Staro 20.11.2009., 21:19   #1
tales1
Lokacija: bih
Postovi: 7
Ne mogu pokrenuti Windows Defragmenter
Odnedavno ne mogu da koristim defragmentiranje u system tools gdje dobijem poruku:
MMC cannot open the file C:\WINDOWS\system32\dfrg.msc.
Nakon fiksiranja problema sam postupio:
This issue may occur when one or more of the .dll files that are used by the Microsoft Management Console (MMC) are missing or corrupted. These files include the following:
* Msxml.dll
* Msxml2.dll
* Msxml3.dll
To resolve this issue, follow these steps:
1. Click Start, click Run, type cmd, and then click OK.
2. At the command prompt, type cd %windir%\system32, and then press ENTER.
Note The %Windir% folder is the folder where you installed Microsoft Windows.
3. Type the following commands. Press ENTER after each command.
Regsvr32 Msxml.dll
Regsvr32 Msxml2.dll
Regsvr32 Msxml3.dll
4. Type exit, and then press ENTER to close the Command Prompt window.
5. Restart the computer.
I sve je ostalo isto. Molim prijedlog šta da sledeće pokušam.
tales1 je offline   Reply With Quote
Staro 20.11.2009., 22:27   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Jesi probao ovo:
C:\Windows\Inf, right click at dfrg.inf file and select Install.
http://www.raymond.cc/blog/archives/...rgmsc-problem/
IE6
Linux is Not Windows
Staro 22.11.2009., 09:37   #3
tales1
Lokacija: bih
Postovi: 7
jesam i ništa nisam riješio nego sam skinuo prvi defragmenter sa neta i njime uredio diskove
Staro 22.11.2009., 11:08   #4
Joke
N00B
Joke's Avatar
Postovi: 3,886
Autor tales1 Pregled postova
Dobro si i ucinio, inace bi preporuka bila za O&O Defrag ili Diskeeper (nisu free)!
IE6
Staro 22.11.2009., 13:05   #5
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,635
Probaj tražiti navedene *.dll fajlove pa ak ih nema skini sa neta pa stavi u sistemski folder gdje im je mjesto (vjerojatno system32) pa probaj opet.
