#631 |
Postovi: 12,425
2x 2GB na 1600MHz DDR2 ne buš našo ![]() Bolje uzet još dva Kingmaxa nego uzimat nekaj drugo... a razliku 800MHz vs 1066 nećeš baš skužit
#632 | |
Lokacija: VG
Postovi: 92
Code:
Matièna ploèa: Procesor Intel Pentium 4 530, 3000 MHz (15 x 200) Naziv matiène ploèe Gigabyte GA-8I915P Duo (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 2 DDR DIMM, 2 DDR2 DIMM, Audio, Gigabit LAN) Chipset na matiènoj ploèi Intel Grantsdale i915P Sistemska memorija 1024 MB (PC3200 DDR SDRAM) DIMM1: GoodRAM GR400D64L3/512 512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-4-4-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz) DIMM2: GoodRAM GR400D64L3/512 512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-4-4-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz) Tip BIOS-a Award Modular (01/21/05) Grafika: Grafièka kartica NVIDIA GeForce 6600 (256 MB) 3D akceleratorski èip nVIDIA GeForce 6600 PCI-E Monitor LG L1780Q (Digital) [17" LCD] (150674375) Multimedija: Zvuèna kartica C-Media CMI9880 @ Intel 82801FB ICH6 - High Definition Audio Controller [B-1] Diskovni podsustav: IDE kontroler Intel(R) 82801FB Ultra ATA Storage Controllers - 2651 Storage kontroler AXB5QOVZ IDE Controller Tvrdi disk Maxtor 6Y120M0 (120 GB, 7200 RPM, SATA) Optièki ureðaj FMPWHK FGLEZK12N SCSI CdRom Device Optièki ureðaj PIONEER DVD-RW DVR-109 (DVD+R9:6x, DVD-R9:6x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-ROM:16x, CD:40x/24x/40x DVD+RW/DVD-RW) SMART status tvrdih diskova OK Particije: C: (NTFS) 20481 MB (8216 MB slobodno) D: (NTFS) 67068 MB (8509 MB slobodno) E: (NTFS) 20544 MB (6329 MB slobodno) Ukupna velièina 105.6 GB (22.5 GB slobodno) Ulazni ureðaji: Tastatura Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Miš PS/2 Compatible Mouse Mreža: Primarna IP adresa 192.168.1.2 Primarna MAC adresa 00-0E-2E-9D-F3-7C Mrežni adapter Ralink Turbo Wireless LAN Card (192.168.1.2) Modem Intel(R) 536EP Modem Periferni ureðaji: Printer HP PSC 2350 series Printer Microsoft XPS Document Writer Printer SnagIt 8 USB1 kontroler Intel 82801FB ICH6 - USB Universal Host Controller [B-1] USB1 kontroler Intel 82801FB ICH6 - USB Universal Host Controller [B-1] USB1 kontroler Intel 82801FB ICH6 - USB Universal Host Controller [B-1] USB1 kontroler Intel 82801FB ICH6 - USB Universal Host Controller [B-1] USB2 kontroler Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1] DMI: DMI proizvoðaè BIOSa Award Software International, Inc. DMI verzija BIOSa F6 DMI proizvoðaè sustava DMI proizvod sustava DMI verzija sustava DMI serijski broj sustava DMI proizvoðaè matiène ploèe Gigabyte Technology Co., Ltd. DMI proizvod matiène ploèe 8I915P Duo DMI verzija matiène ploèe x.x DMI serijski broj matiène ploèe DMI proizvoðaè kuèišta DMI verzija kuèišta DMI serijski broj kuèišta DMI Asset Tag kuèišta DMI tip šasije Desktop Case DMI ukupno / slobodno memorijskih utora 4 / 2 |
#633 |
Postovi: 12,425
Gle, radit će ti bilo koji DDR2, tj trebao bi radit No pitanj eje na kojem radnom taktu će ti radit bez potrebe za overclockingom tj podizanjem takta sabirnice. To ti pak diktira BIOS ploče tj koje ti memorijske djelitelje nudi
#634 |
Lokacija: VG
Postovi: 92
Znaci ja mogu uzet i neku bolesnu ddr2 pc8000, 1066 Mhz koja radi na vise od 2V i to bi trebalo radit, samo na onim performansama koje ima maticna/bios tra-la-la? |
#635 |
Postovi: 12,425
da, samo kaj ćeš morat ručno unosit vrijednost radnoga takta (ako uopće imaš toliki mem djelitelj), latencija i radnoga napona btw PC8000 = 1000MHz, PC8500 = 1066MHz
#636 | ||
Lokacija: VG
Postovi: 92
![]() Citiraj:
#637 |
Postovi: 12,425
Da u Biosu moraš unijet ručno sve parametre rada memorije, više o tome imaš tu Prošeći se svojim biosom pa vidi što može a što ne btw možda ćeš trebat otvorit skrivene opcije koje na Gigabyteu otvaraš unutar BIOS-a sa Ctrl+F1 I da, kako je to ipak jako stara ploča, moja preporuka je da od nekoga prvo posudiš barem PC6400 tj 800MHz DDR2 da vidiš hoće li uopće taj chipset to prihvatit Vjerojatno hoće ali da budeš ziher
#638 |
Lokacija: VG
Postovi: 92
E sad vec kuzim ![]() ![]() |
#641 |
Lokacija: VG
Postovi: 92
Pogledao sam u bios i ove opcije sam nasao cpu host frequency (Mhz) - 200 / min. 100 - max. 600 / memory frequency for - auto / 1.66 / 2.00 / 2.66 / 3.00 / memory frequency (Mhz) - 400 dimm overvoltage control - + 0.1 / 0.2 / 0.3 dram timing selectable - spd / manual cas latency time - 3 / 2.5 / 2 active to precharge delay - 8 / min. 4 / max. 15 dram ras# to cas# delay - 4 / 2 / 3 / 5 dram ras# precharge - 4 / 2 / 3 / 5 refresh cycle time - 15 / min.4 / max. 35 refresh mode select - 7.8 us / 15.6 us MIB 2 - disabled / enabled vendor\brand kingstone\winbond a-data\hynix samsung twinmos infineon Ovo je ploca http://www.gigabyte.com.tw/Products/...ProductID=1802 Boldano je ovo sto je sad aktivno. Jeli se moze iz tog zakljucit tocno koja memorija ce radit, ili nece radit? Ne baca mi se bas 400-500kn, pa se igrat sa prodajom ako ne radi... |
#642 |
Lokacija: vž
Postovi: 77
hoće li RAM DDR2 1066MHz raditi na ploči koja podržava samo do 800MHz? znam da ako imam dva keksa različitih brzina na ploči (npr. 667 i 800 na ploči koja podržava do 800) da će raditi na 667.. Pa me isto tako zanima ako na ploču koja podržava do 800MHz upiknem RAM 1066MHz, hoće li on raditi na 800Mhz ili neće raditi uopće? radi se o ovoj ploči i RAM-ima ako to pomaže: http://www.adm.hr/product_info.php?c...oducts_id=4599 http://www.gigabyte.com.tw/Products/...ProductID=2644 |
#645 |
Datum registracije: Jan 2010
Lokacija: Here
Postovi: 25
Kompatibilnost memorije
Do nedavno sam ima 2x512 i odlucio sam nadograditi racunalo pa sam kupio jos 2x512. Kingmax MPWC22D-38KT3R-FNA 512 MB PC3500 DDR SDRAM (2.5-4-4-7 @ 217 MHz) (2.0-2-2-5 @ 133 MHz) <-- ovo je stara memorija u racunalu Kingmax MPXC22F-D8KT4B 512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-4-4-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz) <-- ovo je novo kupljena memorija. Problem je nastao kad sam ubacio ovu novu memoriju u racunalo da se racunalo jednostavno blokira. Neznam jel moram nesto posebno namjestiti u BIOS-u. Hvala na pomoci |
#646 |
Postovi: 12,613
Cesto se dogadjaju frke sa sva 4 slota popunjena. 1. Procitaj pravila 2. Krivi pdf, trebao si u probleme stavit. 3. Nikakav opis problema (procitaj pravila ![]()
#647 |
Lokacija: Here
Postovi: 25
Mislio sam da na podforum memorija spadaju i problemi oko memorije. Ako sam pogresno postao molio bih moderatora da prebaci u odgovarajuci forum i isprika od mene za krivo postanje |
#648 |
Postovi: 27
Evo imam jedno pitanje radi se o ploci gygabite P35-DS3L (http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2629=) Na ploči je trenutno 2x1G DDR2 PC5300 (677Mhz) Kingmax rama Ja bi sad nadogradio sa još rama pa me zanima dal mora biti PC5300 ili mogu dodat neki drugi ram primjer PC6400 ili PC8500 i dal moram dodat jednu ili dvije pločice rama? Hvala! Pozz! |
#649 |
Postovi: 2,523
mozes dodat pc6400, ali prvo treba isprobat da li ovaj pc5300 kojeg imas moze radit na tom taktu (800mhz) vrlo vjerojatno moze, tako da nebi trebalo bit problema znaci da nebi bilo zabune, sve plocice moraju radit na istoj frekvenciji, kad budes stavio novi ram koj je na 800mhz on ce automatski radit na 667 jer se sve skalira po onim ramima koji rade najsporije, no onda nema smisla uzimat ram na 800mhz, ako neces forsirat ovaj na 667 da radi na 800, a to nije tesko, samo treba promjenit omjer na kojem rade u biosu kako bi njihova konacna frekvencija bila 800mhz mozes kupit ili jednu plocicu od 2gb ili 2x1gb ili pak ako ti treba 2x2gb, u svakom slucaju ces zadrzat dual channel tako da ti je svejedno ali najbolja opcija bi ti bila da prodas taj 2x1gb ram i kupis jednostavno novi ili sa trznice 2x2gb ram na 800mhz, tako ces imat najmanje komplikacija |
#650 |
Lokacija: kutina
Postovi: 72
Pitanje RAM hitno mi je
Ovako prelazio bi sa ddr2 na ddr3, ali sa 4 gb ddr 2 na 10066 mhz bi presao na 2 gb ddr 3 1866 hmz, radi se oramu patriot RAM 2 GB, DDR 3, PC-15000, 1866 MHz, Patriot Viper ( jer za vise se nema para) sad ne znam sta mi je pametnije da prelazim ili da ostanem na postojecem ramu, ostatak konfe je q6700, hd 4890 2gb vapor x, kingmax 2x2 gb 1066 Mhz, gigabyte GA-P35C-DS3R |
#651 |
Postovi: 12,613
Ne isplati se. ![]()
#653 |
Datum registracije: Dec 2009
Lokacija: Sarajevo
Postovi: 10
Pomoc oko memorije
Eh ovako, trenutno imam 2x512mb +256mb DDR1, ali hocu jos da stavim ali pitam vas da li ova moja maticna podrzava ove DDR2 od 533Mhz, posto sam upoređivao DDR2 i DDR1 ali im rupe na ulazima nisu na istom mjestu, razlika je mozda 2-3mm Ev slike od info by everest od maticne i cipseta http://i47.tinypic.com/fxyq3b.png > maticna http://i47.tinypic.com/js2792.png > cipset |
#655 |
Drift king
Postovi: 255
Na laptopu imam 1*2 GB plocicu od 667 MHZ i planiram ubost jos 2 GB. Mogao bih nabavit povoljno jednu od 800 MHz pa me zanima dal da cekam i probam nabavit jos jednu od 667 ili da ubodem tu od 800 MHz |
#656 |
herr Flick
Postovi: 2,085
.:S:T:A:L:K:E:R:. ![]() ![]() nema vise zippacha ![]() |
#657 |
Postovi: 6
Kod mene je situacija ovakva. Kupio sam tu na forumu od jednog lika ddr1 memoriju na 400 mhz. Platio sam 1Gb 140kn, a memoriju mi prepozna ko 512 mb. I zovem njega da mi vrati pare jer me je zajebo, no on kaže da mi matična vjerojatno ne podržava dvostranu memoriju (mamorija koja ima čipove na obadvi strane). Jeli to moguće? Na memoriji ( na naljepnici ) piše da je 1GB no ta slova se prelako brišu pa imam osjećaj da je on to isprintao i zaljepio. |
#659 |
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,260
ddr 400 i ddr500 kombinacija
Imam nforce 3 chipset koji podrzava 3gb rama,dosad sam imao 1GB(2*512) Kingmax hardcore ddr500 i sad sam dodao jos jedan keks kingmaxa od 512mb ali ddr400...jel se to moze tako kombinirat i hoce li to funkcionirat(sve je ddr2) |
#660 | |
Torrent freek
Postovi: 3,946
![]() A hoće li funkcionirat...trebalo bi (sve će radit naravno na 400), umeti pa vidi ![]()
