#2491 |
Addicted to music.
Postovi: 1,782
Ne znam brate,ne mogu ti to objasniti,iako bih volio - zbilja. Settings.ini kaže : [WindowSettings] Width=1280 Height=720 Fullscreen=true RefreshRate=75 VSync=false [Sound] Quality=low VoipEnable=false [Graphics] Effects=low Soldiers=low Vehicles=low Overgrowth=low Undergrowth=low StaticObjects=low Terrain=low Shadows=low Bloom=false HSAO=false MSAA=0 Water=low MainQuality=low Texture=low DxVersion=9 Aniso=0 Detail=low I radi k'o podmazano. (=
All you have is your fire and the place you need to reach. Don't you ever tame your demons, always keep them on a leash. |
#2492 |
Tuco “the Rat” Ramirez
Postovi: 476
#2493 |
Datum registracije: Mar 2010
Postovi: 13
ovaj od win 7, nikakav drugi. |
#2495 |
Nuclear Experiment
Datum registracije: Aug 2009
Postovi: 650
Ja igram bc2 na 60-70 fpsa s Intel Core2 Duo CPU E8400 3.00GHz,4 gb rama, dvije 4870(svaka 512 mb) a moj setting kaze ova:Width=1680 Height=1050 Fullscreen=true RefreshRate=59.883251 VSync=false [Sound] Quality=low VoipEnable=true SpeakerCount=0 [Graphics] Effects=high Soldiers=high Vehicles=high Overgrowth=high Undergrowth=high StaticObjects=high Terrain=high Shadows=high Bloom=true HSAO=true MSAA=0 Water=high MainQuality=custom Texture=high DxVersion=9 Aniso=4 Detail=high RenderAheadLimit=2 Fov=55 Prezadovoljan.Jos kad bi mogo na dx10.
For everything you gain, You lose something else. |
#2496 |
Postovi: 13
kad pokrenem game kao admin vidim pingove, win 7. eto, nadam se da ce jos nekome pomoci ako ga to muci. |
#2498 |
Postovi: 623
Nebih htio opet reći da igra radi, ali eto, igrao tri sata i nema pucanja niti ničeg. Jel oćemo večeras na PCE? |
#2499 |
its slightly turbocharged
Postovi: 5,430
Ja baš na hard way moram saznati da je M1 Abrams jači od T-90 head-to-head ![]() (naravno, ja sam bio vozač ovoga što je izvukao deblji kraj, i još ktome sam prvi opalio )
blaa |
#2500 |
Postovi: 668
jesi siguran,ja sam oduvijek mislio da je T90 jaci,no vjerovatnije je da su potpuno identicni. |
#2501 |
Postovi: 5,430
Na Arica Harboru sam bio defender, početak partije, uskačem u T-90 i pičim prema izlazu iz baze da dočekam goste kad mi nailazi Abrams, ja prvi opalim i pogodim direkt, on mene direkt, ja njega opet direkt i onda on mene uništi. Ja sam imao onaj secondary weapon, a možda je pak on imao onaj firepower upgrade... to neznam Trebali bi se naći na nekom praznom serveru di se trenutno vrti Arica pa to isprobati ![]()
blaa |
#2502 |
Lokacija: Dubrovnik
Postovi: 1,287
http://en.wikipedia.org/wiki/M-95_Degman E to je tenk. I ako ikad Hrv opet bude u ratu, dobivat ćemo ih kroz akcije "Kupujmo Hrvatsko" od stranaca.
S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX |
#2504 | |
Lokacija: Éire
Postovi: 1,812
![]() Meni je bilo fascinantno kada mi je jucer UAV skinuo svih 100% jednim pogotkom na T90 ![]() Neo, o kakvim snimkama ti pricas? ![]() |
#2507 | |
Postovi: 5,430
Head-to-head Direkt jedan na drugoga front armor to front armor Nikakvi pogoci u bok a i sigurno mu se nisam naguzio da mi spraši jednu u rear armor ![]() Dakle svi pogoci i moji i njegovi su bili direkt u front armor.
blaa |
#2508 | |
Postovi: 668
@hammer of thor,mozda te jos netko pogodio u istom trennutku kad i on,mozda te lik pogodio ispod tenka ako si prelazio preko zapreke,mozda je imao veci armor na vozilu,previse je varijabli tako da ja mislim da je damage od t90 i m1 isti. |
#2510 | |
Postovi: 488
#2511 | |
Datum registracije: Jun 2003
Postovi: 533
1680x1050, medium detalji, dx9, render ahead 0, prosjek 50-60 fps, minimum 30ak. Citiraj:
#2512 |
Lokacija: Požega
Postovi: 271
to ti je jako varljivo.. mislim da kupola ima razliciti armor u odnosu na tijelo, ovisi takodjer gdje ga pogodis cak i frontalno, na spoju kupole i sasije su tenkovi ranjiviji nego na okomitim povrsinama. ako te je iz dva shusa sredio tip je vjerovatno imao onaj perk za pojacane Warheads + kako znas da cim ste se sreli nije njegov inzinjer iskocio iza i bacio se na popravke !? Dobro uigrani tenkisti tako prashe.. p.s. Ako nemas Armor perk i UAV te spici ravno u 'otvor' kupole, to je instant kill ![]()
I'm all alone, I smoke my friends down to the filter, but I feel much cleaner after it rains.. |
#2513 |
Postovi: 668
aha,da,kako sam na inžinjerce zaboravio,to je najvjerovatnije. |
#2514 |
Toshiba ko' ludo
Lokacija: zagreb-west side
Postovi: 250
Pozz i help , evo kupio sam cdkey na g2play.net i nemrem regat key (kaze mi da je product code disabled) sad da li je to do EA servera ili da pišem žalbu da mi je key krivi. Ili da probam kroz instalaciju igre regat key bez ea download managera. Zadnje izmijenjeno od: dedal. 28.03.2010. u 22:50. Razlog: xy |
#2516 |
Postovi: 5,430
Dosta za danas. Naživcirao sam se na PCE ![]() ![]() Ja sam sa PcE sa timom nekih debila kao attack, protiv večine PcE članova koji su defenderi ![]() Arica, došli do zadnjeg M-Coma kao attackeri, ali ja ne mogu vjerovati sa kako ja glupim ljudima igram... Svaki drugi je medic a niko neće revievat, a još SC pa sve okolo svjetli od oznaka ko je od teammateova mrtav da ga treba oživit... Kretenizam na najvišem nivou. Nevjerovatno. Da ne govorim kako niko neće krenuti na taj zadnji MCom već svi sjede na 150 metara i misle si onaj drugi će ![]()
blaa |
#2517 | |
iako jos nigdje nisam vidio hit zone vozila za bc2, u bf2 su bili moguci 1 shot killovi s tenkom. samo je trebalo pogodit na jedan od 2 mala sektora sprijeda i onda bi se projektil "odbio" od armora i pogodio ispod cijevi. dupli dmg efektivo ![]() gadjajte oklopna vozila ili straga ili u gusjenice ili na spoj kupole i samog vozila. |
#2518 |
Postovi: 623
PcE server je full. Aj kickajte nekog. ![]() |
#2519 |
wtf zasto je samo 16 igraca limit na PCE?? |
#2520 |
Postovi: 668
mozda zato sto server ima 16 slotova :/ |
