#1892 |
its slightly turbocharged
Postovi: 5,430
![]() Pa otključaš odmah specijalizacije u prvom levelu, netrebaš ih otključavati igrajući Ukratko rečeno u prednosti si jer imaš neke korisne specijalizacije odmah ![]()
blaa |
#1898 |
only fool, not a horse
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,280
#1899 |
Postovi: 488
#1901 |
Postovi: 1,662
Kada sam instaliro igru, naravno da nisam gledo kaj tam pise kak ocu da mi se igra registrira i ja odabro prvu i sada me trazi DVD non stop. Ak ju reinstaliram ocu morati ponovo upisivati onaj reedem kod? ili mi je to vezano uz serial? |
#1903 |
gejmer
Lokacija: Virgin Islands
Postovi: 452
PCE nick.................BF nick Veki-OS..................Veki[CRO] Slash555.................LegolasHR Visitor Q.................Visitor Q aircanada................S3mp3r (clan tag: [PcE]) ThePornstar.............carpediem90 blava......................Marko008 B3mt1.....................B3mt1 Mansky Hunt............ManHunt1986 (clan tag: [PcE]) proudixz..................proudixz hammer_of_thor........Narsil Neo-ST...................Neo-ST (clan tag: [PcE]) PointDexter..............Triumph2407 (clan tag: [PcE]) dUG1......................dUG1 Constantine.............The Constantine zwer54....................zwerr | clan: [CTN] bluefluid...................bluefluid michel......................MichelGTX bacyc......................bacyc385 Blue_Fatal1ty............Blue_Fatal1ty zgmmax....................zgmmax hobitxxx....................tOm[CrO] tech.........................[PCE]JadrankaKosor Danko86...................Danko86 Berovk......................(PCE)Bero Ninja666xx.................AsaHayyim Strider......................CRO Strider Paxton......................var|skovic [clan tag: =BoX=] Paxton......................varoskovic [clan tag: =BoX=] _Cox.........................CoxUT [clan tag: p.3h] morozinho..................Orozinho (cro) Nebbo......................Nebbo Eto dobio i ja igru, pa da vidimo kako to izgleda sa 2 tjedna zakasnjenja ![]() |
#1905 |
Tuco “the Rat” Ramirez
Postovi: 473
Tu su najavili taj update i jos neke buduce fixove kao npr. server browser... http://blogs.battlefield.ea.com/batt...2-q-amp-a.aspx |
#1906 |
Datum registracije: Jun 2004
Postovi: 3,996
Evo,piše lijepo da ono nije ping High pings even on local game servers. We're actually showing game latency instead of ping. Pa još gledam,nemoguče da odkad igram nisam vidio ama baš nikog sa pingom manjim od 100 ![]() |
#1908 |
Lokacija: Dubrovnik
Postovi: 1,287
Par rundi danas predobro. Otključo F2000 kako mala radi ![]()
S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX |
#1909 |
Postovi: 26
PCE nick.................BF nick Veki-OS..................Veki[CRO] Slash555.................LegolasHR Visitor Q.................Visitor Q aircanada................S3mp3r (clan tag: [PcE]) ThePornstar.............carpediem90 blava......................Marko008 B3mt1.....................B3mt1 Mansky Hunt............ManHunt1986 (clan tag: [PcE]) proudixz..................proudixz hammer_of_thor........Narsil Neo-ST...................Neo-ST (clan tag: [PcE]) PointDexter..............Triumph2407 (clan tag: [PcE]) dUG1......................dUG1 Constantine.............The Constantine zwer54....................zwerr | clan: [CTN] bluefluid...................bluefluid michel......................MichelGTX bacyc......................bacyc385 Blue_Fatal1ty............Blue_Fatal1ty zgmmax....................zgmmax hobitxxx....................tOm[CrO] tech.........................[PCE]JadrankaKosor Danko86...................Danko86 Berovk......................(PCE)Bero Ninja666xx.................AsaHayyim Strider......................CRO Strider Paxton......................var|skovic [clan tag: =BoX=] Paxton......................varoskovic [clan tag: =BoX=] _Cox.........................CoxUT [clan tag: p.3h] morozinho..................Orozinho (cro) Nebbo......................Nebbo Jumper......................Jump3r101 |
#1910 |
super user
Lokacija: Houston, TX
Postovi: 1,805
#1911 |
Postovi: 328
Evo grindo sam sa medicom do 15 levela da otkljucam magnum ammo i sada pwnam sa M4 ![]() Sa medicom se moze vrlo brzo levelirat, ali mi je k/d oso kvragu. M60 definitvno treba nerfat jer sa tim machine gunom medic postaje assult. I sekira me taj mrtvi noz, odnosno taj njegov auto aim. Noz je bio najbolje rjesen u counteru di si mu morao zabit noz u glavu da ga ubijes iz prvog puta. Onda se vidjelo ko je baja, a ne sad u guzvi samo stiscu taj noz i jednog ce valjd dovatit....glupost |
#1912 |
Lokacija: United Kingdom
Postovi: 512
HM eto malo googlo i jedino ovo naso... "Ping is simply the back-and-forth to the server and client. That is travel time on the wire. Latency figures in the delay on the client side computer for processing, as well as the server side. This is in addition to the ping back and forth from the server/client. Other problems that can raise latency is having your "rate" cvar set too high for your connection. If you have two friends and neighbors on the same ISP/internet plan connecting to the same server, and one has a latency 50ms higher than the other, it is safe to assume that there is an issue with their game configurations, since something else must be boosting his latency." BTW igro danas malo na BUG serveru Ajme katastrofe. Od ljudi koji su totalno nesposobni squad izabrad do toga da je FF upaljen pa sjedne neki idiot u tenk i 10 svojih pogazi... Strava... ![]() Zadnje izmijenjeno od: Beo. 16.03.2010. u 17:38. |
#1913 | |
Datum registracije: Feb 2010
Postovi: 297
#1914 | |
super user
Postovi: 1,805
#1915 | |
Postovi: 729
A da ne spominjem glitcheve (nađite knife flying u xifre videima) BTW jel vi vidite ping u server browseru, kaže da treba runnat kao admin al to meni ne pomaže. edit : evo link - > http://www.xfire.com/video/241f62/ Izgleda ko dbz XD |
#1916 |
hm ja nisam primjetio autoaim s nozem, wtf? sto se tice pinga, probaj reinstalirat igru, meni je pomoglo. |
