Staro 04.09.2010., 17:22   #1
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
lenovo 3000 n200 i win7-problem
problem je ovakav:
na xp-u sve radi ok ali nakon instalacije win 7 (32bit i 64bit)
pocinju problemi...
touchped neradi nakon poljenja racunala nego moram napravit restart da bi touchped radio...i tako u 90% paljenja racunala .....i da ima jos : kad neradi touchped i rezolucija padne na 800x600....nakon restarta sve ok....jel se neko sreo s slicnim slucajem i dali postoji rjesenje
sinke.ZG je offline   Reply With Quote
Staro 04.09.2010., 17:42   #2
Dottore
Dottore's Avatar
Postovi: 7,631
Jesi li probao skinuti Thinkvantage system update? Ona ti skida potrebne drivere.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 05.09.2010., 09:52   #3
nino_z
nino_z's Avatar
Lokacija: Valpovo/Osijek
Postovi: 267
Imaš sve drivere ovdje (ako nema Win7 skineš za Vistu)
http://www-307.ibm.com/pc/support/si...IGR-67855.html
nino_z je offline   Reply With Quote
Staro 06.09.2010., 17:53   #4
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
probao sam sa svim mogucim driverima i opet ista stvar
Staro 06.09.2010., 18:17   #5
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Onda ima jedno fantastično rješenje: Instaliraš XP i sve opet radi kako treba.
[GOW]Nec je offline   Reply With Quote
Staro 06.09.2010., 18:59   #6
maky111
maky111's Avatar
Lokacija: Zg - D.S.
Postovi: 52
Probaj napravit update win 7 .
maky111 je offline   Reply With Quote
Staro 09.09.2010., 17:00   #7
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
probao i update win 7 ...jednostavno nece i nece....izgleda da ce bit laptop u torbu i zel-cos
Staro 09.09.2010., 18:25   #8
Postovi: 23,512
Po opisanom problem je sa loše napisanim drajverom (ima) i inicijalizacija istih nakon buđenja iz sleep / suspend stanja.
Ovo se dosta često dešava kod određenih kombinacija model laptopa / os.
Sve šta možeš napravit je:
- update BIOS - a na zadnju verziju, nisi precizno naveo Machine / Product ID
- kako Lenovo nije "službeno" izdao drajvere za Win 7 trebaš povadit za sav ugrađeni hw Device ID i po tome tražit drajvere koji imaju cetrifikat baš za Win 7.
Ovo nije lak zadatak niti je siguro da postoji rješenje ali vrijedi probati, pogotovo za touchpad.
Staro 09.09.2010., 18:29   #9
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
3000 n200 uredno radi pod 7-com, samo treba izbjegavati par stvari. Ako koristiš bilo kakav oblik sleepa ili hibernacije, nemoj instalirati power manager. Nije radilo kako treba na nijednoj verziji, ni na jednoj kombinaciji. Drugo, lenovo je skoro za svaku seriju izdao par critical nadogradnji, za Vistu i 7-cu, one su nužne. I ovo što je Nikky napisao, obavezni čitati što piše, instalirati drivere za točan hardver ID i sve ide kao podmazano.
Staro 09.09.2010., 19:12   #10
nino_z
nino_z's Avatar
Postovi: 267
Autor tor Pregled postova
Moj N100 radi i s instaliranim Power Managerom. Kako se očituje greška? Ne podiže se iz hibernacije?
Staro 12.09.2010., 12:09   #11
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
kak nac taj hardver id?
i di skinut te critical nadogradnje?
Staro 12.09.2010., 12:12   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Autor nino_z Pregled postova
Sory, nisam vidio prije - ne ide u hibernaciju ili sleep, već baci BSOD.
Autor sinke.ZG Pregled postova
Po serijskom broju lapa, pa onda dio po dio...
Staro 12.09.2010., 12:24   #13
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
a te critical nadogradnje di cu skinut, i kak najbezbolnije rjesit bios
Staro 12.09.2010., 13:33   #14
Postovi: 23,512
Evo primjer za grafičku (ista stvar za svaki hw):
Device Manager > Display adapters > odabereš ugr. grafičku > Properties > Details > Device Instance ID
Za početak na support stranici proizvođača, napiši Product number da znamo točni model.
Staro 12.09.2010., 14:11   #15
Dottore
Dottore's Avatar
Postovi: 7,631
pošto nemaš pojma kako napraviti i i ponavljaš dva puta pitanje.
Skini si ThinkVantage System Update 4.0 (10MB)
Preko nje se vidi tip i model laptopa. Čim ona pretretraži sav hardver ( potrajat će 15 sekunda ) i odmah će ponuditi kritične, preporučene zakrpe, softvere. ( što god ima )
Nema kemijanja i možeš odabrati što ti treba, a možeš sve pa skida i automatski instalira. Ništa lakše.
Druga opcija ako voliš ručno pozabaviti. Okreni na poleđini laptop i zapiši si svoj type model laptopa, naprimjer moj laptop IBM T43p, 2668 PFG ( ovako izgleda). Odeš popuniti na opciju Downloads and drivers. Potom dobiješ specifikaciju laptopa i njegove drivere, bios i softvere.
To skidaš a moraš ručno instalirati.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
