#122 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
WinUAE 1.3.4 released
WinUAE i dalje uredno vozi ![]() WinUAE 1.3.4 (30.12.2006) ========================= Bugs fixed: - Improved bsdsocket emulation stability - Winuaeclipboard crash fix - Windows Vista compatibility problems fixed - Filesystem flag handling on FAT volumes - Page Down-key Input panel remapping works properly - Sound system improved - ECS Denise/AGA borderblank feature works properly - Dualcore/SMP random freezes properly fixed and more minor fixes.. Bugs introduced in 1.3.3 fixed: - AVIOutput out of sync fix - CPU emulation condition code fix - Fixed handle leak in bsdsocket and AHI - Sound pitch shifting in VSync-mode and more.. - Catweasel MK4 mouse support New features: - Improved emulation of AGA sprites outside display window - uaeserial.device introduced. Multi-port serial device, unit numbers are directly mapped to PC serial ports (unit 0 = COM0, 1 = COM1 etc..) - Improved serial port detection, virtual devices also supported - Improved Catweasel MK3/4 support without Windows driver installed (requires TVicPort, http://www.entechtaiwan.com/dev/port/index.shtm) - Improved debugger features - Sound system is not anymore reinitialized when losing/gaining focus - 1M (1024KB) ROM image support - Sound volume configuration setting also sets AHI audio volume (previously was Paula audio only) - Custom chipset interrupt timing improved http://www.winuae.net/
#123 |
Postovi: 4
Dreadnoughts-i su bili ZAKON!!! jedna od najrealnijih pomorskih strategija koja je ikada izasla na bilo kakvim kompicima ili konzolama. Danasnje strategije filaju samo grafiku i nista vise. |
#124 |
Postovi: 4
Pomagajte! Gdje mogu skinuti dobre igrice za Amigu. Jos nesto, imam nekoliko disketa sa igricama za A500. Postoji li nacin da ih nekako pokrenem preko WinUAE-a ili neceg slicnog, buduci da PC nemoze citati Amigin zapis. |
#125 |
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,143
Buduci da ciljas na koristenje emulatora. Zasto ne lociras te igre sa disketa informativno jednostavnije : Abime ![]() Ako drzis do svog ugleda, nemoj slucajno da ovo ne nabavis. Na cestit i legalan nacin svakako. PS , S&TF , DFOC , S&G , WOD , ED Nek ti Jelc da jos pokoji link ako ima. Meni je ovo glavni site za nesto saznati, doduse, DATA zavrsava samo na Amigama. ... |
#126 |
Super Moderators
Postovi: 17,485
Za početak je najbolje baciti oko tu: http://wiki.abime.net/ Sve lijepo piše, linkovi.... Molim obratiti pažnju da na forumu nema govora o stvarima koje su pod copyrightom ![]() Romovi, igre koje su još pod oznakom "Commercial" i slično. Ako bude problema-slobodno me se može pingati na mail ili PM.
#127 |
Postovi: 4
Hvala decki! |
#128 |
Super Moderators
Postovi: 17,485
WinUAE 1.4.0 released!
WinUAE 1.4.0 (03.03.2007) ========================= New features: - CDTV emulation, including CD controller, internal SRAM and 64KB SRAM expansion memory card support. - More compatible SPTI CD32/CDTV CD support. - Advanced Chipset configuration. Miscellaneous model specific hardware configuration entries like real time clock chip type, CIA-A TOD clock source, RAMSEY, FAT GARY register emulation.. - Rewritten harddisk configuration system. No more lost hardfile or virtual directory configuration entries if path was missing.. - A3000/A4000 motherboard RAM bank support. - Added Arcadia bios rom type selection. - New Windows Vista -style application icon added - Small CIA and custom chip emulation updates. Bugs fixed: - FPU emulation floating point to integer conversion fixed (proper clamping instead of truncating) - uaeserial.device compatibility improved - New serial port detection didn't detect all types of serial ports - Random sound errors after adjusting sound GUI setting on the fly - Directory filesystem memory leaks fixed and compatibility improved - It was not possible to disable keyboard layout C after enabling it. - Sound panel settings were not always enabled correctly. - -datapath command line parameter didn't work. - Disk image drag and drop didn't work. - Quickstart panel disk swapping is properly delayed again. - Some Picasso96 display modes were not available. - bsdsocket freeze fix (Aminetradio) - Windows driver Catweasel support works again. - "Faster RTG"-mode lockups fixed. - External drive sound selection GUI didn't work if fdrawcmd.sys was not installed. http://www.winuae.net/
#129 |
Super Moderators
Postovi: 17,485
WinUAEHelp
Isvrstan WinUAEHelp u kojem je objašnjeno baš sve ![]() http://www.pcguru.plus.com/files/WinUAEHelp209.zip 700 kila. I zadnji WinUAE 1.4.1 Major bug fixed: - Start-up crash introduced in 1.4.0. Bugs fixed: - Yet another bsdsocket crash fix. - ASPI detection ignored NeroASPI, also ASPI detection was improved. - Some interlaced programs had color stripes or wrong colors in right border. - Picasso96 RTG RAM mapping error in non-JIT mode New features: - New input targets added. (disk swapper, input configuration 1-4) - Quickstart-mode automatically selects best available CD access mode. - Master (Windows main volume) volume control added to input targets. - map "POV Hat"-type joypad control to joystick horizontal and vertical. http://www.winuae.net/
#130 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
WinUAE 1.4.3 izašao
Zadnje izmijenjeno od: Jelc. 31.07.2007. u 21:34. |
#131 |
Super Moderators
Postovi: 17,485
New features: - Built-in lha/lzh and lzx support. - Mount archives as a harddrive with transparent, recursive (archives inside archive) decompression. Supported: zip, 7zip, rar (unrar.dll or archiveaccess.dll required), lha/lzh, lzx. - A3000 Kickstart ROM and SuperKickstart disk support. - A590/A2091 SCSI, A3000 SCSI and CDTV SCSI expansion harddrive (HDF) emulation (WD33C93 + (Super)DMAC based SCSI hardware). - Action Cartridge Super IV Professional freezer cartridge emulation. - X-Power Professional 500 (v1.2) freezer cartridge emulation. - Nordic Power (v2.0) freezer cartridge emulation. - Debugger improvements (improved deep trainer, copper memwatch points, CPU-model specific registers can be modified, illegal access logger improved, process breakpoints etc..) - Paths-panel default paths selection improved. - Separate native and Picasso96 vsync setting. - GUI will "autoscroll" if fullscreen mode is smaller than GUI. - Improved rtg.library, speeds up Picasso96 in high resolution modes (obsoletes picasso96fix) Novosti u Bugs fixed: - CDTV emulation improved (DOTC2, Xenon2, ChaosInAndromeda CD player) - CD32 CD emulation improved (Fightin' Spirit, Base Jumpers etc..) - Ghostscript printing fixed (again). - Floppy drive sound selection if fdrawcmd.sys was not installed. - Video recording sound pitch issue. - -datapath command line parameter fixed (again..) - uae-configuration JIT on/off switching fixed. - Sprite attachment fix, fixes "Great Demo" by "The Tremendous Trio" ![]() - Some FPU fixes from Aranym. - Directory filesystem locked files (most commonly s:startup-sequence) after software reset - Filesystem emulation not initializing if JIT was enabled and no other expansions enabled (fast RAM, Z3 fast, etc..)
#132 |
Super Moderators
Postovi: 17,485
AmigaSYS 3 Plus Released!
Feature List : The followings are translated into three languages (HU,ENG,DE) - Easy installation with multiple options 3.0/3.1. - Installation in three languages 3.0-3.9 - Better hungarian, english and german localization of the installers 3.0-3.9. - Amiga OS 3.9 installers (Os3.9, Amiga Forever , Amithlon, OSXL). - Appmenu Tools. - Help files. - About menu. - All themes. - Theme installers. - Theme Saver. - Amistart - All AmigaSYS Scripts - Cd-mount - Theme select - PostED - No Startup Boot - Upgrade - Etc... The language can be set while installing (3.0/3.1) by selecting system language. AmigaSYS 3 Plus Installer : - Completely rewritten 3.0/3.1 installer - Easy installation with multiple options (HUN,DE,ENG,AmigaForever Installer, Kickstart check ) - Ability to install without the Extras disk (for Amiga Forever users). - Choice of system language: Hungarian, English, German - Keyboard layout selection (Hun,Eng,De) - Resolution selection (Low-VeryHigh 800,1024,1152,1280.) - 262144 color intro images. - 262144 color outro images - project contributors and partners. - The music from WOC92 by Sanity is played during installation - Status display during installation (%). - Lots of features, 3-4 times as fast as the previous version! Amiga OS 3.0/3.1 : - Brand new formated hdf - New, cleaned up system with only the necessary components. - Systems scripts rewritten from scratch for better, faster executions. - New look, new images, new fonts. - Completely rewritten Amiga Os 3.9 installer,2 to 3 times as fast as the previous version! - Completely rewritten Amiga Os XL installer,2 to 3 times as fast as the previous version! - Completely rewritten Amigathlon installer,2 to 3 times as fast as the previous version! - Completely rewritten Amiga Forever 6,2005,2006 installer,2 to 3 times as fast as the previous version! - Completely rewritten Amiga Forever 6,2005,2006 online installer,2 to 3 times as fast as the previous version! - New, higher quality installer images. - Theme selection during installation of 3.9. - Resolution selection during installation of 3.9. - The emulators, players and games icons bring up menus for faster access to the built-in programs. - Icon verification (tool, etc). - Rewritten help files, now placed in the System:Readme directory. - New about , new graphics, new menus. - IBrowse configuration converted to version 2.4. - AmigaAMP plugins detection fixed. - Some AmigaAMP skins deleted, and compressed into format JPG. - Some AMR skins deleted. - New filemaster configuration with useful features. - Fixed Bareed GLOW icon bug. - Fixed bareed configuration bug. - Introduced amigasys-startup and amigasys-user. - Fixed appmenu configuration bug. - Fixed IBrowse configuration bugs. - HOL Game Database added in IBrowse. - Fixed GACB URL in IBrowsba - Fixed Packmaster configuration, (Appicon, default extract = ram) - Fixed font encoding problem in limpidclock. - Improved German and Hungarian keyboard layout. - New MCP configuration. - Fixed FTP mount configuration. - Faulty icons no longer appear after the installation of amiga forever. - Added PowerWB (3.0/3.1 only). - Added toolmanager, works in all resolutions (3.0,3.1,3.9 RetroSYS). - Ten Toolmanager Icon for menu , CD mount, Players, games, Emulators , Bareed , packmaster , ppaint, ibrowse, yam , wookiechat. - TinyMeter added; configured to display chipram, fastram, and system dh0 usage(3.0/3.1 és 3.9 RetroSYS). Amiga OS 3.9 : - New theme: BLUE - New theme options. - New, cleaned up Themes with only the necessary components. - Preview images from theme while installing. - Evry theme can change resoulition. - Themes dont contain configuration files. - Icon problems have been debuged in themes. - Theme saving feature has been added, make your own theme and share it with your friends or AmigaSYS Team. - If you create your own theme background image should be in presets/AmigaSYS/theme directory, it may be anywhere but this is the default directory. - Wbstartup problems fixed at theme saving. - All actual settings will be saved at theme saving. - Fixed def icons bugs in all themes with Amiga OS 3.9 installed. - Def icons bugs have been fixed in all themes with Amiga Os 3.9 , Amiga Forever , Amiga OS XL , Amithlon install. - RetroSYS theme actualized (tinymeter , toolmanager) - Themechanging fixed , only RetroSYS has TinyMeter and Toolmanager just like in 3.1. - Fixed font encoding problem in limpidclock all themes. - Def icons supported after installing Amiga Forever. - Amiga Forever has no Unarc , Editpad, def icons use Packmaster and BareEd is default program. - New Amistart configuration. - New Amistart background, logo, etc. - We had problems with emptying Trashcan , fixed. lots of fixes,and all 3.0/3.1 fixes and features! Programs : - New Mui Class's - Librarys - Datatypes - AmigaAMP - Bareed - PowerWB - Tinymeter - Toolmanager - Amiga Spectrum Emu - WormWars - Wookiechat. Deleted programs : - Amirc, to replace Wookiechat free and very good. - Songplayer. - Flamingo Plus 4 emulator. AmigaSYS 3 Plus OS Support : - Amiga OS 3.0 - Amiga OS 3.1 - Amiga OS 3.1 Amiga Forever version - H&P Amiga Os 3.9 series - Amiga Forever 6 CD (3.9). - Amiga Forever 6 Online edition (3.9). - Amiga Forever 6 Installed (3.9). - Amiga Forever 2005 CD (3.9). - Amiga Forever 2005 Premium edition (3.9). - Amiga Forever 2005 Online edition only installed! (3.9). - Amiga Forever 2006 CD (3.9). - Amiga Forever 2006 Premium edition (3.9). - Amiga Forever 2006 Online edition only installed! (3.9). - AmigaOS XL Amithlon CD. (3.9). http://amigasys.extra.hu/
#133 |
Super Moderators
Postovi: 17,485
Evo jedne stvarno dobre vijesti-nakon dužeg vremena legendarni Back to the Roots je ponovno online ![]() http://www.back2roots.org/
#134 |
Postovi: 1,358
http://www.winuae.net/ WinUAE 1.5.1 (12.08.2008) ========================= Major 1.5.0 bugs fixed: - Failed to start with some display card/driver combinations. - Regular (non-RDB) OFS formatted hardfiles didn't mount under KS 1.3. - Memory corruption in configuration file handling causing random crashes when loading or saving configuration files. - Configuration files in subdirectories didn't load if configuration cache was enabled. - RTG hardware mouse cursor may have been invisible (or had wrong graphics) in some cases after resolution change. - Switching between non-interlaced and interlaced modes caused random "scanline" graphics corruption. Other bug fixes: - Built-in HRTMon crashed in JIT modes. - Interlace modes fixed in "normal" (non-doubled/scanline) modes. - Fixed borderblank graphics corruption in interlaced modes. - Fixed possible crashes when switching Windows desktop resolution or when using quick user switching. - "Kickstart Replacement" fixed. - PCMCIA SRAM emulation didn't work in memory expansion mode. - Emulation paused if "stop sound while inactive/minimzed" was enabled. - Improved directory filesystem statefile support. - AVI recording crash if only audio recording was enabled. - Native DLL support fixed. - Forced fullscreen refresh rates didn't work in some cases. - Multiple identical (same serial number) USB game controllers do not confuse input system anymore. - Major blitter slowdown in some AGA modes. - ADF was not updated if disk write was aborted (Cadaver save disk) - Crash when USB mouse/joystick was removed or inserted before emulation was started. New and improved features: - Added support for Direct3D pixel shader filters (very fast compared to software filters, pixel shader 2.0+ compatible display card required), plain Direct3D filter performance improved. Latest (August 2008 or later) DirectX required. - In windowed mode all resolution or chipset/RTG mode switches resize the window instead of window closing and opening. - Aspect ratio setting added to RTG and filter panels. - Window resize enabled in windowed mode (chipset mode). - Added Picasso96 option "Always scale in windowed mode" which enables window resizing and disables automatic resize. Keeps aspect ratio automatically. - Only reset fullscreen mode when resolution or depth changes. - On the fly USB mouse/joystick insert/removal does not modify currently selected input device(s) in Ports-panel. - Enable ini-mode (registry replacement) if .ini (without .exe) is found. Previously always used winuae.ini.
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2 |
#135 |
Super Moderators
Postovi: 17,485
Vani je i novi AmigaSYS 4 i to u verzijama za Windows, XBox, PDA, MacOS, Live, Linux, MorphOS, Amiga OS4, Amithlon i Amigu ![]() http://amigasys.extra.hu/ I thread na English Amiga Board : http://eab.abime.net/showthread.php?t=35764
#136 | |
Super Moderators
Postovi: 17,485
Boing Bag #3 for OS3.9 released
Ljink http://amigan.1emu.net/releases/
#137 |
8-bit Gen.
Postovi: 3,143
Vrijeme je da se probudi ova tema. Posebno nakon ove gadurije. Nakon dugo vremena i kojekakvih ogavnih natrpavanja Amige u razna "DTK look" genericka PC kucista do sredine 90-tih. Pa vec bogu dosadne revizije ploca i prijedlozi OS-a koji se vuku u nedogled. Konacno nakon A4000T, pojavilo se kuciste, dostojno Amiga imena! Takodjer nakon dugo vremena, nikad konkretnije specifikacije i projekt nisu krasile Amiginu mogucu buducnost u novom ruhu. Hardver cije specifikacije zadivljuju jer ako se uzme Amigin odnos prema resursima, to je blago receno > 3x vise snage nego na papiru specifikacija. Kuciste bi (navodno) trebalo iznutra biti bazirano na Fractal kucistu, ali to moze potvrditi samo onaj koji je zbilja imao priliku otvarati x1000. ![]() ![]() Vlastite ideje i hardver, cine Amigu samo jos posebnijom i dostojno inovativnom : AmigaOne X1000 specs: * Dual-core 1.8GHz PowerISA™ v2.04+ CPU * "Xena" 500MHz XMOS XS1-L1 128 SDS * ATI Radeon R700 graphics card * 2GB RAM * 500GB Hard drive * 22x DVD combo drive * customised case, keyboard and mouse * 7.1 channel HD audio Ports and connectors: * 4x DDR2 RAM slots * 10x USB 2.0 * 1x Gigabit Ethernet * 2x PCIe x16 slots (1x16 or 2x8) * 2x PCIe x1 slots * 1x Xorro slot * 2x PCI legacy slots * 2x RS232 * 4x SATA 2 connectors * 1x IDE connector * JTAG connector * 1x Compact Flash ![]() A-EON glavni sajt je doista prepun informacija, svakako ga dobro istrazite. Mjesecima je iz nekog duhovitog razloga bio prepun raznih sifri i probijanje do podataka je bilo vrlo slicno Costinoj igri ![]() Srecom, korisnik je dole u drugom youtube videu, prikazao djelomicno taj humor. Sad je site dostupan za koristenje i manje vicnim poweruserima, jer pravi Amigasi samo takvi dolaze na svijet. Vidjet cemo rekli bi stari ribari a moguce i Jelc. I zbija, vidjet cemo sto ce biti od toga jer Vesalia uredno drzi kao najavu za mogucu rezervaciju. U svakom slucaju, ako bude kasnjenja i za godinu dana, ovo je prva nova Amiga za koju se poseze ruka u djep bez ikakvog neckanja ![]() Kao sto primarni naslove ove teme odzvanja, ovo su stvarno : Dobre vijesti za Amiga-nostalgičare! A-EON Frequently Asked Questions and information |
#139 |
Super Moderators
Postovi: 17,485
Naletil sam već na to ali sam zaboravio postat ![]() Nagradnjača: http://eab.abime.net/showthread.php?t=52010 I tema koja se vuće još od kraja 2007-e ![]() http://eab.abime.net/showthread.php?t=33024 Fakat lijepo kućište.... Nego, sjeća li se itko ove kornjače? ![]() ![]()
#140 | |
8-bit Gen.
Postovi: 3,143
![]() Naravno, tko bi zaboravio, ali bilo je tu i ekonomicnijih replika kucista ![]() ![]() |
#141 |
Super Moderators
Postovi: 17,485
Meni je baš žao kaj Walker nije zaživio-koliko god ličio na usisivač. Sve je to lijepo i krasno ali mene je ubijalo to kaj mi je iz Amige išla IDE kabelčina u midi kućište gdje je bilo napajanje, CD i hard ![]()
#142 | |
8-bit Gen.
Postovi: 3,143
M'da, ruznjikav je na poseban nacin. Ali opet poseban je i ne moze ga se zaboraviti. Citiraj:
#143 | |
Super Moderators
Postovi: 17,485
![]() Kaj se tiče kablovinja-mi proleteri smo se morali tako snalazit na 1200 a nije bilo drugog načina da se spoji CD i hard...nije svako mogao kupiti A4000 koja je koštala u vražju mater ![]()
#144 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,261
Jaoo, sad sam u bedu sto sam prodo A1000 prije 15+ godina ![]()
#145 |
Postovi: 517
uh, ja imao Amigu 1200... za potrebe dpainta, imaginea, protrackera i genlokanja ![]() |
#146 |
Super Moderators
Postovi: 17,485
Sudeći po kutiji-to nije orginal Commodore nego Escomova, te su se radile negdje 95-e ![]()
#147 | |
8-bit Gen.
Postovi: 3,143
#148 |
Lokacija: Slovenija/Samobor/ZG
Postovi: 36
Imam doma jos A600 standard, A1200 upgrade 8MB ram, 4GB CompactFlash IDE, PCMCIA CF card, Commodore 1084 monitor i jos jednu A1200 standard koja je pre nekoliko meseci nestala raditi ![]()
#150 |
8-bit Gen.
Postovi: 3,143
