Staro 18.09.2010., 23:59   #1
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Logitech Z 5500 DIY kutije ?
Ja sam prije par godina naletio na jednu super stranicu na kojoj je lik iz Z 5500 povadio drivere i iso radit neke, ako se dobro sjecam horna kutije, bilo je sve step by step, i sad nema boga da ja to opet nadjem, ako netko slucajno zna nesto o tome, bio bih zahvalan...
p.s. nisu to oni logiwood, to me ne zanima... ovo su bas bile kutijice , od bar pola metra visine
Konfa: Intel Core 2 Duo E 6400, 2.72GHz || Asus P5B Deluxe || 8800 EVGA GTS 320 mb || Super Talent 2x1 gb 800MHz CL5 || Seagate Barracuda 7200.10 320 GB 16 mb || Samsung Spinpoint F1 750 GB 32mb || Seasonic S 12 430W || A+ X-Blade || Logitech Z 5500 || CL X-Fi Xtreme Game || Logitech G500 || Logitech UltraX Flat Desktop || Canon Pixma iP4300 || Samsung ML-2510 || Toshiba Regza 32XV733G
Poggiali je offline   Reply With Quote
Staro 19.09.2010., 00:03   #2
syss
syss's Avatar
Postovi: 10,805
ako nađeš, okači... kaj da ti kažem
Staro 19.09.2010., 00:39   #3
Facelessone
Facelessone's Avatar
Postovi: 4,205
LogiWood možda?
Link
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 19.09.2010., 00:42   #4
syss
syss's Avatar
Postovi: 10,805
pročitaj p.s. čovjeka
Staro 19.09.2010., 00:48   #5
Facelessone
Postovi: 4,205
tog nije bilo kad sam išo odgovarat :=)
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 19.09.2010., 00:57   #6
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
hahaha... a da danas je subota xD
evo nesto sto sam naso.. nije to to.. ali opet je DIY
http://www.vikash.info/audio/W3-871S/index.asp
I sad.. ono sto sam iskopao , za te tang band drivere koje logi trpa u z5500
Ne kontam, ako su to ovi sateliti http://www.tb-speaker.com/detail/1208_03/w3-593sf.htm na koju je foru logi izvuko 62wrms, ako proizvodjac deklarira 12 w ? :/
http://www.tb-speaker.com/detail/1208_03/wt-644f.htm, dobro za sub nisu puno promjenili.. 180 na 188 wrms
Zadnje izmijenjeno od: Poggiali. 19.09.2010. u 02:25.
Staro 19.09.2010., 02:37   #7
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
joj ovako nesto
http://www.yolike.com/video/bollywoo...dio-Setup.html
steta sta nemogu nac dimenzije za ovo
Ovo je najblize sta sam naso
Zadnje izmijenjeno od: Poggiali. 19.09.2010. u 04:25.
Staro 19.09.2010., 13:47   #8
tech
Postovi: 1,687
Cyburg Needle project ili TangBand cyburg needles
I još postoji thread od 60-tak stranica na tu temu i još se odnosi na W3-871 driver.Tko bi reko, jel?
Pa to ti je to, lik je napravio cyburg needle sa Tang Band driverima koje logi koristi u manje više svim svojim sistemima.
Te "igle" su popularan low budget projekt.
A kolko vidim imaš i dimenzije i sav potreban info da ih napraviš u jednom vikendu.
Google-->Cyburg Needle project ili TangBand cyburg needles
Staro 19.09.2010., 18:29   #9
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Dobro, prokopao sam malo po tom topicu, ima svega, malo je razbacakano, ali ok....
Nego sad me zanima, vidim svi stavljaju te skretnice, sta nije svrha skretnice, ako postoji vise drivera, pa da se ne mjesaju sve frekve ?
Zasto stavljat skretnicu ako postoji samo jedan driver u kutiji, kao samostalna jedinica?
Staro 19.09.2010., 23:22   #10
syss
syss's Avatar
Postovi: 10,805
možda da ga odrežu na nižim frekvama?
Staro 20.09.2010., 00:02   #11
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Pa kud da se rezu na tim driverima nize frekve, sta ih tolko puno ima, mislim zar da idu toliko duboko da treba rezati :// ??
Staro 20.09.2010., 09:35   #12
Perki
Lokacija: VG
Postovi: 775
Nije to skretnica, već filter. Peglaju se visoki na tangbandima, needle s visatonom to navodno ne treba.
Trust me - I know what I'm doing!
Perki je offline   Reply With Quote
Staro 20.09.2010., 12:23   #13
syss
syss's Avatar
Postovi: 10,805
Autor Poggiali Pregled postova
kolega je odgovorio, pošto sam ja napamet pričao... međutim režu se najdublji tonovi da ne dolaze na driver (ovo generalno pričam) pošto je skromnih dimenzija, pa da se ne ošteti pri većim glasnoćama.
Staro 22.09.2010., 00:55   #14
Vido
[SW]'V^idO
Vido's Avatar
Postovi: 424
To ti usput objašnjava kako trpe više snage. 12W je očito snaga bez skretnice (znači driver svira cijeli spektar koliko može), a onih 60ak W je snaga sa skretnicom tj driver svira samo visoke frekvencije (rezna frekvencija i nagib reza ovisi o skretnici jel)
Evo npr ovdje: http://www.dobar-zvuk.hr/hi-fi/westr...3-134-8_01.pdf
Vidiš da ima zvjezdicu kod snage, dolje piše da je to ako ima odgovarajucu skretnicu, vjerojatno ne bi istrpio ni 5W bez nje
Member of [SW]' CoD2 clan. Join us!
Moji DIY projekti i sl.: http://vidosprojects.freei.me/
Vido je offline   Reply With Quote
Staro 22.09.2010., 09:40   #15
srale7
srale7's Avatar
Postovi: 5,796
Iskreno, NHF, ali Poggiali, mani se ti ćorava posla, da se nebi jos sta zapalilo
a serijskim spajanjem sam vise opteretio pojacalo ?
A sta ide ono ako spajam dva zvucnika na jedan kanal jel onda dobim 4 ohma ili ... noob sam za ovo
srale7 je online   Reply With Quote
Staro 22.09.2010., 10:10   #16
Ziiky
Ziiky's Avatar
Postovi: 2,882
joj ovako nesto
Na sta ovo lici, zaliveo i spajano silikonom, packe od prstiju
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Staro 22.09.2010., 10:30   #17
srale7
srale7's Avatar
Postovi: 5,796
Autor Ziiky Pregled postova
I sto je najzalosnije, potrosen kvalitetan materijal, znači nije iverica, i onda to isao spajat silikonom i to jos sa vanjske strane, totali fail
Staro 22.09.2010., 13:21   #18
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Fail je uopće upuštat se u modding Z5500. Jedan mali aluminijski driver koji bi trebao pokrivati sve moguće iznad tutnjave subwoofera? Bez neke adekvatne midbass jedinice i tweetera tu se uopće nema šta razgovarati o donekle kvalitetnom zvuku...
Staro 22.09.2010., 15:13   #19
srale7
srale7's Avatar
Postovi: 5,796
A i to sto kazes, ali vjerujem da se sa i ovako neozbiljnim jedinicama mogu dobiti nelosi rezultati, ali kao sto kazes, sve ovo nema bas puno smisla, pogotovo utrositi ovoliku kolicinu drveta, ugraditi ove jedinice i onda sve to zamazati silikonom. Ko da smo u kupaoni.
Staro 22.09.2010., 16:48   #20
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Autor srale7 Pregled postova
Ja bi se usudio reći da niti jedan pc 2.1 sistem ne valja. Do koje frekvencije ti subovi lupaju u pravilu? 150hz? Da se mene pita to ne bi imalo šta tražiti iznad max. 60hz.
Imao sam dosta davno prije Megaworks 250D koji je, kao, bio dobar. Međutim sateliti su bili smeće jer sam jednom prilikom posudio JBL Control 1 i spojio njih i ostao frapiran razlikom, to je već u cjelini zvučalo kako spada.
Staro 22.09.2010., 17:04   #21
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor Bluzer Pregled postova
Ne valja za kaj?
Pa to su zvučnici za računalo pobogu-orginalni koncept je ciljao prvenstveno na igre, pa je "multimedija" bila na drugom mjestu a ostalo kak ti bog da ili marketing uvali
Da se i mjuza relativno kvalitetno poslušat pod uvjetom da je bolji model, da se malo poigraš sa kontrolama i makneš bar dva-tri metra od kompa
Staro 22.09.2010., 17:15   #22
syss
syss's Avatar
Postovi: 10,805
baš me drugar jučer pitao jesam zadovoljan sa z5500... reko da krepaju sutra po iste bi išao u dućan.
za filmove i zvukove sa telke uz poneku iznimno glasnu muziku - i više nego solidno.
puno bolja opcija imat tak nekaj + dedicated stereo (naravno ako se ima prostora za oboje).
Staro 22.09.2010., 17:32   #23
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Imam doma prilično solidan stereo sustav, čuo sam Z5500, jedino što valja je SUB jer je brutalan. Ali ipak, planiram si u dogledno vrijeme uzet svejedno Z5500. Zašto?! Filmovi i kad pukne film štemanje sa 188W. Za te pare bolje ne može za tu namjenu.
Staro 22.09.2010., 20:24   #24
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Autor -POP- Pregled postova
nhf al za male pare mozes slozit sub da ti glavu odvali kolko je "brutalniji" od suba u z5500....
Staro 22.09.2010., 20:43   #25
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Autor Jelc Pregled postova
Ne valja za kaj?
Ono šta sam htio reći da ne valjaju pogotovo za cijenu koju koštaju jer ima hrpa sustava za preko 1k kuna, a za te novce možeš nabaviti neko pojačalce i bookshelfe koji to sve skupa pojedu za doručak.
Primjera radi, jedan frend dao 1400kn za HK Soundstickse pa onda čuo kod jednog drugog neko Teac pojačalo i Wharfedale Diamonde koje je nabavio sve skupa za valjda 1000kn i čudi se "gle, ovo svira".
Staro 22.09.2010., 21:43   #26
tech
Postovi: 1,687
A nije ti palo na pamet da netko nema ni 10m2 sobe i da nemre strpat 70cm visoke zvučnike i amp pored kompa?
A ne brojim ni kolko sam puta zaželio imati nešto malo i obješeno na zid...
Nije ti svejedno kada se klinci zalete i počnu vješati po stalku i zvučniku a da ne spominjem da vole gurat olovke u BR port i prste u visokotonce
Staro 22.09.2010., 21:52   #27
syss
syss's Avatar
Postovi: 10,805
krećemo opet...
fleks (opet) ima sub koji rastura za nikakve pare, jedino se za njega mora kupiti još el-niš industrijsko pojačalo koje je opsluživalo razglas bivšeg tpk za 300kn i monacor 38cm za 400kn, kutija od ormara i voila - jedan zvučnik za cijenu trećine cijelog seta.
ALI
za još samo 3000kn se može kupiti savršeno rabljeni set od 5 dvosistemskih wharfedale zvučnika i onda još 3 rabljena pojačala i naravno procesor da iskontrolira to sve.
možda je jedno 6-7k kn skuplje od 5500, ali svira ajme-majko dobro.
daj mi fleks pliz pokaži taj aktivni sub za sitne pare.
Staro 22.09.2010., 22:03   #28
Jelc
Super Moderators
Postovi: 17,485
Pa, možeš-jedan je problem kuda sa tim.
Nagledao sam se stolova za komp kod brdo ljudi i to su u pravilu stolići 70 cm široki na koje nemreš ništa stavit
Ne znam koliko je isplativio ulagat u manji stereo isključivo za korištenje na računalu (mp3-ce, tu i tamo pogledat koji video ili film+malo igranja)
Na kraju krajeva stvar je ista kao i sa svim ostalim, do onog kaj tebi treba-ako je na prvom mjestu mjuza onda je to stereo, ako se voliš poigrati na kompu, pogledati koji film i malo poslušat mjuzu onda je 2.1 nekak logičniji.
Staro 22.09.2010., 22:14   #29
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Autor syss Pregled postova
Ovo već spada u domenu trolanja.
Yamaha RX-V365 1589kn
http://www.optimum-online.hr/detalji_proizvoda.1e013e0cf38d44738263394c252a1f69.av_receiver_yamaha_rx-v365_black_akcija_!.aspx
Jamo Studio S 406 HCS1 1489kn
http://ronis.hr/?jamo/452/zvucnici-j...-hcs1/S406HCS1
3000kn za nešto što sliči na sustav ili 2500kn na nešto što ima preddimenzinirani sub i poddimenzionirane satelite i generalno pojačalo koje je izrađeno od smiješnih komponenata. Z5500 je super, ali za one koji nisu čuli nešto bolje ili što je u svijetu zvuka još češće - ne žele čuti nešto bolje.
Staro 22.09.2010., 22:14   #30
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Pa Jelc, nisi li banana?! :-)
Fleks, ne radi se ovdje samo o subu za te pare, nego i o 5 zvučnika, što se sve zajedno može naći za 200E. A za te pare, nema tog "HI-FI-a" koji će imati tih 5 zvučnika + 1 zvučnik i pojačalo. Lijepo sve upiknem na zvučnu i vidi čuda. A kad mi se sluša mjuz, imam USB i DAC, simple. Jednostavno, nekima je Z5500 jedino rješenje (čitaj. smještaj, djeca, pa i novci...)
