Staro 28.11.2008., 13:52   #31
max_extreme
Lokacija: split
Postovi: 1
Imam jedno pitanje,nadan se da ce mi moc netko od vas pomoc.
Ovaj navedeni router dobia san s maxtv-om nedavno,i tu iman jedan problem s konfiguracijom.Prije san koristia "kasdu".Koristia bi wampserver i kad bi nesto programira npr u php-u jednostavno server stavin online i preko svoga IP-a netko moze vidjeti to sta san radia,e al sad tako vise nije,jer kad upisem svoj IP u address bar onda mi se ne otvori localhost,jeli ima netko ideju kako to napravit???? hvala
max_extreme je offline   Reply With Quote
Staro 28.11.2008., 15:08   #32
Facelessone
Facelessone's Avatar
Postovi: 4,203
Forwardaj port 80 na svoj lokalni IP, a i složi si preko dinamički dns preko dyndns-a ili no-ip-a. Nemoraš stalno IP tražit koji ti je.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 28.11.2008., 16:05   #33
thopok
Lokacija: Splity
Postovi: 3,003
Game & Application Sharing
Assign the public IP address of a connection to a device
You might want to do this if:
  • You encounter issues with some applications through the Network Address Translation engine of your SpeedTouch.
  • This device is running server applications (web server, ...) and you want it to be accessible from the internet.
  • This device has to be considered as the unique entry to your local network (DMZ).
Staro 29.11.2008., 21:05   #34
Pingo
Lokacija: Vkci
Postovi: 16
Autor Pingo Pregled postova
Pozdrav,
imam ovaj ruter i zadnjih nekoliko dana mi je poceo stvarati probleme prilikom spajanja preko wlana. Uglavnom, na stolnom racualu..ovom s kojeg se javljam, je sve ok, povezan je s ruterom žicom. Laptop spajam preko wlana i do sada je redilo ok. KAd bih se spojio veza bi se podjelila 50% i 50% i to je bilo ok. Sad mi se događa da je brzina veze preko wlana od 15 do cca 200 kbps. Uzasno sporo. trebala bi biti najmanje 1mbps. Zvao sam sluzbu, rekli da su nesto pnovno pustili, resetirali, da ja ukljucim iksljucim ruter iz struje i onda da iskjucim wlan i tako. Radi nekih 10-15 minuta i onda opet opadne brznia.
Jel ima netko slicnih iskustava...i mozda zna kako to ispraviti.
Inace ako se spojim negdje drugdje na "neciju" mezu brzina je ok, sve radi. Samo kod kuce ne!
Hvala unaprijed!
nitko nema ovakav problem?
Pingo je offline   Reply With Quote
Staro 11.01.2009., 20:26   #35
Japanac
Japanac's Avatar
Postovi: 15
Imam ovaj ruter i zanima me kako mogu u njemu podesiti bandwidth budući da sam ga pretražio i nigdje nisam našao te opcije!?
Ako već ne mogu u njemu podešavati, bez da ga flash-am, sa kojim programom mogu najlakše podesiti bandwidth!?
Zadnje izmijenjeno od: Japanac. 11.01.2009. u 20:49.
Japanac je offline   Reply With Quote
Staro 14.11.2009., 12:48   #36
vale4674
Datum registracije: Mar 2009
Postovi: 5
Pitanje.
Imam navedeni router. Usluga Iskon.DUO.
Kada sam ga tek dobio išao sam ga podešavati i vidio na nigdje u izborniku nema da odaberem PPPoE pa da tamo upišem username i password od CarNET-a.
To mi nije bio problem jer sam imao jednog U.S. Roboticsa kojega sam spojio na SpeedToucha i onda sam u U.S.Robotics upisao user i pass Carnetov i lijepo sam imao wireless mrežu u stanu.
Sad je U.S. Robotics otišao u vječna lovišta i ostao mi je samo ovaj SpeedTouch i onaj prvotni problem. Sada se moram spajati wireless na SpeedTouch-a pa tek onda sa kompa praviti PPPoE konekciju (ali to mi nije rješenje jer sa mobitelom ne mogu praviti to).
Puno googlanja i čitanja ovog foruma i naišao sam samo na informaciju da je moguće podestiti ga, ali treba zvati službu za korisnike.
Da li me netko može uputiti? Jel ima neki način, a da ih ne zovem?
Hvala!
vale4674 je offline   Reply With Quote
Staro 16.11.2009., 01:01   #37
vale4674
Postovi: 5
hmmmm... ili da zovem SZK
Staro 20.11.2009., 01:54   #38
thopok
Lokacija: Splity
Postovi: 3,003
a ne bi ni to pomoglo kad nije podrzano...
zasigurno se radilo o propustu
Staro 22.11.2009., 01:34   #39
Viperus
Viperus's Avatar
Postovi: 729
Router mi se negdi jednom tjedno zblesira (mama više manje nikad ne gasi maxtv) , prestane net radit, neće uopće uć u 192.168.1.1, sad sam igrao sa prijateljem cod5 i njemu na serveru u poljskoj ping 50-85, a meni 105-135, jel povečani ping znag routera šta crkava ili bi trebao tražit problem drugdje?
Viperus je offline   Reply With Quote
Staro 23.11.2009., 20:18   #40
iggyone
u borbi protiv sna
iggyone's Avatar
Lokacija: Kruge, ZG
Postovi: 175
Neznam točno gdje smjestiti moj problem, nadam se da je ovdje ok.
Imam adsl/net preko T-coma, navedeni modem, brzina - 4MBit Flat tarifa.
Modem i veza su skroz ok, samo mijenjao port forwardanje za torrente, i neke sitnice oko IP adresa i WLAN mreže. Otkako sam se počeo poprilično koristiti sa Fring-om na mobu (štedi se poprilična suma novaca), prilikom razgovora preko WLAN konekcije, dolazi do samostalnog restartanja modema (cold reset). Nije se desilo svaki put, ali 5 od 7 puta u jednom danu je ipak naznaka problema. A bome zna užasno živcirati kad se to dogodi usred važnijeg razgovora...pa onda čekanje da se sve konekta...
Ima li tko kakve ideje u čemu je problem i kaj bi trebalo napravit da mi se to više ne događa?
Asrock B550M Pro4
AMD Ryzen 5600 @ Thermalright Assassin King 120SE
2×8GB Corsair DDR4 CL16 3600MHz
Powercolor Red Devil 6700 XT 12GB
Kingston KC3000 SSD 512GB + Kingston NV2 SSD 2TB
LG DVD-RW
Corsair RM750e
Dell S2716HN
Fractal Design Define Mini
mouse&keyboard Logitech vulgaris
Predzadnja trgovina | Zadnja trgovina
iggyone je offline   Reply With Quote
Staro 25.12.2009., 17:19   #41
rokoko
In Rainbows
rokoko's Avatar
Postovi: 714
nvm,našao
"Success can only be achieved with a kind of pioneer spirit and repeated use of three tools: failure, introspection and courage." - Soichiro Honda
Zadnje izmijenjeno od: rokoko. 25.12.2009. u 17:33.
rokoko je offline   Reply With Quote
Staro 24.12.2010., 11:06   #42
goranbo
Lokacija: Bjelovar
Postovi: 135
Eh ljudi, za sve one koji su konfigurirati ovaj router, my bad, isprika, čini mi se da sam zaboravio navesti vam ejdan ejdan korak .
Te T-comove routere smo dobili zaključane tj da bi vi mogli promijeniti sve te postavke potrebne u ovom procesu, trebate se logirati kao administrator a ne kao user.
Tek kad se logirate kao administrator vam neke postavke postanu vidljive.
Username je : adminsitrator
lozinka: !M1PhoIAD2
(to je akos te ga dobili od T-coma, za Iskon pronađuite na internetu po forumima)
Tek tada cete u meniju konfiguracija rutera moci promijeniti setup file ili konfigurirati SIP usluge.
PS. Sad sam se toga sjetio jer mi je odjedanput sve riknulo i moram sve isponova.
Zadnje izmijenjeno od: goranbo. 24.12.2010. u 11:13.
goranbo je offline   Reply With Quote
Staro 24.12.2010., 14:17   #43
Postovi: 23,503
Eto šta radi alkohol, da si otvorio veliku temu o tom uređaju onda bi vidio da je taj info poznat već ohoho (možda par godina).
