Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 05.01.2010., 04:34   #1
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
php-cgi se rushi
evo, php-cgi mi se rushi redovno, svakih par minuta.
php 5.3.1
php-cgi 5.3.1
nginx 0.7.64
proces jednostavno nestane. ajd bilo bi sve ok da je neki load, ali ja sam jedini korisnih i jedno sto sam trazio je rutorrent-ov index.htm (ostavim otvorenu stranicu par minuta i valjda svi ti updejti ubiju php-cgi).
koje logove trebate?
zna li netko mozda ovako na prvu loptu? (iz iskustva)
danij3l je offline   Reply With Quote
Staro 05.01.2010., 08:33   #2
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,795
Autor danij3l Pregled postova
php 5.3.1
php-cgi 5.3.1
nginx 0.7.64
Pogledaj prvo ngixove logove (vjerojatno su negdje u /var/log) a ne bi bilo lose vidjeti sto kaze strace.
Programer
Staro 05.01.2010., 14:11   #3
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
/var/log/nginx/error.log
Code:
2010/01/05 20:56:50 [error] 1947#0: *235 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.100.100, server: localhost, request: "POST /rtorrent/plugins/rpc/rpc.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.119", referrer: "http://192.168.100.119/rtorrent/index.html"
2010/01/05 20:56:50 [error] 1947#0: *235 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.100.100, server: localhost, request: "POST /rtorrent/getplugins.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.119", referrer: "http://192.168.100.119/rtorrent/index.html"
2010/01/05 20:56:58 [error] 1947#0: *235 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.100.100, server: localhost, request: "POST /rtorrent/plugins/rpc/rpc.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.119", referrer: "http://192.168.100.119/rtorrent/index.html"
2010/01/05 20:56:59 [error] 1947#0: *235 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.100.100, server: localhost, request: "POST /rtorrent/plugins/rpc/rpc.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.119", referrer: "http://192.168.100.119/rtorrent/index.html"
2010/01/05 20:56:59 [error] 1947#0: *377 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.100.100, server: localhost, request: "POST /rtorrent/plugins/rpc/rpc.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.119", referrer: "http://192.168.100.119/rtorrent/index.html"
2010/01/05 20:57:00 [error] 1947#0: *235 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.100.100, server: localhost, request: "POST /rtorrent/plugins/rpc/rpc.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.100.119", referrer: "http://192.168.100.119/rtorrent/index.html"
sudo strace php-cgi -b 127.0.0.1:9000
Code:
lstat64("/etc/nginx/html/rtorrent/plugins/rpc", {st_mode=S_IFDIR|0755, st_size=45, ...}) = 0
lstat64("/etc/nginx/html/rtorrent/plugins", {st_mode=S_IFDIR|0755, st_size=27, ...}) = 0
lstat64("/etc/nginx/html/rtorrent", {st_mode=S_IFLNK|0777, st_size=24, ...}) = 0
readlink("/etc/nginx/html/rtorrent", "/home/danij3l/.rutorrent", 4096) = 24
lstat64("/home/danij3l/.rutorrent", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/danij3l", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home", {st_mode=S_IFDIR|0755, st_size=20, ...}) = 0
read(4, "\1\5\0\1\3\333\5\0", 8)        = 8
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 987) = 987
read(4, "\0\0\0\0\0", 5)                = 5
time(NULL)                              = 1262721408
setitimer(ITIMER_PROF, {it_interval={0, 0}, it_value={60, 0}}, NULL) = 0
rt_sigaction(SIGPROF, {0x8212540, [PROF], SA_RESTART}, {0x8212540, [PROF], SA_RESTART}, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [PROF], NULL, 8) = 0
lstat64("/etc/nginx/html/rtorrent/plugins/rpc/rpc.php", {st_mode=S_IFREG|0644, st_size=625, ...}) = 0
open("/home/danij3l/.rutorrent/plugins/rpc/rpc.php", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=625, ...}) = 0
lstat64("/home/danij3l/.rutorrent/plugins/rpc/rpc.php", {st_mode=S_IFREG|0644, st_size=625, ...}) = 0
lstat64("/home/danij3l/.rutorrent/plugins/rpc", {st_mode=S_IFDIR|0755, st_size=45, ...}) = 0
lstat64("/home/danij3l/.rutorrent/plugins", {st_mode=S_IFDIR|0755, st_size=27, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb74a6000
read(5, "<?php\r\n\r\nrequire_once( '../../ut"..., 4096) = 625
_llseek(5, 0, [0], SEEK_SET)            = 0
getcwd("/home/danij3l", 4095)           = 14
chdir("/home/danij3l/.rutorrent/plugins/rpc") = 0
ioctl(5, SNDCTL_TMR_TIMEBASE or TCGETS, 0xbf945238) = -1 ENOTTY (Inappropriate ioctl for device)
mmap2(NULL, 657, PROT_READ, MAP_PRIVATE, 5, 0) = 0xb74a5000
munmap(0xb74a5000, 625)                 = 0
close(5)                                = 0
munmap(0xb74a6000, 4096)                = 0
getcwd("/home/danij3l/.rutorrent/plugins/rpc", 4096) = 37
lstat64("/home/danij3l/.rutorrent/plugins/rpc/../../util.php", {st_mode=S_IFREG|0644, st_size=9066, ...}) = 0
lstat64("/home/danij3l/.rutorrent/util.php", {st_mode=S_IFREG|0644, st_size=9066, ...}) = 0
lstat64("/etc/nginx/html", {st_mode=S_IFLNK|0777, st_size=15, ...}) = 0
readlink("/etc/nginx/html", "/srv/http/nginx", 4096) = 15
lstat64("/srv/http/nginx", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/srv/http", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/srv", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/home/danij3l/.rutorrent/util.php", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=9066, ...}) = 0
mmap2(NULL, 9066, PROT_READ, MAP_SHARED, 5, 0) = 0xb74a4000
munmap(0xb74a4000, 9066)                = 0
close(5)                                = 0
lstat64("/home/danij3l/.rutorrent/plugins/rpc/./config.php", 0xbf94106c) = -1 ENOENT (No such file or directory)
lstat64("/usr/share/pear/config.php", 0xbf94106c) = -1 ENOENT (No such file or directory)
lstat64("/home/danij3l/.rutorrent/config.php", {st_mode=S_IFREG|0644, st_size=1034, ...}) = 0
open("/home/danij3l/.rutorrent/config.php", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=1034, ...}) = 0
mmap2(NULL, 1034, PROT_READ, MAP_SHARED, 5, 0) = 0xb74a6000
munmap(0xb74a6000, 1034)                = 0
close(5)                                = 0
lstat64("/home/danij3l/.rutorrent/plugins/rpc/./Torrent.php", 0xbf94106c) = -1 ENOENT (No such file or directory)
lstat64("/usr/share/pear/Torrent.php", 0xbf94106c) = -1 ENOENT (No such file or directory)
lstat64("/home/danij3l/.rutorrent/Torrent.php", {st_mode=S_IFREG|0644, st_size=24622, ...}) = 0
open("/home/danij3l/.rutorrent/Torrent.php", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=24622, ...}) = 0
mmap2(NULL, 24622, PROT_READ, MAP_SHARED, 5, 0) = 0xb74a0000
munmap(0xb74a0000, 24622)               = 0
close(5)                                = 0
lstat64("/home/danij3l/.rutorrent/plugins/rpc/./util.php", 0xbf94106c) = -1 ENOENT (No such file or directory)
lstat64("/usr/share/pear/util.php", 0xbf94106c) = -1 ENOENT (No such file or directory)
socket(PF_NETLINK, SOCK_RAW, 0)         = 5
bind(5, {sa_family=AF_NETLINK, pid=0, groups=00000000}, 12) = 0
getsockname(5, {sa_family=AF_NETLINK, pid=1950, groups=00000000}, [12]) = 0
sendto(5, "\24\0\0\0\26\0\1\3\200\231CK\0\0\0\0\0\0\0\0", 20, 0, {sa_family=AF_NETLINK, pid=0, groups=00000000}, 12) = 20
recvmsg(5, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"0\0\0\0\24\0\2\0\200\231CK\236\7\0\0\2\10\200\376\1\0\0\0\10\0\1\0\177\0\0\1"..., 4096}], msg_controllen=0, msg_flags=0}, 0) = 108
recvmsg(5, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"@\0\0\0\24\0\2\0\200\231CK\236\7\0\0\n\200\200\376\1\0\0\0\24\0\1\0\0\0\0\0"..., 4096}], msg_controllen=0, msg_flags=0}, 0) = 128
recvmsg(5, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\24\0\0\0\3\0\2\0\200\231CK\236\7\0\0\0\0\0\0\1\0\0\0\24\0\1\0\0\0\0\0"..., 4096}], msg_controllen=0, msg_flags=0}, 0) = 20
close(5)                                = 0
gettimeofday({1262721408, 818367}, NULL) = 0
socket(PF_INET, SOCK_STREAM, IPPROTO_IP) = 5
fcntl64(5, F_GETFL)                     = 0x2 (flags O_RDWR)
fcntl64(5, F_SETFL, O_RDWR|O_NONBLOCK)  = 0
connect(5, {sa_family=AF_INET, sin_port=htons(5000), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 EINPROGRESS (Operation now in progress)
poll([{fd=5, events=POLLIN|POLLOUT|POLLERR|POLLHUP}], 1, 15000) = 1 ([{fd=5, revents=POLLOUT}])
getsockopt(5, SOL_SOCKET, SO_ERROR, [0], [4]) = 0
fcntl64(5, F_SETFL, O_RDWR)             = 0
send(5, "26:CONTENT_LENGTH\000987\0SCGI\0001\0,<?"..., 1017, MSG_DONTWAIT) = 1017
poll([{fd=5, events=POLLIN|POLLPRI|POLLERR|POLLHUP}], 1, 0) = 1 ([{fd=5, revents=POLLIN}])
recv(5, "S", 1, MSG_PEEK)               = 1
poll([{fd=5, events=POLLIN|POLLERR|POLLHUP}], 1, 60000) = 1 ([{fd=5, revents=POLLIN}])
recv(5, "Status: 200 OK\r\nContent-Type: te"..., 8192, MSG_DONTWAIT) = 541
recv(5, "", 1, MSG_PEEK)                = 0
close(5)                                = 0
chdir("/home/danij3l")                  = 0
write(4, "\1\6\0\1\2N\2\0X-Powered-By: PHP/5.3.1\r"..., 616) = 616
shutdown(4, 1 /* send */)               = 0
recv(4, "\1\5\0\1\0\0\0\0", 8, 0)       = 8
recv(4, "", 8, 0)                       = 0
close(4)                                = 0
open("/dev/urandom", O_RDONLY)          = 4
read(4, "5N|H", 4)                      = 4
close(4)                                = 0
read(4, "@\"\307\177", 4)               = 4
close(4)                                = 0
read(4, "\320N\20!", 4)                 = 4
close(4)                                = 0
setitimer(ITIMER_PROF, {it_interval={0, 0}, it_value={0, 0}}, NULL) = 0
accept(3, {sa_family=AF_INET, sin_port=htons(45913), sin_addr=inet_addr("127.0.0.1")}, [16]) = 4
poll([{fd=4, events=POLLIN}], 1, 5000)  = 1 ([{fd=4, revents=POLLIN}])
read(4, "\1\1\0\1\0\10\0\0", 8)         = 8
read(4, "\0\1\0\0\0\0\0\0", 8)          = 8
read(4, "\1\4\0\1\3\345\3\0", 8)        = 8
read(4, "\17,SCRIPT_FILENAME/etc/nginx/html"..., 1000) = 1000
read(4, "\1\4\0\1\0\0\0\0", 8)          = 8
read(4, "\1\5\0\1\t'\1\0", 8)           = 8
read(4, "<?xml version=\"1.0\" encoding=\"UT"..., 2343) = 2343
read(4, "\0", 1)                        = 1
time(NULL)                              = 1262721409
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
sendto(5, "\24\0\0\0\26\0\1\3\201\231CK\0\0\0\0\0\0\0\0", 20, 0, {sa_family=AF_NETLINK, pid=0, groups=00000000}, 12) = 20
recvmsg(5, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"0\0\0\0\24\0\2\0\201\231CK\236\7\0\0\2\10\200\376\1\0\0\0\10\0\1\0\177\0\0\1"..., 4096}], msg_controllen=0, msg_flags=0}, 0) = 108
recvmsg(5, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"@\0\0\0\24\0\2\0\201\231CK\236\7\0\0\n\200\200\376\1\0\0\0\24\0\1\0\0\0\0\0"..., 4096}], msg_controllen=0, msg_flags=0}, 0) = 128
recvmsg(5, {msg_name(12)={sa_family=AF_NETLINK, pid=0, groups=00000000}, msg_iov(1)=[{"\24\0\0\0\3\0\2\0\201\231CK\236\7\0\0\0\0\0\0\1\0\0\0\24\0\1\0\0\0\0\0"..., 4096}], msg_controllen=0, msg_flags=0}, 0) = 20
close(5)                                = 0
gettimeofday({1262721409, 514704}, NULL) = 0
send(5, "27:CONTENT_LENGTH\0002343\0SCGI\0001\0,<"..., 2374, MSG_DONTWAIT) = 2374
poll([{fd=5, events=POLLIN|POLLPRI|POLLERR|POLLHUP}], 1, 0) = 0 (Timeout)
recv(5, "Status: 200 OK\r\nContent-Type: te"..., 8192, MSG_DONTWAIT) = 8192
recv(5, "/", 1, MSG_PEEK)               = 1
recv(5, "/i8></value>\r\n<value><i8>3</i8><"..., 8192, MSG_DONTWAIT) = 8192
recv(5, "u", 1, MSG_PEEK)               = 1
recv(5, "ue>\r\n<value><i8>30276</i8></valu"..., 8192, MSG_DONTWAIT) = 8192
recv(5, "/value>\r\n<value><i8>1</i8></valu"..., 8192, MSG_DONTWAIT) = 4857
recv(5, "", 8192, MSG_DONTWAIT)         = 0
close(5)                                = 0
write(4, "\1\6\0\1\0r\6\0X-Powered-By: PHP/5.3.1\r"..., 136) = 136
write(4, "<?xml version=\"1.0\" encoding=\"UT"..., 29368) = 29368
write(4, "\1\3\0\1\0\10\0\0\0\0\0\0\0ere", 16) = 16
close(4)                                = 0
read(4, "L9\"\364", 4)                  = 4
close(4)                                = 0
read(4, "\3^\330\334", 4)               = 4
close(4)                                = 0
read(4, ")@\336\216", 4)                = 4
close(4)                                = 0
accept(3, {sa_family=AF_INET, sin_port=htons(45915), sin_addr=inet_addr("127.0.0.1")}, [16]) = 4
read(4, "\1\4\0\1\3\343\5\0", 8)        = 8
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
close(5)                                = 0
gettimeofday({1262721409, 747463}, NULL) = 0
close(5)                                = 0
close(4)                                = 0
read(4, "A\351\233u", 4)                = 4
close(4)                                = 0
read(4, ">\236\207c", 4)                = 4
close(4)                                = 0
read(4, "$\250\237\263", 4)             = 4
close(4)                                = 0
setitimer(ITIMER_PROF, {it_interval={0, 0}, it_value={0, 0}}, NULL) = ^C
munmap(0xb728a000, 11140)               = 0
brk(0x9d9c000)                          = 0x9d9c000
munmap(0xb728d000, 163840)              = 0
exit_group(0)                           = ?
^C
[1]+  Done                    sudo strace php-cgi -b 127.0.0.1:9000
P.S. vidim da mi vura nije ok
Staro 08.01.2010., 16:53   #4
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
Bump
Staro 10.01.2010., 11:07   #5
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,795
Ti si rucno prekidao strace (vidim ^C u outputu) ili sto?
Onako na brzinu, ne vidim nista previse sporno. To je x64 kernel?
Programer
Staro 10.01.2010., 15:59   #6
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
je, ja sam prekinuo strace. (u tom trenutku je php vec bio mrtav)
problem je bio u nacinu na koje sam spwnao instance (jbg kad sam skuzio sto sam napravio bilo je smjesno)
sad sve radi kao podmazano
