#271 |
Datum registracije: Jun 2010
Postovi: 23
Ja sam imal samo sfrkane žice, znači bez utičnice, sad sam ih zalemil al nisam ništ dobil. |
#272 |
Postovi: 49
Koliko sam skužio iz gore navedene tablice moja parica nije loša, samo ne znam zašto je SN Margin down toliko manji? Svejedno ću pitati Mudrace ![]() ![]() Anybody ![]() Zadnje izmijenjeno od: serke. 23.06.2010. u 15:19. |
#274 |
Postovi: 23,510
Općenito CRC error je greška kontrolnog zbroja a kod adsl - a evo par tumačenja / primjera: What causes CRC errors? adsl crc errors, whats normal? |
#275 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Lokacija: Slavonija
Postovi: 37
Line Coding: | Trellis On | Status: | No Defect | Link Power State: | L0 | | | Downstream | Upstream | SNR Margin (dB): | 11.2 | 11.9 | Attenuation (dB): | 26.0 | 14.9 | Output Power (dBm): | -2.0 | 6543.6 | 20344 | 1603 | Rate (Kbps): | 4703 | 316 | 59 | 16 | 146 | 14 | 1 | 1 | 1 | 2 | 0 | 16 | 0.9932 | 1.4675 | 1184 | 169 | 1 | 1 | 0 | 0 | | Super Frames: | 225082 | 225080 | Super Frame Errors: | 24 | 2117 | RS Words: | 0 | 15305440 | RS Correctable Errors: | 0 | 33865 | RS Uncorrectable Errors: | 0 | N/A | | HEC Errors: | 17 | 25802 | OCD Errors: | 0 | 0 | LCD Errors: | 0 | 0 | Total Cells: | 241652269 | 3176839105 | Data Cells: | 4895041 | 92276707 | Bit Errors: | 0 | 2053739 | | Total ES: | 351 | 546 | Total SES: | 33 | 280 | Total UAS: | 61 | 4381234 | |
Mode: | ADSL2+ | |
Line Coding: | Trellis On | |
Status: | No Defect | |
20344 | 1603 | |
59 | 16 | |
146 | 14 | |
1 | 1 | |
1 | 2 | |
0 | 16 | |
0.9932 | 1.4675 | |
1184 | 169 | |
1 | 1 | |
0 | 0 | |
#276 | |
Lokacija: Dbk
Postovi: 1,260
#277 |
MPower
Lokacija: Zabok, Zagorje
Postovi: 100
Link Information Uptime: 12 days, 1:10:14 Modulation: G.992.5 annex B Bandwidth (Up/Down) [kbps/kbps]: 315 / 4.703 Data Transferred (Sent/Received) [MB/MB]: 2,39 / 14,98 Output Power (Up/Down) [dBm]: -1,0 / 0,0 Line Attenuation (Up/Down) [dB]: 22,5 / 36,5 SN Margin (Up/Down) [dB]: 17,5 / 12,5 Vendor ID (Local/Remote): TMMB / IFTN Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): 0 Error Seconds (Local/Remote): 0 / 0 FEC Errors (Up/Down): 0 / 0 CRC Errors (Up/Down): 0 / 52 HEC Errors (Up/Down): 0 / 24 Kolko bi se dalo s tom na max? Pošto mi nigdje ne piše.. I kako natjerati ove u t-comu da povuku nove žice? |
#278 |
Lokacija: Vt
Postovi: 18
Zadnje izmijenjeno od: Hellgion. 22.07.2010. u 05:18. |
#279 |
Lokacija: Zagorje
Postovi: 19
jel ima kakve veze ak je od splittera do routera 15m kabla? |
#281 |
Lokacija: Zagorje
Postovi: 19
#282 |
Postovi: 12,607
Moze procjena kvalitete linije kod mene? SNR Margin (dB):..........15.6 19.0 Attenuation (dB):.........21.0 10.0 Output Power (dBm):....20.3 12.3
#284 |
Postovi: 12,607
Hvala nikky, treba editirat 1. post pa ubacit ovo gore jer sam gledao pocetak samo. Kako vidim, linija je cisto u redu, osim sto mi odskace Output Power (dBm):....20.3
#286 |
Lokacija: Zagorje
Postovi: 19
imam pitanje,propusnost parice mi je 2178kbps,trenutno imam stavljen softverski paket od 1mbit,da nazovem t-com i kažem da mi stave 2mbit,jel bi se spojilo onda na nekih 1.6 - 1.7 mbps,hvala |
#288 |
Lokacija: Zagorje
Postovi: 19
sad sam opet očitao propusnost,trenutno je 2560kbps,pa valjda nebi pucala veza,jel mogu to oni odmah promjeniti? |
#290 |
Datum registracije: Dec 2009
Lokacija: *
Postovi: 118
nazvao sam 0800 900,i prijavio kvar,čekam tehničara da nazove,btw ovo mi je profil no.1 |
#291 |
Lokacija: Zagorje
Postovi: 19
Zadnje izmijenjeno od: norecx. 13.08.2010. u 23:25. |
#292 |
Lokacija: Zagorje
Postovi: 19
neki dan su mi opet vratili na staro,rekli su da je to automatski prebačeno zbog velikog broja alarma na liniji???no ipak su opet prebacili na 2mbit,al neželim da opet vrate |
#293 | ||
Lokacija: .com
Postovi: 519
Tvoja linija poprilično oscilira po pitanju propusnosti i najvjerojatnije ostalih čimbenika koji utječu na liniju. Bakrene parice, loša infrastruktura, bla bla, podložno vremenskim uvjetima, bla bla...znači nije stabilno i zato se desi da ti je propusnost u jednom trenu 2000kbps, u drugom 2500kbps, u trećem 1800kbps...i onda se linija ruši, puca. Pogledaj u thread "Upute za rješavanja problema sa ISP-om" i probaj napraviti sve što smo spomenuli. Kreni od svoje kućne instalacije te zatim prijavi kvar u T-com da pošalju nekoga da pogleda gdje dolazi do problema. Ovisno koliko si udaljen od centrale. Ako si u mjestu koje je jako udaljeno od centrale ili je jednostavno loša mreža, objasniti će ti da veću brzinu nisu u stanju isporučiti i to je to, ali tad ćeš bar konkretno znati ![]() Svakako javi što se i kako riješilo ![]() |
#294 |
Lokacija: *
Postovi: 118
izmjenio sam kabel u kući i sad mi se stabilno spaja na 2016kbps i tako već par dana ![]() |
#298 | ||
√uメ丂
Lokacija: WrboWec - paradise city
Postovi: 8
-ako imas vise telefona..koristi samo JEDAN splitter..iz njeg spoji ostale telefone..a ne na svaku uticnicu splitter.. ako imas kucu..onda ufrci spojeve..ako si u zgradi..zamoli tehnicara da ti makne spoj s reglete i da ga ufrce.. Citiraj:
lemiti na router ŽICU..wtf..pa to je parica..a konektori na par milimetara..pa kaj da ti to neki stroj zalemi... tocno to ![]() jedino ak imas dobrog tehnicara pa pozove montere da promjene barem jednu supljinu kabla ili promijene paricu u zracnom kablu..ali da dobijes novu mrezu..nikada..pa cak ni' onda.. |
#300 |
Lokacija: Zagorje
Postovi: 19
da li postoji t-comov glavni tehnicar u zagrebu,da ne moram razgovarati s ovim iz zaboka? |
