Staro 01.07.2010., 12:01   #1
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Nvidia GeForce GTX 460
Što god mi govorili o neisplativosti, bez sumnje će se prodavati.
230$ = 230€ ~ 1850 kod naših trgovaca. Hlađenje je interesantno, nešto slično smo vidjeli na GTX295 single pcb gdje je ovaj ventilator u sredini bio mnogo tiši nego turbina na kraju
Cjenovno konkurent HD5830, performansama vrlo vjerojatno HD5770.
Info:
Here are the first pictures of NVIDIA's GeForce GTX 460 graphics card, an upper-mainstream model based on the company's new GF104 GPU which was pictured earlier. The pictures reveal the reference design card to be shorter than any of the GF100-based graphics cards (such as GTX 470, GTX 480), and compacted in many ways. The cooler is dual-slot, and instead of an air-channel that's draws air from the interior and blows it out from the rear, the cooler has a centrally-located fan right over the GPU. As expected from the older article, the GPU package indeed is rectangular in shape rather than square.
The PCB is black, though a green PCB cannot be written off given the product's positioning. There are traces for eight memory chips on the card (looking at the components on the reverse-side of the PCB), confirming a 256-bit wide memory interface, though six chips are occupied (indicating that for this SKU only, a 192-bit wide memory interface is used. There is only one SLI finger showing that it only supports 2-way SLI multi-GPU standard. Connectivity on the rear panel is consists of the usual 2x DVI-D and mini-HDMI. Power is drawn in by two 6-pin PCI-E power inputs. Other specifications include DirectX 11 compliance, 336 CUDA cores, 768 MB of 192-bit GDDR5 memory (or another SKU with 1 GB of 256-bit GDDR5 memory), and clock speeds of 675 MHz core, 1350 MHz shader (CUDA cores), and 900 MHz (or 3600 MHz effective) memory. The GTX 460 768 MB is expected to launch next month at a price of US $230.
TechPowerUp!
The much talked about upcoming GeForce GTX 460 GPU from NVIDIA was recently pictured and detailed. Out of its first, grainy pictures, it became clear that the GF104 core it's based on indeed supports a 256-bit wide GDDR5 memory interface, but that only six of its eight 32-bit wide channels were occupied (192-bit), yielding 768 MB of memory. Fresh reports suggest that NVIDIA indeed will release the GeForce GTX 460 in two variants, a 768 MB one, and a 1024 MB (1 GB). The 1 GB variant by design will be faster, even if an application doesn't need all its video memory, because it will have a wider 256-bit memory interface, that's 25% higher memory bandwidth. Both variants will have the same memory clock speed of 900 MHz (3600 MHz effective). The GF104 core will be clocked at 675 MHz on both models, with 336 CUDA cores. Built on the 40 nm process at TSMC, the GeForce GTX 460 768 MB will have a TDP of 150W, while the 1 GB model will have a TDP of 160W. New reports suggest that the 768 MB model will be priced at less than $200. NVIDIA will release the GeForce GTX 460 on the 12th of July.
TechPowerUp!
GeForce GTX 460 Pricing Surfaces, Gets Listed in EU
With its launch reportedly scheduled for 12th July, certain European etailers just can't resist listing it on their sites to pool in prospective buyers or pre-orders. Price aggregator Geizhals.at compiled a list of stores that have already listed the ASUS GeForce GTX 460 768MB (part number 90-C3CHB0-P0UAY0KZ). Prices of this part range start at 204.51 EUR. Another source reports that NVIDIA is targeting the US $199 price point with the GeForce GTX 460 768MB variant, and $229 price point with the 1 GB variant. The 25% more higher memory amount isn't the only thing that warrants the $30 increase in price, the 1 GB variant also has 25% higher memory bandwidth.
The GeForce GTX 460 is NVIDIA's latest product in the making, it is based the new GF104 core, that packs 336 CUDA cores, 256-bit GDDR5 memory interface (192-bit on the 768 MB variant), and has all the features of the GeForce 400 series, including advanced tessellation, DirectX 11, CUDA, PhysX, and 3D Vision Surround.
TechPowerUp!
P.S. Moderatori, ako krši neka pravila molim na PM.
Zadnje izmijenjeno od: fran123456. 07.07.2010. u 09:49.
fran123456 je offline   Reply With Quote
Staro 01.07.2010., 12:25   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
1800 kn za nesto performansama jednako 5770 ? hell yeah, cepaj me bato dok mozes.Za te pare ubodes 5850. Hvala, ali ne hvala.
Staro 01.07.2010., 13:13   #3
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,744
Mislim da će prije biti 230$x10=2300 kuna, a ima performanse kao i kartica od 1100 kuna. LOL
Staro 01.07.2010., 13:14   #4
Postovi: 34,066
Za cijenu 5830 dobiješ snagu 5770 i potrošnju 5850? Full isplativo (kao i sve druge GTX4xx). LOLčina
Staro 01.07.2010., 17:35   #5
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
470 gtx i nije nesto neisplativa, performanse priblizne hd5870 za nesto manju cijenu. ok trosi vise, ali 50w i nije tako bitno u toj klasi kartica tbh. Inace jel ima gdje test te 460gtx kad je usporedjujete sa hd5770? Vidim da su ju na expreviewu nafrljili u nebesa, ali nikakvih testova nema.
tole_ je offline   Reply With Quote
Staro 01.07.2010., 17:44   #6
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Autor tole_ Pregled postova
Pročitaj tekst gore još jednom.
Nije još izašla.
Staro 01.07.2010., 17:55   #7
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Definitivno je ATi u velikoj prednosti što se tiče DX11! Gube bitku u svim klasama, a ako ovako nastave niske i srednje niske klase su im također poražene. Bolje se moraju pripremiti za novu seriju.
Zadnje izmijenjeno od: ivand123. 06.07.2010. u 11:34.
ivand123 je offline   Reply With Quote
Staro 01.07.2010., 17:59   #8
tole_
Casual Racist
tole_'s Avatar
Postovi: 422
Autor fran123456 Pregled postova
Nije još izašla.
Pretpostavio sam da imaju neki leakani rezultati kako to obicno biva kada se blizi datum izlaska, a pretpostavka je potpomognuta vasim tvrdnjama da je kartica ista kao 5770.
Staro 01.07.2010., 23:15   #9
Maki2
Maki2's Avatar
Datum registracije: Feb 2010
Postovi: 5
Zadnje izmijenjeno od: Jelc. 02.07.2010. u 00:22. Razlog: dupli postovi
Maki2 je offline   Reply With Quote
Staro 06.07.2010., 08:51   #10
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 432
ASUS GTX460 = 204,64€
ASUS HD5770 = 160,54€
ASUS HD5830 = 255,20€
Po ovome bi GTX460 trebala cijenom biti negdje tocno izmedju HD5770 i HD5830.
Po predvidjanjima koja sam citao trebala bi po performansama biti negdje oko HD5830. Jos tjedan dana, pa cemo vidjeti.
Tumor je offline   Reply With Quote
Staro 08.07.2010., 12:39   #11
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,717
Bono je online   Reply With Quote
Staro 09.07.2010., 21:56   #12
gusta
gusta's Avatar
Datum registracije: Jun 2010
Postovi: 35
Autor xulos Pregled postova
ne dopada se niti meni niti cijena niti perfomanse-ati je u velikoj prednosti u bilo kojem segmentu pričali-vidjet ćemo ali nekak sumnjam da će se u dogledno vrijeme nekaj pozitivno dogodit pa da 460 postane isplativa kupnja i ne samo ona nego cijela ergela nvidije!
gusta je offline   Reply With Quote
Staro 09.07.2010., 23:43   #13
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Ako bude 200 eura kod nas, a jaca od 5830 onda ce to bit ok kupnja.
Staro 11.07.2010., 10:12   #14
Tumor
Tumor's Avatar
Postovi: 432
Palit GTX460 Sonic Platinium
Tvornicki overclockana na 800/1000 i to jaca verzija sa 256-bitnom sabirnicom.
Ovo bi mogla jedna zanimljiva kartica s obzirom na poprilican tvornicki overclock.
Staro 11.07.2010., 10:34   #15
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Sta sad vise ni jedan model kartice nije isti, aj sto mjenjaju klokove , al sad je svaki proizvodac poceo i svoju sabirnicu stavljati ?
Staro 11.07.2010., 12:00   #16
Maki2
Maki2's Avatar
Postovi: 5
Biti ce dvije GTX 460, jedna sa 768 MB i 192 bit a druga 1GB i 256 bit.
Staro 11.07.2010., 12:16   #17
extremepc
Datum registracije: May 2009
Lokacija: Okolica Zagreba
Postovi: 306
Bojim se da ce kod nas cijena biti oko 1600kn...
E da je 1300 uzeo bih odmah novu, a za 1400 bi još razmislio
Ako ništ drugo bumo jos cekali....jer i dalje je jedna gtx260 dovoljna za fino igranje...
extremepc je offline   Reply With Quote
Staro 12.07.2010., 08:40   #18
Tumor
Tumor's Avatar
Postovi: 432
Evo i review raznih verzija GTX460.
Dosta njih su tvornicki overclockani modeli
http://www.guru3d.com/article/geforce-gtx-460-review/1
IMHO, odlicna kartica za tu cijenu.
Naravno, cijenu vani jer ce kod nas trgovci sigurno napucati cijene u nebo.
Staro 12.07.2010., 09:37   #19
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
Konačno je Nvidia izbacila poštenu grafu. Sve ovisi kak bu bila cijena kod nas. Možda budu konačno pale cijene grafi.
gtx460 review, hardOCP
MAGARAC je online   Reply With Quote
Staro 12.07.2010., 09:56   #20
tole_
Casual Racist
tole_'s Avatar
Postovi: 422
Fenomenalna kartica. Ne samo da nije jednaka kao 5770 nego do nogu potuce 5830, a ova Palitova izvedba bome ulazi u domenu 470gtx za osjetno manju cijenu (vani). Bravo nvidia, napokon prava stvar. Ne mogu vjerovati da to malo cudo moze biti tako dobro, a tek monstruozni OC potencijal, pfff Sad se postavlja pitanje, koja je svha 465gtx? Po svemu vidjenom ta kartica nije za nista drugo vec za EOL
Kako god bilo, ovo su prvi znaci da mozemo uskoro ocekivati jeftinije kartice
Staro 12.07.2010., 10:29   #21
Nybelung
Autor Tumor Pregled postova
Palit Sonic Platinum izgleda fenomenalno.
A ni ostale ne zaostaju puno, i također se daju clockati u nebesa.
Staro 12.07.2010., 10:53   #22
Shaka111
Shaka111's Avatar
Postovi: 650
5770 killa,aber naturlich...
Shaka111 je offline   Reply With Quote
Staro 12.07.2010., 11:13   #23
extremepc
Postovi: 306
Amere 1GB model sa dostavom izađe 1250kn : ((((
A kod nas nema ikakve šanse da cijena bude manja od 1500kn bez dostave : ((
Staro 12.07.2010., 11:28   #24
Nybelung
Autor Shaka111 Pregled postova
Vjerojatno ne, ATi će opet posegnuti za svojim najjačim oružjem: rezanjem cijena.
Blagoslovio Bog konkurenciju.
Staro 12.07.2010., 11:37   #25
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
Autor extremepc Pregled postova
Bliže 2000
Staro 12.07.2010., 11:44   #26
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Sto se mene tice kad dodje prvu bi uzeo ovu cyclone MSI 1 gb , njhove grafe su uvjek bilo dobro hladjene i imale dobar OC potencijal ( kao i u ovom linku. msi je imala najveci oc potencijal) , al ako bude preko 1500 kn jebg...
Staro 12.07.2010., 12:57   #27
blue#13
Postovi: 516
jos da nvidia spusti cijene ostalim grafama,koja bi pomutnja nastala ...
blue#13 je offline   Reply With Quote
Staro 12.07.2010., 13:18   #28
extremepc
Postovi: 306
http://www.youtube.com/watch?v=cUgCzNN46Y8
Simpatična kartica i simpatičan video
Staro 12.07.2010., 13:48   #29
aard
aard's Avatar
Datum registracije: Jul 2009
Lokacija: Zaprešić
Postovi: 120
Ako to kod nas bude ispod 1800 kn, ja sam jazavac
Other than that, cini se kao (napokon) dobra kartica
aard je offline   Reply With Quote
Staro 12.07.2010., 15:00   #30
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Konačno su nešto dobro napravili, grdo puše za vrat 5850. Moglo bi biti nekog rezanja cijena.
d4rk_ch1ld je offline   Reply With Quote
