Staro 27.01.2010., 01:38   #1
-ELF
-ELF's Avatar
Lokacija: eire
Postovi: 366
Smile AMD 6Core Thuban Procesor
Ljudi dolazi nam novi prob krajem godine.
Kodnog imena AMD Thuban, ima L2 2mb i L3 6mb...
-ELF je offline   Reply With Quote
Staro 27.01.2010., 04:19   #2
Rebbit
Postovi: 660
ko ziv ko mrtav do kraja godine, a i pitanje sta ce intel spremit za iznenadjenje, i naravno da ce sve opet bit skupo ko grcka
nek sam isti kao on, ma nek sam isti ko stari moj, dok zivot juri, ja cu lagano....
Lenovo Thinkpad T14
Logitech MX Master 2S
Logitech MX Keys
Galaxy S23+
Rebbit je offline   Reply With Quote
Staro 27.01.2010., 09:12   #3
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
samo neka bacaju nove proceve taman bi mogao na ljeto sjest jedan i7
.i.
Razer Blade 15
Staro 27.01.2010., 11:28   #4
-ELF
-ELF's Avatar
Lokacija: eire
Postovi: 366
Pa kako kazu, prvo ce nam doci i7 980x, a onda od aprila dolaze 6 jezgreni intel procesori i Pentium G6950...
Staro 27.01.2010., 12:18   #5
Mad_Duke
Jel se zna nešto o arhitekturi više?
I da li će se moći "skalirati" kao do sada (1,2,3,4, odnosno kog novih 5,6,7,8 jezgri)?
Staro 27.01.2010., 12:22   #6
-ELF
-ELF's Avatar
Lokacija: eire
Postovi: 366
AMD’s processor code-named Thuban is the company’s first desktop processor with six processing engines. The microprocessors will be compatible with socket AM3 infrastructure and will have integrated dual-channel PC3-10600 (DDR3 1333MHz) memory controller. It is very likely that Thuban processors will retain AMD Phenom II brand name as well as design of the code-named Istanbul chips for servers, thus, will feature 3MB L2 cache (512KB per core) and 6MB of L3 cache. The chips will be made using 45nm SOI fabrication process.
Thuban is a star in the constellation of Draco and it also means “dragon” in Arabian language. The new six-core chip should be compatible with existing AM3 infrastructure (and, quite possibly, even with AM2+ infrastructure with split power plane), it remains to be seen whether Thuban becomes a part of AMD’s current high-end desktop platform called Dragon, or will power the company’s next-generation Leo platform.
AMD’s Leo platform will be based on the AMD 890FX and 890GX core-logic sets. The new chipsets will offer better performance and functionality, e.g., they will support Serial ATA-600, 14 Serial ATA 2.0 ports and so on, but both will only hit mass production in April, 2010, and will be formally released in May next year, according to market sources.
Provided that AMD has its Thuban processors ready before May 2010, the company is likely to start shipping them as soon as possible so that to be able to compete for the high-end desktop segment. In fact, it is somewhat surprising that AMD will only be able to offer six-core desktop chip about a year after it started to ship six-core chips for servers. Nevertheless, based on currently available information, AMD Thuban is due only in Q3 2010.
At present AMD does not position its six-core Opteron processors even for single-socket workstations and recommends its customers among makers of dual-socket workstations to stick to quad-core chips due to their higher clock-speeds compared to existing six-core central processing units. At present AMD’s highest-performance six-core chips operate at 2.80GHz, meanwhile, the fastest quad-core CPUs function at 3.40GHz.
With six physical cores AMD will be able to demonstrate rather high performance in multi-tasking and applications that need to execute numerous threads at once. Moreover, as future video games that rely on DirectX 11 start to arrive, the advantages provided by six-core Thuban and Istanbul processors will be even more apparent.
Intel Corp., the larger rival of AMD, plans to unveil its six-core code-named Gulftown chips for desktops in Q2 2010.
The folks at PCLab.pl have gotten their hands on a sample of Intel's upcoming Gulftown Core i9 processor and put it through its paces. PCLab pitted the six-core chip against Intel's Core i5, Core i7, Core 2 Quad and AMD's Phenom II. The chip was tested in three separate motherboards, the Gigabyte EX58-Extreme, Asus Rampage II Gene, and Asus P6T SE.
Clocked at 2800MHz, the Core i9 beat the competition in a majority of the tests -- especially those optimized for multi-core chips -- but Gulftown slips behind its predecessors in many benchmarks. Intel's upcoming hexa-core CPU takes the cake when it comes to tasks like video encoding, but those two additional cores make little to no real-world difference in most games and other standard use.
PCLab found that the Core i9 performed rather well in terms of power usage, consuming far less than the Core i7 during maximum load, and only a hair more when idle. It ran cooler than the competing CPUs, with an idle temperature of 30C and 42C under load, which compares to the Core i7 at 32C and 49C. The chip also overclocked well, reaching a core clock frequency beyond 4.3GHz.
Realize that these results could change, as the tested product was only an early engineering sample. The Core i9 is expected to launch at some point during the first quarter of 2010
Staro 27.01.2010., 13:43   #7
Minos
Lokacija: doma
Postovi: 21
"CroSimRacing"
Minos je offline   Reply With Quote
Staro 27.01.2010., 14:38   #8
-ELF
-ELF's Avatar
Lokacija: eire
Postovi: 366
jeste odlicno, ali koja ce cena biti...
btw, koja je onda poenta kupovat, recimo i3 kad ce sad izac i9...
ja sam i dalje za q9550,... eheh
Staro 27.01.2010., 14:57   #9
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Poanta je da je i3 namjenjem low end tržišnom segmentu i "kao" za nezahtjevne korisnike ali su preskupi za ono što nude doduše tako je bilo i sa E7xxx modelima koje zamjenjuje i tu se najbolje smjestio E6300 koji je bio pun pogodak kako sa cijenom tako i mogučnostima.
Tako da je tu AMD vidio kako bi mogao omastiti brke u toj klasi jer je poprilično jeftiniji sa modelima koji konkuriraju i3 procesorima još kad uzmeš MBO ajme cijene....... 1.500+ krznaša
Staro 27.01.2010., 15:00   #10
-ELF
-ELF's Avatar
Lokacija: eire
Postovi: 366
ma joj...
kud je recesija tu i novi procesori... ehhe..
ni i7 nije posto hit, izlazi i9...
