Staro 27.04.2010., 23:05   #571
Dottore
Dottore's Avatar
Postovi: 7,638
tnx
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 30.04.2010., 18:26   #572
CoreDownloader
Skidaj se do kraja ;-)
CoreDownloader's Avatar
Lokacija: Tunguzija
Postovi: 158
evo od 10.53 ni jedan crash, radi sve ko podmazano...sto od prijasnjih verzija i nije bas...ali do sada stvarno sve ko po loju...
Bez linkova u sigu.
CoreDownloader je offline   Reply With Quote
Staro 30.04.2010., 18:39   #573
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Mislis od 10.52? Koliko ja znam to je zadnja official verzija. Btw, meni takodjer Opera radi super, zadovoljan sam..
Edit: pardon, ruka mi je brza od mozga ... spavam otvorenih ociju.
Zadnje izmijenjeno od: Sn4k3. 30.04.2010. u 18:50.
Staro 30.04.2010., 18:45   #574
CoreDownloader
Lokacija: Tunguzija
Postovi: 158
Autor Sn4k3 Pregled postova
ne, od 10.53, to je zadnja verzija..
Bez linkova u sigu.
Staro 30.04.2010., 22:07   #575
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Mogli ste i napisat da je Opera 10.53 Final vani
Staro 01.05.2010., 23:50   #576
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Autor Jelc Pregled postova
Evo Jelc samo za tebe:
Opera 10.53
Release Notes:
# Security
* Fixed
- Fixed an issue where multiple asynchronous document modifications could be used to execute arbitrary code
http://www.opera.com/browser/download/
ivand123 je offline   Reply With Quote
Staro 02.05.2010., 00:11   #577
Jelc
Super Moderators
Postovi: 17,485
E jebiga sad-već je dva dana na kompu
Staro 02.05.2010., 18:43   #578
Postovi: 7,568
Zadnje izmijenjeno od: McG. 13.01.2012. u 01:13.
Staro 02.05.2010., 21:07   #579
Jelc
Super Moderators
Postovi: 17,485
Baš sam sad isprobal, fino radi
Staro 12.05.2010., 18:22   #580
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Pici ko blesava...
Samo imam jedan problem koji se vucara od prijašnjih verzija,prikaz Youtubea mi je spigan,ko da ga ne loada do kraja.
Staro 12.05.2010., 20:33   #581
Dottore
Dottore's Avatar
Postovi: 7,638
Autor McG Pregled postova
Opera@USB 10.53 za one koji trebaju preglednik u toj varijanti.
ima na stranici Portableappz portable verzija Opera i sa pluginom flash (itd...)
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 13.05.2010., 11:51   #582
Romul
Romul's Avatar
Lokacija: Rijeka/Bratislava
Postovi: 222
ljudi neznam kakvi su vasi osjecaji ali ja sam ful razocaran u ovu "novu" operu narocito ovu nakon 10.50.
Inace koristim Operu jos od serije 4, mislim da je to vec 10 godina i nikad nisam bio vise razocaran.
To vise nije mali brzi browser sa uvijek naprednim idejama i rekao bih nekim sitnim stvarima,novotarijama koje vesele covjeka.
Danas mi se cini da ju vise koristim iz navike i averzije prema drugim browserima ali razocaran sam.
Postala je glomazna i spora i bugovita (onaj pdf problem u 10.51 me izludio)...
steta...
Romul je offline   Reply With Quote
Staro 13.05.2010., 13:01   #583
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
meni bas nasuprot, brza je i trenutno stabilna (bar meni)...crome mi nije nikako sjeo-FF je spor (sad se prica da ce u 4 verziji biti radjeno na brzini), imo sam u operi, jedino bug kad sam znao izaci a stalno pise da se ne moze zatvoriti jer mora sinkronizirati podatke, i od kada je ova zadnja verzija dosla sve ide kao po loju
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 13.05.2010., 14:29   #584
Romul
Romul's Avatar
Postovi: 222
Testiram trenutno na home PC i Win 7 pa mozda ce tamo bolje raditi. Naime cuo sam od nekoliko ljudi da im ova nova opera bolje (brze,stabilnije) radi od kad su na Win 7 presli.
Ali na laptopu na kojem sam puno vise i dalje ce biti XP a to znaci Opera 10.10
Staro 13.05.2010., 14:42   #585
Dottore
Dottore's Avatar
Postovi: 7,638
Win XP 64bit i Win 7 32bit (laptop) rade bez problema. Rade ko podmazano i sa 30 tabova
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 13.05.2010., 14:50   #586
Postovi: 7,568
Staro 13.05.2010., 15:23   #587
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Imo nikad nije bila bolja.. Ne znam otkut te ideje o "glomaznosti", "sporosti" i sl.
Staro 16.05.2010., 10:53   #588
rodriguez
rodriguez's Avatar
Postovi: 2,054
Jel ima kakav add-on za blokiranje pop ups sa youtuba?
Staro 16.05.2010., 10:58   #589
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Pop up sa youtubea? Nikad čuo niti vidio tako nešto...
Spoiler alert!
Staro 16.05.2010., 13:12   #590
rodriguez
rodriguez's Avatar
Postovi: 2,054
Ah mislio sam na one reklame koje iskaću dok gledaš video...Nismo svi tako ufurani u net izraze:P.
Staro 16.05.2010., 13:20   #591
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Ne. Addonovi za operu praktički ne postoje. Widgeti su jedini oblik toga, al oni imaju druge namjene.
Spoiler alert!
Staro 16.05.2010., 13:26   #592
ThePornstar
ThePornstar's Avatar
Postovi: 4,402
Da se pridružim Romulu, mene je isto razočarala ova Opera. Neće mi par stranica otvarat, kaj mi je s prijašnjim verzijama bez beda. Npr. mail koji najviše koristim -> hotmail. Nekad se zna vucarat, ali sve u svemu meni osobno ipak bolje nek ostali browseri.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
ThePornstar je online   Reply With Quote
Staro 16.05.2010., 13:36   #593
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Ad muncher skida sve moguce reklame i youtube i ostatak
Tomo je offline   Reply With Quote
Staro 16.05.2010., 13:38   #594
Postovi: 7,568
Staro 16.05.2010., 13:41   #595
rodriguez
rodriguez's Avatar
Postovi: 2,054
Thx Tomo,skinuo sam ad muncher ali vidim da imam pravo samo na 30 dana trial verzije...
Staro 16.05.2010., 14:04   #596
MarKill
N/A
MarKill's Avatar
Lokacija: Međimurje
Postovi: 434
Meni se nakon upgradea na 10.50 sve syebalo. Stranice se nisu do kraja ucitavale, neke se nisu ni otvarale, layout je bil razmrdan, puno toga nije radilo kak spada. Posto reinstalli nisu pomogli uninstalliral sam ju i obrisal foldere, no prije toga sam exportiral bookmarke i spremil wand.dat file di su passwordi.
Friska instalacija je radila dobro, vratil sam spremljeno i podesil ostale postavke, ta da na kraju nisam prakticki nist izgubil
MarKill je offline   Reply With Quote
Staro 16.05.2010., 14:37   #597
tocka
Postovi: 175
Ne znam zasto vama Opera dela probleme meni onak besprijekorno radi godinama...
tocka je offline   Reply With Quote
Staro 16.05.2010., 15:55   #598
Dottore
Dottore's Avatar
Postovi: 7,638
Na verziji 10.53 nema problema s učitavanjem stranice. Svaki dan otvaram na FF 20-tak tabova i na Operi 30-tak i više tabova. Sve uredno učitalo.
Još nema buga a kamoli nije ni srušio.
Iz stare na nove verzije apgrejdao.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 16.05.2010., 19:18   #599
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Ovo je jedan od programa koji se isplati imat i platiti par dolara Ako oces, imas i besplatnu zamjenu - http://www.privoxy.org/ ... Nemam pojma kak se koristi, ali vele ljudi da je dobar...
Staro 17.05.2010., 08:55   #600
Ziiky
Ziiky's Avatar
Postovi: 2,880
Autor Dottore Pregled postova
Potpisujem ...
Oduvjek me odusevljavala i vizualno i funkcionalno, a zadnja, 10-a verzija pogotovo.
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
