Staro 30.07.2010., 01:05   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
RadeonPro BETA -- CCC and CrossFire-X profile manager
RadeonPro is a free utility to automate Catalyst Profiles to be applied upon user's game or application start.
Just setup 3D settings for each game and have all those settings applied automatically everytime you play!
No more desktop or keyboard shortcurts to remember, create it once, play it the way it's meant to be!
http://www.radeonpro.info/
http://forums.guru3d.com/showthread.php?t=322031
You'll need Microsoft Visual C++ 2008 Runtime and Microsoft .NET Framework 2.0. If you have Catalyst Control Center installed they're already on your system.
Staro 30.07.2010., 07:58   #2
ivan77
THNX majstore , baš sam ovo tražio!
jedino je bed kaj ja ne vidim opciju za kontrolu venta? Ili je nema?
Zadnje izmijenjeno od: ivan77. 30.07.2010. u 12:10. Razlog: ..
Staro 19.08.2010., 23:32   #3
Jelc
Super Moderators
Postovi: 17,485
08/19/2010 - New build 1.0.8.0
- New: individual profiles can now be temporarily disabled, the program will warn the user when an existing profile have been skipped processing
- New: launcher based (Steam, Games for Windows Live) games now can be forced to use another Anti-Aliasing or CrossfireX profile (OpenGL is not supported yet)
- New: the error reporting dialog now sends (whenever possible) a detailed trace of internal application actions sequence for better error tracking and fixing
- Fixed: launching an URL may fail on some systems
- Fixed: the program may enter in an infinite load-unload loop if an error occurs in main window initialization and no skin is being used
- Fixed: if main mutex cannot be created the program may fail silently
- Fixed: if an instance of the program is already running and the program is started again, the program may fail silently if an IPC communication channel cannot be opened
- Changed: HD 2000/3000/4000 Series now shows correct Adaptive Anti-Aliasing modes, Performance and Quality instead of Multisampling and Supersampling used by HD 5000 Series
- Changed: the program window doesn't flash anymore at startup when it's configured to start mimized
- Changed: the online error reporting dialog don't report errors anymore for older builds than the current one to avoid reporting errors already fixed by latest build (the program will inform the user to update the program)
- Changed: small tweaks to the Add New Profile Wizard
- Changed: JumpLists now show a bullet near the active monitoring option to indicate current status
- Changed: LOD adjustment now can be set to zero to enforce negative LOD clamp (previous builds ignores LOD=0 by removing the entry from registry to emulate driver defaults when LOD is not set)
Staro 06.09.2010., 23:25   #4
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,932
Dobar programčić. Puno lakše upravljat profilima nego iz CCC-a. Pregledan i jednostavan.
Samo što sam primjetio da se "kolje" sa nekim programima. Npr. Xfire-om. CoD 4 izbacuje grešku vezanu za xfire. Dok je ugašen igra radi, ali onda mutavi PB izbacuje radi "disallowed program/drivers". Još ga nisam uspio isprobat na ostalim igrama. Valjda će to popravit.
sinisa1989 je online   Reply With Quote
Staro 22.09.2010., 14:02   #5
Jelc
Super Moderators
Postovi: 17,485
Latest updates
Updates
09/21/2010 - New build 1.0.9.1
- Fixed: Forced vsync off not being saved correctly with all skins except Verde
Updates
09/21/2010 - New build 1.0.9.0
- Fixed: "index_damaged" message is displayed when trying to start a game with some special characters present in path (i.e. Kane & Lynch, Command & Conquer)
- Fixed: Steam no longer crashes if RadeonPro is finished and Steam is kept running
- Fixed: random hiccups while scrolling pages or doing non related game tasks
- Fixed: profiles backup feature not saving launcher settings
- Fixed: program crash with Windows XP and .NET Framework 2.0 pre-SP2 due to a missing overloaded method [System.Threading.WaitOne(bool)]. If you got that error message, you should keep updated your operating system!
- Fixed: restore option restoring all items instead of only checked items
- Fixed: Monitoring option at tray icon context-menu don't change state
- Changed: introduced new fail counter measures to avoid broken profiles due to unexpected program crashes
- Changed: Global profiles are saved in a separated profile so they don't get messed by processes that don't terminate correctly
- Changed: must check for main program's updates before downloading new skins
- Changed: revamped FPS display and screenshot grabber engine with high-quality real time image resizer (Direct3D 8/9/10/11 are supported now, OpenGL support will be introduced in a future build)
- Changed: RadeonPro Support Service is now started on demand
- Changed: when a profile has a launcher defined and the game is started by RadeonPro through the Play option in Profiles' list context menu, the launcher is executed now instead of profile target executable
- Changed: due to the way pressed keys are checked by the FPS/Screnshot engine, modifier support (Shift, Alt, Control) keys has been dropped. If your hotkeys stop working and you are using modifiers, please change them in settings and remove the modifier key
- Changed: backup/restore items are now alphabetically sorted
- New: update dialog now have an option to show the changelog before the download of updates
- New: Benchmark feature
- New: screenshot grabber engine can resize screenshots in real-time
- New: screenshot grabber engine can insert an image overlay over the screenshot at a pre-defined image corner and position
- New: FPS number overlay can be hidden from screenshots
- New: video spoof feature is now available also on Direct3D 8/10/10.1/11 (previously was supported only on Direct3D 9)
- New: forced triple-buffering and/or forced vsync on/off can now be used with games that don't have a profile defined (e.g. any Direct3D 8/9/10/11 application)
- New: forced vsync on allows the activation of a new feature: Double Vsync, which limits the framerate to half of the current refresh rate (i.e. 60 Hz LCD displays will limit framerate to 30 FPS instead of 60 FPS). Works only with full-screen games, windowed games will use normal vsync
- New: FPS display, screenshot grabber, video spoof feature and forced display refresh rate can be used with games that don't have a profile defined (e.g. any Direct3D 8/9/10/11 application)
- New: display refresh rate can be specified as part of profile or global settings (experimental feature, please report if it worked for you)
- Removed: Start with Skin shortcut from JumpLists
--- Verde
---- New: added shortcut to Launcher Settings in Anti-Aliasing/CrossfireX settings page
---- Fixed: LOD adjustment is not being saved
Download: http://www.radeonpro.info/Download.aspx
Or use program's Check for updates link
Staro 15.05.2011., 23:00   #6
nathan
IT Consultant
nathan's Avatar
Lokacija: Geneva, Petit-Lancy / Zagreb , Dubrava
Postovi: 323
Progam je jos malo napredovao, nadam se da ce se i broj igara povecavati s vremenom
"All we have to decide is what to do with the time that is given us" J.R.R. Tolkien
nathan je offline   Reply With Quote
