Staro 01.06.2010., 19:37   #121
tonyx
Postovi: 49
tonyx je offline   Reply With Quote
Staro 01.06.2010., 22:41   #122
Sinisazg
Sinisazg's Avatar
Datum registracije: Jul 2009
Postovi: 194
A ja ko za vraga posudio ga frendu veceras, sad sam znatizeljan
Sinisazg je offline   Reply With Quote
Staro 02.06.2010., 00:50   #123
domis
Lokacija: Hrvatistan
Postovi: 4,165
konacno normalni boot time
Staro 02.06.2010., 15:18   #124
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Je-
Sa Mede8er sitea od jutros:
June 2nd 2010 - By reason of some bugs in firmware V3 will be firmware V3.01 released later on the day. We recommend not to install V3, wait for V3.01.
Dalje, na forumu:
Kindly note that the AAC audio codec, which appears to have been erroneously left out of the final V3 build, will be included in an update (V3.0.1) to be released later today.
This omission will be added to the 'known issues'.
AAC su zaboravili, ok, no ima dosta prijavljenih bugova pa bi valjalo sačekati da se vidi jel to od slučaja do slučaja ili nešto generalno.
Zadnje izmijenjeno od: tor. 02.06.2010. u 15:31.
Staro 03.06.2010., 00:39   #125
gog
gog's Avatar
Postovi: 582
Ja isto čekam 3.0.1 pa ćemo vidjeti. Malo mi je neozbiljno kako im je to uspjelo promaknuti. Za očekivati bi bilo da imaju bateriju testova koje moraju izvrtiti prije puštanja novog fw-a.
Druga stvar koja me muči je 6 channel AAC passthrough koji je napomenut pod known issues, da li to radi trenutno sa zadnjom verzijom iz serije 2.X?
Evo i popisa poznatih problema:
Known issues:
o AAC audio codec not working -- To be included in update
o Network (SMB) write not available to Non-Mede8er-formatted HDD (NTFS-only) -- Under investigation
o DVD resume on VIDEO_TS structure - Not working -- SDK
o Repeat A-B on BDISO -- SDK
o AAC 6 channel passthrough - only stereo -- SDK related
o Restore from v1.x or v2.x backups -- Not restoring all fields correctly
o On certain 16:9 DVD menus - selection highlight is misplaced -- SDK issue
o Simultaneous audio output via both HDMI and SPDIF -- SDK restriction
o Extension .divx unsupported -- SDK - temp fix rename file to .avi
o Resume dialogue DVDISO -- SDK
o Resume play DVD VIDEO_TS -- SDK
o File format: .ogg unsupported -- SDK
gog je offline   Reply With Quote
Staro 03.06.2010., 23:03   #126
hrki100
Postovi: 7
jel netko zna jel se one oci mogu staviti na folder?!Ako da,kako?
hrki100 je offline   Reply With Quote
Staro 04.06.2010., 15:03   #127
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,925
V3.0.2 je vani - LINK.
Konacno sam digao svoj sa 1.2.2 i sve radi besprijekorno (na prvi pogled). Ugradjeni disk od 1.5 TB (koji nije formatiran u Mede8eru nego na PC-u) radi bez problema.
Matta je offline   Reply With Quote
Staro 04.06.2010., 22:35   #128
quazar912
quazar912's Avatar
Lokacija: north-northwest
Postovi: 1,982
Autor zelja55 Pregled postova
toliko iščekivanja i obečanja i opet sve prepuno rupa
svi ti vulgaris "brandovi" su puni rupa...
quazar912 je online   Reply With Quote
Staro 05.06.2010., 12:18   #129
domis
Postovi: 4,165
windows je vulgaris brand? tcom firmware za rutere je isto vulgaris?
nauci se da svaki firmware/software ima rupa, neki imaju više, neki manje...neki imaju bitne neki nebitne.
ipak ljudi rade na tome, a grješiti je ljudski
Staro 06.06.2010., 17:09   #130
zelja55
Datum registracije: Feb 2010
Lokacija: sisak
Postovi: 30
sve 5 što griješe ali prave se najpametniji i pljuju po drugima ,tobože nedaju bete izdaće zadnju verziju full bez rupa,daj betu pa pomoći će ljudi kod prijave grešaka
zelja55 je offline   Reply With Quote
Staro 07.06.2010., 00:06   #131
Sinisazg
Sinisazg's Avatar
Postovi: 194
Autor hrki100 Pregled postova
Meni se na novom FW same stave nakon sto pogledam film.
Staro 07.06.2010., 00:13   #132
hrki100
Postovi: 7
ma nisam jos pogledao niti jedan film od kada sam stavio taj novi FW,ali sam probao rucno staviti,a mogu staviti samo na film unutar foldera a na folderu mi ne daje tu mogucnost,pa ne znam jel nekaj krivo radim
Staro 07.06.2010., 11:26   #133
gog
gog's Avatar
Postovi: 582
Ako nemaš filmova u folderu onda ne možeš označiti da je pogledano. Inače ti označi i folder, samo ne znam da li je dovoljno da si jedan video fajl iz foldera pogledao ili malo više.
Meni se dogodilo par puta da je slika ljubičasta i onda ugasim video i ponovo ga pokrenem i onda proradi. To mi se prije baš i nije dešavalo.
Boot time je malo preko 20 sekundi, jedino mi je bedasto što kada imaš ugrađen disk unutra kada odeš na media library te ne pozicionira odmah na HDD nego na USB.
Staro 08.06.2010., 00:31   #134
zelja55
Lokacija: sisak
Postovi: 30
ma koma umjesto da naprave bolje sve gore rade ni flv video više neradi još dalje nisam sve stigao vidit
Staro 08.06.2010., 01:05   #135
hrki100
Postovi: 7
Jel netko zna zasto mi nece prijevod raditi?Napravio sam rename isto kao i film ali i dalje ga nece prikazati?Kad na daljincu stisnem subtitle ocita ga kao srt ali i dalje ga nema!
Staro 09.06.2010., 15:33   #136
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Jel samo do tog filma? Možda je sam prijevod u banani, ako radi na ostalim filmovima.
Staro 09.06.2010., 16:45   #137
hrki100
Postovi: 7
ma samo na tom filmu,ali skinuo sam vec par prijevoda i niti jedan ne radi!Ali uredno ga ocita kao SRT samo ga nece prikazati1
Staro 11.06.2010., 00:37   #138
Spamer
Postovi: 152
ekipa krećem u kupovinu za dan dva, imate li šta posebno savjetovati , kupujem disk od 2 terabajta ....pa koji disk je najbolje da uzmem, mede8er ću naručiti na nabava.net i zanima me dali je komplicirano podesiti da se ripovi šalju sa kompjutera koji će biti udaljen metar od mede8er a da ne moram vaditi disk iz njega , hvala
Spamer je offline   Reply With Quote
Staro 11.06.2010., 00:47   #139
khm
Lokacija: Slavonija
Postovi: 1,200
Autor Spamer Pregled postova
Sumnjam da oni imaju, ali svakako ce te uputit na pravo mjesto.
lol
khm je offline   Reply With Quote
Staro 11.06.2010., 00:49   #140
domis
Postovi: 4,165
http://www.nabava.net/trazilica.php?...=Pretra%C5%BEi
ovog si ja planiram upiknuti pocetkom sedmog kad mi plaća sjedne
Staro 11.06.2010., 01:05   #141
tonyx
Postovi: 49
Zašto Green disk? Ali se osjeti razlika između njega i "normalnog"?
Staro 11.06.2010., 01:15   #142
domis
Postovi: 4,165
pa za glomazne fajlove kak su filmovi, nema razlike osim u cijeni
Staro 11.06.2010., 12:50   #143
Spamer
Postovi: 152
mede8r naručen u ronisa dolazi u ponedjeljak , disk našao 2TB uzimam ga popodne ))
dali je komplicirano spojiti mrezu sa kompjuterom?
Staro 11.06.2010., 18:38   #144
zelja55
Lokacija: sisak
Postovi: 30
samo za info svi koji imate Lg lcd tv sa usbom na večini se da otključat za gledanje divxa,mkva,mp3a i jpega http://lgusb.wikispaces.com/
Staro 14.06.2010., 18:37   #145
Spamer
Postovi: 152
može li pomoć , koje kabele trebam ukljuciti u tv iz mede8era a koje u kompjuter i sta trebam instalirati i kako se ubacuje taj firmware u mede8er hvala
Staro 14.06.2010., 19:45   #146
Spamer
Postovi: 152
evo skinio firmware Mede8er_V3.0.4__14_JUNE_2010.rar to je danas izaslo, moze li mi netko reci kako se instalira u uređaj i kako spajam uređaj sa tv-evom i kako ga spajam u mrezu sa kompjuterom kabelom, ne wireless.
Staro 14.06.2010., 20:00   #147
domis
Postovi: 4,165
već su novog izdali? -.-'
@spamer
procitaj readme i samo prati upute...nebreš ništ fulati
Staro 14.06.2010., 20:06   #148
Spamer
Postovi: 152
Autor domis Pregled postova
@spamer
a kabeli za tv i komp koji mi trebaju ?
Staro 14.06.2010., 20:13   #149
nexus-6
Pero_Snajper
nexus-6's Avatar
Postovi: 649
nexus-6 je offline   Reply With Quote
Staro 14.06.2010., 20:15   #150
domis
Postovi: 4,165
u mrežu s kompom preko wireless sticka ili sa lan kablom (možeš i usb-om al neznam kak to radi )
na tv spajaš preko hdmi ako možeš, ako ne odna sa component video i koristis bijeli i crveni cinch za zvuk.
ako nemoze ni to, onda zuti, crveni i bijeli cinch.
a ako imas noviji reciever onda zvuk spoji digitalno na njega
