Staro 27.12.2009., 12:31   #691
mars952
Lokacija: split
Postovi: 188
Pronašao sam kako i hvala na odgovorima. Jao, jao, al su ga zakomplicirali.
Bez reklama u sigu!
mars952 je offline   Reply With Quote
Staro 27.12.2009., 16:10   #692
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Nitko nema ideju o ovom wallpaper problemu?
Brown Acid je offline   Reply With Quote
Staro 27.12.2009., 16:54   #693
alien51
alien51's Avatar
Datum registracije: Dec 2009
Postovi: 1
Angry
Autor alen.s Pregled postova
Evo da se i ja ubacim iako neznam dal je win 7 krivac.....moj problem je zamrzavanje u igrama praćeno prilično nezgodnim zvukom iz zvucnika ( dosta neugodno zujanje ) . Malo san gugla al nisam nasa nista korisno pa ako neko ima isti problem.....svaki savjet je dobrodošao . Vidim da nisam jedini al za sada nisan nasa rjesenje ;
Hi everyone,
I have a problem running MMORPG games on Windows 7, they are: warhammer online and Aion. At some point during game (could be anything between 5 minutes and hour) the game freezes and speakers start repeating annoying sound (almost always same sound).
Can you please help to understand the nature of my problem and fix it?
Hi everybody
In the past couple of days, I've experienced a new thing with my pc, I suddenly get a strange annoying sound in my speakers and the computer freezes and I can't do anything anymore, but restart or unplug...
Any idea? I have recorded the sound but I don't know who to upload it here so you can hear it...
BUT i have greater issues. After about 10+ mins of gameplay i get a freeze, and a damnd solid one at that, which makes me have to restart. I cant figure out for the life of me whats causing this, Ive even gone as far as to set my computer to defaults with no Overclocks and fiddled round in the CCC to no avail, Ive un-installed and re-installed 3 times now, each time using a different patch version, so atleast i know its not a patch issue. Anyone else ever experienced something like this before?
BTW my speakers start Squealing while the screen is frozen if that helps any, and the gameplay freezes after 10 mins (+-) reguardless of what lvl or save point is reached.
Isti problem je i meni a nekužim zašto.
alien51 je offline   Reply With Quote
Staro 28.12.2009., 00:02   #694
tocka
Postovi: 175
zasad (kuckuc) u ovih par mjeseci korištenja imam jedan bug.
Radi se o 'njavi u wmv formatu xD
Nakon svakog gledanja krene serija explorer crasha.
Jel zna neko sto bi mogao bit uzrok problema?
tocka je offline   Reply With Quote
Staro 28.12.2009., 09:51   #695
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,796
...imam jedan problem kojeg neznam riješiti, povremeno mi se na sekundu zacrni slika na monitoru ( to mi se ne događa na winxp)...grafa iz Moj komp,drajveri najnoviji (sa starima je bilo isto)
tintin je offline   Reply With Quote
Staro 28.12.2009., 14:01   #696
Breathe
Breathe's Avatar
Lokacija: Kud me vjetar nosi
Postovi: 23
Imam jedno pitanje... Ja imam zvucnu razer baracudu dali mogu instalirat bilo koje drivere ili moraju biti bas za windows 7. Nigdje nemogu naci drivere za win7
Breathe je offline   Reply With Quote
Staro 28.12.2009., 14:36   #697
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
dosta drivera je komaptibilno od viste za sedmicu pa potrazi ako ni to neuspije probaj s xp driverima
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 29.12.2009., 10:35   #698
ONeill
ONeill's Avatar
Datum registracije: Mar 2008
Postovi: 347
Tako je, stavis drivere za Vistu i radit ce. Kod mene je tako rijesen problem s zvucnom.
ONeill je offline   Reply With Quote
Staro 29.12.2009., 21:19   #699
spawn
spawn's Avatar
Postovi: 8,437
Jel ima neko problema sa usb portovima? Imam spojen Bluetooth,Tele2 usb hdspa stick,i printer istovremeno, i ako ubodem bilo sta dodatno,recimo usb stick tele2 stick mi izgubi vezu s pc-om, moram ga izvadit iz usb-.a i ponovo ubacit. Na xp-u i na visti sve sljaka kako treba.
Staro 29.12.2009., 22:15   #700
FitzTN
FitzTN's Avatar
Lokacija: Samobor, HR
Postovi: 1,615
Evo ja ne uspjevam ugasit onaj ludi taskbar thumbnail preview (kad s mišem dođem preko nekog programa u taskbaru onda pokaže mali prikaz iznad). To mi ne treba a i smeta mi za dock
Probao ono gpedit msc, pa enablat da ne prikazuje to...al nis
Jel imao ko takav slučaj?
FitzTN je online   Reply With Quote
Staro 29.12.2009., 22:23   #701
Facelessone
Facelessone's Avatar
Postovi: 4,204
Makni kvačicu sa Use Aero Peek u Task bar and start menu properties
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 29.12.2009., 23:02   #702
FitzTN
FitzTN's Avatar
Postovi: 1,615
Nije to, to je za ono gledanje desktopa (ne znam čemu je to korisno, al može ostat )
BTW. I kad se makne, ostane isto
Staro 29.12.2009., 23:06   #703
Baja 001
Baja 001's Avatar
Postovi: 7,504
Kako podesit default screen poziciju programa? Nativno je taskbar doli i onda svi prozori idu do vrha, što je sux jer mi je taskbar gore (onda nemogu prozor maknuti) i moram pomaknuti taskbar da bi program vratio ispod njega. Ako neko nije skužio budem bacio SS
Staro 29.12.2009., 23:39   #704
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
win key + arrow (ljevo ili desno) ako hoces maximize lupis win + gore, a ja sam to rijesavao da npr kod resize programa kak imas one dvije strelice ljevo desno da kliknem a desni ili lejvi rub prozora dva puta i on se sam spusti ispod taskbara
bar mislim da sam skuzio da ti se program podvuce pod taskbar ?? jesi na ovo mislio
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 30.12.2009., 03:31   #705
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor fre@k Pregled postova
Da fala na infu, ali sam mislio da ima negdi po defaultu određeno
Ovo će mi koristit, jer sam uvik micao taskbar
Staro 30.12.2009., 08:27   #706
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,012
@Brown acid
To se događa ako ti windowsi pokazuju da ih moras aktivirati. Znam samo ako je to u pitanju.
Staro 30.12.2009., 11:53   #707
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
ali bas sam mallo jucer kod sebe isprobavao, neda mi da se program podvuce pod taskbar ovaj SS sam napravio s opcijom move na program i oso s strijelicama prema gore i cim sa uslikao autmatski ga je vratio ispod taskbara
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 30.12.2009., 17:37   #708
Brown Acid
..dno
Brown Acid's Avatar
Postovi: 1,973
Autor kasko Pregled postova
@Brown acid
Aktivirani i stavljeni svi updateovi, tako da nije do toga.
Staro 31.12.2009., 12:52   #709
Tomekk_7
Lokacija: Sveta Nedelja
Postovi: 115
Ima li netko neki savjet, ili neki link za optimizaciju, kako bih mogao smanjiti aktivne procese u windowsima. imam ukljucen msn, winamp, ffox, steam i antivirus i 53 procesa mi pokazuje. Hvala!
Tomekk_7 je offline   Reply With Quote
Staro 31.12.2009., 15:22   #710
Rain Man
Lokacija: x
Postovi: 1,447
Ja ih imam 85 gotovo u startu. Zderu mi 1.6GB memorije gotovo odmah nakon paljenja.
Autor tocka Pregled postova
Imas kakve codece instalirane? Oni se cesto posvade s explorerom posebice ako se koriste za thumbnail view.
Rain Man je offline   Reply With Quote
Staro 31.12.2009., 16:59   #711
tocka
Postovi: 175
Nope ni jedan codec.
Gledam preko goma i wmp-a i problem samo sa wmv formatom
Staro 02.01.2010., 14:54   #712
Josip Madjarevi
Datum registracije: Jan 2010
Postovi: 1
Stavio sam windows 7 ultimate i manje više sve radi ok, ali imam jedan problem koji ne znanam kako riješiti.
Imam digitalnu JVC-evu kameru s koje ne znam kako prebaciti video na comp pa da ga gasnije spržim. Stvar je u tome što ne mogu naći tu kameru (na xp-u mi bude prikazana u my computer, a ovdje ništa) kada je spojena pa da prebacim taj sadržaj. Kada sam ju spojio windowsi su instalirali driver za nju i prikazana mi je u Device manageru, ali ju ovako ne mogu naći.
Jel zna netko kako da riješim taj problem? Unaprijed hvala!
Evo ipak sam uspjeo naći rješenje, morao sam skinuti Windows Live Photo Gallery i Windows Movie Maker. Uz pomoć Windows Live Photo Gallery sam uspjeo prebaciti sadržaj sa kamere na komp.
Josip Madjarevi je offline   Reply With Quote
Staro 02.01.2010., 15:45   #713
Buger
Postovi: 4,391
ljudi jel zna netko neki recovery program koji radi na sedmici, probao sam on track easy recovery ali se na sedmici x64 ruši, isto tako probao sam taj program preko hiren's-a i pronađe sadržaj koji mi se obrisao, ali ne mogu ga nigdje spremiti, ima samo neki A disk, CDROM i RAM file...
inače radi se o nekim slikama koje su fantomski nestale, a nekidan sam gledao i bile su sve, čak sumnjam da je to Google Picasa uspio uništit jer sam vidio da ih je indeksirao nekidan...
uglavnom, neki program za recovery bi mi trebao
Staro 02.01.2010., 16:39   #714
kwan
kwan's Avatar
Postovi: 87
Autor Buger Pregled postova
evo pa probaj,meni radi
http://www.snapfiles.com/downloads/dlrestoration.html
kwan je offline   Reply With Quote
Staro 02.01.2010., 17:11   #715
Bambusha
Bambusha's Avatar
Lokacija: Čepin
Postovi: 297
Autor Rain Man Pregled postova
Nakon paljenja 39 procesa uključujući Object Dock, Xfire i Bittorrent. 780 MB.
Nego, sad gledao malo i vidim napravili su ZoneAlarm Free za Windows 7, al' kad instaliram miš skače po ekranu i sve šteka sve u šesnajst.
Kad ugasim ZA sve normalno. To neka njihova greška ili moja? Vidim na nekim drugim forumima ljudima radi sve kako treba.
Reinstall probao, Task Menager i Resource Monitor sve normalno...
Intel G1610; ASUS B75M-LX Plus; 4096 MB; Intel HD; Hitachi 7K1000.C 500 GB; LG GH24NS95; Silverstone Strider Essential 400 W; Logitech K200; Logitech B110; Logitech X-240 2.1; Philips 200V4LAB 20" DVI; Windows 7 64-bit Professional
Bambusha je offline   Reply With Quote
Staro 02.01.2010., 17:37   #716
Buger
Postovi: 4,391
Autor kwan Pregled postova
hvala, ali ništa
na svu sreću radi se o ne tako važnim datotekama pa mogu preživjeti, ali mogu ih i nabaviti od nekog prijatelja koji je to sačuvao...konkretno radi se o učeničkom digitalnom godišnjaku...
Staro 02.01.2010., 18:02   #717
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
acronis true image trenutno mi je najbrzi i najednostavniji za koristiti
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 02.01.2010., 19:25   #718
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Jel ima netko ovaj problem s Nero 9 v9.4.26.0
Znači izaberem koje "djelove" hoču instalirati,instalira se onaj patcher i kad kreče instalacija izbaci ovo...
Probao sam sve savjete što sam našao na netu-brisanje iz registrya,disejblanje AV-a,čiščenje temp foldera...
Probao sam i sa original Nero trial sa Naro web stranice i "druge" verzije ali sa svakom je isto.
Ima netko još koju ideju?
Staro 02.01.2010., 19:43   #719
Buger
Postovi: 4,391
ako ti treba smao za snimanje na CD/DVD, odnosno ako ti ne trebaju Nero Vision i ostale gluposti probaj program InfraRecorder
Staro 02.01.2010., 19:55   #720
Veki-os
Veki-os's Avatar
Postovi: 3,996
Probao sam ja par drugih programa i snimam sad sa BurnAware ali hoču baš Neru
