|  01.06.2010., 19:37 | #121 |
| Premium Datum registracije: Mar 2006 Lokacija: Split
					Postovi: 49
				 | Izašao v3 Firmware http://www.mede8erforum.com/index.php?topic=2130.0 |
|  02.06.2010., 15:18 | #124 |
| Administrator Datum registracije: Nov 2001 Lokacija: Sesvete
					Postovi: 15,963
				 | Je- Sa Mede8er sitea od jutros: June 2nd 2010 - By reason of some bugs in firmware V3 will be firmware V3.01 released later on the day. We recommend not to install V3, wait for V3.01. Dalje, na forumu: Kindly note that the AAC audio codec, which appears to have been erroneously left out of the final V3 build, will be included in an update (V3.0.1) to be released later today. This omission will be added to the 'known issues'. AAC su zaboravili, ok, no ima dosta prijavljenih bugova pa bi valjalo sačekati da se vidi jel to od slučaja do slučaja ili nešto generalno. Zadnje izmijenjeno od: tor. 02.06.2010. u 15:31. |
|  03.06.2010., 00:39 | #125 |
| Premium Datum registracije: Apr 2005 Lokacija: Zagreb
					Postovi: 582
				 | Ja isto čekam 3.0.1 pa ćemo vidjeti. Malo mi je neozbiljno kako im je to uspjelo promaknuti. Za očekivati bi bilo da imaju bateriju testova koje moraju izvrtiti prije puštanja novog fw-a. Druga stvar koja me muči je 6 channel AAC passthrough koji je napomenut pod known issues, da li to radi trenutno sa zadnjom verzijom iz serije 2.X? Evo i popisa poznatih problema: Known issues: o AAC audio codec not working -- To be included in update o Network (SMB) write not available to Non-Mede8er-formatted HDD (NTFS-only) -- Under investigation o DVD resume on VIDEO_TS structure - Not working -- SDK o Repeat A-B on BDISO -- SDK o AAC 6 channel passthrough - only stereo -- SDK related o Restore from v1.x or v2.x backups -- Not restoring all fields correctly o On certain 16:9 DVD menus - selection highlight is misplaced -- SDK issue o Simultaneous audio output via both HDMI and SPDIF -- SDK restriction o Extension .divx unsupported -- SDK - temp fix rename file to .avi o Resume dialogue DVDISO -- SDK o Resume play DVD VIDEO_TS -- SDK o File format: .ogg unsupported -- SDK |
|  03.06.2010., 23:03 | #126 |
| Registered User Datum registracije: Apr 2010 Lokacija: Zagreb
					Postovi: 7
				 | jel netko zna jel se one oci mogu staviti na folder?!Ako da,kako? |
|  04.06.2010., 22:35 | #128 |
| Premium Datum registracije: Nov 2008 Lokacija: north-northwest
					Postovi: 1,979
|  05.06.2010., 12:18 | #129 |
| Premium Datum registracije: Sep 2006 Lokacija: Hrvatistan
					Postovi: 4,165
				 | windows je vulgaris brand? tcom firmware za rutere je isto vulgaris? nauci se da svaki firmware/software ima rupa, neki imaju više, neki manje...neki imaju bitne neki nebitne. ipak ljudi rade na tome, a grješiti je ljudski  |
|  06.06.2010., 17:09 | #130 |
| Premium Datum registracije: Feb 2010 Lokacija: sisak
					Postovi: 30
				 | sve 5 što griješe ali prave se najpametniji i pljuju po drugima ,tobože nedaju bete izdaće zadnju verziju full bez rupa,daj betu pa pomoći će ljudi kod prijave grešaka |
|  07.06.2010., 00:13 | #132 |
					Postovi: 7
				 | ma nisam jos pogledao niti jedan film od kada sam stavio taj novi FW,ali sam probao rucno staviti,a mogu staviti samo na film unutar foldera a na folderu mi ne daje tu mogucnost,pa ne znam jel nekaj krivo radim |
|  07.06.2010., 11:26 | #133 |
					Postovi: 582
				 | Ako nemaš filmova u folderu onda ne možeš označiti da je pogledano. Inače ti označi i folder, samo ne znam da li je dovoljno da si jedan video fajl iz foldera pogledao ili malo više. Meni se dogodilo par puta da je slika ljubičasta i onda ugasim video i ponovo ga pokrenem i onda proradi. To mi se prije baš i nije dešavalo. Boot time je malo preko 20 sekundi, jedino mi je bedasto što kada imaš ugrađen disk unutra kada odeš na media library te ne pozicionira odmah na HDD nego na USB. |
|  08.06.2010., 00:31 | #134 |
					Postovi: 30
				 | ma koma umjesto da naprave bolje sve gore rade ni flv video više neradi još dalje nisam sve stigao vidit |
|  08.06.2010., 01:05 | #135 |
					Postovi: 7
				 | Jel netko zna zasto mi nece prijevod raditi?Napravio sam rename isto kao i film ali i dalje ga nece prikazati?Kad na daljincu stisnem subtitle ocita ga kao srt ali i dalje ga nema! |
|  09.06.2010., 16:45 | #137 |
					Postovi: 7
				 | ma samo na tom filmu,ali skinuo sam vec par prijevoda i niti jedan ne radi!Ali uredno ga ocita kao SRT samo ga nece prikazati1 |
|  11.06.2010., 00:37 | #138 |
| Premium Datum registracije: Nov 2006 Lokacija: Split
					Postovi: 152
				 | ekipa krećem u kupovinu za dan dva, imate li šta posebno savjetovati , kupujem disk od 2 terabajta ....pa koji disk je najbolje da uzmem, mede8er ću naručiti na nabava.net i zanima me dali je komplicirano podesiti da se ripovi šalju sa kompjutera koji  će biti udaljen metar od mede8er a da ne moram vaditi disk iz njega , hvala |
|  11.06.2010., 00:47 | #139 |
| Banned Datum registracije: Dec 2006 Lokacija: Slavonija
					Postovi: 1,200
|  11.06.2010., 00:49 | #140 |
					Postovi: 4,165
				 | http://www.nabava.net/trazilica.php?...=Pretra%C5%BEi ovog si ja planiram upiknuti pocetkom sedmog kad mi plaća sjedne  |
|  11.06.2010., 12:50 | #143 |
					Postovi: 152
				 | mede8r naručen u ronisa dolazi u ponedjeljak , disk našao 2TB uzimam ga popodne )) dali je komplicirano spojiti mrezu sa kompjuterom? |
|  11.06.2010., 18:38 | #144 |
					Postovi: 30
				 | samo za info svi koji imate Lg lcd tv sa usbom na večini se da otključat za gledanje divxa,mkva,mp3a i jpega  http://lgusb.wikispaces.com/ |
|  14.06.2010., 18:37 | #145 |
					Postovi: 152
				 | može li pomoć , koje kabele trebam ukljuciti u tv iz mede8era a koje u kompjuter i sta trebam instalirati i kako se ubacuje taj firmware u mede8er hvala |
|  14.06.2010., 19:45 | #146 |
					Postovi: 152
				 | evo skinio firmware Mede8er_V3.0.4__14_JUNE_2010.rar to je danas izaslo, moze li mi netko reci kako se instalira u uređaj i kako spajam uređaj sa tv-evom i kako ga spajam u mrezu sa kompjuterom kabelom, ne wireless. |
|  14.06.2010., 20:06 | #148 |
					Postovi: 152
|  14.06.2010., 20:13 | #149 |
| Pero_Snajper Datum registracije: Dec 2005 Lokacija: Rijeka
					Postovi: 649
|  14.06.2010., 20:15 | #150 |
					Postovi: 4,165
				 | u mrežu s kompom preko wireless sticka ili sa lan kablom (možeš i usb-om al neznam kak to radi   ) na tv spajaš preko hdmi ako možeš, ako ne odna sa component video i koristis bijeli i crveni cinch za zvuk. ako nemoze ni to, onda zuti, crveni i bijeli cinch. a ako imas noviji reciever onda zvuk spoji digitalno na njega  |
