#2101 |
Postovi: 993
Stavio sam na 10 barova, ping u najboljem slučaju 60, i to 2 od 10 puta, najviše preko 100 |
#2102 |
Mirko, a ne Harry
Postovi: 5,482
#2103 |
Lokacija: Osijek-Zagreb
Postovi: 336
#2104 | |
LateralusX
Postovi: 1,788
preporucujem jos i opciju: Code:
seta cg_ScoresPing_MaxBars “10″ seta cg_ScoresPing_Interval “20″ Ping interval - 100 means you have a 100 ping when you have full bars. If your interval is 20 it means you have 20 ping if you have full bars, and 20 extra ping for each bar missing, so 6/10 bars would mean 100 ping. |
#2106 | |
Postovi: 95
#2109 |
Postovi: 467
#2111 | |
Postovi: 95
tocno, zaboravio sam napomenut |
#2113 |
Postovi: 95
#2115 |
Postovi: 95
neka proba portove forwordat u ruteru, evo liste Application: CODMW2 External port: 1500 Internal port: 1500 Protocol: UDP Application: CODMW2A External port: 3005 Internal port: 3005 Protocol: UDP Application: CODMW2B External port: 3101 Internal port: 3101 Protocol: UDP Application: CODMW2C External port: 28960 Internal port: 28960 Protocol: UDP Application: CODMW2D External port: 27015 Internal port: 27015 Protocol: TCP |
#2116 |
Postovi: 467
evo,zahvaljujuci janu sve radi ko puska,mada sam i prije,sa nat type stricted mogao igrati,al nekad je znalo izbljunuti unable to connect to host,ali mogao sam se spojiti,a sad tam pise nat type open..... zivio jan...... ![]() ![]() |
#2117 |
Postovi: 95
#2119 |
its slightly turbocharged
Postovi: 5,430
Kakav Scavenger pro, kakav Bling pro, ja više ne mogu igrati bez Marathona pro ![]() Za rushera poput mene must have perk, trčiš koliko hočeš, brzo pokrivaš velike prostore Otključa Fall Camo za ACR, sad je na redu M4, na kojem sam na 190 HS-ova, još 60 do Fall Camo. class je: M4A1 w/ red dot sight, red tiger Desert Eagle akimbo ( ) Semtex & 2 Stun Granades Marathon Pro Hardline Pro Scrambler Pro killstreak: 1. UAV 2. Precision Airstrike 3. Emergency Airdrop Airdrop uvijek imam, predobar reward ![]() Ostale rewardove znam mjenjati.
blaa |
#2120 |
Postovi: 590
išao sam isprobat malo model 1887 akimbo... sad samo s njim igram:=) |
#2121 |
Propali User
Postovi: 221
Jel napravio mozda tko ovo a da mu ostane sejvano.Inace otvaranje portova u ruteru nema ploda http://i.imagehost.org/0527/MW2NATOPEN.jpg Ja moram svaki put posebno pisati |
#2122 |
Postovi: 553
Evo danas počeo igrat igru, pa ne znam kako da vidim framerate tokom igre, fraps ne funkcionira, tj radi u glavnom izborniku, a u igri se smrzne na 91 i tak stoji stalno. Naivno sam stiskao tildu za console, al narafno...... Inaće, mp mi se čini puno teži od cod4, jedva skupim 3 killstreak. Možda se popravim kad mape naučim. Skužio sam zapravo da me full jebe lag, osjeti se uvijek, valjda zbog tog pinga smrdljivog. I to što u cod4 visim isključivo na HC serverima, ovdje mi ni malo ne pomaže, naviko sam ispalit dva-tri metka i nastavit dalje, ovdje to u pravilu ne vrijedi. Mape su puno veće, otvorenije tj, baš imaju drukčiji layout, i treba im drukčije pristupit nego u cod4, mogu te sa svih strana drmat, praktički da nema sigurnog kutka di se možeš malo "odmorit" ^^ Treba vremena da se naviknem valjda, jer sad me ovo deprimira kolko sam loš. O genijalnom matchmaking sustavu neću pričat, dovoljno je reć da poslje dvije-tri partije mw2, palim xfire i pokrenem cod4. Nije mi to to. Gušt je odigrat, al ipak je cod4 nešto drugo. Valjda sama činjenica da možeš birat gdje ćeš igrat znači puno, pogotovo na serverima di je stalna ekipa, ima neki timski štimung koji mi u mw2 nedostaje. To je jedina zamjerka zapravo s moje strane, al eto, nadajmo se da će cod7 vratiti dedicated servere. |
#2123 |
Postovi: 5,430
91 je trenutni lock u samoj igri i ne brini, Fraps funkcionira, igraš na maximalnim FPS-ima Inače, dok se uigraš naravno da češ postati bolji, a i brzo češ do 18. lvl-a da otključaš HC Što se tiće laga, ja ga stvarno rijetko osjetim, ovisno o hostu a i lag-o-metar je vrlo miran Što se tiće pinga, najčešče mi je ko 80, nekad 100, što mi je sasvim prihvatljivo (naravno dok ne naletim face-to-face na hosta )
blaa |
#2124 | |
Postovi: 553
To je lock znači. To sam prvo i mislio, ali sam onda vidio da uopće ne pada framerate, što god da sam radio, pa sam mislio da se smrzo na 91.Kako misliš da ću otključat HC? Nakon 18-og lvl te trpa samo u HC servere ili? Ma ono, nije neka lagčina, više kao delay, pucam po liku recimo, ali ne pada odmah, nego napravi još metar dva i onda je kao mrtav. Neznam kak da objasnim... Velim, nije tolko jako da bih to nazvao lagom, ali osjeti se. Stvar navike isto vjerojatno. E da, to sam skužio, da u biti hostove tj partije traži prvo po pingu, meni uredno nađe već na 30-60, nekad 90-100, iznad 100 još nisam primjetio. |
#2125 |
Postovi: 5,430
U biti, probaj baciti smoke granade pa uletiti u dim, vidi hoće li padati FPS, 91 je trenutni lock prema IW-u, ali tko zna ![]() Kad dođeš na 18 lvl. otključat će ti se HC TDM kad odeš na Find Game, kao i još par game modova, ti biraš koji mod želiš, ali češ imati među njima moći birati i HC TDM ![]() BTW, jeste znali za ovo mjesto iznad šanka na Invasion-u? ![]() Predobro mjesto , a nije se ni neki problem popeti gore.. Ne vidiš ni prst pred nosom, i nitko ne vidi mene kad sam gore ![]()
blaa |
#2126 |
Mirko, a ne Harry
Postovi: 5,482
#2127 |
LateralusX
Postovi: 1,788
#2130 |
Postovi: 83
