Staro 25.03.2010., 12:53   #1
Nvidia ForceWare 197.13 WHQL driveri
Download WHQL
This is a WHQL driver for GeForce 6, 7, 8, 9, 100, 200, and 300-series desktop GPUs and ION desktop GPUs.
This driver resolves fan speed issues reported with version 196.75 drivers. NVIDIA asks that you remove 196.75 drivers and update to this 197.13 WHQL driver.
If you currently have 196.75 installed, please first uninstall it before installing 197.13.
New in Version 197.13
  • Adds support for Next Generation ION.
  • Adds support for GeForce GT 320, GeForce GT 330, and GeForce GT 340.
  • Upgrades PhysX System Software to version 9.10.0129.
  • Upgrades HD Audio driver to version 1.0.9.1 (for supported GPUs).
  • Increases performance in several PC games from v196.21 WHQL. The following are examples of measured improvements. Results will vary depending on your GPU and system configuration:
    • Up to 13% performance increase in Crysis: Warhead with a single GPU
    • Up to 30% performance increase in Crysis: Warhead with SLI technology
    • Up to 13% performance increase in H.A.W.X with single GPU
    • Up to 15% performance increase in H.A.W.X with SLI technology
    • Up to 30% performance increase in Left 4 Dead with single GPU
    • Up to 28% performance increase in Left 4 Dead with SLI technology
  • Adds SLI and multi-GPU support for top new gaming titles including Assassin Creed II, Battlefield: Bad Company 2, Command and Conquer 4: Tiberium Twilight, Grand Theft Auto IV: Episodes from Liberty City, Mass Effect 2, Napoleon: Total War, and Zombie Driver.
  • Enhanced SLI support for Metro 2033, Supreme Commander 2, Unigine, and World of Warcraft.
  • Adds override anti-aliasing support for Mass Effect 2.
  • Includes numerous bug fixes. Refer to the release notes on the documentation tab for information about the key bug fixes in this release.
Existing Support:
  • Supports GPU-acceleration for smoother online HD videos with the new Adobe Flash 10.1 beta. Learn more here.
  • Supports OpenCL 1.0 (Open Computing Language) for all GeForce 8-series and later GPUs.
  • Supports OpenGL 3.2 for GeForce 8-series and later GPUs.
  • Supports CUDA Toolkit 3.0 features and performance enhancements. See CUDA Zone for more details.
  • Supports single GPU and NVIDIA SLI technology* on DirectX 9 and OpenGL.
  • Supports NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here.
  • Download these FREE PhysX and CUDA applications now!
  • Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
*Note: The following SLI features are only supported on Windows Vista and Windows 7: Quad SLI technology using GeForce 9800 GX2 or GeForce GTX 295, 3-way SLI technology, Hybrid SLI, and SLI multi-monitor support.
Menščini da je ovo isto kao i 196.75, osim problema sa temperaturama. inače, instalirao bez greške i razgulio malo Crysis Warhead. razliku sam primjetio tamo i malo u Metro 2033. sve ostalo koliko mi se čini isto.
nikakvih problema nema ni kod GPU Acceleration kad gledam Full HD materijal.
Staro 25.03.2010., 13:04   #2
Gx25
RiSeN FrOm tHe BaNNeD
Lokacija: cro
Postovi: 662
Znaci da slobodno izbjegnem ove? Imam 196.75 i ako nema poboljsanja u 197.13 u odnosu na moje jer mi se ne isplati brisati bezveze moje i stavljat nove.
Gx25 je offline   Reply With Quote
Staro 25.03.2010., 13:12   #3
ako ti je ovo grafa iz potpisa, da, možeš ih preskočit ovako i onako ti se ventovi hrane iz molexa ili sa ploče, jeltako?
Staro 25.03.2010., 13:17   #4
Gx25
Lokacija: cro
Postovi: 662
hehhe ravno s ploce
Znam za taj bug s ventom ali vent s ac s1 je spojen na maticnu pa me ne zabrinjava.
Nije mi jasno ovo:
EDIT: Skuzio sta e pjesnik htio reci
Staro 25.03.2010., 13:20   #5
pa da, ako ti je ovo grafa iz potpisa tj iz "moj komp", dakle sa A-ćeletom i 92mm ventom, koji se NE napaja iz grafe get it ?
Staro 25.03.2010., 21:21   #6
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,746
Ima li koja žrtva osim Burka da ih je probala ?
Staro 25.03.2010., 21:44   #7
alengrosevic
alengrosevic's Avatar
Postovi: 3,777
ja sam ih isprobao i sve je bilo ok. COD4/6, FEAR2, Bioshock2, Battlefield BC2, sve je radilo bez greske.
no vidio sam da ima i 197.25 pa sam njih bubnuo i na njima sam. isto kao i s prijasnjim, nema problema!
http://downloads.guru3d.com/Forcewar...load-2502.html
Staro 25.03.2010., 21:58   #8
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Ja stavio na laptop sa modanim inf-om. Za sada mi jedino sto sam primjetio gpu-z ne pokazuje da je directcompute ukljucen. Moze li mi netko sa desktop grafom provjeriti ovo pa da probam dalje mrljavit po inf-u?
tnx
197.25 su beta još:
http://www.nvidia.com/Download/Find.aspx?lang=en-us
Staro 26.03.2010., 08:04   #9
ja sam stavio te 197.25 beta i sve mi radi najnormalnije. vele da su to isti driveri kao i 197.13, samo što je nešto poboljšano glede Starcraft 2 beta.
i da, GPU-Z mi pokazuje DirectCompute da je uključen.
Staro 27.03.2010., 19:08   #10
junkieee
junkieee's Avatar
Postovi: 993
ja sam dobio 2-3 fpsa vise u BC2, a u drugim igrama bas i nisam skuzio razliku
junkieee je online   Reply With Quote
Staro 27.03.2010., 19:14   #11
xtreme96
OC addict
xtreme96's Avatar
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
Jel zna itko hoce bit Xtreme-G verzija 197ice?
Pošten trgovac: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15...
- prije mi je bio nick "xTreme Gamer" (profil je isti ali sam promjenio nick)
xtreme96 je offline   Reply With Quote
Staro 27.03.2010., 20:57   #12
Baja 001
Baja 001's Avatar
Postovi: 7,504
Opet neradi DXVA. Dođe mi da pobrišem Windowse i vratim se na 195 drivere, ovo je katastrofa.
Staro 29.03.2010., 16:00   #13
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
CUDA is the way
http://imouto.my/configuring-kmplaye...itecture-cuda/
Staro 29.03.2010., 16:35   #14
Mast3r Chi3f
Mast3r Chi3f's Avatar
Postovi: 118
Autor Mihael Pregled postova
Cemu uopce to forsiranje gledanja preko grafe? sta laptop procesori nemaju dovoljno snage ili je prikaz slike bolji? rekao bi da grafa prije pocucla bateriju
Ima li uopce razlike izmedju DirectX akceleracije (DXVA) i Nvdiijine CUDA-e
Par puta sam za probu ukljucio u Powerdwd-u graphic acceleration, razlike nema, dapace slika je gora jer nemogu onda korisit filtre za poboljsanje slike.
Hvala unaprijed
Sine, ako stvarno nešto želiš u životu, morat ćeš raditi za to. A sada tišina! Počinje izvlačenje brojeva za lutriju
Mast3r Chi3f je offline   Reply With Quote
Staro 29.03.2010., 22:33   #15
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor Mast3r Chi3f Pregled postova
Hvala unaprijed
Pa nema forsiranja... zašto bi forsirao, koristim ono što mi je dostupno.
Konkretno kod mene što se snage cpu-a tice, nemam problema, osim kada stavim Power saver plan, tada cpu radi na 800mhz i 1080p voli štekat, skakat i zvuk kasni, rani što već. Kako mi grafa to radi taj problem više ne postoji.
E sad, ovo je dobro pitanje za bateriju, baš bi trebo test jedan nabacit sa 1080p i budem kad uhvatim vremena.
Razlika između dxva i cude, dxva render ide preko directx-a, a cuda preko cude :P koja je samo za nVidine grafe koje ju podržavaju. Zašto ne bi to koristio barem za takvu glupost kad već to imam.
Razliku u kvaliteti prikaza nisam primjetio. koristim kmplayer koji ima vrhunsku sliku.
Staro 01.04.2010., 12:11   #16
Reedy
Reedy's Avatar
Postovi: 770
XG 197 su vani
Reedy je offline   Reply With Quote
Staro 01.04.2010., 12:31   #17
197.25 by XG
Windows 7 32-bit
Windows 7 64-bit
nema nVidia HDAudio drivera i maknut je PhysiX. pa ko oće, go for it
