Staro 14.07.2010., 20:53   #691
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
haha ...da totalno...
DomagojX je offline   Reply With Quote
Staro 14.07.2010., 21:00   #692
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Jel to onaj 950 od Timmya?
blaa
Staro 15.07.2010., 00:54   #693
DomagojX
Postovi: 1,307
da, kao njegov...
soo far so good
Zadnje izmijenjeno od: Razer. 24.07.2010. u 17:37. Razlog: koristi edit
Staro 24.07.2010., 19:43   #694
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor DomagojX Pregled postova
da, kao njegov...
soo far so good
Max BCLK si mu izvukao?
C L O W N I N G A R O U N D
Staro 24.07.2010., 19:48   #695
DomagojX
Postovi: 1,307
a skroz zaboravih na to...budem danas/sutra i to probao pa javim...inače ostao sam iznenađen nisam se nadao da će tak ić...
evo konačno 5GHz
Zadnje izmijenjeno od: DomagojX. 25.07.2010. u 11:32.
Staro 29.07.2010., 21:48   #696
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
"While the i7-970 may only be slightly slower than the i7-980X EE out of the box, it’s a whole new game when it comes to overclocking. This is because while the i7-980X EE is an absolute beast, hitting 4.4GHz on air, we were only able to overclock the i7-970 from 3.2GHz to 4GHz.
While this isn’t a bad overclock, and did boost performance considerably, it’s a much worse overclock than the i7-980X EE. In fact, this result makes the i7-970 one of the worst Core i-series CPUs for overclocking that we've seen."
bi-tech
anandtech
Staro 14.08.2010., 16:31   #697
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
Evo moj brzinski setup za 24/7 , meni sasvim dosta ( i previše )
http://valid.canardpc.com/show_oc.php?id=1345957
Voltaze
Vcore : 1.3 V
CPU PLL : 1.8 V
QPI/VTT : 1.255 V
Vdimm : 1.6 V
Samo me zanima dali da ostavim C1 i eist ukljucenim da mi bezveze ne radi na 4.0 ako nije u pogonu ?
Zadnje izmijenjeno od: JuiceBox. 14.08.2010. u 16:38.
Staro 14.08.2010., 17:22   #698
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Ostavi ga. Kod mene ne smeta ni malo na tim klokovima.
smanji ga za 1 ili 2blck da vidiš kolko mu treba voltaže jer recimo kad mene je 3980 stabian na 1.209v a za 4.0 treba 1.224v. Nikakva razlika u taktovima a osjetna u voltaži.
Zadnje izmijenjeno od: MAGARAC. 14.08.2010. u 17:40.
Staro 14.08.2010., 17:25   #699
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
Aha, a i mislio sam sto bi se vrtio na 4 stalno ako nista ne radi... Ili si mislio da ugasim eist ? Jos nesto, dali da turbo ostavim upaljen ili ne ? Isto to vrijedi i za HT ( na 1.3 je i sa HT stabilan na 4.0) ?
Jos nesto, zasto mi pali turbo kad vrtim prime, jel nebi trebao turbo paliti samo kad vrti single core aplikacije ?
Edit : 1.28 bez HT @ 4.0 stabilan vise od sat vremena, vjerujem da ide i na manjoj voltazi.
Edit : 1.264 @ 4.0 bez HT stabilan 14 sati
Zadnje izmijenjeno od: JuiceBox. 15.08.2010. u 11:00.
Staro 15.08.2010., 12:57   #700
dejanbinladen
konjpjukter
Postovi: 934
eo jedan fini tutorijal jednsotavan i pregledan za oc i7 i5 i3 procesora
http://hwgurus.com/testovi/edukacija/426.html
dejanbinladen je offline   Reply With Quote
Staro 15.08.2010., 14:13   #701
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
@xulos
Imas demo na stranici koji dobro objasnjava TB...
Staro 15.08.2010., 14:58   #702
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
Fala, sad sam sve rijesio , stabilan je 14 sati na 1.264, al me sad pati klikanje ploce dok se pali , jebg nikad na zelenu granu s tim kompovima :/
Staro 25.08.2010., 22:02   #703
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
evo mene opet. Imam problem , proc mi prolazi prime95 na smallfft ( priority 9 ) i po 14 sati na 1.27 na 4.0( 200x20) ali blend nemoze ni 15 min. Memorija je kingmax 1333 na cl9 ( zbog kloka radi na 1600, uncore na 3200) , nemoze opustenije latencije i to na 1.62 V i blend pada.dizao sam vtt na 1.3 i opet mi se srusi nakon 20 min. neznam vise koji mu je k -.-
Edit : dobio sam ga stabilno
umjesto 20x200 stavio sam 190x21 , vcore 1.27, qpi/ddr :1.25V, cpu pll 1.8 V , rami na 1.6 V , 9 sati prime stabilan priority 9.
Zadnje izmijenjeno od: JuiceBox. 26.08.2010. u 09:53.
Staro 23.09.2010., 19:25   #704
Matija Š.
Lokacija: Podravina
Postovi: 118
Moj overclock
Matija Š. je offline   Reply With Quote
Staro 25.09.2010., 11:51   #705
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
Evo ovako, posto me je MAGARAC zaintrigirao, krenut cu s OCom ispocetka jer mi je sumnjivo da na 1.28 nece raditi iz HT na 4.0. E sad par pitanja , dali je pozeljno dizati IOH i ICH sa def 1.1 na 1.2 pri tim brzinama, dali Uncore mora biti tocno duplo veci od brzine memorije i na koliko drzati QPI( 4.8 , 7.2 itd..) ? I kad krecem s oc iz 0, dali sve drzim na auto a idem s vcore lagano gore ili imaju neke srednje vrijednosti od kojih se krece ?
Staro 25.09.2010., 11:57   #706
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
IOH i ICH nije potreba dirati sve dok si ispod 210MHz BCLKa. QPI na 4.8. Uncore na 2x Mem ili više. Ukoliko je manje onda bude sranja nekad. Postavi memoriju na ~1600MHz a uncore na 3600MHz i to bude ok. VTT na nekih 1.28-1.32. LLC uključi. Najbitnije ti je da se igraš sa VTT i vCore voltažom.
Staro 25.09.2010., 12:03   #707
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
Jel moguce da sam imao problema zato jer mi QPI na 7.2 ? Uncore mi je na tocno 2x, VTT na 1.25 , PLL na 1.8 , vcore1.264 ( overvolta u loadu na 1.280), bez hta ( 21x190), no s tim postavkama uz HT dobijam error u prajmu ( roundcheck) .Ali po sugestiji drugih i citanju malo po forumima, taj bi proc trebao ici i na manjim voltazama i to uz HT.Cilj mi je dobiti proc na sto manjoj mogucoj voltazi uz HT i bez ht-a , tako da sejvam 2 profila i palim po potrebi HT.
Staro 25.09.2010., 12:08   #708
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Moguće je.
Btw. čemu forsirat QPI? Vrati ga na najnižu vrijednost i budi miran. povećaj VTT kad već hoćeš HT. Nije sve u vCore-u.
Staro 25.09.2010., 12:12   #709
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
aha, u tom grmu leži zec, i tuca .Nisam znao da on ide na najnizu mogucu, thx for the tip.Pozabavit cu se s vtt i vcore cim dodjem u os.
Edit : 1.28 vcore, 1.2625 vtt, 1.64 ddr , 1.8 pll 190x21 stabilan u prajmu ( HT on ) Thx svima koji su imali zivaca saslusati me
Zadnje izmijenjeno od: JuiceBox. 27.09.2010. u 21:44.
Staro 29.09.2010., 18:19   #710
Inelim
Inelim's Avatar
Postovi: 78
Samo bih još nadodao (iako je o tome vjerojatno već bilo riječi) da je poželjno voltažu memorije držati na što je moguće manjoj vrijednosti (naravno, koliko to OC mogućnosti pojedine memorije dopuštaju na određenim taktovima), budući da je memorijski kontroler u samom procesoru, pa će se stoga onda i sam procesor manje zagrijavati.
Meni je osobno temperatura jezgri pala za cca 8 stupnjeva otkako sam spustio voltažu memorije s tvorničkih 1.65 V na 1.55 V (pri taktu memorije od 1750 MHz), što je znatno poboljšanje, jer su mi automatski pale i temperature ostalih komponenti u kućištu, zbog općenito manjeg zagrijavanja. A naravno, onda bi i OC procesora trebao biti bolji uz manje zagrijavanje.
Zadnje izmijenjeno od: Inelim. 29.09.2010. u 18:36.
Inelim je offline   Reply With Quote
Staro 01.10.2010., 22:01   #711
ehohr
ehohr's Avatar
Postovi: 348
Autor xulos Pregled postova
Voltaze
Vcore : 1.3 V
CPU PLL : 1.8 V
QPI/VTT : 1.255 V
Vdimm : 1.6 V
Ista maticna i isti proc uz iste postavke ne load ni na 3.6
ehohr je offline   Reply With Quote
Staro 01.10.2010., 22:39   #712
Inelim
Inelim's Avatar
Postovi: 78
@ ehohr
Ako si siguran da radiš sve kako treba, onda ćeš se, nažalost, morati pomiriti s činjenicom da isti procesor ne znači i isti primjerak, jer svaki je primjerak ''poseban'', a tebe je očito zadesio loš primjerak, bar kad je u pitanju OC.
S druge strane, ni iste ploče nisu identične po pitanju OC-a, jer sve ovisi kakav te primjerak zadesi.
Generalno, tako je s gotovo svim komponentama i zato nitko nema identične postavke, kao ni identične OC rezultate.
Staro 09.10.2010., 21:57   #713
DomagojX
Postovi: 1,307
evo da anus ne padne u zaborav, prije sam max na toj ploči mogao oko 223 bclk-a ako se ne varam sad ide još +2
Staro 09.10.2010., 21:59   #714
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Da mi je znat koliki si joj IOH napuco
Staro 14.10.2010., 11:35   #715
jurbAs
jurbAs's Avatar
Postovi: 2,583
Da li je moguce da nakon nekog vremena clock postane nestabilan?! Meni se dogada da evo 2 dan da mi se komp uslijed igre sam od sebe restarta temp nisu previsoke tako da bi to iskljucio kao jedan od razloga.
Staro 14.10.2010., 12:37   #716
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
Sumnjam da moze postati nestabilan ako nisu napucavane neke esktra voltaze.Probaj clr cmos i sve postavke ponovno rucno unesi i istestiraj prajmom ili lynxom.Moguce je i da te yebe ona oscilacija na naponu za rame 1.60-1.64.
Staro 14.10.2010., 17:02   #717
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,315
Autor jurbAs Pregled postova
...vrlo lako da je do procesora,imao sam par slucajeva (775 socket) gdje procesor postane netabilan nakon nekog vremena na odredjenom clocku i voltazi,nakon spustanja frekvencije (ili dizanje volataze) stvar rijesena...
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 15.10.2010., 10:23   #718
jurbAs
jurbAs's Avatar
Postovi: 2,583
Evo da probam objasnit problem koji ja imam. Kompjuter upalim ujutro i sad pitanje je hoce li doc do windowsa ili ne resetira se i krece sam iz pocetka post ekran ne javlja nikakvu gresku nista. Evo jucer sa istim tim klokom stavim ga u prime i nista radi bez beda ne javlja gresku. Cijelo popodne i navecer bez restarta je vrtio gotovo sve igre filmove serije ma ono najnormalnije. Evo sad ga upalim iz 5 pokusaja sam dosao do windowsa. Digao sam malo voltazu ali nije pomoglo mozda imam neki drugi problem a ne da je do clocka. Ali za svaki slucaj vratit cu na default pa da vidim jer istina jucer kad sam vratio radio je normalno ali nakon toga je i sa clockom radio normalno....
Staro 15.10.2010., 11:02   #719
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,548
Ja mislim da tebe malo ploca zajebaje... si probao stavit zadnji bios ?
Staro 15.10.2010., 11:07   #720
jurbAs
jurbAs's Avatar
Postovi: 2,583
je zadnji bios je gore ma da je ploca u pitanju onda bi me zajebavala non stop
EDIT skonto clock nestabilan kako stvari stoje i to nakon 2tjedna normalnog rada kompa loool. sutra krecem dalje trazit stabilan clock !!!
Zadnje izmijenjeno od: jurbAs. 16.10.2010. u 01:04.
