
eto http://www.sendspace.com/file/crhrua Jos 1 stvar,kada gasim komp normalno,znaci start shut down,monitor se ugasi,ali svi ventovi nastave raditi...a kada stisnem jednom na kucistu power button,znaci jednom momentlano ne dugo,onda ga normalno ugasi...
7800X3D @ Scythe Fuma 2 ASRock B650I Lightning WiFi 32 GB Corsair Vengeance DDR5-6000 RTX 4070 ti Gamerock Corsair SF750 Cooler Master NR200P Zadnje izmijenjeno od: thesaint255. 08.10.2010. u 13:28. |
Postovi: 12,613
Za ovo gore probaj za sad mreznu stavit na disable u biosu.
Lokacija: Graz
Postovi: 539
Ok,posto nezelim otvarati novu temu posto je isti problem,znaci identicno,ujutro kada palim komp ili nakon par sati nekoristenja uvijek mi pici blue screen na win startupu,evo vam dmp fileovi,znaci,konfiguracija ja ista iz potpisa,za test sam probao staviti svjeze windowse na SSD disk koji sam dobio nedavno(ssd disk nije problem,i prije mi se desavalo isto),stavio zadnje drivere za grafu itd itd,opet blue screen Ovo su svi danasnji fileovi dmp http://www.mediafire.com/?jd1atyud8eson6o http://www.mediafire.com/?647swpilyc5n44f http://www.mediafire.com/?ci26gbf2jt9nxzo
Postovi: 12,613
Dali ti u safe modu radi normalno?
Lokacija: Graz
Postovi: 539
Trebam ugasiti komp na par sati da se skroz ohladi i onda ga upaliti i automatski uci u safe mod pa cu javiti
#17 |
Lokacija: Graz
Postovi: 539
Probao safe mod,odmah bsod,probao sam svasta,isto bsod na startu,a nista onda,znaci pitanje,ako skinem i testiram na win xp,jel mogu na xp iskoristiti 6 gb rama na 64 bit verziji?
#18 |
Postovi: 12,613
Mozes.
#19 |
Lokacija: Graz
Postovi: 539
Uglavnom momci,stavio sam xp,opet isti drek,znaci ali ovdje je ipak malo bolje,boota iz 2. a na sedmici iz 4.-5. ,e sada,do cega je na kraju?Software nije,hardware,testirao sam memoriju i cista je,takoder hard testiran,dajte mi neki program ili sta god vec s kojim mogu sve testirati,hvala!
#20 |
Postovi: 1,692
Nekidan sam imao neugodno iskustvo kod prijatelja, naime, minjao je plocu, i slicne stvari su me desavale. Ja izludio, testirao sve zivo, sve se cinilo OK, i onda nakon nekog vremena skuzim da nije stavio odbojnike izmedju maticne i kucista, naravno, bilo je sve u kratkom spoju. Kod drugog prijatelja prije koju godinu takodjer slicni problemi, i skuzili na kraju da je kuciste lose kvalitete tj. bendalo je plocu. Imaj na umu da teski cooleri takodjer mogu bendat plocu i radit svakakve pi*darije pogotovo s memorijom. probaj izvadit sve na stol, pa spojit |
#21 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,072
Možda napajanje ne daje dovoljno struje prilikom bootanja pa neka komponenta posusta. Znam da je long shot mogućnost ali i dalje vjerojatna.
