#692 |
Postovi: 12,425
Intel Core i3 530 za oko 870 kn je vrlo dobar proc za te pare. ![]() Pa preko te cifre nema kaj tražit kad je najskuplji Phenom II X4 965BE oko 1.400 kn.
''Of all the things I've lost I miss my mind the most'' Mark Twain Zadnje izmijenjeno od: McG. 05.04.2010. u 17:54. |
#693 | |
Postovi: 648
Ja bi AMD quada za manje para svaki dan, a i cijena platforme se penje zbog dosta skupljih matičnih+obavezan DDR3 što otežava nadogradnju. AMD still rules. Citiraj:
#695 |
Postovi: 1,816
Stupid is as stupid does |
#696 |
Datum registracije: Dec 2009
Postovi: 144
ja nisam fan ni jednog ni drugog, do sad sam imao amd ali sad me bk stacu uzet, samo bi uzeo ono sta je bolje, to mi je jedino vazno, amd me privlaci zbog hexa core za jeftina pare pa smatram da ce za koju godinu kad bude programa koji ce koristit 6 jezgri amd davat bolje preformanse nego neki quad i7 a uostalom i amd procevi i ploče za njih su jeftinij od intela. |
#698 |
Lokacija: Zabok
Postovi: 3,385
Bio jednom ... sada je nenabavljiv, bilo koji P2 X3 ![]() Do kraja mjeseca će biti predstavljen Thuban, kasnije njegovi X4 derivati i to je to do 2011. Ja osobno čekam Llano ako bude za desktop segment ... ne kupujem ništa do onda ![]() |
#699 |
Postovi: 7,568
Asus M4A88TD-V EVO/USB3 AM3 ploča
Asus is readying one of its first motherboards based on the AMD 880G chipset, the M4A88TD-V EVO/USB3. This model comes in two variants, with or without USB 3.0 support, designated with the - USB3 suffix in the model name. It is a socket AM3 motherboard, supporting the upcoming line of Phenom II X6 and Phenom II X4 T series processors. The CPU socket is powered by a 10-phase VRM, it is wired to four DDR3 DIMM slots for dual-channel memory. Even as ATi CrossFire is not part of the 880G's feature-set since it won't support an external PCI-Express lane switch like the 890GX, Asus found a way around and provided a second PCI-Express x16 slot, only that this one is electrical PCI-Express 1.1 x4, wired to the SB800 southbridge chip.Izvor: techPowerUp Zadnje izmijenjeno od: McG. 30.09.2010. u 16:45. |
#700 | |
Lokacija: n/a
Postovi: 1,258
"Asus found a way around and provided a second PCI-Express x16 slot, only that this one is electrical PCI-Express 2.0 x4 (= PCI-Express 1.1 x8), wired to the 880G northbridge chip." ![]() evo ga 890GX/SB850 blok diagram, 880G/SB850 je isti ko ovaj jedino sto sluzbeno ne moze razdvojit 1x16 na 2x8... kak ne volim ove samoprozvane novinare koji pisu "novosti"... sam da nest objave... @ McG no hard feelings ![]() |
#701 |
Postovi: 7,568
Pokvareni telefon. ![]() |
#702 |
Lokacija: Daruvar
Postovi: 1,743
![]() Zadnje izmijenjeno od: McG. 07.04.2010. u 20:49. |
#703 | |
Napokon dočekao DNF :)
Postovi: 1,460
![]() @pinkskin - novi best buy možda? ![]()
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you. Zadnje izmijenjeno od: McG. 07.04.2010. u 20:47. |
#704 | |
Datum registracije: Mar 2009
Lokacija: Sk-Zg
Postovi: 1,097
Clock za clock, Intel je brži, ali je i skuplji i to je već ulazak u sferu overclocka, a tu se toga dosta mijenja u slaganju konfe. Pričekajmo pošteni usporedni test AMD X6 vs. Core i5/i7, pa ćemo vidjeti što je AMD napravio ![]() Zadnje izmijenjeno od: McG. 07.04.2010. u 20:48. Razlog: slovo viška |
#705 |
Postovi: 648
Jedva čekam! U ovom segmentu se dvije kompanije bore za svakog kupca, a ne kao sad sa grafičkim karticama. Doduše, 6 jezgri nemaju realno neke prednosti ispred 4 u multimediji i igrama, vidjelo se sa i7 980, tako da neće biti revolucija. Ali, malo pomalo, evoluira. Sve pozitivno! Zadnje izmijenjeno od: McG. 07.04.2010. u 20:49. |
#706 |
Lokacija: Sk-Zg
Postovi: 1,097
Vidjet će se odmah gdje će se nekom bechmarku svidjeti tih 6 jezgri i tu će AMD tražiti priliku. Za igre čisto sumnjam da će mu nešto značiti, barem ove sadašnje. Meni su i 4 jezgre overkill al eto, ispravne su pa neka ih. Jel ti to ozbiljno ili ne čitaš šta sam napisao? Naravno da je overkill ako se time ne baviš. Zadnje izmijenjeno od: McG. 18.04.2010. u 17:46. |
#707 |
Postovi: 7,568
Biostar 880G serija ploča
Biostar talks about new AMD 880G chipset market position and introducing 880G based motherboard line up, including two T-Series TA880G HD, TA880GB HD and A880G HD motherboards.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 16:50. |
#708 |
Postovi: 477
Dal je overkill za grafičke programe, renderiranje, Photoshop itd? |
#709 |
Xulos :)
Postovi: 7,554
The Rich pays to win. The Poor spends to lose. Zadnje izmijenjeno od: McG. 12.04.2010. u 13:32. |
#710 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Zadnje izmijenjeno od: McG. 18.04.2010. u 17:25. |
#712 |
Postovi: 359
Njušim još jedan uspjeh AMD-a. Intel svoj 6-core CPU prodaje na ludo skupih 999$, plus što uz njega ide i skupa matična sa skupom DD3 memorijom, sve skupa jako skupo dok s druge strane ovaj Thuban bude išo i na dobar dio AM2+ ploča s DDR2 memorijom od po stotinjak baksa. ![]()
let my people go! Zadnje izmijenjeno od: McG. 18.04.2010. u 17:26. |
#713 |
Postovi: 517
Za grafiku i rendanje ne postoji overkill. Ne moras probat nista rendati, ali samo opali screenshot ovog ekrana, pejstaj ga u Photoshop, uzmi alat prst, stavi mu 100 piksela i pocni mrljati. U roku od 10 sekundi, kasnit ce za tvojim pokretima barem 4 sekunde. Na nevidjeno tvoje konfiguracije. Dakle, Phenomi X6 trebali bi se pojaviti krajem mjeseca u ducanima? Navodno bude cifra nekih 2.000 kn za Phenom II X6 1075T Black Edition? (295$), a 1055T 200$ (kazu 1.400 - 1.500 kn)? Zadnje izmijenjeno od: McG. 18.04.2010. u 17:28. |
#714 | |
Lokacija: n/a
Postovi: 1,258
Zanimljiv clanak na bit-tech-u. Naime rijec je o otkljucavanju zakljucanih jezgri na MSI 890GXM-G65 ploči. Ne bi bilo nista cudno da, orginalno, ploča nije podrzavala "Core Unlocking". Citiraj:
![]() ![]() Zadnje izmijenjeno od: McG. 18.04.2010. u 17:30. |
#715 |
Postovi: 1,011
Asus will also unlock two AMD Zosma core - Nisam ljubitelj Asusa, ali vjerujem da ce i drugi proizvodjaci ovo omoguciti. ![]() Zadnje izmijenjeno od: McG. 22.04.2010. u 15:14. |
#716 |
Postovi: 7,568
Već su omogućili. Svi vodeći proizvođači nude obilje AMD 800 baziranih ploča, koje imaju sve kaj treba za pokušaj otključavanja. |
#718 |
Lokacija: VG
Postovi: 1,758
Norwegian retailer ships AMD six-core processors
Well, rest assured someone made a black-list at AMD, damn that's bold. A Norwegian retailer started shipping Phenom II X6 1090T Black Edition processors to customers.Izvor: Guru3D Iduci tjedan je launch, a kad dolaze kod nas na trziste? Zadnje izmijenjeno od: McG. 30.09.2010. u 14:29. |
#720 |
Postovi: 7,568
ASRock 890FX Deluxe3 AM3 ploča
This board comes with everything essential, excellent features include the ASRock unique Turbo UCC function, system performance Turbo 60 technology, UCC function, and it is also a True333 edition that provides USB3.0 (5 Gb/s), SATA3 (6 Gb/s) and eSATA3 technologies. Equipped with luxury components, ASRock 890FX Deluxe3 supports ultimate software solutions and brings you the industry’s most extreme level for gaming, computing and overclocking enthusiasts.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 16:51. |
