Staro 11.08.2010., 11:41   #5431
robert7
robert7's Avatar
Postovi: 1,708
bind TAB "+scores;g_teamname_allies ^1Attack^7;g_teamname_axis ^4Defence^7;g_scorescolor_allies 0 0 0 0; g_scorescolor_axis 0 0 0 0; g_scorescolor_free 0 0 0 0;g_teamcolor_allies 1 0 0 0; g_teamcolor_axis 0 0 1 0;sv_clientsidebullets 0;g_teamcolor_myteam 0 1 0 1"
bind ESCAPE "togglemenu"
bind SPACE "+gostand"
bind 1 "openscriptmenu quickpromod assault"
bind 2 "openscriptmenu quickpromod specops"
bind 3 "openscriptmenu quickpromod demolitions"
bind 4 "+smoke"
bind 5 "openscriptmenu -1 loadout_grenade:flash_grenade"
bind 6 "openscriptmenu -1 loadout_grenade:smoke_grenade"
bind ` "toggleconsole"
bind A "+moveleft"
bind B "mp_QuickMessage"
bind C "gocrouch"
bind D "+moveright"
bind E "+leanright"
bind F "+activate"
bind G "+frag"
bind N "+actionslot 1"
bind O "^0Colors^2!;r_filmtweakenable 1;r_filmtweakContrast 1;r_filmtweakLighttint 1.6 1.6 1.8;r_filmtweakDarktint 1.7 1.7 2;r_filmtweakDesaturation 0;r_gamma 1.6;r_filmtweakbrightness 0"
bind Q "+leanleft"
bind R "+reload"
bind S "+back"
bind T "chatmodepublic"
bind W "+forward"
bind Y "chatmodeteam"
bind Z "+talk"
bind ~ "toggleconsole"
bind PAUSE "toggle cl_paused"
bind DOWNARROW "openscriptmenu quickpromod grenade"
bind ALT "openscriptmenu quickpromod 2"
bind CTRL "goprone"
bind SHIFT "+breath_sprint"
bind MOUSE1 "+attack"
bind MOUSE2 "+speed_throw"
bind MOUSE3 "+frag"
bind MOUSE4 "+melee"
bind MWHEELDOWN "weapnext"
bind MWHEELUP "weapnext"
http://eu.prepsafe.com
robert7 je offline   Reply With Quote
Staro 11.08.2010., 12:51   #5432
Lak
Lak's Avatar
Datum registracije: Feb 2010
Postovi: 397
Ja sam valjda jedini koji igra na strelice a ostatak je sljedeće
jump-enter
crouch-desni shift
prone-desni ctrl
nade-delete
smoke/flash-page down
reload-end
lijevi lean-insert
desni lean-page up
use-home
trčanje-ž (odmah lijevo od enter)
switch oružja-scroll
nož-scroll klik
Ostalo od đuke njuke 3d
Lak je offline   Reply With Quote
Staro 11.08.2010., 12:57   #5433
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
OMFG, kak mos na strelice igrat? jel te nezaboli ruka nakon nekog vremena?
Kod mene na default, samo sto mi je melee atack na scrol gore, dolje
Campeonato je offline   Reply With Quote
Staro 11.08.2010., 13:03   #5434
njoka.
njoka.'s Avatar
Datum registracije: Jul 2010
Lokacija: Vukovar
Postovi: 111
Autor Lak Pregled postova
jump-enter
crouch-desni shift
prone-desni ctrl
nade-delete
reload-end
lijevi lean-insert
desni lean-page up
use-home
nož-scroll klik
Uhh,posteno sam se nasmijao.Stvarno ne kuzim kako mozes igrat na takvim kontrolama.Ok,ako si naviknut mozda,ali meni je ne zamislivo da igram na ovako necemu.Ovo su definitivno najmastovitije kontrole ikada
njoka. je offline   Reply With Quote
Staro 11.08.2010., 13:11   #5435
Lak
Lak's Avatar
Postovi: 397
hehe znao sam da će biti komentara na moj odabir, svi se križaju kad čuju kako igram, ali ja ne želim pobjeć od strelica tako da mi sve ostalo treba biti oko njih, a one desne brojke od strelica ne rade, obično tamo znam nešto staviti, ali u COD 4 tamo ne rade.
Ovako već igram preko 2 godine i meni je super
Staro 11.08.2010., 13:12   #5436
robert7
robert7's Avatar
Postovi: 1,708
rade samo ti numlock mora biti ugasen brijem,uglavnom moji bindovi tamo rade
Staro 11.08.2010., 13:21   #5437
Lak
Lak's Avatar
Postovi: 397
To nisam znao, ali sad je ionako gotovo, naučen sam na ovo i neću ništa mijenjati
Staro 12.08.2010., 13:19   #5438
BlackZ0r
Datum registracije: Aug 2010
Lokacija: Poreč
Postovi: 57
evo ako nekom zatreba tu ima poprilicno puno configa za download http://www.gamerconfigs.com/ .preporucam cfg od eksora
BlackZ0r je offline   Reply With Quote
Staro 13.08.2010., 13:41   #5439
trpi
preporucite neki config za grafiku. ovo gore od eksora kolko vidim mijenja key configuration a ne zelim to dakle samo grafiku odnosno povecanje fpsa. probah yitch3 http://bashandslash.com/index.php?It...tent&task=view ali me izbacuje sa nekih servera kad ga upalim, pocne pistat i crvenim slovima prek ekrana set max packets to 100 i jos 2-3 stvari... inace imam 6600gt i igram na 800 600 low sa 50ak fpsa, sasvim solidno, zelja mi je 1680 1050 sa isto toliko fpsa, mislim da bi mi yitch3 to omogucio al eto steka...
Staro 13.08.2010., 14:39   #5440
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
Ja se na prvim fps-ovim nisam nikako mogao priviknut na WASD i probao sam isto podesit kontrole ko i kolega Lak, ali ipak to nije bilo to. Kasnije kad sam se sve više i više privikavao na WASD, i sad kad gledam njegove postavke, vjerojatno bi morao gledat i tipkovnicu i monitor da bi se mogao normalno kretat.
sinisa1989 je online   Reply With Quote
Staro 13.08.2010., 15:24   #5441
perich
I hate mondays..........
perich's Avatar
Datum registracije: Nov 2002
Lokacija: Zagreb - Zaprešić
Postovi: 1,534
aj da ja sad pitam, kako vratit fps postavke na default? bio sam lockao na 250, sve je radilo fino al sad mi se u zadnje vrijeme pocelo mrznut a i zna me izbacit sa pojedinih servera.... pa bi htio vratit kako je bilo nakon instalacije...
kako, budisa, kako kako?
perich je offline   Reply With Quote
Staro 13.08.2010., 15:26   #5442
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Stavl lock na 125, ili mislim da potpuno maknes komandu onda "0", ili je to za neku drugu igru
xGAME je offline   Reply With Quote
Staro 13.08.2010., 18:50   #5443
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
Po defaultu je 85, odnosno 91.
Staro 14.08.2010., 02:00   #5444
robert7
robert7's Avatar
Postovi: 1,708
u konzolu /com_maxfps 91
ali to ne stvara tebi problem, odnosno nemoze tebi fps cap smrznuti kompjuter i slicno, jer tvoje racunalo postize maximum fpsa, a ti mozes samo zakljucati to na stabilniju brojku da ti se ne dogada prevelika oscilacija i ne javlja graphic lag
problem smrzavanja sigurno ne lezi u toj naredbi tako da dobro jos razmisli di bi te i sta moglo muciti
Staro 14.08.2010., 10:28   #5445
BlackZ0r
Lokacija: Poreč
Postovi: 57
Autor trpi Pregled postova
pa samo promijenis controle kao sto ti imas a taj cfg yitch je star jos od 2008 tako da i nije nes meni imo sam ga davno,a od eksa je jako dobar,meci se dosta ljepe i fps nije los..
Staro 14.08.2010., 13:47   #5446
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Ajd nabaci link na taj eksov konfig... men se neda trazit dugo, u 5 min nisam nista nasao
Evo u 6. min naso na onom gore linku http://www.gamerconfigs.com/configs/eksor
Predobar config... 125FPS-a na 8600GT s dual core celerom na 2.66.. i to na FULL HD
I nije uopce losa grafika.. Bolja neg na def cfg
Zadnje izmijenjeno od: Campeonato. 14.08.2010. u 13:54.
Staro 14.08.2010., 19:06   #5447
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 414
Autor perich Pregled postova
gdje si vec instalirao -> Call of Duty 4 - Modern Warfare -> Players -> Profiles -> perich (ili kako ti se vec zove character)
Tu ti se nalazi config_mp.cfg datoteka.
Izbrises ju (zapravo maknes/backupiras negdje za svaki slucaj).
Kada pokrenes igru sve ce ti biti resetirano kao nakon instalacije (graficke postavke i kontrole) i stvorit ce se novi config_mp.cfg.
Ponovo sve podesis i to je to.
NAPOMENA: config_mp.cfg si spremi negdje za backup prije nego ga pobrises iz gore navedenog foldera.
Tumor je offline   Reply With Quote
Staro 14.08.2010., 19:56   #5448
keyser_s()ze
Postovi: 589
jump-enter
crouch-desni shift
prone-desni ctrl
nade-delete
reload-end
lijevi lean-insert
desni lean-page up
use-home
nož-scroll klik
omfg, najjači kupus ikad.
p.s. upravo ponovno instaliran đuka (sa svim modovima
keyser_s()ze je offline   Reply With Quote
Staro 14.08.2010., 23:27   #5449
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
Autor Campeonato Pregled postova
Stvarno nije loš config. Sviđa mi se. Samo ću još nešto posložit kak meni odgovara.
Staro 16.08.2010., 17:41   #5450
Mato_Ivanovac
di sam ja tu je i nevolja
Mato_Ivanovac's Avatar
Postovi: 19
COD 4 rank vratio se na 1 a bio na 22
Evo ovako danas sam kupio još 1 disk od 640gb i sada imam 2x WD Black 32mb 640gb no igram cod4 mp već par tjedana i došao sam do 22 ranka i prebacio podatke potrebne na disk od 320gb prenosni i formatiro disk di je bio win i stavio ih u raid0 i stavim nove winse sve instaliram kad ono rank mi 1 kako da se vratim na 22 rank? HVALA!
http://forum.pcekspert.com/faq.php?faq=new_faq_item#faq_faq_osnovna_pravila
Mato_Ivanovac je offline   Reply With Quote
Staro 16.08.2010., 17:54   #5451
jucca
jucca's Avatar
Postovi: 1,689
Jesi probao kontaktirat korisnicku sluzbu?
Staro 16.08.2010., 17:57   #5452
Mato_Ivanovac
Postovi: 19
Autor jucca Pregled postova
Ni oni neznaju zašto je to tako,a original igra kupio ju prije mjesec dana pa sam ju našao nedavno pa da zaigram došao do 22 ranka i sad sve na 1.
Staro 16.08.2010., 17:58   #5453
jucca
jucca's Avatar
Postovi: 1,689
Jesi igrao na privat serverima?
Staro 16.08.2010., 18:05   #5454
Mato_Ivanovac
Postovi: 19
Igram na serveru
[=tRt=] TARRGET RUSH TEAM ||HC||TDM||No FF :::: RPG ONLY FOR HELI NO Marty , GL , Last Stand , Jugger !!!
213.202.106.145:28960
HRV server,igram preko xFirea,znam nekad otić na javne servere.
Staro 16.08.2010., 18:07   #5455
jucca
jucca's Avatar
Postovi: 1,689
Ako se dobro sjecam (ne igram COD) bo je hack na nekim privat serverima na kojima su ljudima resetirali statse. E sad jel to to, ne znam, proguglao sam malo tvoj problem i ima raznih misljenja. Sorry ako nisam uspio pomoc
Staro 16.08.2010., 18:16   #5456
Mato_Ivanovac
Postovi: 19
Prvi put čujem za taj hack,a jel ima išta šta bi mi moglo vratit na rank 22? gledao sam te hackove i tak to stavi na 55 i probao na nekom stranom serveru i dobio ban odma,pa me zanima dal ima šta legalno da me vrati na 22 rank.
Staro 16.08.2010., 18:43   #5457
RS_BuRnOuT
RS_BuRnOuT's Avatar
Lokacija: Kž\Vž
Postovi: 458
Autor Mato_Ivanovac Pregled postova
Bok, ako sam dobro shvatio, ti si prebacio "profil" iz COD4 na neki drugi HDD te ih opet iskopirao nazad nakon reinstaliranja Windowsa i nove instalacije igre?
Ne znam kako se ponovno vracaju ti korisnicki podaci da nastavis dalje.
Takoder sam nedavno dodao novi HDD u komp i njega stavio za sistemca, iskopirao sam profil no nije mi povuklo i rankove pa igram ispocetka.
Nisam istrazivao kako se vracaju rankovi nakon reinstaliranja ali zato cuvam staru instalaciju na onom starom HDD-u za danas sutra.
Ne vjerujem bas da je do nekog hacka jer se nitko na serveru nije bunio da su mu se rankovi resetirali sami od sebe.
Prije nekoliko tjedana na serveru je bio instaliran mod sa power rankom tj. sa lvl 1 se prelazi na lvl 55 nakon jedne runde.
Sad je mod ugasen i oni rankovi koje sam imao do igranja moda mi se nastavljaju.
Pozz
RS_BuRnOuT je offline   Reply With Quote
Staro 16.08.2010., 19:36   #5458
Mato_Ivanovac
Postovi: 19
Autor RS_BuRnOuT Pregled postova
Pozz
Evo ovako prebacio sam bitne podatke,igre,pjesme,filmove slike programe i tako to,no nisam nikakve profile od COD i takvih igara prebacivao,igram preko xFirea jer su svi frendovi na njemu,i mislio sam da mi to ostaje sve na profilu od xFirea i fino formatiram diskove i stavim u raid0 i stavim windows 7 na 250gb particiju i windows xp 120gb i instaliram sve potrebno i cod4 i odem na server igrat kad mi je rank 1 a bio 22 i sad me pati kako da ga vratim.
Staro 16.08.2010., 21:02   #5459
weaponx
weaponx's Avatar
Datum registracije: Jul 2009
Lokacija: Skyrim
Postovi: 329
Ništa ti ne ostaje na xfire-u. Tvoj korisnički profil se po defaultu sprema u "Call of Duty 4 - Modern Warfare\players\profiles". Ako nisi sačuvao sadržaj te mape onda ti nema druge nego krenuti ponovno od prvog lv.
Lijepo je biti važan, ali je važnije biti lijep.
weaponx je offline   Reply With Quote
Staro 16.08.2010., 21:35   #5460
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
Nije bitan samo sadržaj mape profil, bitno je da koristiš isti key. Jer ako ti npr. prebaciš igru na drugi disk/reinstaliraš OS/napraviš nešto treće, bitno je da si sačuvaš mpdata i opet upišeš isti key. Inače ljudi koji igraju sa piratskom kopijom vrlo često zaborava key pa ne mogu vratit rankove.
BTW. team o CoD 4 postoji, mogao si tamo postavit pitanje.
