Staro 08.10.2010., 11:29   #1
thesaint255
thesaint255's Avatar
Datum registracije: Dec 2009
Lokacija: Graz
Postovi: 538
Svaki puta pri paljenju PC- Blue screen izbacuje
Znaci drustvo,imam problem s tim prokletim blue screenom,cijeli komp sam si novi sagradio,imate pod moj pc koji,koristim windows 7 64bit ultimate,ovi su frisko instalirani,jer sam mislio da je do starog problem ali nije,i na starom i na friskim win izbacuje blue screen,nakon sto mi se napokon digne sistem dobijem ovaj log
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1050
Additional information about the problem:
BCCode: 1000007e
BCP1: FFFFFFFFC0000005
BCP2: FFFFF8800449B9B2
BCP3: FFFFF88003B70938
BCP4: FFFFF88003B701A0
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\100810-23197-01.dmp
C:\Users\ePlati\AppData\Local\Temp\WER-29952-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
7800X3D @ Scythe Fuma 2
ASRock B650I Lightning WiFi
32 GB Corsair Vengeance DDR5-6000
RTX 4070 ti Gamerock
Corsair SF750
Cooler Master NR200P
thesaint255 je offline   Reply With Quote
Staro 08.10.2010., 11:39   #2
Postovi: 33,917
Deinstaliraj taj ePlati program (vjerojatno nekakav netbanking) pa vidi šta će se dogoditi.
Staro 08.10.2010., 11:40   #3
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Jesi pogledao u Event Viewer koji su errori u pitanju?
C L O W N I N G A R O U N D
Staro 08.10.2010., 11:42   #4
thesaint255
Lokacija: Graz
Postovi: 538
doink,event viewer,kako se to otvori i pogleda?coconut,nemam nikakav netbanking instaliran
Corsair SF750
Staro 08.10.2010., 11:43   #5
Wolverine
Wolverine's Avatar
Postovi: 12,425
Pa gledaš li što je napisao?
Problem signature:
Locale ID: 1050
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 08.10.2010., 11:50   #6
Doink the Clown
Postovi: 6,214
Yup, sljedeći korak bi bio posjeta minidump folderu i debugging tool.
Staro 08.10.2010., 12:23   #7
nino
nino's Avatar
Postovi: 12,599
Ajd digni ovdje ovaj file: C:\Windows\Minidump\100810-23197-01.dmp
Staro 08.10.2010., 13:06   #8
thesaint255
Lokacija: Graz
Postovi: 538
Corsair SF750
Staro 08.10.2010., 13:09   #9
nino
nino's Avatar
Postovi: 12,599
The file link that you requested is not valid. Please contact link publisher or try to make a search.
Daj ga na http://www.sendspace.com
Nece ni tu dole.
Zadnje izmijenjeno od: nino. 08.10.2010. u 13:16.
Staro 08.10.2010., 13:10   #10
thesaint255
Lokacija: Graz
Postovi: 538
eto
http://www.sendspace.com/file/crhrua
Jos 1 stvar,kada gasim komp normalno,znaci start shut down,monitor se ugasi,ali svi ventovi nastave raditi...a kada stisnem jednom na kucistu power button,znaci jednom momentlano ne dugo,onda ga normalno ugasi...
Corsair SF750
Zadnje izmijenjeno od: thesaint255. 08.10.2010. u 13:28.
Staro 08.10.2010., 14:30   #11
jucca
jucca's Avatar
Postovi: 1,687
Autor coconut Pregled postova
haha, pa to mu je username
C:\Users\ePlati
Staro 08.10.2010., 14:42   #12
nino
nino's Avatar
Postovi: 12,599
Za ovo gore probaj za sad mreznu stavit na disable u biosu.
Staro 02.12.2010., 11:15   #13
thesaint255
Lokacija: Graz
Postovi: 538
Ok,posto nezelim otvarati novu temu posto je isti problem,znaci identicno,ujutro kada palim komp ili nakon par sati nekoristenja uvijek mi pici blue screen na win startupu,evo vam dmp fileovi,znaci,konfiguracija ja ista iz potpisa,za test sam probao staviti svjeze windowse na SSD disk koji sam dobio nedavno(ssd disk nije problem,i prije mi se desavalo isto),stavio zadnje drivere za grafu itd itd,opet blue screen
Ovo su svi danasnji fileovi dmp
http://www.mediafire.com/?jd1atyud8eson6o
http://www.mediafire.com/?647swpilyc5n44f
http://www.mediafire.com/?ci26gbf2jt9nxzo
Corsair SF750
Staro 02.12.2010., 11:34   #14
nino
nino's Avatar
Postovi: 12,599
Dali ti u safe modu radi normalno?
Staro 02.12.2010., 11:56   #15
thesaint255
Lokacija: Graz
Postovi: 538
Trebam ugasiti komp na par sati da se skroz ohladi i onda ga upaliti i automatski uci u safe mod pa cu javiti
Corsair SF750
Staro 02.12.2010., 21:21   #16
Anonymous_01
Anonymous_01's Avatar
Postovi: 29
Hiren's boot pomaže :-) Imao problem s novim kompom, jednostavno memorija nije bila kompatibilna, nekako je to xp prožvakao, ali windows 7 ni pod razno.
Anonymous_01 je offline   Reply With Quote
Staro 03.12.2010., 07:18   #17
thesaint255
Lokacija: Graz
Postovi: 538
Probao safe mod,odmah bsod,probao sam svasta,isto bsod na startu,a nista onda,znaci pitanje,ako skinem i testiram na win xp,jel mogu na xp iskoristiti 6 gb rama na 64 bit verziji?
Corsair SF750
Staro 03.12.2010., 07:48   #18
nino
nino's Avatar
Postovi: 12,599
Mozes.
Staro 10.12.2010., 18:05   #19
thesaint255
Lokacija: Graz
Postovi: 538
Uglavnom momci,stavio sam xp,opet isti drek,znaci ali ovdje je ipak malo bolje,boota iz 2. a na sedmici iz 4.-5. ,e sada,do cega je na kraju?Software nije,hardware,testirao sam memoriju i cista je,takoder hard testiran,dajte mi neki program ili sta god vec s kojim mogu sve testirati,hvala!
Corsair SF750
Staro 10.12.2010., 20:56   #20
jucca
jucca's Avatar
Postovi: 1,687
Nekidan sam imao neugodno iskustvo kod prijatelja, naime, minjao je plocu, i slicne stvari su me desavale. Ja izludio, testirao sve zivo, sve se cinilo OK, i onda nakon nekog vremena skuzim da nije stavio odbojnike izmedju maticne i kucista, naravno, bilo je sve u kratkom spoju.
Kod drugog prijatelja prije koju godinu takodjer slicni problemi, i skuzili na kraju da je kuciste lose kvalitete tj. bendalo je plocu. Imaj na umu da teski cooleri takodjer mogu bendat plocu i radit svakakve pi*darije pogotovo s memorijom.
probaj izvadit sve na stol, pa spojit
Staro 10.12.2010., 21:50   #21
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,030
Možda napajanje ne daje dovoljno struje prilikom bootanja pa neka komponenta posusta.
Znam da je long shot mogućnost ali i dalje vjerojatna.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
