Staro 06.07.2010., 15:50   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Powercolor introduces the Power Jack
Eh
Ja osobno rabim drvene štapiće za ražnjiće ali ko voli nek izvoli
TUL Corporation, a leading manufacturer of AMD graphics cards, today announced a professional graphics interface card supporter: the PowerColor PowerJack. As high-end graphics are becoming more powerful, the sizes are increasing as well as their weight. This poses a problem that gamers may not know they had. Owners of high-end graphics may be able to attest to the problem of the weight of the card bending in the case. A couple screws and the motherboard may not be enough to hold the heavier cards in place anymore.
This is where the PowerColor PowerJack comes in. The PowerJack supports the weight of the card from the back where it’s most needed. With its multistage extension function, it can extend its height from 61.25 mm up to 150 mm and it’s applicable to E-ATX / ATX / M-ATX motherboards and can be used in full tower, mid tower & mini tower chassis.
Staro 06.07.2010., 15:58   #2
syss
syss's Avatar
Postovi: 10,805
ne znam jel da se smijem ili plačem.
jeeeez
Staro 06.07.2010., 15:59   #3
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
Hahah, prestrašno.
Ovo bi trebao biti veliki žuti uskličnik momcima iz nevidije i amda da ne pretjeruju sa veličinama grafa.
Već vidim uskoro u reviewima:
Plusevi: yada yada yada
Minusi: bundle ne sadrži pouverđek
Spoiler alert!
Staro 06.07.2010., 16:13   #4
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Djeluje korisno iako ja nemam potrebe za tim. Stvarno neznam kako se toga nisu prije sjetili jer sam vidio gro teških i velikih kartica koje su iskrivljene.
Kad bi ja imao neko čudovište (čitaj: skupo) od kartice nebi nikako dozvolio da pati tj. da se krivi.
ivand123 je offline   Reply With Quote
Staro 06.07.2010., 16:20   #5
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor ivand123 Pregled postova
Sva "ozbiljnija" kućišta imaju vodilice koji pomažu takvim stvarima, davno definirano, danas zaboravljeno u mainstreamu...
Igor Batinic
Staro 06.07.2010., 16:25   #6
Jelc
Super Moderators
Postovi: 17,485
Pa uvjek se može upotrijebiti nekaj multifunkcionalno...kao na primjer ovaj držač za gejpad-lako se pripaše i za držanje grafe a nije ni skup ko Power Jack
Staro 06.07.2010., 16:50   #7
ThePornstar
ThePornstar's Avatar
Postovi: 4,399
Kolika je cijena toga? Nemogu nigdje nać :/
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 06.07.2010., 17:19   #8
Baja 001
Baja 001's Avatar
Postovi: 7,504
KOlika je puno je.
Da nije smješno bilo bi žalosno, pogotovo ako budu ovo odvojeno gurali
Staro 06.07.2010., 18:01   #9
WraGG
WraGG's Avatar
Lokacija: Stuttgart
Postovi: 1,593
Da nebih ja sad ovo na S1 naslanjao....
Staro 06.07.2010., 18:32   #10
Red Dwarf
Bajker s AMD-om na dresu
Red Dwarf's Avatar
Postovi: 960
Makar ga nisu nazvali iHolder ili iCardsupporter fali im fensi ime...bolje da su otišli do veselog jabučnog steve i pitali ga za neko domišljato ime...
kladim se da bi se onda prodavao ko lud jer bi odjednom svima trebao
Red Dwarf je offline   Reply With Quote
Staro 06.07.2010., 19:26   #11
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Ja sam prosle godine (na ovom forumu) postavio pitanje o nosivosti pci-e utora, nikakvih pametnih / korisnih odgovora. Moja 4850 se nakon dodatka jaceg hladnjaka jako izvinula. Sada sam ju privezao za vrh kucista... Razmisljam o ovom Power jacku i vidim mu grdu manu - iznimno mala baza! Totalno neupotrebljivo za neki transport.
Opet, posve neupotrebljivo za nekakav CF/SLI ili ako imate jos kakvu dugacku / siroku karticu ispod svega.
Autor Old Iggy Pregled postova
Nekoc davno, jos prije 2005. bilo je kucista sa tim vodilicama. Sjecam se da ih je Theo Valich donosio u drustvo i pokazivao. Bila su to midi tower kucista, vodilice su se iznimno lako otvarale... No koliko se sjecam, osim bocnih vodilica bili su tu i drzaci za kartice koje imaju "rucku" na strani okrenutoj prema prednjoj maski kucista.
Nije mi jasno da cak ni kucista koja kostaju debelo preko 2000kn nemaju te vodilice... no to je vec za posve drugu temu.
Zadnje izmijenjeno od: Amepshi. 06.07.2010. u 19:32.
Staro 06.07.2010., 19:30   #12
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,142
Autor Jelc Pregled postova
ražnjiche
More bit da si ovo iz sprdnje stavio, ali meni stvar uopce nije losa. Ne sumnjam da ce biti 5x skuplje nego sto vredi, ali patim na balkoniranje dugih kartica.
Syss koristi teleskop metodu, ali meni je to predugacko :
Ima samo jednu jedinu manu : nema trajnu vezu s limarijom! Trebali su staviti na donju glavu jedan magnet, to bar nije problem. Mali magnet toliko da se fino stabilnije fiksira na podnicu. Mozda su Powercolorci to vec napravili?
Kucista koja imaju drzace kartica su obicno kompaktno napucana i ne svidja mi se raspored. Toliko puta sam iz HP serverije htio izvuci drzac pa ga dodati u svoja kucista, ali nikad mi se nije dalo. Pa seljoberski koristim obicnu kuhinjsku gumicu. Dehidrira taman za koji mjesec, kad je ionako usputno usisavanje kucista - pa dodam novu. Chobanska metoda priznajem ali radi posao. Zato mi ovo i nije tako odbojna stvar. Barem je estetski dojmljiv.
Staro 06.07.2010., 20:04   #13
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,484
stvar je ok, da je neka realna cijena toga do 30 kuna kupio bi ga
Ma da se može brzo složiti i neka alternativa
Staro 06.07.2010., 20:19   #14
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor Alister Pregled postova
Sićan se da je Domy OS imao štapić umisto toga
Naravno da se može složit alternativa, pa bar to nije kompleksno
Staro 06.07.2010., 20:47   #15
Jelc
Super Moderators
Postovi: 17,485
Da je nešto za jabučare-kobog bi se zvalo iKlocna
Staro 06.07.2010., 20:56   #16
Baja 001
Baja 001's Avatar
Postovi: 7,504
iMagicStick Pro je puno bolje ima, ima nešto profesionalno
Staro 06.07.2010., 21:05   #17
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 833
Pa ja stvarno ne kuzim.Jel nije lakse podmetnuti pod graficku nego narucivati iz kine tamo neki power jack
Zadnje izmijenjeno od: Jelc. 06.07.2010. u 21:17. Razlog: mda...
Staro 06.07.2010., 22:22   #18
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Jeltz-drzac, upotrebljava zena
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 06.07.2010., 22:46   #19
The AC
The AC's Avatar
Postovi: 1,147
no šalu na stranu, kada će izaći case modding verzija sa diodama?
Staro 06.07.2010., 22:57   #20
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,142
Autor The AC Pregled postova
Ljudi iz Powercolora jos mahom koriste godisnji ili dovrsavaju privatne projekte koje zbog posla nisu mogli dovrsiti. Zato i nisu Jelcu mogli formirati cijenu
Salu na stranu, ali uzimam dva komada cim se pojavi!
Staro 06.07.2010., 23:02   #21
Roby-V
Datum registracije: Jul 2009
Postovi: 175
i ja bih trebo jednu jer ultra visi ,,, sva se savinula vec
Zadnje izmijenjeno od: Roby-V. 07.07.2010. u 19:26.
Roby-V je offline   Reply With Quote
Staro 06.07.2010., 23:21   #22
The AC
The AC's Avatar
Postovi: 1,147
Autor Visage Pregled postova
a dobro, sada kada si pomaknuo šalu u stranu (pritom, nadam se, pazeći da ti ne padne sa klocna na nogu ) koliko bi bilo realno dati za to? 20kn max.! sve iznad toga je smiješno..
Staro 07.07.2010., 09:17   #23
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,142
...for a suggested $9.99 a few weeks later.
Znaci trebao bi dolaziti uz top P.Color modele djabalesku u kompletu, dok ce ostali moci kupiti (Cnet tvrdi) za spomenutu cifru. $10-20 mi se cini kao neki plafon prihvatljivog smisla naplate. Jedino se nadam, da se kod lijepo ne zaokruzi na 100 kn po komadu! Ipak su tu "silni manipulativni" troskovi i Power Joco more nagrabusiti kad predje nase vode
Datum sluzbenog pustanja jos nije stigao, ali ne vjerujem da ce biti znatno vise od ovih cijena.
Staro 07.07.2010., 16:39   #24
okarm
Postovi: 772
lol... ukrali su mi "patent"
ja vec 2 godine koristim podesavajucu nogicu za namjestaj... cijena u elgradu je oko 2 kn...
Staro 07.07.2010., 16:52   #25
bacyc
mučko đubre
bacyc's Avatar
Lokacija: B.P.S.
Postovi: 285
Autor okarm Pregled postova
za komad plastike koji se u kini štanca za par lipa? FAIL
phenom x3 435@phenom II x4 2900mhz big typhoon
asus m4n8 pro
2*2gb gskill
vtx ati radeon hd 5850
wd 640 aaks, blue
LG 42N
SEASONIC 380W
mx-518, Logitech wave
samsung 225bw
bacyc je offline   Reply With Quote
Staro 07.07.2010., 17:05   #26
Overhaul
Overhaul's Avatar
Postovi: 517
E da, Okarm mi je oteo savjet iz tipkovnice A inace, bilo je nekih ala hama mini tripoda/monopoda za isto 15-20 kn, znam da sam kupio par komada za "uradisam" hdri sfere.
Inace, mislim neskromno da posjedujem prilicno glomazne i teske kartice, nisam primjetio deformacije.
Nekad jesam, u doba pentiuma3 i zadnjih generacija AGP grafa, no cini se da su novije maticne ako su propisno prisarafljene, i sa dualslot grafom koja je dobro ucvrscena za straznju stranu kucista sa po dva sarafa, projektirane da se ne deformiraju. I budimo realni, ta dva slota na straznjoj strani kucista su dovoljan oslonac.
Overhaul je offline   Reply With Quote
Staro 10.07.2010., 02:31   #27
tutix
tutix's Avatar
Postovi: 4,068
/piccut
Isprva mi se činilo kao neloša ideja - sve te nove kartuše se jako pigaju, a onda vidim ovo. Koji win .
Staro 10.07.2010., 03:10   #28
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Ovo što je okram stavio treba proširit po netu, neki ljudi koji su na nekim stranim forumima/njuzima odma širit vjesti
Moja 3870+S1+120mm vent visi pošteno već 2.5 godine i funkcionira savršeno tak da imat nešto da smeta u kejsu, no deal.
Ova za namještaj je stvarno prevelik WIN de nek neko napravi slikicu sa okvirom i napiše ono jeld
Staro 10.07.2010., 07:48   #29
Uber Gosu
FORD Fix Or Repair Daily
Uber Gosu's Avatar
Postovi: 872
Hahah, ovo je najkorisniji izum od patrone za brisanje "paka" iz zločeste dece I.
OT
Inače nemam nekih zamjerki ni preferiranja tipa Sapphire, Asus, Điđibajt, XFX, EVGA itd., ali brate ovaj Powercolor je najveće smeće koje ne zna niti po tvorničkim specifikacijama Atija napravit generički dizajn da radi kako treba, naime, crkle su mi dve identične njihove kartice u roku 2g u 2 različita kompa (a i dok su radile bilo je bugova).
Uber Gosu je offline   Reply With Quote
Staro 10.07.2010., 11:20   #30
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Autor Uber Gosu Pregled postova
..Powercolor je najveće smeće koje ne zna niti po tvorničkim specifikacijama Atija napravit generički dizajn da radi kako treba, naime, crkle su mi dve identične njihove kartice u roku 2g u 2 različita kompa (a i dok su radile bilo je bugova)..
Power Jack je ipak vanserijski, dobro testiran, dizajnerski superioran, mega funkcionalan i potencijalno turbopopularan proizvod, pa sigurno ne bude nikakvih problema. I sve to uz odlicno odmjerenu cijenu.
Vas Top Shop
Cekajte ali to nije sve kupnjom drzaca ostvarujete pravo na popust bon od fantasticnih 33,33% na sve Powercolor kartice koje se krive i savijaju, a nebitno da li uopce rade (cisto da ne kupujete Power Jack uzalud, buduci da 99.99% kartica ne pati od ovih "problema")
Pomelo mi sig -.-
