Lokacija: bih
Postovi: 7
Ne mogu pokrenuti Windows Defragmenter
Odnedavno ne mogu da koristim defragmentiranje u system tools gdje dobijem poruku: MMC cannot open the file C:\WINDOWS\system32\dfrg.msc. Nakon fiksiranja problema sam postupio: This issue may occur when one or more of the .dll files that are used by the Microsoft Management Console (MMC) are missing or corrupted. These files include the following: * Msxml.dll * Msxml2.dll * Msxml3.dll To resolve this issue, follow these steps: 1. Click Start, click Run, type cmd, and then click OK. 2. At the command prompt, type cd %windir%\system32, and then press ENTER. Note The %Windir% folder is the folder where you installed Microsoft Windows. 3. Type the following commands. Press ENTER after each command. Regsvr32 Msxml.dll Regsvr32 Msxml2.dll Regsvr32 Msxml3.dll 4. Type exit, and then press ENTER to close the Command Prompt window. 5. Restart the computer. I sve je ostalo isto. Molim prijedlog šta da sledeće pokušam. |
#2 | |
N00B
Postovi: 3,886
Jesi probao ovo: Citiraj:
N00B
Postovi: 3,886
Lokacija: München/Varaždin
Postovi: 4,876
Probaj tražiti navedene *.dll fajlove pa ak ih nema skini sa neta pa stavi u sistemski folder gdje im je mjesto (vjerojatno system32) pa probaj opet.
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / OpenSuse Leap 16 |
