Staro 11.05.2010., 14:15   #3661
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Proudixz je čiter.
Čiteru.
Btw,
BFBC2 PC is back up now, PLAY NOW is currently offline so please use the server browser while we bring PLAY NOW back into service.
28 minutes ago via TweetDeck
I sad što je smiješno,logiraš se u igri i čim se logiraš,sekundu nakon izbaci poruku da je lost connection sa EA. lol
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Zadnje izmijenjeno od: Alph4Dawg. 11.05.2010. u 14:21.
Alph4Dawg je offline   Reply With Quote
Staro 11.05.2010., 14:21   #3662
Verbum
Postovi: 682
Mansky Hunt je whajner.
Whajneruuu
Verbum je offline   Reply With Quote
Staro 11.05.2010., 14:30   #3663
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor creativo91 Pregled postova
Whajneruuu
Ti si sisica.
I zbog ovoga više nećeš dobit keks. :P
Staro 11.05.2010., 15:21   #3664
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Whajneruuu
Istina!
Treba mu otvoriti posebni WHINE chanell na TS-u pa ko ga oče slušat nek ode u taj kanal,whine 0-24
Autor zgmmax Pregled postova
ovo ko da rade neki amateri
Some players may find they can't login to BFBC2 PC. It is affecting all EA PC games at the moment and EA is working on fixing it as priority 17 minutes ago via TweetDeck
A naravno da affecta samo PC usere OMFG
Ne daj bože da affecta debilne amere od 150kg pred svojim x-boxevima i PS3
Veki-os je online   Reply With Quote
Staro 11.05.2010., 15:22   #3665
zgmmax
zgmmax's Avatar
Postovi: 1,674
Autor Mansky Hunt Pregled postova
Btw,
zgmmax je online   Reply With Quote
Staro 11.05.2010., 15:26   #3666
Neo-ST
Neo-ST's Avatar
Postovi: 8,444
Najjače mi je bilo jučer kad je autobalance prebacio Manskyja u protivnički team na Arici, ja rekao da ću ga vratit, a netko je rekao "ma ostavi ga tamo, nek malo njima whinea, lakše ćemo ih dobit"
NHF mansky
Staro 11.05.2010., 15:29   #3667
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Sise.
Staro 11.05.2010., 16:03   #3668
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor Neo-ST Pregled postova
NHF mansky
sjecam se
zasto mi nikad ne uletimo kao 2 recona na mcom i svaki planta sve svoje c4 i to je dovoljno za unistiti mcom, puno je brze od aktiviranja
znam da je problem dovuci 2 recona tamo, ali recimo jedan (bilo tko iz squada dodje u sobu s mcomom, tamo kampira dok se 2 recona ne spawnaju na njega i to je to)
DeadMan+ je offline   Reply With Quote
Staro 11.05.2010., 16:11   #3669
Neo-ST
Neo-ST's Avatar
Postovi: 8,444
Jesi ti siguran da 2 recona mogu uništiti mcom? Da li je to sa standardnim zalihama ili sa onim addonom za dodatne zalihe?
Staro 11.05.2010., 16:18   #3670
Veki-os
Veki-os's Avatar
Postovi: 3,996
Čitao sam jučer na EA forumu,treba 10 C4 sa Explosive perkom ili 12 ili 14 "običnih" C4.
EDIT:I 10-15 direktnih pogodaka iz tenka.isprobano
Staro 11.05.2010., 16:19   #3671
thesekiman
Pr0d1gy
thesekiman's Avatar
Postovi: 288
treba 9 ili 10 C4 za jedan M-COMM, ako imas perk za extra explosion damage.
a jedan covjek moze nositi max.6 sa onim perkom da mozes nosit jos 3 C4 komada
thesekiman je offline   Reply With Quote
Staro 11.05.2010., 16:26   #3672
Neo-ST
Neo-ST's Avatar
Postovi: 8,444
Ma ne treba čak stavljati na sami mcom, staviš po unutarnjim zidovima zgrade, aktiviraš mcom, izađeš, čekaš da uđu i aktiviraš. Zabavnije i više štete
Staro 11.05.2010., 16:31   #3673
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor Veki-os Pregled postova
na wiki pise da treba 12 obicnih C4
istina, sad znamo sto raditi veceras
Staro 11.05.2010., 16:32   #3674
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 454
Autor thesekiman Pregled postova
Ja sam bio admin taj dan i pratio cjelu situaciju pa tako i u vrijeme dok si ti igrao. Lijepa ti je bila ona poruka kad si odlazio: "je*o vam server mamu chitersku", al nema veze. Ti si se još jedini i žalio na čitere taj put, mada nisam uocio nikog bi bio čiter niti su drugi nešto reportali. To je opet tipična stvar, kad te neko ubije par puta za redom počinješ sumnjat da su svi oko tebe čiteri. Bit će da nije bio tvoj dan.
Naravno da je kod nas Punkbuster uključen, ali to opet ne sprječava čitera da uđe u server, sve dok ga PB ili admin banira. Nas 8 admina kontroliramo server kako god stignemo od jutra do kasnih nocnih sati, ali ni to nije lagan posao, budući da u igri nema SPECTATE moda onda moramo ili biti u igri i pratit igrače ili pratiti situaciju preko programa. Čitera provjeravamo i izbacujemo ako se vecina počne žaliti na nekoga, ako ga sami uočimo i ako ima score daleko veći od drugih, tipa 70-2.
Druga stvar su team killeri, gdje postoji određen bug na serverima, gdje se team killera nemože kickati vani sve dok runda ne bude gotova, taj je bug poznat adminima i biti će rješen sa sljedecim patchom:
"Server – Teamkill-kick system is controllable"
Taj se problem desio i dok si ti igrao, vidio sam da si prijavio team killera, ja sam ga kickao al on nije mogao ispasti van dok runda nije zavrsila. On je ostao u igri i nastavio team killat a niko mu nista nije mogao, sto ostavlja dojam da niko od admina nije bio aktivan. A bili smo tu. Ako ima jos nekih admina ovdje koji imaju svoj server, onda ce znati o kakvim problemima govorim.
Meni je žao što si ti stekao takav dojam, vjerovatno ti nije krenulo od ruke.
Inace, svi su dobrodošli, pogotovo domaća ekipa, dokle god se igra po pravilima
p.s. sorry na dugoj poruci
ma no frks,ja sam stekao takav dojam,jer mene i frenda je neki tip tri cetiri puta skini nakon respawna,i to neki koji je imao ako se sjecam rez 42-12 ili tak nesto,istina je da je i onaj timkiler bio kikan ili banan nakon moje druge ili trece primjedbe ali cudno da je tip nakupio već -400 bodova,iskreno ja seam mislio da nema admina i da nema tko reagirat,ali se toliko već dugo nisam nasekiro kao taj dan na serveru,već sam bio na par servera di je bilo chitera i jednostavno odem ali ovo je hr server i mislio sam malo cesce tu igrat pa me pogodilo,vijerovatno cu opet doc na server i nadam se da neću imat problema kao zadnji put,inace znam i kako je biti admin na serveru dok igras,pa te svi cimaju i zaje...ju jer sam bio dugo admin na css serveru!
vidimo se na bojištu!!
dart_tom je offline   Reply With Quote
Staro 11.05.2010., 16:40   #3675
zgmmax
zgmmax's Avatar
Postovi: 1,674
alo jel vama radi??
neda mi se spojit jos uvijek
evo citat neda mi se prevadjat
For those that dont know it takes 12 c4 to blow a mcom (10 with explosive perk)
Staro 11.05.2010., 17:07   #3676
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ne radi.
about 2 hours ago via TweetDeck
Staro 11.05.2010., 17:11   #3677
zgmmax
zgmmax's Avatar
Postovi: 1,674
hehe
ja sada instaliro settlers 7 idem malo vidjet na kaj to lici. Prvi mi je bio mrak
Sjecam se da sam stalno visio kod frenda koji je imal 486 i 14" monitor i na njemu smo igrali jedinicu jedan protiv drugoga, a svaki je imao pola ekrana po horizontali
Staro 11.05.2010., 17:17   #3678
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ti bi mogao nekad i MSN upalit.
Staro 11.05.2010., 17:44   #3679
Constantine
Constantine's Avatar
Postovi: 668
ma ne,samo plantas,stavis 1-5 c4 direktno na mcom(ali ima tocno određeno mjesto gdje se najmanje primjeti),bacis motion mine i trcis prema coveru,ako prezivis cekas da se pocnu okupljat,cekas da pocnu defusat,detoniras,ubijes dvojicu trojicu i onda odma natrag prema mcomu da pobijes jos nekog pistoljem,tako ja uvijek radim.
Constantine je offline   Reply With Quote
Staro 11.05.2010., 18:40   #3680
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,811
"Reset has come and gone and servers are back up. You should be able to log into BFBC2 PC with existing soldiers. Sorry for the delay PC."
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 11.05.2010., 19:30   #3681
Neo-ST
Neo-ST's Avatar
Postovi: 8,444
Autor Constantine Pregled postova
Zato ako nas ima više, ja nikada ne idem defusat nego idem okolo tražit likove poput tebe dok moji defusaju
Staro 11.05.2010., 22:30   #3682
CyCl0p$
majke mi, kad zaspem u snu cujem manskog kako whinea
Staro 12.05.2010., 00:33   #3683
Cartmann
Cartmann's Avatar
Postovi: 488
*ebo vas, tako mi se dogodi da dođem do mcoma i nitko ne želi unutra jer pretpostavljaju da ih čeka c4, pa uđem ja i krenem defuseat, lik digne c4 i ubije me, onda ulete moji kad su c4 već ispaljeni i defuseaju.
Cartmann je offline   Reply With Quote
Staro 12.05.2010., 01:46   #3684
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Što su sad sjebali, sve prijatelje mi pokazuje da su offline a nisu -.-
xGAME je offline   Reply With Quote
Staro 12.05.2010., 02:42   #3685
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
evo mozete i mene dodat na onu listu na prvoj stranici
nik u bc2 mi je [VIPER]...cya in da game
btw kad je onaj updejt od 600mb?
viper je offline   Reply With Quote
Staro 12.05.2010., 03:11   #3686
Neo-ST
Neo-ST's Avatar
Postovi: 8,444
Pravi fan ili debil?
Staro 12.05.2010., 03:52   #3687
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Nijedno, čovjek koji dobro crta, sa viškom vremena i para, koji je upropastio takvu autešinu.
Dobro kaže komentar ispod:
a clever man would never do this to his BMW
blaa
Staro 12.05.2010., 04:10   #3688
Mad_Duke
Auto izgleda zakon sada.
Suptilno, unikatno i nije napadno.
Više govori o čovjeku, jer više ne vozi BMW X5, nego svoj BMW X5.
Staro 12.05.2010., 04:57   #3689
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Šta debil bokte,prejebeno izgleda.
Staro 12.05.2010., 08:11   #3690
CyCl0p$
dobro izgleda, napokon auto na nesto lici
