Datum registracije: Mar 2008
Postovi: 22
ST780wl novi firmware, podešavanje IPTV ulaza
Pozdrav svima voljnim pomoci. Naime imao sam nekih problema sa routerom da se "resetirao" (svijetlila je samo power ledica narancasto i ethernet zeleno). Nakon toga nisam se mogao spojit na internet pa sam u internet caffe otisao provjeriti i nasao rjesenje. Stavio sam novi firmware, sve podesio kako treba ali sam znao da necu imati IPTV za maxtv podesen. Tragajuci internetom nasao sam postupak za IPTV ulaz da imam ali sam nesto sprckao u telnetu i tako opet ostao bez interneta...opet firmware trebao novi stavit. ![]() Evo ja sam ovo unjeo, s tim da sam promjenio brojke 35 u 40 (sve, i one 0.35 u 0.40). I da dodam, ja kad pokrenem telnet I opcenito neznam kako da unosim, ja sam unosio komandu po komandu s tim da bih kopirao ono sto je iza dvotočke. Na ovo mislim: Code:
2) List the atm interfaces. {admin}=>:atm iflist atm_Internet: dest : pvc_Internet Retry : 10 QoS : default Encaps : llc Fcs : disabled Ulp : mac Connection State : connected 3) Add a new ATM interface called TPG_IPTV {admin}=>:atm ifadd intf = TPG_IPTV 4) Verify that the new ATM interface is added {admin}=>:atm iflist atm_Internet: dest : pvc_Internet Retry : 10 QoS : default Encaps : llc Fcs : disabled Ulp : mac Connection State : connected TPG_IPTV : dest : (none) Retry : 10 QoS : default Encaps : llc Fcs : disabled Ulp : ip Connection State : not-connected 5) Add a new phonebook entry for VPI=0 VCI=35 {admin}=>:atm phonebook add name=atm_pvc_0_35 addr=0.35 6) Verify that the new phonebook entry is added {admin}=>:atm phonebook list Name Use Address pvc_Internet 1 8.35 atm_pvc_0_35 0 0.35 7) Configure the TPG_IPTV ATM interface {admin}=>:atm ifconfig intf=TPG_IPTV dest=atm_pvc_0_35 encaps=llc ulp=mac 8) Attach and connect the ATM interface {admin}=>:atm ifattach intf=TPG_IPTV 9) Create a new bridge interface {admin}=>:eth bridge ifadd intf=IPTV 10) Configure the bridge to TPG_IPTV ensure multicast filter is disabled. {admin}=>:eth bridge ifconfig intf=IPTV dest=TPG_IPTV mcastfilter=disabled 11) Attach the bridge connection {admin}=>:eth bridge ifattach intf=IPTV 12) Save the configuration to flash (default filename= user.ini) {admin}=>:config save filename = user.ini {admin}=> |
Postovi: 23,512
Pogledaj onu veliku temu o tom uređaju u ISP grupi |
