#31 |
Lokacija: Malaysia
Postovi: 96
CPU-Tweaker 1.4 beta9 http://www.tweakers.fr/download/CPU-Tweaker14b9.zip -Interface was changed (the system information panel is more complete now). -Add the change of core multiplier for Intel Core i3/i5 Clarckdale CPU. -Improve the change of core multiplier for Intel Core i5/i7 Lynnfield CPU. -Add support for Intel Core i3/i5 Clarckdale CPU. -Fix the bug when aero is disabled if CPU-Tweaker is open on AMD CPU under Windows 7. -Add some chipsets detection ID. ![]()
Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1 |
#32 |
Lokacija: Malaysia
Postovi: 96
Update today 2 am ,link same. -fix reading CAS# problem for Clarkdale Edit: Now CPU-Tweaker show correct CAS for Clarkdale,CPU-Z still bug. Setting 7-7-7-21,1T in BIOS: ![]()
#33 |
Lokacija: Malaysia
Postovi: 96
#34 |
Lokacija: Malaysia
Postovi: 96
CPU-Tweaker v:1.4 Final -Increase Reading Cas# on Intel Core i3 CPU. -Interface was changed (the system information panel is more complete now). -Add the change of core multiplier for Intel Core i3/i5 Clarckdale CPU. -Improve the change of core multiplier for Intel Core i5/i7 Lynnfield CPU. -Add support for Intel Core i3/i5 Clarckdale CPU. -Fix the bug when aero is disabled if CPU-Tweaker is open on AMD CPU under Windows 7. -Add some chipsets detection ID. ![]()
#35 |
Lokacija: Malaysia
Postovi: 96
CPU-Tweaker v:1.5 beta3 http://www.tweakers.fr/download/CPU-Tweaker15b3.zip -Add a window monitoring (Graphes CPU Load, CPU Temp, CPU & RAM frequency, Used RAM size). -Add 2 systray Icons (CPU Load and Highest Temp).
#36 |
Lokacija: Malaysia
Postovi: 96
CPU-Tweaker 1.5 beta4 http://www.tweakers.fr/download/CPU-Tweaker15b4.zip -Improve reading frequency on all CPUs.
#37 |
Lokacija: Malaysia
Postovi: 96
CPU-Tweaker 1.5 Final http://www.tweakers.fr/download/CPU-Tweaker.zip -Add a window monitoring. -Add 2 systray Icons (CPU Load and Highest Temp). -Replace the Average Temp graph by Highest Temp graph. -Add a panel with time elapsed. -Improve Reading Frequency on all CPUs. -Fix Cas Latency reading with DDR3 on K10 CPUs.
