Staro 10.01.2010., 10:25   #1
leonardo
leonardo's Avatar
Lokacija: somewhere
Postovi: 284
Full-HD LCD televizije sa ugrađenim MPEG-4 TVB-T tunerom - pregled ponude
42/46/50''42/47/52''40/46/52''
 PanasonicLGPhilipsToshibaSamsungSonySharp
Model:TXP42G10TXL42G10ETXL42U10E42LH500042LH400042LH300042PFL9664H42PFL7404H42PFL5604H42ZV635DB42XV635DB42RV635DBLE40B750LE40B650LE40B530KDL40z5500KDL40w5500KDL40v5500LC46DH77ELC46DH65E
frekvencija osvježavanja10010050200100502001005020010050200100502001005010050
tehnologija
tip panelaNeoPDPIPS-alphaH-IPSS-IPS / H-IPS / ASVS-PVASony / Samsung S-PVASharp ASV
matrica (xvYCC)10-bit8-bit10-bit10 / 8-bit17-bit14-bit??10-bit8-bit10-bit8-bit10-bit10 / 8-bit
sharpness-enhancingVreal Pro 4?TruMotion-Perfect PixelPixel PrecisePixel+ HDResolution+Motion Plus-Motionflow-??
odziv (ms)0.001??2.435135??5??????46
kontrast2.000.00050.00080.00050.00080.00050.000100.00050.000100.00060.000100.00060.00050.00020.000
svjetlina (cd/m2)?500500500450??450
ostalo
podjela ekranaPaT-PiP, PaT-?PiPotkljucatiPiP, PaP, PaTPaTPiP, PaT
priključci
HDMI2+13+11+13+12+14+13+12+13+13+13+12+1
DVB-C+ (CI Plus standard)--o-od 09/2009o-
S-Video & compositeocomposite ONLYoocomposite ONLYoo
SCART *composite1(RGB, S-video) + 1(RGB)1(RGB) + 12(RGB, S-Video)1(RGB) + 1(S-Video)2(composite ONLY)2(RGB)1(RGB) + 1
USB + video reprodukcija-ootkljucatiMPEG-1/2/4 (no DivX)ooB550MPEG-1/2/4 (no DivX)Music, Photo ONLY
memorijske karticeSDHC--SDHC----SDHC
Ethernet & DLNA networko--o--o-o-
Wireles / Bluetooth--WiFi--WiFi---
digital audio OUTopticalopticalcoaxialopticalopticalopticaloptical?
audio
zvučnici2 x10W2 x10W2 x15W2 x10W?2 x 10W2 x10W2 x10W2 x10W
surround soundV-audioSRS TrusurroundDolby VirtualDolby Digital SurroundSRS Trusurround HDS-Force Front Surroundo
dimenzije
debljina (mm)106958790/101885083/88?92?78.679.386/8693/9610397
cijena
32''-5.4003.5004.4004.0003.200-5.1004.200???-5.3003.500-5.4004.6007.0004.500
37''-6.0004.5405.0005.3004.600-?4.800???-6.2504.800-6.0005.100?6.650
40/42''7.000-5.3005.8005.8004.90012.8007.3005.300???9.0006.8005.1509.0006.6505.90010.700?
46/47''10.700--9.200?6.60015.00010.0008.700???12.50010.2008.00012.50010.0008.80013.6009.000
50/52''12.500-----?13.20012.000???18.000??15.00012.00011.20018.00014.400
U tablici je uključena Panasonic G10 plazma radi usporedbe. Zajedničko svim modelima je Full HD (1920x1080) rezolucija, analogni / DVB-T MPEG-2 / MPEG-4 AVC(H.264) tuner, CI utor za dodatne kartice, komponentni video (Y, Pb, Pr + Audio), PC (15-pin D-Sub) priključak i 3.5mm izlaz za slušalice.
objašnjenje tablice:
  • frekvencija osvježavanja - U tablici su prikazani 50/100/200Hz modeli iz 2009. godine. Za razliku od Sony i Samsunga 200Hz modeli marke LG, Philips i Toshiba su zapravo 100Hz televizije koje koriste tehniku 'Black Frame Insertion' kako bi stvorili utisak fluidnosti i bolji kontrast. Panasonic i Sharp u ponudi nemaju 200Hz modela.
  • tip panela - Samsung i Sony koriste panele iz zajedničkog razvoja. Philips je u 2008. koristio LG-ove H-IPS panele. 2009 Philips se povukao iz vlasništva LG, tako da je sada uz te panele koriste i Sharpove ASV panele.
  • matrica (RGB reprodukcija) - xvYCC (x.v.Color ili Deep Colour) je prošireni spektar boja. 1,8 puta veći u odnosu na 8-bitni standardni sRGB. xvYCC je uključen u HDMI 1.3 specifikaciju. Razlika između 10 i 8-bitnih panela je vjerojatno manja nego kod 8-bitne (IPS, xVA) i 6-bitne TN LCD matrice.
  • podjela ekrana - Picture-in-Picture (slika u slici), Picture-and-Teletext (slika do teleteksta)
  • DVB-C+ - Budući sistem kodiranja zaštićenog DVB-C signala, još nije prihvaćen kao standard. Za prijem (možda) nećete trebati vanjski receiver već ćete karticu sa modulom direktno ubaciti u CI slot.
  • SCART - Svi SCART imaju mogućnost ulaza i izlaza kompozitnog video (žuti RCA izvučeno preko preko adaptera) i stereo zvuka (bijeli i crveni RCA konektori). Neki proizvođači jednostavno ne iskoriste dodatne žice u SCART-u za S-Video ili RGB komponente.
  • USB + video reprodukcija (USB 2.0) - LG i Samsung čitaju MKV i DivX, Sony je tu negdje iako je nešto slabiji po pitanju broja podržanih formata. Philips ne čita MKV i ima problema s titlovima (zapravo ima problema sa svime osim sa čistim MPEG-2), Panasonic i Sharp nemaju mogućnost gledanja filmova.
  • Ethernet (DLNA) - Pristup home mreži u kojoj postoji kompjutor koji služi kao DLNA media server i surfanje netom direktno (samo sa daljinskim gotovo neupotrebljivo) ili preko specijaliziranih portala trenutno više ili manje pod kontrolom pojedinih proizvođača.
  • zvuk - Svi modeli imaju standardno loše 2 x10W zvučnike osim Philips-a serije 9 koji ima standardno loše 2 x15W zvučnike.
  • cijena - Cijene preko nabava.net početkom siječnja 2010
Stvari koje mene zanimaju a malo ih je teže pronaći u specifikacijama su postojanje digitalnih audio ulaza i mogućnost prijema, odnosno samo prijenosa DTS signala. Svaka pomoć je dobrodošla.
Također bilo bi stvarno korisno ukoliko netko ima podatke za pojedinačne modele o izmjerenom nivou crne boje i kalibriranom kontrastu (uz recimo 200cd/m2 maksimalnog osvjetljnja). Podaci o 1:1.000.000 maksimalnom kontrastu i 1.000 cd/m2 samo su indikacija ali ne moraju predstavljati realne mogućnosti pojedinog modela.
Tablica je napravljena da bude što preglednija. U tablici naravno nedostaje dosta podataka iz specifikacija kao što su 24p reprodukcija, postojanje senzora osvjetljenosti, mogućnost isf kalibracije i slično. U tablici najviše nedostaje podataka o Toshibi. Ukoliko imate podatke o tome ili o bilo čemu što smatrate da bi bilo dobro ubaciti slobodno se uključite. Sve se naravno može dodati po potrebi.
Uživajte
Zadnje izmijenjeno od: leonardo. 12.01.2010. u 08:48.
leonardo je offline   Reply With Quote
Staro 10.01.2010., 10:26   #2
leonardo
leonardo's Avatar
Lokacija: somewhere
Postovi: 284
preporuka LCD: Samsung B650
dobro: odlična slika u svim uvjetima, ima USB koji vrti gomilu formata, manja potrošnja (100-tinjak vati kalibriran).
loše: samo 2 god. garancije, mogućnost da je ugrađen slabiji panel (na naljepnici sa desne strane pod version mora prvo slovo biti "S" to znaći da je Samsungov panel), nešto veći input-lag u odnosu na LG.
preporuka Plazme: Panasonic G10
dobro: 5 god. garancije, savršena slika u idealnim uvjetima (smanjeno svijetlo bez refleksija). TX-P42V10 ima THX certifikat, dodatni HDMI i ugrađeni DVB-S tuner. V10 i G15 imaju ugrađene 12-bitne panele.
loše: nema mogućnost reprodukcije filmova preko USB (iako se to naravno da rješiti kupnjom vanjskog playera), zujanja koje servis ne priznaje kao kvar, dvostruko veća potrošnja struje u odnosu na Samsunga, 200 sati uhodavanja, opasnost od burn-ina (što god drugi pričali o NeoPDP-u), fosforni tragovi na koje su neki osjetljivi, slabija slika u uvjetima svijetlije prostorije, naroćito ako je TV nasuprot prozoru, slab video i film deinterlacing, što znači da nije tako dobar prilikom prebacivanja iz digitalnog signala OiVa (PAL, 576i, 50 Hz) odnosno interlaced u progresive 576p koji se zatim upscalira na full HD rezoluciju G10 panela. Blur kod brzih pokreta je izraženiji nego kod Samsung B650 i Sony LCD-a sa 100 Hz tehnologijom. Princip osvježavanja plazma ekrana je isti kao i kod LCD-a. “600Hz” je čisto makretinški trik, odnosi se na TV sub-field frame creation engine ili kako ga Panasonic naziva IFC (Intelligent Frame Creation) i služi kako bi smanjio treperenje boja. Uz nižu frekvenciju to je princip rada svih plazmi dosada. Treperenje boja ima za posljedicu umor očiju kod gledanja plazme izbliza i uz potrošnju razlog je zašto izbjegavati starije plazme.
Plasmas work in a similar way to CRTs, based on a very similar phosphor based technology, they flicker in the same way that LCDs do. They do have a degree of blur but it's nowhere near what you get on LCDs. The 600Hz marketing is a complete marketing scam, the 600Hz number comes from the sub field drive, which has always been the way plasmas work (allbeit not at 600Hz), it's actually related to reducing colour dithering and other plasma problems along those lines. The 100Hz systems on plasmas are there solely to reuce the flicker, because flicker is visible to the human eye at 50Hz, there's no frame interpolation system like on LCDs because it's not needed (there has been one added to a couple, but only because of marketing reasons). Blurring is in direct relation to the response times (CRT 0.006 microseconds, plama 0.001 miliseconds and LCD 2ms at best). And response time is effectively the speed at which a pixel can change colour (or grey to grey).
Sorry morao sam
Ne kužim.tu je vec par ljudi reklo da sd nije baš zadovoljavajuća tj lošiji nego na nekim drugim modelima(izmjereno očima) i uvjek je odgovor da to nije dobro spojeno u dućanu.kak se baš na toj g10 uvjek zahebu sa spajanjem ili kalibriranjem ili več sa čim se zajebu.
Zadnje izmijenjeno od: leonardo. 10.01.2010. u 11:19.
Staro 10.01.2010., 11:36   #3
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Zagreb / Maksimir
Postovi: 4,003
televizori, ne televizije...
i već vidim da će počet flejmanje u vezi ovoga što si nadrobio o G10...
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 10.01.2010., 11:50   #4
tech
Postovi: 1,687
A kaj je najgore, 80% je glupost, zapravo sve je glupost čim si krenuo uspoređivati lcd i plazmu.
I da, imaš gore zakeljenu temu, mogao si tamo postati.
Staro 10.01.2010., 13:22   #5
kis
kis's Avatar
Datum registracije: Oct 2001
Postovi: 156
Čuj u ovo si krenuo možda i s dobrim namjerama, no nije dobro ljude navoditi na zablude.
Na tržištu ima puno više televizora s MPEG-4 DVB-T tunera, naročito kod Panasonica.
Sorry no pusti ovu temu ljudima koji o tome znaju više od tebe.
NHF
kis je offline   Reply With Quote
Staro 10.01.2010., 15:25   #6
leonardo
leonardo's Avatar
Lokacija: somewhere
Postovi: 284
Zanima me odakle ti znaš koliko ja znam o ovome što sam napisao? Na tržištu nema puno više LCD-a s MPEG-4 DVB-T tunerom. Panasonic ima dva modela - 100Hz G10E i 50Hz U10E. U tablici su navedeni osnovni modeli zato jer bi s podvarijantama tablica stvarno bila nepregledna.
Što se tiče zabluda, hm. Podaci su točni toliko koliko znam iz vlastitog iskustva i onoga što sam pročitao. Ukoliko vidite nešto pogrešno u tablici ili tekstu, napišite slobodno. Topic je kao takav i zamišljen. Tako da ljudi na jednom mjestu mogu pregledno pročitati neke tehničke stvari za koje bi im inače trebalo daleko više vremena da to rade sami.
Generalno diskreditiranje cijelog posta je generalna glupost. Ljudi koji znaju više od mene nisu napravili ništa slično ovoj temi. Niti su pokušali ukrako objasniti neke pojmove. Sad se mene pokušava ušutkati. Odlično. Ništa, ljudi kupujte samo Panasonic zato jer drugi nemaju pojma. Nemožete gledati filmove sa USB-a - nemožete ali nema veze. Plazme se više griju nego LCD i sve je to potrebno nekako ohladiti ali nema veze. Potrošnja struje - nema veze. Uhodavanje, burn-in, fosforni tragovi, problemi s deinterlacingom - nebitno. Uspoređivanje 100Hz kod LCD-a i naprednih 600Hz kod Panasonica koji nemaju veze jedno s drugim ali zato dobro zvuči kod usporedbe. Panasonic je ako niste primjetili isto 100Hz nativno.
NeoPDP tehnologija kod plazmi je super i veliki je napredak u odnosu na postojeće ali ... ma nema veze, umori se više.
Zadnje izmijenjeno od: leonardo. 12.01.2010. u 09:01.
Staro 10.01.2010., 16:45   #7
nino
nino's Avatar
Postovi: 12,602
Autor leonardo Pregled postova
..... Ukoliko vidite nešto pogrešno u tablici ili tekstu, napišite slobodno. Topic je kao takav i zamišljen. ....
Pogresno? Pohvala na trudu, ali malo pogledaj svoj kompletan post, koji si "svojerucke" naskrabao ne u korist LCD-a nego si "popljuvao" Plasma tehnologiju u odnosu 1:1000. Zasto? Pa pogledaj zakljucak svoj preporuka LCD pa nam ovdje objasni koje su lose strane Samsung B650, osim input-lag-a koji si napisao.
Po tvome je taj Zamzung (S) toliko savrsena tv da bi to bilo revolucionarno dijelo.
Sa druge strane si se dobrano potrudio popljuvat Plasmu, ali stvarno potrudio.
Budi drugi put objektiva kao ovaj cova pa te mozda netko i pohvali. ovako je ovo idealan topic za flejm i ko ima veceg.
Staro 10.01.2010., 17:18   #8
leonardo
leonardo's Avatar
Lokacija: somewhere
Postovi: 284
Zaista mi nije potrebno da me netko pohvali ili pokudi. Što se mene tiče tema se može slobodno i pobrisati. Ukoliko ostane potrudit ću se da prvi post držim koliko-toliko aktualnim sa najnovijim stvarima ukoliko ne... C'est la vie.
Staro 10.01.2010., 17:36   #9
electric_dreams
electric_dreams's Avatar
Postovi: 46
Autor nino Pregled postova
"Ili ću pak još neko vrijeme ostati na, oh, tako lošem i zastarjelom katodnom CRT-u. Na kojem je BTW standardna SD slika još uvijek triput bolja neog na bilo kojoj šminkerskoj plazmi ili LCD-u."
Ovo je tužna ali istinita činjenica. Pitanje je da li će ikad SD slika biti bolja na plazmi ili LCD-u nego na CRT-u. Vjerojatno neće. Jedini problem je u tome da će trebat proć bar 10 godina da bi blu ray imao onu aktualnost koju danas ima 10-15 godina stari medij zvan DVD. Barem 95 posto svega onoga što ljudi danas gledaju je još uvijek u starom dobrom SD formatu. Dajmo im televizore na kojima će imat lošiju sliku od one koju su imali prije 10 godina na crt-u, i prodajmo im spiku da je to cool, i da su tako trendy i in.....
electric_dreams je offline   Reply With Quote
