Staro 17.09.2010., 17:54   #1291
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
@DJ Distinctive
Ljepi pesek. njam njam
@The Pill Man
Razerviram par maslina od prve berbe. Fora "ljubimac".
@Thoroughbred B
Mogli su jako dugo skupa živeti samo da miš nije došel blizu nje/njega.
Baš ga je hrvački zgrabila, di trenira?
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 17.09.2010., 18:11   #1292
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
@TB kolko opce svoju cesto hranis?
Ja imam G. Roseu (RCF), tijelo joj je cca 7,5cm, a ako uzmem u obzir i noge onda oko 11cm...
Staro 17.09.2010., 19:41   #1293
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Njunjo teško da bi živjeli u nekoj idili
Hranim dok ne počne odbijat hranu...svaki dan više manje...
Staro 17.09.2010., 19:45   #1294
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Ni ja svojima ne dajem miseve ( tarantulama) .Dubiji ftw
Staro 17.09.2010., 22:10   #1295
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
Autor xulos Pregled postova
sad me prosvjetli i reci mi sta su dubiji (cuo jesam, al se ne sjecam) xD
Staro 17.09.2010., 22:14   #1296
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
zohar !
Staro 17.09.2010., 22:56   #1297
The Pill Man
The Pill Man's Avatar
Postovi: 325
@The Pill Man
Budem postao sličice kako se bude razvijala, pa kad prvi plodovi dođu, javi se, samo treba tu nekolicina godinica.
(to hoću reći zdravi mi i forum bili i dugo živili)
Pill Man
The Pill Man je offline   Reply With Quote
Staro 17.09.2010., 23:12   #1298
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Autor Problem Pregled postova
http://sphotos.ak.fbcdn.net/hphotos-..._2502385_n.jpg
to je dubi
Staro 18.09.2010., 18:20   #1299
Berax0r
Berax0r's Avatar
Postovi: 623
Jel ste vi na akvarij.net forumu?
Berax0r je offline   Reply With Quote
Staro 18.09.2010., 19:56   #1300
nino
nino's Avatar
Postovi: 12,613
http://www.easilysharing.com/images/...0773476876.jpg
Tko je rekao da zmije ne mogu jesti piletinu. Ostao sam bez miseva i po savjetu jednog uzgajivaca , dao sam joj piletinu i naravno da je sve smazala .
Jesi to ti na RTL-u bio sad sa zmijicom.
Staro 18.09.2010., 20:00   #1301
syss
syss's Avatar
Postovi: 10,805
bogami je... bez obzira na slavu živina je pomalo bljak
Staro 19.09.2010., 05:07   #1302
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Autor nino Pregled postova
jeste , ja sam bio
Staro 20.09.2010., 14:06   #1303
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
omg, moja tarantula je pussy
nije jela vec dobra cetri tjedna, kukce ne zeli, danas joj kupio pinkija i nesto se u startu nahuštrila na njega i skocila je ali se povukla, sad lagano sece oko njega ali nece da papa. Znam da g. rosea nije nesto extra agresivna vrsta ali ima na netu pun k videa gdje miseve ubijaju samo tako, i to ne pinkije nego ove vece. Kaj stvarno nije gladna??? TB, ti velis da svoju hranis manje/vise svaki dan. A moja nije bas ni tako mala da joj je jedan kukac dosta za mj. dana
Staro 20.09.2010., 14:17   #1304
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Jede dok je gladna...ne može vječno jest svaki dan...izgleda da ti nije gladna...iako g.rosee imaju dosta spor metabolizam tako da su rijetko gladne...i imaju velike "pauze" između hranjenja...
EDIT => Problem => G.rosee znaju odbijat hranu i po godinu dana...tako da se ne brineš.
Zadnje izmijenjeno od: Thoroughbred B. 21.09.2010. u 02:15.
Staro 20.09.2010., 14:24   #1305
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
ma znam da nesto sporije jedu od ostalih, ali mi je ovaj mj. dana bez hrane nekak puno
mislim da cu je morat prodati i kupit nesto tipa a. geniculata kao sto ti imas, jer ovo je predosadno stvorenje
Staro 20.09.2010., 22:27   #1306
Speedbreaker
Postovi: 545
Evo opet mog čupavog stvorenja...
micek 1
micek 2
Speedbreaker je offline   Reply With Quote
Staro 28.09.2010., 17:08   #1307
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
Staro 04.10.2010., 01:17   #1308
elanst
Lokacija: split
Postovi: 28
Bolje Micko nego Vuki
elanst je offline   Reply With Quote
Staro 04.10.2010., 14:03   #1309
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Danas je Svjetski dan životinja, pa eto... posvetite se malo svojim ljubimcima
blaa
Staro 04.10.2010., 15:34   #1310
MyJoy
MyJoy's Avatar
Postovi: 63
The Badonkadonk Chick:
MyJoy je offline   Reply With Quote
Staro 04.10.2010., 15:39   #1311
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
jel ima netko francuskog buldoga da malo popricamo?
nakon god dana kako je uginuo moj najbolji prijatelj (11 god je bio samnom) nekako sam skupio snagu pa sam u potrazi sa psom ..
V.I.P je offline   Reply With Quote
Staro 05.10.2010., 12:55   #1312
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
http://sphotos.ak.fbcdn.net/hphotos-..._4264935_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._6965145_n.jpg
Moj mjesanac Shar-pei-s i necega . Zenkica stara 2 mj, ime joj je luna
Staro 21.10.2010., 22:50   #1313
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Upoznao sam u Rovinju preko ljeta čovjeka koji se bavi uzgojem belgijskih ovčara i prije 8 tjedana je na svijet došlo drugo leglo, lik poklanja pse, čistokrvne belgijance ali preduvjet je naravno da novi vlasnik zna postupati sa takvim psom na pravi način i odgojiti ga kako treba, naravno tu su i ostali uvjeti poput velike okućnice i udoovljavanja svih ostalih prohtjeva koje takva pasmina ima. Iz prvog legla 4 psa su otišla policiji i sad iz drugog su rezervirala 3, koristit će se za traženje mina na miniranim područjima.
Pošto živim u stanu nisam u mogućnosti držati takvog hiperaktivnog psa ali frendu koji već ima kuju belgijskog ovčara sam sredio jednog štenca
Iz legla od 8 izabran je ovaj mali vojnik, sigurno će biti zeznut igrač
http://www.pohrani.com/f/3a/Eq/1Y6D9TDf/1/dsc01676.jpg
http://www.pohrani.com/f/2V/b9/3LDClxs9/1/dsc01677.jpg
C L O W N I N G A R O U N D
Staro 22.10.2010., 00:15   #1314
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
Izgleda da je tu labrador odradio poso..
boris87 je offline   Reply With Quote
Staro 30.11.2010., 01:04   #1315
Prcko Prcić
Datum registracije: Sep 2010
Lokacija: Lepoglava
Postovi: 178
fotka Waltera
nazalost, sa 3 godine starosti obolio je od epilepsije....imao je napade u prosjeku jednom mjesecno dok nismo skuzili da se radi o epilepsiji i poceli mu davati lijekove...pije ljudske ljekove, zaboravio sam tocno ime tableta, i otkad pije, samo jednom je imao napad...da mu se ovo nije dogodilo, garantirano bih ga dao pariti, jer je vjerojatno najljepsi pas u gradu, ako ne i sire....nema teorije prosetati s njim po gradu, a da me netko ne zaustavi, pridje i pozeli se fotkati s njim ili ga pomaziti....a narav mu je milina, svim drugim psima se postavlja kao alfa muzjak i kad se pokore, onda se igra s njima, obozava lizati malu djecu po licu, cuva moju staru ko oci u glavi, iako haskiji inace nisu cuvari, a trenutno spava na mom krevetu i grije mi jastuk....
Zadnje izmijenjeno od: Prcko Prcić. 30.11.2010. u 01:10.
Prcko Prcić je offline   Reply With Quote
Staro 30.11.2010., 01:15   #1316
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,490
Staro 03.12.2010., 20:43   #1317
mate11111
mate11111's Avatar
Lokacija: Đurđevac
Postovi: 22
Imam Newfoundlanda Lucy, pekinezera Buby, lavljoglavog zeku Gricka, 2 kornjače i nedavno pokojni Micko (
mate11111 je offline   Reply With Quote
Staro 13.12.2010., 21:42   #1318
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Eo snimano frisko :
Pterinochilus Murinus :
http://www.youtube.com/watch?v=DGBRBK0j-ZE
Staro 13.12.2010., 22:09   #1319
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
kaj je tak agresivna?
ja sam svoji rosei danas kupio neke crve. Uglavnom ja joj sipam 5 komada iz vrecice u terarij i odem bacit vrecicu u smece i dok sam se vratio vec se gamad zakopala u zemlju. Sad ova moja jadnica regulja (kopa xD) po terariju i treazi crve. Kaj je najgore neznam opce dal je ona to polovila ili ne kad nist ne vidim. Mislim da je jednog smazala kad sam nasao neku ko bljuvotinu boje kak je bio crv . Da idem sad trazit dal ih ima jos nutra ili nek samo ostavim pa nek ova dalje lovi ko u prirodi? xD
Staro 13.12.2010., 22:24   #1320
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Crve nikad ne bacas bzvz u terarij, nego jednog po jednog pred nju tako da jede, nije to kokos da kljuca .Ne radis to iz razloga da ti se crvni ne zakukulje i pretvore u bube.Ostavi sad tako, osjeti ona njih , ali ubuduce jedan po jedan .Najbolji savjet : ostavi se fobasa ( crvi) i nabavi lateralise
