#31 | |
Lokacija: Ne znam
Postovi: 65
normalno kad ea i nvidija sobotiraju ati u vecini igrica kako i samo ime kaze ![]() |
#32 |
Postovi: 11,642
Ja sam s druge strane čuo kako Nvidia i EA već neko vrijeme plaćaju PC Eskpertu i korisnicima masne pare da pišu okolo kako imaju problema s ATI-jevim karticama. |
#34 |
Lokacija: Ne znam
Postovi: 65
#35 | |
Lokacija: Ne znam
Postovi: 65
The BETA patch was designed to address some of the key issues with ATI & Nvidia graphics cards and resulting freezing issues. We are aware of and committed to providing extended support for other PC issues being reported & want to ask you, the community, to help keep those reports coming in. I will be opening a new thread on Friday that will play host for anyone with direct feedback on the released BETA patch & I would like to request everyone reporting issues follow the below guidelines. By following these steps we will be able to better determine what is going on & reproduce the errors you might be encountering here at the studio & hopefully address them in updated patches. Summary: A brief description of the problem you have encountered. (Example: Screen Freezing or Game Crashing to Desktop etc…) Problem Description: The defect explained in more detail. (Example: What were you doing, where are you at in the game, what actions you were doing when the error occurred) Reproduction Method: How to reproduce the bug through a series of concise and complete steps. (Example: 1.) If you go to this point in the game 2.) Do this action 3.)Than you run over to this point 4.)Than the error will happen.) Hardware Configuration: CPU: (Intel or AMD) & CPU name GPU: ATI or Nvidia & the series & driver being used Memory: How much is your system reporting Hard Drive: How big is the drive the game is installed on & how much space is left? OS: What version of Windows are you running? (Example: CPU: Intel Core i7 920 2.66GHz GPU: Nvidia 9800GTX – Driver 192.56 Memory: 4GB Memory Hard Drive: 500GB HD with 256GB of Free Space OS: Windows 7 Ultimate 64bit) Reproduction Rate: Did it happen just once, some of the time or all of the time? (Example: This issue happens every other time when doing the above reported steps) Comments: Any extra information that you want to add that didn’t fit into the above spaces. *Download and use of the Beta Patch requires acceptance of an End User License Agreement Zadnje izmijenjeno od: krlja. 17.12.2009. u 11:19. |
#36 |
Hurr durr
Lokacija: Stančić
Postovi: 1,449
Ako netko zna da mi pomogne ![]() ![]() ![]() ![]()
#37 |
Postovi: 2,327
za ovaj mayhem prvo trebas bacit 5 nacia sa tornja a onda ces dobit da ih moras zgazit 10 ili 20 ne sjecam se. Nego kak si pobjego sa level 5 alarma? 4 bez pol frke pobjegnem ali 5 me onaj avion ganja
#39 |
Lokacija: ZAgreb
Postovi: 31
Još malo problema :-)
Da li se netko suočio s ovim: Dakle, konfiguracijaje u sig-u: ATI + Win 7 Igra radi savršeno sa zadnjim patchom, no u nekim dijelovima grada, pada aktivnost GPU-a?!?!?! Okrenem se prema ajmo reći sjeveru i GPU radi na nekih 80-90 posto, dok krenem prema jugu i aktivnost padne prvo na 20% pa na 0%... i imam strip... ![]() ![]() |
#40 |
Datum registracije: Jul 2009
Postovi: 278
dakle vidim da ljudi imaju ovakvih problema kao i ja, točnije kada idem gledat full mapu sve stvari mi se pomaknu izvan karte i potpuno je neupotrebljiva za markere misije i sve ostalo. :S Uglavnom igram na rezi 1920x1080. Ima li kakvo rješenje za ovo ? I da, instaliran je 1.03 patch http://img141.imageshack.us/i/sabote...252009280.jpg/ ![]() |
#41 |
Lokacija: Chernobyl NPP
Postovi: 4,777
#42 | |
its slightly turbocharged
Postovi: 5,430
![]() ![]() Jedan od najsmješniji ljudi na netu ![]()
blaa |
#46 |
Hurr durr
Lokacija: Stančić
Postovi: 1,449
Igrica je relativno kratka ali ove sporedne stvari poput skupljanja tih perkova i rijesavanja svih tockica na mapi traje jako dugo. Meni je jos ostao samo jedan dio grada za rijesiti.
#48 | |
Lokacija: ZAgreb
Postovi: 31
#49 |
Premija
Datum registracije: Mar 2009
Postovi: 1,634
Poznato je da igra ima problema s ATi karticama. Pričekaj još patcheva, to je jedina opcija.
K: 7950GX2, 8800 Ultra, GTX295 |
#51 |
Xulos :)
Postovi: 7,550
Naravno igra na frendovom lapu s nvidiom 9300 SE radi kak treba, a moja 4330 kao ranjena krava , steka i odma blok , bez obzira na patch. Jao , kad ja moram bit konj i kupit lap s ATI grafikom, od samog pocetka sranja s njom , te mobility modder da bi driveri radili , te neki hotfixevi i patchevi za igre, ma nabijemih, i nek kaze sto hoce al nikad vise ati, makar mi ju poklonili.
#52 |
Bajker s AMD-om na dresu
Postovi: 960
Evo baš sam malo danas odigrao igru i na početku je ful zbunjujuća dok se ne pohvata konce...dalje je laganica...a igra najbolje opisuje : gta IV s assassins creed elementima tijekom drugog svj. rata u parizu rađen sin city tehnikom dok se ne "oslobode" određeni djelovi grada |
#54 |
Postovi: 7,504
Moram se malo BUMPat ![]() Igra je prejebena, igrao sam je nekih 2 dana i očarala me. Ima sitnih bugova (koje će ispravit, bar se nadam), i stvarno je preigriva. Meni odličan spoj AS i SC, samo bi volio da ima više SC šema ![]() Stvarno prepruka ko nije igrao ![]() |
#55 |
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
Slučajno sam jučer navećer naletio na review igrice (KLIK) i onak se čudim kako nisam do sad naišao na to. Samo me muči što mi faks idući tjedan počinje a u Zagrebu nemam komp nego laptop ![]() EDIT: Odigrao nešto više od pola igrice i iskreno baš mi se svidjela, je da ima mana ali solidna igrica za odigrat. Najviše mi vuče na Mafiu. Penjanje po zidovima/kućama/zgradama u svemu me začudilo jako i to je onak trashasti dio igre ali nije da kvari previše sveukupni dojam. 7/10
««-´`-´`·..·´`-´`-»» Zadnje izmijenjeno od: Z-man. 18.10.2010. u 18:12. Razlog: da ne ostavljam post na post, editirao sam stari |
#56 |
Never Forgetti
Lokacija: .
Postovi: 1,640
Evo nakon dosta vremena sam opet instalirao igru ali me sada smeta sto mi je Draw Distance preslab...da li postoji rjesenje za to?
