Staro 20.08.2006., 20:02   #1
S.T.A.R.S.
Postovi: 2
Playstation 2 emulator
Čuo sam da mnogi traže ispravan ps2 emulator.Ne znam dali je itko imao
psx 1.8 , ali taj ne koristi nikakve pluginove.Pa sam mislio da se i za ps2 napravi bez njih.No pustite sad to.Ja sam probao sve moguče ps2 emulatore
i uopče ih nije teško namjestiti da rade.Naravno sporo.No mislio sam kada
bismo mi svi skupa pokušali napraviti jedan na Visual Studio 2003.U tome
oni rade PCSX2.Ja sam več nešto pokušao,nije lako,ali za prvi put sam več uspio izmjeniti sliku u "pcsx2.exe" aplikaciji kada se pali.Isto tako u grafičkom
pluginu "ZeroGS KOSMOS 0.95.2 sse2.dll".Također sam malo opcije u njemu
ispremještao.Nazvao sam ga "VERTIX".Nije ništa drugačiji ali ipak se več u 2
dana nešto uspjelo.Evo nekih komanda za pcsx2 koje sam vidio u Visual Studiu 2003:
ID:1 for "OK" (1 button control)
ID:2 for "Cancel" (2 button control)
ID:65535 for "Window Size" (655352 group-box control)
ID:1026 for "640x480" (1026 radio-button control)
ID:1027 for "800x600" (1027 radio-button control)
ID:1028 for "1024x768" (1028 radio-button control)
ID:1029 for "1280x960" (1029 radio-button control)
ID:65535 for "Antialising for higher quality (F6)" (655351 group-box control)
ID:1022 for "NONE" (1022 radio-button control)
ID:1023 for "2X" (1023 radio-button control)
ID:1024 for "4X" (1024 radio-button control)
ID:1030 for "Wireframe Rendering (Shift+F6)" (1030 check-box control)
ID:1020 for "FFX Hack (F9)\n For fixing geometry in ffx" (1020 check-box control)
ID:1021 for "Save Snapshots as BMPs (default is JPG)" (1021 check-box control)
ID:1017 for "Interlace Enable (toggle with F5)\n there are 4 modes + interlace off" (1017 check-box control)
ID:1018 for "Capture Avi (zerogs.avi) (F7)" (1018 check-box control)
ID:1025 for "Bilinear Filtering (Shift+F5)\n Best quality is on, turn off for speed" (1025 check-box control)
ID:1019 for "Fullscreen (Alt+Enter)\n to get out press Alt+Enter again" (1019 check-box control)
ID:65535 for "Show Frames Per Second (Shift+F7)" (655353 text control)
ID:1056 for "Configure..." (1056 button control)
ID:1057 for "Test..." (1057 button control)
ID:1058 for "About..." (1058 button control)
Čak su mnoge i radile!No naravno,u pluginu nije ništa promjenjeno,no sada mi barem ne blokirava u Resident Evil-u Code Veronici na nekom dijelu kao prije.
Ako bi mi itko mogao pomoči da napravimo ps2 emulator ili usavršimo pcsx2 , neka me kontaktira na moj MSN: marin.j@hotmail.com
S.T.A.R.S. je offline   Reply With Quote
Staro 20.08.2006., 20:48   #2
1VAN
1VAN's Avatar
Lokacija: Zabok
Postovi: 331
1VAN je offline   Reply With Quote
Staro 20.08.2006., 21:51   #3
S.T.A.R.S.
Postovi: 2
Pa to je isti onaj sa www.pcsx2.net
Radi totalno isto.7 fps,ne može do kraja prikazati reklame i nema zvuka svuda.Sve sam to ja več odavno probao.Još je to jako loše.
Zadnje izmijenjeno od: S.T.A.R.S.. 20.08.2006. u 22:02.
Staro 16.03.2009., 17:10   #4
Njokli
Postovi: 97
Evo 2009 je i kompovi bez problema vrte ove emulatore, naravno svi osim mog. Budući da mnogi koriste Pcsx2 zamolio bih neku dobru dušu koja se kuži da mi pomogne. Pročitao sam brdo stranih foruma i ne znam što krivo radim. Skinuo sam ovaj novi Pcsx2 sa službene stranice stavio biose. Imam na kompu iso file final fantasy X, sve napravio kako piše ali kad pokrenem dođe samo do glavnog izbornika od playstationa gdje se mogu namjestat jezik, sat itd...
Njokli je offline   Reply With Quote
Staro 16.03.2009., 20:45   #5
Ant3G
Lokacija: Gospić
Postovi: 71
Autor Njokli Pregled postova
probaj biose mjenjati, usa, japan i eu verzija, jedan ce dici igru
mozda upali, ako ne, moze ovisiti o puno drugih opcija :S
Ant3G je offline   Reply With Quote
Staro 18.03.2009., 11:09   #6
panisher20
panisher20's Avatar
Postovi: 939
neisplati se uopce gubit vrijeme sa tim, izgubio sam 2 dana dok sam to sve namjestao, i sad neke igrice su radile neke ne, radije si kupim ps2
panisher20 je offline   Reply With Quote
Staro 18.03.2009., 11:29   #7
media_plejer
Postovi: 115
Sve poslje Nintendo 64-a je vrlo nezahvalno emulirat
media_plejer je offline   Reply With Quote
Staro 29.09.2009., 18:53   #8
Baja 001
Baja 001's Avatar
Postovi: 7,504
Evo da dignem temu, neznam da li je vijest (!) ili nije. Uglavnom prije dva dana nisam se mogao čuda načudit, dečko na PCu vozi FF11. I uglavnom da skratim emulator radi odlično, a grafika sa svim filtrima na HD3850 izgleda 2x bolje nego na PS2ici.
Ipak sada nisam probao druge igre (iako ne igram FF11, samo sam htio probat), izgleda da je došlo vrijeme za GT4 na PCu, isto tako i meni ne prežaljeni Manhunt 2
Staro 29.09.2009., 19:04   #9
mymoon
nautic expert
mymoon's Avatar
Lokacija: Rijeka-Opatija, negdje između
Postovi: 1,386
ok. koji "emulator radi ok"?
mymoon je offline   Reply With Quote
Staro 29.09.2009., 19:07   #10
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor mymoon Pregled postova
http://pcsx2.net/
Uglavnom ima i compatibility lista igara, i GT4 i Manhut 2 je na njima
Staro 29.09.2009., 20:18   #11
Keyser Söze
Rent-a-maniac
Keyser Söze's Avatar
Postovi: 756
evo ja sam nakon 2 god uspio upogonit gt4 na pc-u. napatio sam se ko majmun
ne izgleda bog zna sto a to dugujem crappy hw-u u mom kompu, ali to nije ni bitno jer ovo je ionako jedan vid satisfakcije jer mi je frend (koji ima plejku i kod kojeg sam slinio nad gt4) tvrdio da je to nemoguce i da nece ni biti moguće. e pa in your face
evo i malo ss-ova
http://img2.imageshack.us/gal.php?g=...9092919454.png
i ne, ne znam zasto je tako mracno
Staro 29.09.2009., 20:40   #12
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,793
Autor Keyser Söze Pregled postova
evo i malo ss-ova
Pa daj detalje kako si osposobio
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / Fedora Workstation 42
Staro 29.09.2009., 21:05   #13
Keyser Söze
Rent-a-maniac
Postovi: 756
moram pogledat jer sam toliko razlicitih postavki prosao...javim kad stignem
Staro 30.09.2009., 16:30   #14
Baja 001
Baja 001's Avatar
Postovi: 7,504
evo i malo ss-ova
Pa komp ti je dosta jak ako je ovaj iz Moj Komp, ne vidim zašto bi ti bilo do toga
A je mi drago baš radi GT4, nisam se nikome rugao ali mi je trebala ta igra jer sam je na Plejci dosta igrao.
Staro 30.09.2009., 16:58   #15
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
daj upali i fraps pa provjeri kako se fps krece!
uh, uh. GT4 na kompu . mnogo mnogo vec izbor auta nego na NFS-u novom (srednja klasa auta iz 90-ih) + nurburgring! Neprocjenjivo
Staro 30.09.2009., 17:08   #16
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor papčić Pregled postova
To je to, još DS ili neki ekvivalent i deri. Volan da ne govorim.
Staro 30.09.2009., 23:10   #17
Keyser Söze
Rent-a-maniac
Postovi: 756
dosad nisam imao neta. tu su neki radovi oko mene. meni je u 60 fps a trka u nekih 49-60fps. mislio sam da ce se vidjet na ss iz frapsa al sam kasnije skuzio da sam tu opciju iskljucio. slika nije extra jer sam morao iskljucit aa i sve te gluposti. inace na onom ss je m5 na nord
idem sad za drugi komp pa cu stavit postavke.
edit: evo ovo je brzinski sklepano
dakle prvo trebate pcsx2-r1888 verziju emulatora
igra bi trebala biti (za gt4 govorim) NTSC, ne znam zasto ali eto pal nikako nije htio krenuti a i ako netko ima pal verziju neka proba
1. nakon istalacije prog treba podesiti ovako
http://img225.imageshack.us/i/postavke.png/
jaci komp q proc ili neka jača grafa bi mogli izvuci sigurno bolje ali eto radim s onim sto imam , (a i kako sam malo citao radi dostahirovito sve to skupa, od konfe do konfe je drugacije pa nemojte odustat ako ne proradi otprve)
2. dalje je vazno ovo i ovo podesit kao da ss-ovima
(razlog bas tim postavkama- nepoznat )
i to bi trebalo biti to
u postavkama plugins i bios directory trebate postavit rucno. ako nemate biose odmah nakon instalacije treba ih skinut a mozete googlat po nazivu iz prvog koraka ili udarit tu
u kratkim crtama to je to. ne mogu ici u sirinu jer kao sto sam rekao dosta je hirovit emulator i svakako se ponasa od konfe do konfe.
eto nadam se da sam nekom bar malo pomogao
a sad secer na kraju
Zadnje izmijenjeno od: Keyser Söze. 01.10.2009. u 00:10. Razlog: dodatak
Staro 30.09.2009., 23:46   #18
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
znam da nije toliki izbor auta al je fizika na razini daleko iznad gt4, a ima nurburgring: gtr evolution. al ni ne pokusavaj bez volana.
natrag na temu, dakle napokon (vec 2-3g ak na x2 240 radi tj, al nisam znao) je hw dovoljno jak za ps2 emulator, cool, ajde neki tutorial keyser stavi pa da i mi gotovani isprobamo kak to radi
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 04.11.2009., 17:44   #19
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
tu je najbolji guide, tak sam ja osposobio
http://forums.pcsx2.net/thread-5999.html
igram normalno Smackdown VS Raw 2010 i Fight Night Round 3
ali na 1080p i sve max...
treba jaka mađina za te emulatorčiče
Pizz je offline   Reply With Quote
Staro 04.11.2009., 17:50   #20
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Jel moguce osposobiti volan u GT4 (Logitech DFP točnije)?
Staro 04.11.2009., 18:02   #21
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor Pizz Pregled postova
Pa ne treba ni tak jaka makina-prije puno guglanja koji plugin za koju igru i koje postavke u emulatoru
Staro 04.11.2009., 22:57   #22
RS_BuRnOuT
RS_BuRnOuT's Avatar
Lokacija: Kž\Vž
Postovi: 458
Prije mjesec dana nabavio emulator za PSX1, i stavio GT2 da se malo prisjetim starih dana kad sam visio na plejki, isss, koji filing, bio frend kod mene, pa smo igrali time trial naizmjence.
Grafika losa naspram danasnjih igara, al zabava i gameplay odlicni, osmijeh od uha do uha kod obojice
Nakon toga, nabavio sam PSX2 emulator, kako bi odigrao jos jednu igru iz serijala koji mi je jako drag a tog nastavka nema za PC: Metal Gear Solid 3.
Igra radi ali samo do cca 22 FPS-a max, a u prosjeku nekih 13-15, pokrenuta na ovoj konfi:
Athlon 64 X2 5000+ Black Edition (bez clockanja)
GA-MA78G-DS3H Gigabyte
1GB DDR2 @533
ATI Radeon HD3200 (integrirana)
OS:W7
Sad sam nadogradio ram (4GB DDR2 @
Testiranje: konfa sve isto ko i prije samo sada vise RAM-a:
Tu i tamo skoci do 25FPS-a ali i u prosjeku nekih 15-17 FPS-a
Planiram nabaviti u skoro vrijeme 4850 ili GTS 260 pa se nadam da ce se poboljsat performanse tj. nadam se da ne ovisi samo o procesoru brzina izvodenja.
RS_BuRnOuT je offline   Reply With Quote
Staro 04.11.2009., 23:19   #23
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
Autor Jelc Pregled postova
heh, probal sam osposobit fajt najt 3 kod frenda na P4 @ 3ghz i 8600GTS
tam nikakav plugin ni pomogel :-(
mislim, sve dela samo kaj je slajdšou...
Staro 19.08.2011., 08:22   #24
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Guglam i nikako da zguglam - postoji li nekakva verzija Super Maria za PS2? I poželjno da na njoj radi Save opcija.
Pregledao Algoritam, CroVortex itd - ne nalazim. Zanimaju me samo originali. Možda netko od vas ima za prodati?
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 19.08.2011., 09:47   #25
Mad_Duke
Mario je Nintendo ekskluziva!
Staro 19.08.2011., 09:48   #26
Guls
Guls's Avatar
Postovi: 2,938
A da li možda postoji neki emulator za ps2? Ili ipak ništa od toga?
Intel i7 9700F
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 19.08.2011., 09:51   #27
Mad_Duke
Ima! Guglaj za emulatore i nađi.
Staro 23.08.2011., 07:31   #28
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,410
Da li emulator koristi visejezgrenost?
Staro 24.08.2011., 00:52   #29
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Ovo ću definitivno probat u kombinaciji sa FF XII
54' / 74' / 90' / 2014
Staro 21.04.2012., 15:00   #30
Cico96
Cico96's Avatar
Datum registracije: Mar 2012
Postovi: 151
Da ne otvaram novu temu, našao sam hrpu starijih i novijih igrica za plejku 2, a već sam koristio emulator za plej 1 na staroj konfi.
Jel mi komp može pokrenut taj PCSX2?
Cico96 je offline   Reply With Quote
