Staro 29.08.2010., 09:17   #1
Mrk1
Lokacija: Dalmacija
Postovi: 49
Invisible folder na Win7
Jelpostoji shema kako napraviti invisible folder, ne mislim na hidden folder nego na invisible koji se mogao napraviti u xp-u kombinacijom tipki i stavljanjem "nevidljive ikone". Je li to isto možda netko uspio na 7ici jer nisam našao na netu
Mrk1 je offline   Reply With Quote
Staro 30.08.2010., 03:05   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Ovo si probao i ne "ide"?
Steps to hide folders without using any software:
Follow the following steps to hide folders without using any software:
1. Firstly, create a new folder.
2. Right-click on the newly created folder and from the the menu select Rename option.
3. Hold Alt key and press 9 key nine times and then press Enter key. You will see a blank folder name for that folder.
4. Again right-click on that folder and select Properties.
5. From the properties window, select Customize tab.
6. Select Change Icon form the Folder icons part.
7. Now, select a blank folder icon form the Change Icon for Folder window.
8. Click on OK button.
9. Again, click on OK button of the folder properties.
That's all. You will see that the folder is invisible or hidden. In this way, you can easily hide any folder from others in Windows 7 all versions including Ultimate, Ultimate, Premium, Professional, Basic, Starter and Enterprise edition.
If you face any difficulties or problem of the above instructions, then tell me in the comment section and I will try to help you.
http://hubpages.com/hub/Hidden-folde...r-in-Windows-7
IE6
Linux is Not Windows
Staro 30.08.2010., 04:16   #3
AbAdd0n
AbAdd0n's Avatar
Postovi: 246
probao sam i ja i ne "ide" .
uspjesno maknem naziv ali kod mene na properties ne
postoji customize tab .
edit : jedino sto daje nekakvog rezultata je kad napravim shortcut od foldera pa sakrijem shortcut ... ali opet ima onaj okvir ....
test konfa
Zadnje izmijenjeno od: AbAdd0n. 30.08.2010. u 04:37.
AbAdd0n je offline   Reply With Quote
Staro 30.08.2010., 07:01   #4
Mrk1
Lokacija: Dalmacija
Postovi: 49
kod mene ne funkcionira alt i 9 puta devetka u tome je problem
Staro 04.09.2010., 01:01   #5
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
@AbAdd0n
Moguće da nemaš 'Costumize' tab jer folderima pristupaš preko 'Libraries' u desnom izborniku Explorera ili putem 'Documents', 'Pictures' i sličnih kratica na Start Meniju.
Do tog foldera moraš ići preko explorera klasičnim putem kroz foldere.
@Mrk1
ASCII kombinacije sa Alt+broj se uvijek upisuju putem numpada (brojevi na desnom dijelu tipkovnice).
vedranzeman je offline   Reply With Quote
Staro 04.09.2010., 17:52   #6
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,025
"Razmak" je sa Alt + 0160
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
