Staro 10.05.2010., 12:47   #241
ojpi
ojpi's Avatar
Postovi: 1,127
Autor frgh Pregled postova
evo uspio sam popraviti ali meni i dalje izgleda lose, sto vi kazete?
Parica ti sad rula,
ojpi je offline   Reply With Quote
Staro 10.05.2010., 14:19   #242
SrKi
SrKi's Avatar
Postovi: 841
posto ja to ne znam iscitati, jel ovo moje stogod valja posto razmisljam uzeti vecu brzinu a glupo mi je ako mi je nece moci podnijeti parica
DSL Type:G.992.5 annex B
Bandwidth (Up/Down) [kbps/kbps]:925 / 4.889
Data Transferred (Sent/Received) [GB/GB]:3,61 / 18,42
Output Power (Up/Down) [dBm]:12,0 / 17,5
Line Attenuation (Up/Down) [dB]:19,5 / 31,5
SN Margin (Up/Down) [dB]:12,0 / 11,5
Vendor ID (Local/Remote):TMMB / BDCM
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):3 / 0
FEC Errors (Up/Down):0 / 0
CRC Errors (Up/Down):0 / 15.019
HEC Errors (Up/Down):73 / 5.704
SrKi je offline   Reply With Quote
Staro 10.05.2010., 15:19   #243
ojpi
ojpi's Avatar
Postovi: 1,127
Trebalo bi ići 10 mbita na ovoj parici.
Staro 10.05.2010., 17:01   #244
SrKi
SrKi's Avatar
Postovi: 841
hvala. mislim uzeti amis TV, najvise zbog brzine jer im je tamo 24mb/sec sa TVom jeftinije nego samo 2 u 1 usluga te brzine, ono wtf amis?
sve u svemu, nadam se da ce biti bar 10.
Staro 13.05.2010., 21:26   #245
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Meni ovo piše:
Connection status: Connected (0:23:45:10)
Connection mode:Connect on demand
IP address:89.164.140.230
MAC address: 00:21:04:85:24:27
Default gateway:89.164.0.1
Preferred DNS server:213.191.128.8
Alternate DNS server:213.191.128.9
Downstream rate:9596 kbps
Upstream rate:637 kbps
PPPoE pass-through: Disabled
ADSL Line
Status:Cable connected
Line mode:ADSL2+
Maximum line rate:16136 kbps (downstream) / 1051 kbps (upstream)
Noise margin:15.3 dB (downstream) / 22.6 dB (upstream)
Line attenuation:14.6 dB (downstream) / 7.3 dB (upstream)
Output power:15.9 dBm (downstream) / 12 dBm (upstream)
MC
Staro 13.05.2010., 21:28   #246
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Yebemu, nemrem z editirat, pa da nastavim:
Koliko bi ja mogao čupat?
I šta napraviti da se parica poboljša? Dali se može nekoga platiti (Tcom, Iskon) neki treći provider da... kad recimo prelazim na njih da mi srede nove instalacije i sve... ?!
MC
Staro 13.05.2010., 21:53   #247
ojpi
ojpi's Avatar
Postovi: 1,127
Parica ti je super i ide preko nje otprilike maximum za adsl, oko 24Mbita.
Staro 13.05.2010., 23:28   #248
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
O thx za info.
Nego, kak to znaš?
MC
Staro 13.05.2010., 23:34   #249
branuschi
branuschi's Avatar
Lokacija: Sinj
Postovi: 397
@ojpi
Pozdrav evo ako može i za me procjena koliko bi ja mogao max. izvuć?
ADSL Line
Line mode:ADSL2+
Maximum line rate:
8588 kbps (downstream) / 1300 kbps (upstream) inače ovo mi zna bit i do 11500/1360
Noise margin:13.6 dB (downstream) / 20 dB (upstream)
Line attenuation:41.1 dB (downstream) / 25.2 dB (upstream)
Output power:14.8 dBm (downstream) / 23.7 dBm (upstream)
Zahvaljujem!!!
Moje trgovine: 1 ,2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 10 , 11 , 12 , 13 , 14 , 15 , 16 , 17 , 18 , 19 , 20 , 21 , 22 , 23 , 24
branuschi je offline   Reply With Quote
Staro 14.05.2010., 01:00   #250
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Autor Sa_Stilom Pregled postova
O thx za info.
Nego, kak to znaš?
Tebi je stvarno toliko tesko malo prelistati thread pa zelis da ti sve bude servirano?
2 minute sam potrosio da bi u ovom trehadu nasao 3 posta koji to objasnjavaju 1, 2, 3
Staro 14.05.2010., 01:05   #251
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Autor Nikky Pregled postova
Kako samo lupate podatke tu a nitko se nije potrudio objasniti šta zapravo ti podaci znaće evo nešto o tome iz materijala za my web koji nikako da završim.
Noise Margin (tj. Signal to Noise Margin ili Signal to Noise Ratio)
Relativna visina DSL signala u odnosu na nivo šuma.
Poželjno je da je ova vrijednost što veća.
6dB i niže rezultira povremenim ili kompletnim gubitkom sinhronizacije
7dB-10dB je zadovoljavajuće
11dB-20dB je dobro (mogućnost gubitka sinhronizacije mala pa nikakva)
20dB-28dB je izvrsno
29dB ili poviše je izvanredno
Line Attenuation
Mjeri degradaciju signala između DSLAM - a i modema.
Direktno ovisi o dužini i kvaliteti tel. parice do vaše centrale.
Ova vrijednost bi trebala biti što niža.
20dB ili niža je izvanredno
20dB-30dB je izvrsno
30dB-40dB je vrlo dobro
40dB-50dB je dobro
50dB-60dB je loše i može prouzročiti prekid konekcije
60dB ili niže je prilično loše i gubitak konekcije sasvim siguran
Maximum line rate
Brzina vaše linije odvojeno za download i upload.
Output Power
Nivo signala vašeg modema (upstream) ili DSLAM - a (downstream).
Maximalno preporućena je oko 15dB.
viper je offline   Reply With Quote
Staro 20.05.2010., 08:34   #252
aco123
aco123's Avatar
Lokacija: doma
Postovi: 16
a šta mislite o ovome
ADSL Line
Status: Cable connected
Line mode: ADSL2+
Maximum line rate: 26084 kbps (downstream) / 1448 kbps (upstream)
Noise margin: 30.3 dB (downstream) / 30.4 dB (upstream)
Line attenuation: 1.8 dB (downstream) / 0 dB (upstream)
Output power: 17.1 dBm (downstream) / 6.3 dBm (upstream)
aco123 je offline   Reply With Quote
Staro 20.05.2010., 09:14   #253
ojpi
ojpi's Avatar
Postovi: 1,127
Autor aco123 Pregled postova
ADSL Line
Line mode: ADSL2+
Tebi je centrala u sobi ili?
Staro 20.05.2010., 09:18   #254
ojpi
ojpi's Avatar
Postovi: 1,127
Autor branuschi Pregled postova
@ojpi
ADSL Line
Line mode:ADSL2+
Maximum line rate:
Zahvaljujem!!!
Fali podatak kolka ti je trenutna brzina, ali kao što i sam vidiš, to ti je maximum vjerojatno oko 9 mbita.
Staro 20.05.2010., 14:29   #255
viper
super user
viper's Avatar
Postovi: 1,805
ADSL Line
Line mode: ADSL2+
sta je ovo optika ko ti je ISP?
Staro 20.05.2010., 15:50   #256
aco123
aco123's Avatar
Lokacija: doma
Postovi: 16
Autor ojpi Pregled postova
pa nije u sobi ali pokraj sobe
Staro 20.05.2010., 15:51   #257
aco123
aco123's Avatar
Lokacija: doma
Postovi: 16
Autor viper Pregled postova
ne, obični adsl od t-coma al do centrale ima hmm 50m i novije žice su povučene...
Staro 20.05.2010., 17:09   #258
viper
super user
viper's Avatar
Postovi: 1,805
a znaci u tom grmu leži zec
a btw di je to?
Staro 20.05.2010., 20:59   #259
aco123
aco123's Avatar
Lokacija: doma
Postovi: 16
a btw di je to?
u jednom malom selo 15km od čakovca
Staro 21.05.2010., 13:00   #260
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Nemoj se ljutit, malo mi je bilo sumnjivo to s 24Mbits.
Poslao sam mail u Iskon i dobio sljedeći odgovor:
Maksimalna propusnost Vaše parice odgovara brzini koja je navedena niže u Vašem mailu i iznosi 16.2 Mbps u Downloadu te 1.1 Mbps u uploadu.
Line mode:ADSL2+
Kako vi onda velite da je 24Mbits?
MC
Staro 21.05.2010., 15:39   #261
ojpi
ojpi's Avatar
Postovi: 1,127
Line mode:ADSL2+
Sry, ja sam krivo gledao, ja sam zabrijo da je ovo maximum line rate trenutna brzina koja ti je puštena, nisam vidio da ti je downstream rate zapravo 9.
Staro 21.05.2010., 16:06   #262
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Onda je 16.2 Max?
MC
Staro 27.05.2010., 04:35   #263
ojpi
ojpi's Avatar
Postovi: 1,127
Onda je 16.2 Max?
Da, otprilike.
Staro 27.05.2010., 10:53   #264
n00b-
n00b-'s Avatar
Postovi: 35
Bandwidth (Up/Down) [kbps/kbps]:831 / 8.700
Output Power (Up/Down) [dBm]:12,5 / 12,0
Line Attenuation (Up/Down) [dB]:4,5 / 4,0
SN Margin (Up/Down) [dB]:27,0 / 30,0
Dobro,lose,ok?
jel mi netko moze to analizirat,jel bi mogao uzet 10mb=?
thanks unaprijed.
n00b- je offline   Reply With Quote
Staro 27.05.2010., 15:56   #265
viper
super user
viper's Avatar
Postovi: 1,805
Autor n00b- Pregled postova
Dobro,lose,ok?
thanks unaprijed.
imas jako dobru paricu rijetko tko ima tak dobru
bez problema bi trebalo ic na 10mbit ma i 20mbita
Staro 01.06.2010., 18:35   #266
ehohr
ehohr's Avatar
Postovi: 348
Link Information
Uptime: 4 days, 4:16:59
Modulation: G.992.5 Annex B
Bandwidth (Up/Down) [kbps/kbps]: 1.552 / 7.677
Data Transferred (Sent/Received) [MB/MB]: 95,62 / 946,79
Output Power (Up/Down) [dBm]: 13,0 / 5,0
Line Attenuation (Up/Down) [dB]: 3,0 / 0,5
SN Margin (Up/Down) [dB]: 11,5 / 19,5
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 16.227 / 536
CRC Errors (Up/Down): 350 / 0
HEC Errors (Up/Down): 208 / 0
Znači dešava mi se da puca veza učestalo, dropovi brzine veliki tipa u prosjeku je 6mbita, pa padne na 500 kbit i slicno, tehnicari iz Amisa su rekli da je to do kabela koji ide iz uticnice iz zida do modema, sto mi ne drzi vodu jer je kabel star nekih godinu dana, a sranja su pocela prije skoro godinu dana.
Po ovom gore sto vidim, zapravo veza nebi trebala pucat, DL bi mogao ic do 7.5 mbita, upload 1.4 mbita ili ja krivo mislim?
I na kraju krajeva s ovom paricom mi se ni ne isplati uzimat Amis TV jer this 24 mbit necu vidjet?
Zadnje izmijenjeno od: ehohr. 01.06.2010. u 18:41.
ehohr je offline   Reply With Quote
Staro 10.06.2010., 16:00   #267
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,744
Autor ehohr Pregled postova
Link Information
Koji modem imaš?
Ja imam problema sa brzinom, imam 2Mbita, max linije i thomsona 780. prije jedno dva tijedna je počela strahovito pucat veza i tek kad bi se modem spojio na cca 1.6Mbita onda bi radilo dobro, nebi pucala, a 2 Mbita sam mogao imat 3-4 sata bez pucanja. Ireko ja da probam drugi modem, mijeno se sa frendom na tjedan dana, on meni thomsona 782 a ja njemu moj, on ima dobru liniju. I evo več 18 sati radi veza bez pucanja na 2mbita. Sad ču još 6 dana vididjet kako če se ponašat pa onda ako je dobro sa ovim modemom nabavit takav. Čito sam da je thomsot ST780, jako osijetljiv na lošu paricu, padove napona i grije se jako i da u u t-comu masu tih modema zamijenili, ako pogledamo stanje T-com mreže koja se je postavljala preko qurca samo da radi telefon onda nije ni čudo.
@ehohr:
Probaj sa drugim modemom, možda bude bolje.
Staro 10.06.2010., 20:26   #268
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Ponovit ću još jednom, nešto što mi je savjetovao jedan tehničar i upalilo je.
Rekao je prvo da skinem utičnicu i da žicu direkt zalemim na žice iz utičnice, kako bi smanjio broj spojeva. Odjednom sa max 8Mbits i brdo grešaka, dobio sam 13-14Mbits (kada sam bio na Amisu) i uzeo 24Mbis.
Rekao mi je još ako imaš svoj modem, rastavi ga i zalemi također žicu na modem, ali to se nisam usudio napraviti.
Eto, sada imam mogao bi reći vrlo dobru vezu
Pa eto, probajte možda vam pomogne.
MC
Staro 11.06.2010., 10:22   #269
raven34
raven34's Avatar
Lokacija: HR,ZG
Postovi: 42
parica
E baš ću probati to sa lemljenjem , jer su moje vrijednosti taman granične za brže od 12 MBps..
raven34 je offline   Reply With Quote
Staro 11.06.2010., 20:36   #270
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
No, ako imaš loših spojeva unutar instalacije kuće, zgrade, centrale, vodova, onda ga yebi, meni je ovo pomoglo puno
MC
