Staro 02.01.2005., 13:46   #1
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,188
Kako igrati Need For Speed Underground 2 preko LANA
Zna li netko kako se može igrati NFSU2 preko LAN-a , meni se kad se trebam prikljucit u i gru prikaze neka fa.... poruka da provjerim vezu i sl.... Je li tko uspio igrati preko LAN-a ????
Staro 02.01.2005., 21:28   #2
Kerber
Captain
Kerber's Avatar
Lokacija: Osijek-Bilje
Postovi: 282
Isto pitanje isti problem. Meni ispise connecting to lobby, pa zatim
unable to connect????????
Kerber je offline   Reply With Quote
Staro 02.01.2005., 21:42   #3
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Isto!!!!!
Daj eksperti upomoć!!!!
Staro 03.01.2005., 10:57   #4
Ivor
Ivor's Avatar
Lokacija: Restricted Area
Postovi: 337
Ako imate original verziju sigurno ste dobili broj za support EA pa nazovite
Ivor je offline   Reply With Quote
Staro 03.01.2005., 16:59   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Lakše malo s izjavama inače zatvaram.
Staro 06.01.2005., 20:29   #6
Blue Spirit
Postovi: 2,188
Trazio sam na netu odgovor no neki spominju da se trebaju imati nekakve iste postavke i da onda radi !!!
Staro 07.01.2005., 10:57   #7
Domi
Domi's Avatar
Datum registracije: Feb 2004
Postovi: 302
Na netu kažu ovo:
Here's the Solution
OK, I have the solution that will save ANY and ALL problems revolving around Need for Speed Underground 2 and the LAN. I picked this off of another forums page on another website.
Solution: ALL computers that will be playing together must have (in windows) a set default gateway. The gateway must be the same on all computers.
To set the default gateway: right click on the network icon that appears in the system tray. click on status. click on properties. then click on internet protocol properties. u are now where u set the IP address of the network card. under it, there is a place to set the default gateway and the default DNS server. set a default gateway. this must be the same on all computers.
Information must be free and accessible to all.
sad nisam čitao dalje dal je upalilo.. Još su neki rekli kako treba patchat na 1.1 verziju jer to ispravlja neke bugove na LAN-u.
KAJ
Domi je offline   Reply With Quote
Staro 07.01.2005., 19:28   #8
mann
mann's Avatar
Postovi: 2,222
Iz prve ruke znam da radi. Mada iz nekih razloga duhovi udju u igru i silom nece proradit kada server digne neki odredjeni komp. Mi nismo instalirali nikakav patch...
Staro 07.01.2005., 19:42   #9
Domi
Domi's Avatar
Postovi: 302
A dobro, radi, to sam čuo od dostaljudi po netu, ali kaj napraviti kad ne radi, odnosno da proradi?
Ja sam probao s ovim gatewayem ali nije uspjelo. sad ću još probat patchat pa ću vidjet.
Probao sam hostat igru na svakom od dva kompa koja imam i niti jednom nije radilo. :|
KAJ
Staro 09.01.2005., 10:01   #10
Kerber
Captain
Kerber's Avatar
Postovi: 282
meni je proradilo sa gatewayem i bez patcha
Staro 26.06.2008., 23:21   #11
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
za default gateway treba upisati istu adresu koju posjeduje (w)lan adapter
Staro 26.06.2008., 23:30   #12
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
ja sma imao samo patch i radilo kak spada
Staro 14.04.2009., 18:20   #13
5h4d0w
5h4d0w's Avatar
Datum registracije: Aug 2008
Postovi: 28
ja znam rjesenje a mislim da i ostli znaju takodjer al ipak cu ovo podjelit s vama
odete tamo di ste instalirali igru..
npr. D:\Program Files\Need For Speed Underground 2
i tamo nadji te server.cfg i otvorite ga u notepadu.
U zadnjem redu vam je ovako
ADDR=%%bind("159.153.253.82")
a vi stavite ovako
#ADDR=%%bind("159.153.253.82")
i sada kako igrati preko lana?
ja sam nasao jedan programcic.. Hamachi
(eo vam link) https://secure.logmein.com/products/hamachi/list.asp
i preko njega pokrecete lan igre....
1. instalirate ga
2. pokrenete
3. napravite svoj nick
4. otvorite network
password: 123
i lijepo odete u igru i pokrenete je u lanu..
ak nema niti jednog lan servera ili vam pise searching lan server nemora te se brinut neko valjda nije napravio server pa cekajte da netko napravi ili jednostavno vi mozete napravit....
NADAM SE DA SAM VAM POMOGAO
(ja (sam (zajebant))
5h4d0w je offline   Reply With Quote
Staro 19.01.2010., 14:31   #14
kule#7
Datum registracije: Jan 2010
Lokacija: rijeka
Postovi: 1
Koliko igraca u lanu mogu igrat?
zanima me koliko igraca u lanu mogu igrat i ima li problema prilikom igre?
kule#7 je offline   Reply With Quote
Staro 19.01.2010., 15:22   #15
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Ja sam igrao sam sa 4 frenda. Milslim da može 8 ljudi igrat, ali nisam siguran.
Ne vidim zašto bi trebalo biti problema što se tiče igre.
Staro 12.04.2011., 20:01   #16
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
Evo nakon dugo vremena maknuo prasinu s ove igre i odigrao je do kraja. Mene sad zanima da li ima nekakav mod da otkljucam sve wide-body u karijeri? Znaci zelim da mogu navidat widebody na bilo koje auto u igri, a da ne idem u Quick race?
Drift_King je offline   Reply With Quote
Staro 13.04.2011., 10:11   #17
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Autor Ivor Pregled postova
Uglavnom sve upite iz nase zemlje preusmjeravaju u Algoritam. Dalje ne bih komentirao...
