Staro 03.03.2010., 20:57   #1741
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,179
Ma ništa to ne valja, šta se svađate oko tih grafičkih kojima cijene skaču sim pa tam i trgovci rade s cijenama kako im se "sprdne" i koliko imaju zaliha, koliko je nabava, ovo, ono...ma joj. Tako sam ja svoju uzo u ADM-u za 1600 kuna, a tjedan dana kasnije 1350 kuna iz neznam kojeg razloga E, pojeo sam se :@ I još što je najbolje, nešto mi ne valja (valjda) jer zašteka u nekim igrama te moram resetirat komp. Užas...Nemam ja ništa protiv ADM-a, sve super, al čovječeee...neš je krivo!
PC:
CPU:
Intel Core i7-7700
COOLER:
SCYTHE Mugen 3 rev. B
MBO:
MSI B250 GAMING M3
GPU:
ASUS Dual Radeon RX 6650 XT OC Edition 8GB GDDR6
RAM:
Kingston HyperX Fury (2x8GB) 2133MHz@2400MHz CL16 DDR4
SSD:
Samsung 870 EVO (500GB)
Samsung 970 EVO Plus (2TB)
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
Seagate Basic Portable Drive (1TB)
WD My Passport (1TB)
WD My Passport (2TB)
WD Elements (2TB)
Verbatim Vx500 (240GB)
Silicon Power PC60 (240GB)
Kingston XS1000 (1TB)
PSU:
Corsair 650W RM650, 2019, 80 PLUS Gold
MONITOR (TV):
Dell G2724D + Dell U2414H
Samsung UE55NU8002TXXH
Samsung QE43Q60AAUXXH
Philips 43PUS8506/12
KUĆIŠTE:
Antec 300, 2xSCYTHE Slip Stream 120mm (500rpm, 7.5 dB)
OS:
Windows 10 Pro 64-bit
TIPKOVNICA:
Logitech K800 Illuminated
MIŠ:
Logitech G502 Proteus Spectrum RGB + SteelSeries QcK Edge - Medium
Logitech MX Master 3 Black
Logitech MX Master 2S Bluetooth Edition Graphite
Logitech M590 Silent
ZVUČNICI:
Logitech Z-5500 (S/PDIF) + Logitech Bluetooth Audio Receiver
MAGNAT Monitor Supreme 202 Black 2-way bass reflex bookshelf speakers
MAGNAT Monitor Supreme Center 252 Mocca
SLUŠALICE:
Logitech Zone Vibe 100
Samsung Galaxy Buds3 Pro
Xiaomi Redmi Buds 5 Pro
Xiaomi Buds 3 Star Wars Edition
Mi True Wireless Earbuds Basic 2
Sennheiser CX 3.00
AKG Samsung Galaxy Earbuds
AKG Y500 Wireless
MOB:
Samsung Galaxy S7 Black, 4/32GB +
Samsung microSDXC 64GB EVO+
Samsung Galaxy S10e Black, 6/128GB +
Samsung microSDXC 256GB EVO+
Huawei P50 Pro Golden Black, 8/256GB
Samsung Galaxy A55 5G Awesome Navy, 8/256GB
Samsung Galaxy S24+ Onyx Black, 12/256GB
LAPTOP:
(Lenovo ThinkPad E560)
CPU: Intel Core i3-6100U
MBO: -
GPU: Intel HD Graphics 520
RAM: 2x4GB DDR3L 1600MHz
SSD: Kingston A400 480GB
OSTALO: 15.6-inch HD TN
PC POSAO:
(HP Z2 Tower G9 Workstation)
CPU: Intel Core i7-14700K
MBO: HP 895C
GPU: Nvidia RTX A2000 12GB
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MONITORI: 2 komada HP Z27 27-inch 4K UHD
PERIFERIJA: Logitech K750 Solar, Logitech MX Master 3 Graphite + Logitech MX Master 2S Bluetooth Edition Graphite
LAPTOP POSAO:
(Apple MacBook Air 13.6-inch M2 8/256GB MLXY3CR/A Silver)
(HP EliteBook x360 1040 G11 2-in-1, 14-inch WUXGA Touchscreen, Intel Core Ultra 7 155H, 16GB LPDDR5x, Samsung 1TB PCIe Gen4 NVMe TLC M.2 SSD, Backlit Keyboard, Windows 11 Pro)
(HP ProBook 450 G7, 15.6-inch FHD, Intel Core i5-10210U, 8GB DDR4, Samsung 512GB NVMe M.2 SSD, MX250 Graphics, Backlit Keyboard, Windows 11 Pro)
DiRT je offline   Reply With Quote
Staro 03.03.2010., 23:36   #1742
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
Autor Mansky Hunt Pregled postova
Ajde,dajte mi neku preporuku Atijevke do 500 kn koja bi odrađivala posao kako treba (bezobzirno bila sa pasivnim,ili aktivnim hlađenjem,iako sam do sada imao samo pasivke i nikada problema).
Trenutna HD 4350,koja je low end odrađuje fantastičan posao za 250 kunića,ono,vrtim skoro sve naslove na low sa 1024*768,ili 1280*720 (na ovoj rezi i sa ovom grafom sam prešao Bad Company 2),jedino mi je Fallout neigriv.Ovo govorim čisto onako usputno.Ne patim na max detalje,niti me zanimaju max detalji,kao ni igranje na max rezi.Samo hoću nešto jače od ove,da si malo podignem fpse i tako.Nemojte,molim Vas,sad uletavat kao neki sa: "eeeeeeee,uzmi si HD 5***,košta ti samo 2-3 tisuće kuna".
Hvala lijepo.
EDiT : Linkovi poželjni.
jedan hint - ishop. trgovina ti je u sisku, ne moras se patiti sa odlaskom/kupovinom u zagrebu, i ako ti vrisne - blizu ti je prolaz kod grila (tamo je ishop, ako ne znas). imas par verzija 4670 (koju i sam preporucujem jer ju imam i sve sljaka 5/5 na 1680x1050 btw), a mozes i pogledati svaku, sto se tice hladenja.
Staro 03.03.2010., 23:45   #1743
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor Burko Pregled postova
Tnx,tnx,znam,uzeo sam tamo već matičnu i grafičku prije.Moram samo pogledati cijene grafulja sad.Ali hvala na podsjećanju!
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 03.03.2010., 23:48   #1744
Burko
Burko's Avatar
Postovi: 2,317
nisam siguran koja je sada, ali posljednji put kad sam ispatio goca i apacha imali su vtx-icu 4670 sa AC-ovim hladnjakom, predobra kartica. i upada ti u budget, 499 kuna je (barem po webu).
Staro 03.03.2010., 23:59   #1745
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Da,baš ugledah.Piše 499kn,ništa,sutra ću nazvati tamo,pa pitati,ili još bolje,ako budem u mogućnosti,sletit ću se tamo,pa vidjeti.
Staro 04.03.2010., 15:20   #1746
DiRT
DiRT's Avatar
Postovi: 1,179
Jel se isplati uzet 5770 Vapor-X za 1200 kuna? Sad je jeftinija cijena.
PC:
CPU:
Intel Core i7-7700
COOLER:
MBO:
MSI B250 GAMING M3
GPU:
RAM:
SSD:
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
WD Elements (2TB)
PSU:
MONITOR (TV):
KUĆIŠTE:
OS:
TIPKOVNICA:
MIŠ:
ZVUČNICI:
SLUŠALICE:
Sennheiser CX 3.00
AKG Y500 Wireless
MOB:
LAPTOP:
MBO: -
PC POSAO:
MBO: HP 895C
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
LAPTOP POSAO:
Staro 04.03.2010., 16:02   #1747
Jackson
Postovi: 648
Isplati se Da kupujem sad grafičku, tu bi uzeo, za tu cijenu se baš isplati!
Jackson je offline   Reply With Quote
Staro 04.03.2010., 16:19   #1748
Postovi: 34,005
Jeftinija je jer je na akciji. Pitanje je koliko će komada imati na prodaju. Imam feeling da će biti poprilična gužva i grabež za nju.
Staro 05.03.2010., 22:17   #1749
Šole
Šole's Avatar
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 709
Ako nestane u links-u požurite u ADM
http://www.adm.hr/product_info.php?c...oducts_id=7865
Šole je offline   Reply With Quote
Staro 12.03.2010., 00:27   #1750
Mad Max
Datum registracije: May 2009
Postovi: 20
Po vama što bi bilo pametnije kupiti ?
Sapphire HD 5770 Vapor-X 1200 kn adm
ili
VGA PCI-E VTX3D ATI RADEON HD 4870, 512MB DDR5 1000 kn Links
Ostatak kompa nije kočnica .
Mad Max je offline   Reply With Quote
Staro 12.03.2010., 00:36   #1751
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
I vote for 5770! Razloge imas na zadnjih 50 stranica
Staro 12.03.2010., 01:15   #1752
DiRT
DiRT's Avatar
Postovi: 1,179
A nema dvojbe...novije=hladnije=bolje
PC:
CPU:
Intel Core i7-7700
COOLER:
MBO:
MSI B250 GAMING M3
GPU:
RAM:
SSD:
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
WD Elements (2TB)
PSU:
MONITOR (TV):
KUĆIŠTE:
OS:
TIPKOVNICA:
MIŠ:
ZVUČNICI:
SLUŠALICE:
Sennheiser CX 3.00
AKG Y500 Wireless
MOB:
LAPTOP:
MBO: -
PC POSAO:
MBO: HP 895C
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
LAPTOP POSAO:
Staro 12.03.2010., 04:05   #1753
Rebbit
Postovi: 664
evo da ti kazem, da iam 5770 obicnu verziju, sa referentnim coolerom novije serije, i grafa je u idle na 37C; load nije presla 60C....
sve igre mi vrti na nativnoj rezoluciji na 2048x1152 sve na high, i jako puno fpsa, ali bez AA, sa AA vrti npr cod 4 na 40 fpsa.......
konfa ti je u potpisu pa mozes vidjeti...
vent nikad nije presao 40% vrtnje sto ga cini necujnim...
a buduci da je ono vapor, vjerujem da ce bit jos tisa i hladnija...
nek sam isti kao on, ma nek sam isti ko stari moj, dok zivot juri, ja cu lagano....
Lenovo Thinkpad T14
Logitech MX Keys
Galaxy S23+
Rebbit je offline   Reply With Quote
Staro 12.03.2010., 08:28   #1754
Thommy
Thommy's Avatar
Postovi: 469
ja sam si isto zapikirao tu 5770 i sve mi se cini da cu uskoro po nju, mozda i danas
citao sam negdje na netu da je cak ovakva sa ovim bakrenim heatpipe hladnjakom tisa od vapor-x verzije (budem pogledao doma jel imam negdje link) a razlike u temperaturama su 2 stupnja
jel ima mozda netko takvu kakvi su dojmovi?
Thommy je offline   Reply With Quote
Staro 12.03.2010., 08:38   #1755
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Imaš prvu stranicu 5750/5770 teme,pa slušaj.
Staro 12.03.2010., 09:08   #1756
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor Thommy Pregled postova
Tiša nije, no kako je HD5770 ionako hladna grafa (ipak je idle TDP samo 16 W dok je load TDP relativno niskih 86 W) sve tri verzije hlađenja na safirkama odlično i iznimno tiho rade svoj posao.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 12.03.2010., 14:35   #1757
Rebbit
Postovi: 664
takvu istu ja imam... imas moj post tu iznad.... ugl.. supertiha je...
i evo mog posta o njoj..
" imam 5770 obicnu verziju, sa referentnim coolerom novije serije, i grafa je u idle na 37C; load nije presla 60C....
evo i slika da vidis... na cemu radi i tak.... jos je cak i hladnija nego sam napisao
sad surfam netom, skidam torrente i tak.. znaci nikakav ekstra rad...
SLIKA
vent nikad nije presao 40% vrtnje sto ga cini necujnim... " (najglasnij komponenta mi je u kucistu hdd (zalosno al istinito), pa napajanje, pa jedan vent koji mi hladi NB, i u istom rangu na idle su mi ac freezer i graficka
Lenovo Thinkpad T14
Logitech MX Keys
Galaxy S23+
Staro 12.03.2010., 15:01   #1758
Thommy
Thommy's Avatar
Postovi: 469
tnx svima na odgovorima .. nista do pol 4 sam na poslu pa cu onda do ADM-a po ovu vapor-x, razlika u cijeni između nje i ove sa referentnim hladnjakom je 14kn
Staro 12.03.2010., 21:10   #1759
DiRT
DiRT's Avatar
Postovi: 1,179
Poslušao si I, kakvi su dojmovi?
PC:
CPU:
Intel Core i7-7700
COOLER:
MBO:
MSI B250 GAMING M3
GPU:
RAM:
SSD:
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
WD Elements (2TB)
PSU:
MONITOR (TV):
KUĆIŠTE:
OS:
TIPKOVNICA:
MIŠ:
ZVUČNICI:
SLUŠALICE:
Sennheiser CX 3.00
AKG Y500 Wireless
MOB:
LAPTOP:
MBO: -
PC POSAO:
MBO: HP 895C
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
LAPTOP POSAO:
Staro 12.03.2010., 23:06   #1760
Thommy
Thommy's Avatar
Postovi: 469
uzeo sam vapor-x, za sad kolko ju imam ovih par sati ja sam skroz zadovoljan, odigrao malo battlefield i dirt2 poukljucivao sve opcije na high AA 4x i radi sve bez greske dirt2 prosjecno 45 fpsa, battlefield prosjek 35, sad da iskljucim AA dobio bi jos na FPSima ali i ovako to sve ide jako glatko, mislim da mi za singlepayer vise ni netreba
skinuo zadnje catalyste sa neta i to sve radi bez greske
hladnjak odlican, necujan da ga nisam manualno potjerao na 100% nebi ni cuo kak radi
sve u svemu sam zadovoljan i mislim da ce me ova kartica sluziti bar 2 godine kao sto me sluzila i HD3870 s obzirom da ja nisam vise neki zahtjevni gamer odiram 2 do 3 naslova godisnje
ak mi vrag nebu dal mira mozda kroz pol godine kad cjena rabljenih padne na kakvih 500kn piknem jos jednu pa crossfire
Staro 13.03.2010., 02:54   #1761
DiRT
DiRT's Avatar
Postovi: 1,179
Hehe...sad možeš neko vrijeme uživati i biti miran.
PC:
CPU:
Intel Core i7-7700
COOLER:
MBO:
MSI B250 GAMING M3
GPU:
RAM:
SSD:
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
WD Elements (2TB)
PSU:
MONITOR (TV):
KUĆIŠTE:
OS:
TIPKOVNICA:
MIŠ:
ZVUČNICI:
SLUŠALICE:
Sennheiser CX 3.00
AKG Y500 Wireless
MOB:
LAPTOP:
MBO: -
PC POSAO:
MBO: HP 895C
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
LAPTOP POSAO:
Staro 16.03.2010., 22:37   #1762
CosmModius
CosmModius's Avatar
Lokacija: uglavnom lose
Postovi: 85
to ti nije losa ideja, probao sam crossfire sa HD3870 i savrseno je radio..
sa vaporom ce biti bolje, samo sto ces se nacekat a pitanje ako ce ih bit na trzistu jer su ljudi danas poludili za tom karticom
I najškodljiviji čovjek možda je još uvijek najkorisniji od svih u pogledu održanja vrste; jer svojim djelovanjem on uzdržava u sebi ili u drugima nagone bez kojih bi ljudstvo već odavno bilo malaksalo i istrunulo.
CosmModius je offline   Reply With Quote
Staro 17.03.2010., 18:40   #1763
swen_blueneon
::pacijent::
swen_blueneon's Avatar
Lokacija: Os
Postovi: 27
ATi 5770 vs 4890
dakle, muči mekoju da si uzmem, a svakako moram jednu..
1. XFX 5770 XXX
Clock Speed 875 MHz
Stream Processors 800
Shader Model 5.0
DirectX version 11
OpenGL version 3.2
AMD Stream Yes
Capacity 1024 MB available
Type GDDR5
Clock Speed 5200 MHz
128-bit memory interfacing
2. XFX 4890
Clock Speed 1000 MHz
Shader Model 4.1
DirectX version 10.1
OpenGL version 3.0
AMD Stream Yes
Type GDDR5
Clock Speed 4000 MHz
256-bit memory interfacing
sve je jasno..podrška za dx 11,bla bla bla, al ipak 256 bitna arhitektura i core clock me brinu...da li se ipak 5770 može suprostaviti 4890 zato što je novija i ima podršku za novije stvari???
ako netko ima iskustva sa testom obje bilo bi super...
da bi budali dokazao da je budala, prvo se moraš spustiti na njegov nivo, a onda te porazi i ponizi jer je ekspert na toj razini...
swen_blueneon je offline   Reply With Quote
Staro 17.03.2010., 18:44   #1764
redscro
redscro's Avatar
Lokacija: Kupres
Postovi: 4,085
Mogao si malo pretražiti po forumu, pričalo se dosta.
Svejedno, 5770 se ipak ne može nositi sa 4890 nikako.
Staro 17.03.2010., 18:48   #1765
swen_blueneon
::pacijent::
Lokacija: Os
Postovi: 27
čitao jesam, al ipak me brine to što kada budu dalje izlazile igre s podrškom za dx11 i ostalo, neznam koliko će 5770 dobivati prednosti nad 4890
Staro 17.03.2010., 19:17   #1766
Postovi: 34,005
Igre s podrškom za Dx11 se mogu prebrojati na prste. Sve igre sa Dx11 moći će se igrati i na grafama bez podrške za njega. Trenutno je 4890 bolji izbor za igranje.
Staro 17.03.2010., 19:25   #1767
Mad_Duke
Autor coconut Pregled postova
A i 4890 je jača od 5770, tako da sve te igre budu bolje šljakale na njoj, a ako bi slučajno upalio DX11 mod u igri na 5770 bi mu pale još više perfomanse.
Mislim da je to "zadnji voz" za 4890 ako ju nađe.
Staro 17.03.2010., 19:29   #1768
swen_blueneon
::pacijent::
Lokacija: Os
Postovi: 27
hehe...ta je dobra...ako ju nađem
ok, onda ništa od 5770, eventualno 58xx ali to je onda vjerojatno puno skuplje od 4890.
dečki hvala na odgovorima, dobio sam što me zanimalo.
LP svima
Staro 17.03.2010., 19:58   #1769
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Autor swen_blueneon Pregled postova
LP svima
pa nebuš valjda kupovao novu? Imaš tu brdo postova pa ih malo prouči.
Btw. u zadnjoj igri Metro 2033, 5770 rastura 4890 a mislim da če toga bit još u nadolazečim igrama,osim ak kupuješ grafu za stare igre onda je 4890 odličan izbor.
Staro 17.03.2010., 20:20   #1770
swen_blueneon
::pacijent::
Lokacija: Os
Postovi: 27
pa više za nove nego za starije...zato sam se i raspitivao u vezi te dvije...jer jedna je jača, druga novija...a meni je nekako bilo da bi novija bila kasnije bolja, ne?
ova 5770 xxx je oko 1300kn, što je sasvim ok, a polovna 4890 kontam da je oko 1100
jbg...vidim još okolo, al mislim da je bolje 5770...tak je bar s procevima...ima bolju podršku...to je moje mišljnje, ako ništa drugo
