Staro 11.08.2010., 12:49   #31
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
EVGA releases SR-2 Classified PSU
There is no need to introduce you EVGA, a high-profile manufacturer of motherboards, graphics cards and consumer electronics dedicated to enthusiasts and overclockers. Today, EVGA extends their territory over power supply units by releasing a monster of wattage power, called Classified SR-2. I used the word ‘monster’ to describe this unit, because this PSU is capable of supplying no more or less than 1200W with active Power Factor Correction (also known as PFC) and six 12V rails rated at 38A. Also, as every respectable 80Plus Silver certified PSU, Classified SR-2 offers you 85% power efficiency and over.
So you are a gamer, right? As its appetite grows with what it feeds on, feel free to hook up to four video graphics cards onto your setup. Furthermore, you’ll notice that there are two knobs for tweaking the 12V rail and adjusting the fan speed respectively. Cool features, monster power and innovative design. What else can anyone expect from a power supply unit?
Last but not least the Classified SR-2 costs around EUR/$360 and it’s also backed by a five years warranty from EVGA.
Izvor: guru3d, techpowerup, sluzbene stranice
Staro 11.08.2010., 13:49   #32
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Antec Quattro 1200?
fran123456 je offline   Reply With Quote
Staro 11.08.2010., 13:58   #33
Razer
Razer's Avatar
Postovi: 11,642
Autor fran123456 Pregled postova
Antec Quattro 1200?
.... OC Edition (potenciometri).
Staro 11.08.2010., 18:17   #34
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Zamislite da sa tim cudom od kablova radite kejbl job
za tu lovu su mogli ubaciti i modularne kablove, tj. vise njih ...
Da ne spominjemo da je Corsairov AX 1200 pruza vecu efikasnost (80Gold), nizi ripple, potpunu modularnost, vise kablova, ultra stabilne napone i nizu cijenu
P.S
I ne vire mu kondenzatori po svim mogucim zicama
Staro 11.08.2010., 18:20   #35
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Autor dh41400 Pregled postova
Al nije za DFP ekipu
Staro 11.08.2010., 18:31   #36
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Ah da...
BTW sada sam tek uocio da je ta 80mm ADDA u Antecu ustvari 4,200 RPM model ... ajoj
Staro 11.08.2010., 21:50   #37
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
C L O W N I N G A R O U N D
Staro 11.08.2010., 23:31   #38
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Bas me zanima kaj im je ovo ... "Sextuple 12V Rails"
A i nisu tako seksi sa ovim kondenzatorima po kablovima koji vire na sve strane:
Nego, da ne spamamo bzvze ... nista od njihove cifre od 200$ ... Newegg :/
Sto se tice OEM-a, rijec je o kineskom Great Wall-u tocnije GW-EPS1000DA(90+).
Zadnje izmijenjeno od: dh41400. 11.08.2010. u 23:46.
Staro 13.08.2010., 22:28   #39
MAGARAC
MAGARAC's Avatar
Postovi: 5,995
Seasonic X-Series: X-400FL Silent Power Supply Review, HardOCP. Zvijerčica
"The overall build quality of the Seasonic X-400FL is simply excellent across the board.....The results for the normal load testing with the Seasonic X-400FL at 120v and 100v were outstanding. I mean simply outstanding.................The Seasonic X-400FL passed the DC Output Quality tests today. Ok, it didn't just pass the tests, it excelled in those tests. Ok, perhaps excelled is an understatement. Maybe it would be more accurate to say that it ran circles around the tests like a little child taunting a playmate........The Seasonic X-400FL is fanless, which, unsurprisingly, made this unit silent. I am sure it would make some noise if you dropped it on the floor though."
Zadnje izmijenjeno od: MAGARAC. 13.08.2010. u 22:35.
Staro 13.08.2010., 22:41   #40
Doink the Clown
Postovi: 6,214
Staro 20.08.2010., 20:34   #41
Doink the Clown
Postovi: 6,214
Staro 06.09.2010., 17:57   #42
Doink the Clown
Postovi: 6,214
Staro 15.09.2010., 13:17   #43
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Pomelo mi sig -.-
Staro 15.09.2010., 19:17   #44
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Corsair, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced the Corsair Gaming Series Power Supplies. These PSUs are an ideal price-performance solution for building or upgrading a gaming PC.
The Gaming Series PSUs feature a single +12V rail, providing up to 65A of reliable, continuous power for multi-core gaming PCs with single or multiple graphics cards. The ultra-quiet, dual ball-bearing fan automatically adjusts its speed according to temperature, so it will never intrude on your music and games. Tri-color LEDs illuminate the transparent fan blades with blue, red, or white at your command; they can be turned off at the press of a button. (The GS600 features only blue LEDs). The entire family is 80 PLUS certified to deliver 80% efficiency or higher at normal load conditions, generating a minimal amount of excess heat.
Izvor
Staro 21.09.2010., 10:32   #45
Drvoje
Drvoje's Avatar
Postovi: 4,037
Pomelo mi sig -.-
Staro 21.09.2010., 10:53   #46
Postovi: 34,074
Hebote, sad će svaka šuša proizvoditi svoja napajanja (samo čekam da se u to uključe AMD i nVidia). Doduše, u većini slučajeva će to biti samo ljepljenje drugih naljepnica. Srećom po nas, veća konkurencija u pravilu znači i manje cijene.
Staro 21.09.2010., 12:05   #47
trancer
trancer's Avatar
Datum registracije: Aug 2010
Postovi: 182
Ma to je isto ko ljepljenje naljepnica na referentne graf. kartice, naravno mislim da to može biti samo dobro ne samo zbog cijena već i samog tržišta napajanja jer veća konkurencija znači i bolji proizvod.
trancer je offline   Reply With Quote
Staro 23.09.2010., 17:13   #48
Doink the Clown
Postovi: 6,214
Zadnje izmijenjeno od: Doink the Clown. 23.09.2010. u 22:14.
Staro 24.09.2010., 23:54   #49
MausLuka
Postovi: 25
Dečki iz svijeta napajanja su shvatili da a NVIDIU treba puno juicea
MausLuka je offline   Reply With Quote
Staro 30.09.2010., 11:01   #50
Drvoje
Drvoje's Avatar
Postovi: 4,037
Corsair Builder CX430/500/600
Izvor:
http://hothardware.com/News/Corsair-...ream-Builders/
Sluzbeni info: http://www.corsair.com/products/cx430/default.aspx
Ova nova napajanja imaju manju garanciju, negdi pise 2 negdi 3 god
Pomelo mi sig -.-
Staro 30.09.2010., 12:16   #51
Doink the Clown
Postovi: 6,214
Staro 30.09.2010., 13:45   #52
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Autor Drvoje Pregled postova
Izvor:
Cini mi se da je ipak rijec o 2g garancije, no to nije ono najgore ...
Cini se da je Corsair odlucio stediti gdje stigne, pa je tako nova serija napajanja zasnovana na entry-level CWT platformi (DSA) uz dijelove nesto slabije kvalitete od npr CX400/VX450/VX550.
Promijenjena je i deklaracija snage, pa tako ukupna snaga nije vise deklarirana na 50°C, vec na 30°C.
Uz sve navedeno napajanja ne zadovoljavaju cak ni 80 Plus standard
Ovo je definitivno korak-dva unatrag za Corsair, a jedina svjetla tocka bi trebala biti cijena, no s obzirom na kvalitetu i to je upitna prednost ...
Staro 30.09.2010., 14:35   #53
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
"The Builder Series CX600 has a suggested retail price of $74.99 (US). The CX500 and CX430 have suggested retail prices of $64.99 (US) and $49.99 (US) respectively."
Znači CX430 će kod nas bit oko 350-400 kuna. Sad su i oni počeli sraćkat, jer su stekli jako dobar glas na tržišti i skoro svaka njubara je čula za Corsair i povezuje ga s kvalitetom. Upravo takvi će padat na ove proizvode, eventualno neko sa htpc-om ili low end konfom.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 04.10.2010., 21:51   #54
Doink the Clown
Postovi: 6,214
Temeljiti review XFX-ovih napajanja iz Pro serije na Hardwareheavenu:
XFX Pro Series PSU Review (650W, 750W and 850W Core Edition)
________________________________________________
Xion/AXP Lan Party Edition 700W Power Supply Review
Staro 27.10.2010., 19:31   #55
Doink the Clown
Postovi: 6,214
I Geil, poznati proizvođač memorija je izbacio na tržište svoja napajanja pod brandom Thortech.
Thortech Thunderbolt Plus 800 W Power Supply Review
Staro 20.11.2010., 23:09   #56
Doink the Clown
Postovi: 6,214
Antec Officially Announces the High Current Gamer Series of PSUs
Antec, Inc., the global leader in high-performance computer components and accessories for the gaming, PC upgrade and Do-It-Yourself markets, today announced the first complete series of power supply units (PSUs) to offer consumers the high current capability favored by gamers and other high-power users, along with the safety of over current protection on all power rails.
The High Current Gamer series is designed to optimize high-output current delivery while reducing wiring loss, resulting in unsurpassable value and reliability in a package that provides affordability and accessibility to gamers and power users working within varying budgets.
Every model in the High Current Gamer series features over current protected +12V rails with High Current functionality, allowing them to deliver high power while minimizing power loss to wiring resistance. All High Current Gamer power supplies achieve the 80 PLUS Bronze certification level, delivering their rated Continuous Power with a minimum of 82% efficiency at typical loads. Active Power Factor Correction (Active PFC) on all models, with a power factor above 0.9 helps to reduce electrical waste and further increases efficiency.
The series features two top-end models: the HCG-750 and HCG-900, each delivering 750 and 900-watts of Continuous Power, respectively. The series is rounded out with three additional models: HCG-620, HCG-520 and HCG-400, each outputting its own rated 620, 520 and 400-watts of Continuous Power.
"Gamers and high-performance users looking for a top-notch solution to power demanding builds should look to Antec's High Current Gamer series," said Scott Richards, senior vice president of Antec. "As the first consumer power supply line to offer a fully protected 40 amperes of maximum current on its +12V rails, the HCG gives users outstanding power capabilities needed to support the most current high-end graphics cards, extensive drive arrays and multi-core CPUs. The HCG is a striking example of Antec's ongoing dedication to producing innovative, reliable products that meet the latest needs of gamers and creative users."
The High Current Gamer series supports Intel multi-core, Core i3, Core i7 and Core i5 CPUs, as well as AMD Phemon II X6 CPUs and quad GPUs. In addition, the HCG-750 and HCG-900 are NVIDIA SLI-Ready and ATI CrossFireX certified.
Additional features on the High Current Gamer include reliable Japanese brand capacitors as well as a 135 mm double-ball bearing fan, providing the performance, reliability and high stability required for cutting-edge gaming and professional systems.
The entire High Current Gamer series is now available through major retailers, e-tailers and distributors. The HCG-400, HCG-520 and HCG-620 models are backed by Antec's AQ3 Antec Quality 3-Year limited warranty on parts and labor, and the HCG-750 and HCG-900 are backed by Antec's AQ5 Antec Quality 5-Year limited warranty on parts and labor.
http://www.techpowerup.com/134736/An...s-of-PSUs.html
Staro 20.11.2010., 23:37   #57
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Ukoliko cijene kod nas budu vrlo primamljive (osjetno jeftinije od S12 Sise) možda i ugrabe koju krišku na tržištu ... u suprotnom ne mogu se baš pohvaliti pretjerano dobrom regulacijom u odnosu na konkurenciju.
S obzirom na MSRP nekako sumanjam u uspjeh ove Delte :/
BTW baš gledam na nabavi napajanja po popularnosti ...
The Secret ...
Staro 20.11.2010., 23:53   #58
aard
aard's Avatar
Datum registracije: Jul 2009
Lokacija: Zaprešić
Postovi: 120
Nadajmo se da ce biti dobre kvalitete/cijene kod nas. Otkad je corsair zasrao sa ovom Builder serijom, ponuda entry level kvalitetnih napajanja je postala otuzna...
aard je offline   Reply With Quote
Staro 30.11.2010., 18:07   #59
Doink the Clown
Postovi: 6,214
Staro 14.12.2010., 18:48   #60
Doink the Clown
Postovi: 6,214
OCZ Subsidiary PC Power and Cooling Announces Silencer 760W PSU
OCZ Technology Group, Inc., a leading provider of high-performance solid-state drives (SSDs), memory modules, and power supplies for computing devices and systems, has launched the new Silencer 760 power supply from PC Power & Cooling, OCZ’s PSU (power supply unit) subsidiary. Built for best-in-class stability and reliability for today’s high-end gaming systems and professional workstations, the Silencer line has proven itself as one of the most trusted PSU series on the market for more than 20 years.
“The PC Power and Cooling Silencer power supplies have long been regarded as a top-quality solution by system builders and clients who require the very best performance and dependability,” said Charlie McMenomey, Product Manager at OCZ Technology Group. “Building on the proven core architecture of the original series, the new Silencer 760W further raises the bar with an 80 PLUS Silver efficiency, exceptional reliability and the power output to meet the demands of power users.”
With a history of over 25 years building long-lasting, investment-grade power management, PC Power designed the new Silencer to offer consumers a combination of legendary PSU architecture and the ultimate in performance. The newest addition to the legendary Silencer series completes the family of ultra-quiet, high-reliability PSUs, which now range from 500 to 910 watts. Featuring an 80 Plus Silver certification, the new 760W offers energy and cost savings with 88% efficiency (typical load) combined with a power output to meet the demands of the most component-heavy systems.
The rock-solid Silencer series not only meets a high standard of quality, but also guarantees superior compatibility with the latest graphic cards to provide sufficient output to even the most demanding graphics cards and cutting-edge platforms. The Silencer series is tested and qualified for systems with multiple power-hungry drives and video cards by delivering 760 watts of continuous power and 835W at its peak, and offers a temperature rating of 50ºC, twice that of the industry standard. Featuring rock-solid, super-clean DC output, a powerful Single Rail +12VDC (74A), and complete array of connectors including dual PCI-Express 6-pin, dual PCI-Express 6/8-pin, and 20+4-pin, 8-pin, and 4/8-pin motherboard connectors, this PSU can power a full array of high-end components.
The PC Power Silencer 760 slots into the series under the Silencer 910 and both are built with the highest-quality components and circuitry to provide one of the highest MTBF ratings at over 100,000 hours. In addition to the industry's most powerful yet versatile design on the market, the Silencer is backed by an industry-leading 7-Year warranty commitment and the expert knowledge of PC Power & Cooling technical support and engineering.
http://www.techpowerup.com/136374/OC...-760W-PSU.html
