Staro 03.03.2010., 01:57   #451
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
http://www.opera.com/support/kb/view/872/
Compatibility problems with Adobe Flash Player 9 Update 3
sta je taj GTK
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 03.03.2010., 23:03   #452
Dottore
Dottore's Avatar
Postovi: 7,620
Autor Dottore Pregled postova
a gdje je ad block? u staroj verziji mi je radio savršeno a sada nema te opcije
bump!
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 03.03.2010., 23:05   #453
vercetti
vercetti's Avatar
Datum registracije: May 2003
Postovi: 1,226
Desni klik > Block content
vercetti je offline   Reply With Quote
Staro 03.03.2010., 23:12   #454
Dottore
Dottore's Avatar
Postovi: 7,620
nema ga
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 04.03.2010., 03:22   #455
rak21
COD2 expert
rak21's Avatar
Postovi: 1,918
nema ga
vjerovatno klikaš na sadržaj kojeg želiš blokirati..
uklikaj desnim na prazan dio stranice i onda će ti se ponuditi kolji sadržaj želiš blokirati, radi kako je zamišljeno..
Staro 05.03.2010., 12:36   #456
vercetti
vercetti's Avatar
Postovi: 1,226
Kod mene ne radi "forward" tipka na misu u ovoj novoj Operi.
Npr. kod google search, umjesto next page, kliknem na forward i prebaci na slijedecu stranicu, no sada vise nece...
Staro 05.03.2010., 12:44   #457
Pero 1978
Pero 1978's Avatar
Datum registracije: Jan 2010
Postovi: 4
Autor fre@k Pregled postova
dali je moguce da namjestim da mi opera bude u jednom "windows-u" jer kad koristim na W7 on mi ih razbaca dole na svakog pojedinacno pa nemogu minimizirati klikom na operu, nisam naisao u opcijama na neku opciju. Zna netko mozda rjesenje. I jos nesto prvih 3 dana je opera radila ultra brzo PCE forum se nikad tak brzo otvarao nije odjednom uzasno sporo...
opera:config UserPrefs|Use Windows 7 Taskbar Thumbnails makni kvačicu
Nadam se da je to ono što tražiš, bar je mene to mučilo
Pero 1978 je offline   Reply With Quote
Staro 05.03.2010., 18:05   #458
CoreDownloader
Skidaj se do kraja ;-)
CoreDownloader's Avatar
Lokacija: Tunguzija
Postovi: 158
moram reći da opera 10.5 final rasutra...doslovno u brzini....
Bez linkova u sigu.
CoreDownloader je offline   Reply With Quote
Staro 05.03.2010., 18:16   #459
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Tomo je offline   Reply With Quote
Staro 05.03.2010., 23:03   #460
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
Autor Pero 1978 Pregled postova
bravo decec nisam se ni sjetio da pogledam pod config zahvaljujem
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 06.03.2010., 00:41   #461
Pero 1978
Pero 1978's Avatar
Postovi: 4
Davno sam ja bil dečec
Staro 06.03.2010., 01:14   #462
Mast3r Chi3f
Mast3r Chi3f's Avatar
Postovi: 118
Nova Opera je nazalost predobra, te ce se isto desit ko i s firefox-om, previse ljudi ce je otkrit i prec na nju, onda ce se on previse izkomercijalizirat i poglupit ne bi li ih privukla jos vise i nikad vise nece biti tako dobra i sigurna kao prije a ja cu opet morat koristit nekakv novi, ludi i jos neispeglani browser
Sine, ako stvarno nešto želiš u životu, morat ćeš raditi za to. A sada tišina! Počinje izvlačenje brojeva za lutriju
Mast3r Chi3f je offline   Reply With Quote
Staro 06.03.2010., 02:59   #463
Postovi: 7,568
Zadnje izmijenjeno od: McG. 13.01.2012. u 01:17.
Staro 06.03.2010., 17:11   #464
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,886
McG tak je bilo oduvijek. Ali ako nekom nesto radi za njegove potrebe dovoljno brzo, onda ni ja nebi prelazio. FF sam preporucivao svima no sad mi je postal sranje Opera rastura isto tako mi je i Safari odlican, IE nikad koristio nisam a znam da njih bar 40% iz društva koristi jer za druge nisu ni culi. Tko voli nek izvoli
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 06.03.2010., 18:28   #465
nino_z
nino_z's Avatar
Lokacija: Valpovo/Osijek
Postovi: 267
Nikada Opera neće niti iznad par postotaka, jer to nije browser za mase. Koristim ju od 5.02, ali nikada nisam ljudima kod instalacije windowsa stavljao Operu. Njima treba out-of-box softver, a Opera to nije. Ona je za ljude koji žele mogućnost totalne personalizacije; naravno da radi i po default postavkama, ali onda ti i ne treba. Prije sam stavljao Firefox, koji na žalost moram i na poslu koristiti, a u zadnje vrijeme svima stavljam Chrome koji koristim i kod kuće kao drugi browser. Opera je u rangu Total Commandera ili Forte Agenta, softver za odabrane :-)
nino_z je offline   Reply With Quote
Staro 06.03.2010., 20:16   #466
Mast3r Chi3f
Postovi: 118
Ne znam bas, nadam se da ste u pravu ali Opera Software ASA nije neprofitna organizacija, koliko vidim izlistani su na burzi i sigurno im je stalo do povecanja trzisnog udjela a time i zarade
Sve u svemu ovakve vijesti mi se nimalo ne svidjaju.
Sto se tice navike, s tim se u potpunsosti slazem - dobar dio ljudi je skucena uma i drzi se nekakvog prekambrijskog softvera ko pijan plota
Ja sam za sad zadovoljan s Operom, Aimpom, Kmplayerom, Foxitom, CCcleanerom...al to ne znaci da sutra necu prijeci na nesto divlje i bolje
Staro 07.03.2010., 00:02   #467
Conroe
Power Abuser
Conroe's Avatar
Postovi: 388
Bug?
ne mogu se ulogirat na Facebook s verzijom 10.50, dok sa IE mogu sasvim normalno kao i prije
ima li još tko takav problem?
Conroe je offline   Reply With Quote
Staro 07.03.2010., 01:18   #468
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Kak svoj komp nemam već 2 mj korisim drugi, koji je kakti od staraca a na njemu je FF default. Gore je instalirana i Opera i IE8 i FF ali zbog staraca sam im stavio FF i kad sam na njemu i ja ga koristim.
I nakon 2 mj korištenja FF mogu reć da mi nikak ne leži, em je spor kod otvaranja, em nema nekih sitnica bez kojih više ne mogu a Opera ih ima od desni klik i scroll, od otvaranja novog taba sa midle mouse button, lock taba i ostalih koje nisu koliko presudne ko ove tri.
Ovu novu Operu sam instalirao i malo se igrao u njoj i mogu reć da jedva čekam svoj komp u komadu da se vratim na operu
žmnpp
Staro 07.03.2010., 03:44   #469
Rus666
Datum registracije: Mar 2010
Postovi: 7
Po meni je u zadnje vrijeme iexplore bolji i od opere i od mozzile
uzasno je brz
Rus666 je offline   Reply With Quote
Staro 07.03.2010., 04:25   #470
tutix
tutix's Avatar
Postovi: 4,068
Autor Conroe Pregled postova
Ista stvar. A radila je dobro dva dana bez problema. Stvarno ovo je najbolja inačica dosad, brza i stabilna ali opet sam naišao na par bugova. Recimo jučer nisam mogao pristupit stranicama fakulteta (dok na bilo kojem drugom browseru, pa čak i na prijenosniku sa istom verzijom Opere sam mogao). Restart Opere riješio problem. Danas ovo sa Facebookom za što navodno pomaže brisanje cookiesa (meni nije). Nije mi jasno. Tako rado bi se maknuo sa Firefoxa jer me iritiraju neke stvari, ali jednostavno svaki put kad probam na Operu nešto na njoj ne radi .
Staro 07.03.2010., 05:50   #471
Mast3r Chi3f
Postovi: 118
Autor tutix Pregled postova
To ti je cijena koju opera placa zbog male rasirenosti.
Iako se ona najvise pridrzava standarada za nju se najmanje i zadnje optimizira prikaz stranica pa otuda a ne od bugova 99% problema
Staro 07.03.2010., 10:56   #472
Conroe
Power Abuser
Conroe's Avatar
Postovi: 388
ja riješio problem
Idi na Tools-Delete Private Data chekiraj da obrise cookiese (pazi da ne obrises wand)
zatim idi u folder C:\Users\Tvoje_Ime\AppData\Local\Opera\Opera\ i obrisi sadrzaj foldera vps
zati idi u C:\Users\Tvoje_Ime\AppData\Roaming\Opera\Opera uradi backup filea cookies.dat i obrisi ga (promjeni mu ekstenziju u .dat.old ili slicno)
Staro 07.03.2010., 11:19   #473
Postovi: 7,568
Staro 07.03.2010., 11:30   #474
Bambusha
Bambusha's Avatar
Lokacija: Čepin
Postovi: 297
Napokon si složio Speed dial kak' mi odgovara, ali nisam u potpunosti zadovoljan.
Kako mogu (s kojim programom...) napravit' da mi thumbnails-i izgledaju ko za titlove.com (gore lijevi na slici). Dakle da nema "bjeline" oko simbola (kao You Tube recimo ili crnine na Xfire thumb-u).
Znam da sam noob, al' takav sam kakav sam.
I jel netko možda zna/se sjeća gdje je jedan user s foruma napravio thumb za PC Ekspert forum? Tražilica nije pomogla.
Intel G1610; ASUS B75M-LX Plus; 4096 MB; Intel HD; Hitachi 7K1000.C 500 GB; LG GH24NS95; Silverstone Strider Essential 400 W; Logitech K200; Logitech B110; Logitech X-240 2.1; Philips 200V4LAB 20" DVI; Windows 7 64-bit Professional
Zadnje izmijenjeno od: Bambusha. 07.03.2010. u 12:40. Razlog: Sliku u thumb, ne možeš stavljati 370 kb da se direktno učitava kad je 50 max.
Bambusha je offline   Reply With Quote
Staro 07.03.2010., 12:13   #475
Postovi: 7,568
Staro 07.03.2010., 16:39   #476
beavis
beavis's Avatar
Lokacija: Na moru
Postovi: 155
Imam 10.10, a kada stisnem update pise "You are using the latest version of Opera"
beavis je offline   Reply With Quote
Staro 07.03.2010., 16:57   #477
Rus666
Postovi: 7
Autor beavis Pregled postova
Probaj uninstalirat pa nabacit opet ili proguglat final
Staro 07.03.2010., 19:51   #478
nino_z
nino_z's Avatar
Postovi: 267
Skini 10.50 i kada počneš instalaciju ponudit će ti upgrade
Staro 07.03.2010., 21:05   #479
tutix
tutix's Avatar
Postovi: 4,068
ja riješio problem
Hvala, riješilo problem
Autor McG Pregled postova
Moja sestra isto koristi Operu 10.50 i Fejsbuk joj radi bez problema. Jedino na kaj je u zadnje vrijeme imala pritužbe, je onaj slučaj (otprije koji tjedan) s Fejsbuk serverima kad je "pol svijeta" imalo probema s logiranjem.
Ma nisam ni ja imao problema u početku, ali dva-tri dana poslije počelo zaj..avat...
Staro 07.03.2010., 23:30   #480
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,614
Nije mi jasno zašto je ovo ovako:
http://i46.tinypic.com/106h36p.png
Gotovo uopće ne mogu pročitati što piše s malo veće udaljenosti, jedino me spašava što znam gdje je šta Ne znam zašto to baš mora biti prozirno :S
Dobro, osim u Windows native skinu, koji je gadan
