Staro 26.11.2009., 09:25   #1
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
Nvidia Forceware 195.62 WHQL driveri
http://www.nvidia.com/object/win7_wi...5.62_whql.html
http://www.nvidia.com/object/winxp64_195.62_whql.html
http://www.nvidia.com/object/winxp_195.62_whql.html
New in Version 195.62
  • Adds GPU-acceleration for smoother online HD videos with the new Adobe Flash 10.1 beta. Learn more here.
  • Adds support for GeForce GT 240.
  • Adds support for OpenCL 1.0 (Open Computing Language) for all GeForce 8-series and later GPUs.
  • Adds support for CUDA Toolkit 3.0 features and performance enhancements. See CUDA Zone for more details.
  • Adds SLI and multi-GPU support for many top new gaming titles including Borderlands, Call of Duty: Modern Warfare 2, FIFA Soccer 10, and more.
  • Includes numerous bug fixes including improved performance for Need for Speed: Shift. Refer to the release notes on the documentation tab for information about the key bug fixes in this release.
  • Users without US English operating systems can select their language and download the International driver
ko voli nek izvoli
Pizz je offline   Reply With Quote
Staro 04.12.2009., 22:52   #2
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,833
Probao sam instalirati nove WHQL drivere za laptop (64-bit Vista, posebni notebook driveri za prijenosna računala), i jednostavno ih iz nekog nepoznatog razloga neće instalirati.
Nakon reboota mi instalira defaultni WDM driver za 9600GS, a zadnji driveri za koje mi prolazi install kak spada su stari 186.81 WHQL.
Ima tko ideje u čemu bi mogao ležati problem?
potemkin.hr je offline   Reply With Quote
Staro 04.12.2009., 23:01   #3
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor potemkin.hr Pregled postova
Odakle si skinio? Jesi gledao ovde
Staro 04.12.2009., 23:08   #4
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,833
Ma na nVidia stranici skinuo direkt za 64-bit Vistu / mobile čipove (link).
I dalje mi nije jasno zašto mi ne prolazi setup, noviji od 186.81 jednostavno ne prolaze...
Staro 05.12.2009., 00:09   #5
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
stvarno cudno...
jesi li probao nakon sto ti setup otpakira drivere u nvidia direktorij, rucno instalirati drivere? ako je tvoj mobilni cip podrzan, tako bi trebalo proci.
Staro 05.12.2009., 00:27   #6
Baja 001
Baja 001's Avatar
Postovi: 7,504
Pa ako setup ne prolazi onda sigurno tvoja kartice nije u onom setup fileu. Znači ili skini custom ili stariji driveri
Staro 05.12.2009., 00:44   #7
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,833
stvarno cudno...
Jesam i ne prolazi, jebig*. Čip je u notesima podržani (SUPPORTED PRODUCTS: GeForce 9M series: 9600M GS).
Moral budem tjerati stare gonioce (drivere)
Staro 05.12.2009., 00:49   #8
Baja 001
Baja 001's Avatar
Postovi: 7,504
Tako je meni bilo sa 8400GS, nije bitno šta piše u release notes nego u NV_DISP.
Kažem probaj skinuti sa LaptopVideo2Go, pa onda vidi kako će biti
Staro 05.12.2009., 15:35   #9
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,833
Nikako na zelenu granu s tim driverima, physix setup je poludjel kod installa, napravil u temp folderu ogroman fajl koji se nastavil povećavati, moral sam ga killati preko process explorera
http://img18.imageshack.us/img18/6261/bemtiphysix.jpg
@Baja 001: Nisam probal ove custom drivere, niti ih budem izgleda, sve mi radi kak spada s starim driverima tako da ostajem na 186.81 WHQL zasada. Nema nekih ekstra novosti u odnosu na 186.81 tako da me ovi zadovoljavaju. Anyway, tx na pomoći.
P.S. - Poslal i "dečkima 'z envidije" mail s opisom problema tako da budemo vidjeli što će biti s toga...
Staro 05.12.2009., 17:26   #10
Speedbreaker
Postovi: 545
Driveri se ruše na svježe instaliranoj sedmici x64...
Izbaci van iz igre pa kaže: Video driver has stopped responding.
Speedbreaker je offline   Reply With Quote
Staro 06.12.2009., 13:20   #11
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,738
Autor Speedbreaker Pregled postova
A koje igre?
Ja za sad nemam nikakvih problema..
Staro 06.12.2009., 13:34   #12
Speedbreaker
Postovi: 545
Richard Burns
sad se počelo i u desktopu rušit.Samo se zamrači pa se vrati natrag.
Sad skidam istu verziju Xtreme-G drivera pa javim kak rade.
EDIT: upravo stavio xtreme-g verziju, sad se ne ruši više.Inače uvijek koristim tweakforceove drivere, i nikad problema s njima.
Evo link na TweakForce Xtreme-G 195.62 WHQL drivere.
nadam se da ne kršim neka pravila...
Zadnje izmijenjeno od: Speedbreaker. 06.12.2009. u 14:19.
Staro 06.12.2009., 16:35   #13
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Richard Burns
To majstore!!
xtremeG stranica mi je skoro svakodnevni posjet, valjda su mi promaknuli!!!
hvala na linku!!
Nemam više lema!!!
Staro 06.12.2009., 23:03   #14
ante2
ante2's Avatar
Postovi: 1,313
o majko mila sve mi se cini da cu jos neko vrijeme bit na XP-u, jer na njima sve radi kako treba i to na dva kompa jedan ima 9600 GT a drugi GTX 275 896 MB
,a sedmica mi vec neko vrijeme sjedi na polici i smjeska se :-)
driveri v195.62 na 32bitnim XP SP-3 rade ko puska, tj nikakvih problem
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 07.12.2009., 19:58   #15
LorD ClockaN
od LemilicE
Postovi: 4,712
i meni rade ko puska, ali volim XG drivere!!
Nemam više lema!!!
Staro 13.03.2010., 13:30   #16
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
dobri su driveri... pokazali su mi se bolji nego 196.21...
Tekla je offline   Reply With Quote
