Staro 14.09.2010., 09:42   #1
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,185
Nvidia ForceWare 260.63 beta driveri
Changelog:
New in Release 260.63
New GPU Support
Adds support for the newly released GeForce GTS 450 GPU.
Performance
Increases performance for GeForce GTX 400 Series GPUs in several PC games vs. v258.96 WHQL drivers. The following are examples of some of the most significant improvements measured. Results will vary depending on your GPU and system configuration:
GeForce GTX 480:
Up to 10% in StarCraft II (2560x1600 4xAA/16xAF Ultra)
Up to 14% in S.T.A.L.K.E.R.: Call of Pripyat (1920x1200 4xAA/16xAF)
Up to 16% in S.T.A.L.K.E.R.: Call of Pripyat (SLI – 2560x1600 4xAA/16xAF)
Up to 6% in Aliens vs. Predator (SLI – 1920x1200 noAA – Tessellation on)
GeForce GTX 460:
Up to 19% in StarCraft II (SLI – 1920x1200 4xAA/16xAF Ultra)
Up to 15% in Battlefield Bad Company 2 (SLI – 2560x1600 4xAA/16xAF)
Up to 12% in S.T.A.L.K.E.R.: Call of Pripyat (2560x1600 noAA)
Up to 9% in Aliens vs. Predator (1680x1050 4xAA/16xAF – Tessellation on)
Up to 7% in Metro 2033 (1680x1050 noAA – Tessellation on)
Up to 11% in Dirt 2 (SLI – 2560x1600 4xAA/16xAF)
Up to 12% in Crysis:Warhead (SLI – 1920x1200 4xAA/16xAF Gamer)
Up to 13% in Far Cry 2 (2560x1600 4xAA/16xAF)
Up to 12% in H.A.W.X (SLI – 1920x1200 4xAA/16xAF SSAO Very High)
Up to 5% in Just Cause 2 (1920x1200 4xAA/16xAF)
Up to 22% in Riddick: Assault on Dark Athena (1920x1200 noAA)
Up to 5% in 3DMark Vantage (Extreme Preset)
HD Audio
Upgrades HD Audio driver to version 1.1.9.0.
Installation
New driver installer with enhanced user interface and new Express and Custom installation options.
Express – one-click installation
Custom – customized installation
Option to perform a clean installation (completely removes older drivers from your system prior to installing the new driver).
Option to choose which driver components (ie. PhysX or 3D Vision) to install.
Improved installation time for multi-GPU PCs.
Other Improvements
Upgrades PhysX System Software to version 9.10.0514.
Includes numerous bug fixes. Refer to the release notes on the documentation tab for information about the key bug fixes in this release.
Users without US English operating systems can select their language and download the International driver here.
Additional Information:
Supports the new GPU-accelerated features in Adobe CS5.
Supports GPU-acceleration for smoother online HD videos with Adobe Flash 10.1. Learn more here.
Supports the new version of MotionDSP's video enhancement software, vReveal, which adds support for HD output. NVIDIA customers can download a free version of vReveal that supports up to SD output here.
Supports OpenCL 1.0 (Open Computing Language) for all GeForce 8-series and later GPUs.
Supports OpenGL 3.3 for GeForce 8-series and later GPUs.
Supports single GPU and NVIDIA SLI technology* on DirectX 9 and OpenGL.
Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
Download:
Forceware 260.63 Win Vista | 7 (64-bit)
Forceware 260.63 Windows XP (32-bit)
pozdrav.
izasli 260.63.
na guru-u dosta problema spominju. najvise me brine: "HDMI it looked washed out as if the gamma was too high".
jel probao netko?
edit: hm, ovo zvuci jos gore: "i Had many bsod using my 46'' HD TV thru HDMI"
edit2: hvala razer
Zadnje izmijenjeno od: geronimo_2. 14.09.2010. u 10:14.
geronimo_2 je online   Reply With Quote
Staro 16.09.2010., 14:09   #2
geronimo_2
geronimo_2's Avatar
Postovi: 4,185
hm,
"I have 2 Palit GTX 460 2GB in SLI, one of the cards has no problems with the 260.63 drivers on its own, but the other card will lock-up windows and show severe artefacts on the windows welcome screen, it will also lock up windows if i use the working fine card as primary and switch on SLI.
These cards are identical (brought at the same time), so it might not even be an issue with all Palit GTX 460s but a only a few. I spoke to my supplier and they said that if the issue is still present once these drivers go WHQL (or whatever the next driver version is that goes WHQL) then return it as a faulty card for replacement.
I have a suspicion that this could be an obscure hardware fault showing up in certain palit/gainward GTX 460 cards that the drivers have exposed.
Both cards had zero problems with the 258 official drivers.
I forgot to add that the working card works fine with both pci-e x16 slots, yet the other doesn't work in either with the 260.63s, so i don't think its a compatibility issue with the motherboard and graphics card on this driver.
I have also contacted Palit and Gainward support emails on this matter for more information, hopefully they'll figure out the problem. "
I smell trouble
moguce lose vijesti za Palitaše i Gainwardaše :-(.
